35#ifndef _RTEMS_SHELL_CONFIG_h
36#define _RTEMS_SHELL_CONFIG_h
146#if !defined(CONFIGURE_SHELL_COMMANDS_ALL)
147 #if defined(CONFIGURE_SHELL_COMMANDS_DIR) && \
148 !defined(CONFIGURE_SHELL_COMMANDS_LS)
149 #define CONFIGURE_SHELL_COMMAND_LS
152 #if defined(CONFIGURE_SHELL_COMMANDS_CD) && \
153 !defined(CONFIGURE_SHELL_COMMANDS_CHDIR)
154 #define CONFIGURE_SHELL_COMMAND_CHDIR
157 #if defined(CONFIGURE_SHELL_COMMANDS_EXIT) && \
158 !defined(CONFIGURE_SHELL_COMMANDS_LOGOFF)
159 #define CONFIGURE_SHELL_COMMAND_LOGOFF
163#if defined(CONFIGURE_SHELL_COMMANDS_INIT)
165 #if (defined(CONFIGURE_SHELL_COMMANDS_ALL) && \
166 !defined(CONFIGURE_SHELL_NO_COMMAND_DIR)) || \
167 defined(CONFIGURE_SHELL_COMMAND_DIR)
168 &rtems_shell_DIR_Alias,
170 #if (defined(CONFIGURE_SHELL_COMMANDS_ALL) && \
171 !defined(CONFIGURE_SHELL_NO_COMMAND_CD)) || \
172 defined(CONFIGURE_SHELL_COMMAND_CD)
173 &rtems_shell_CD_Alias,
175 #if (defined(CONFIGURE_SHELL_COMMANDS_ALL) && \
176 !defined(CONFIGURE_SHELL_NO_COMMAND_EXIT)) || \
177 defined(CONFIGURE_SHELL_COMMAND_EXIT)
178 &rtems_shell_EXIT_Alias,
184 #if defined(CONFIGURE_SHELL_USER_ALIASES)
185 CONFIGURE_SHELL_USER_ALIASES,
194 &rtems_shell_HELP_Command,
195 &rtems_shell_ALIAS_Command,
196 &rtems_shell_TIME_Command,
201 #if (defined(CONFIGURE_SHELL_COMMANDS_ALL) && \
202 !defined(CONFIGURE_SHELL_NO_COMMAND_CMDLS)) || \
203 defined(CONFIGURE_SHELL_COMMAND_CMDLS)
204 &rtems_shell_CMDLS_Command,
206 #if (defined(CONFIGURE_SHELL_COMMANDS_ALL) && \
207 !defined(CONFIGURE_SHELL_NO_COMMAND_CMDCHOWN)) || \
208 defined(CONFIGURE_SHELL_COMMAND_CMDCHOWN)
209 &rtems_shell_CMDCHOWN_Command,
211 #if (defined(CONFIGURE_SHELL_COMMANDS_ALL) && \
212 !defined(CONFIGURE_SHELL_NO_COMMAND_CMDCHMOD)) || \
213 defined(CONFIGURE_SHELL_COMMAND_CMDCHMOD)
214 &rtems_shell_CMDCHMOD_Command,
216 #if (defined(CONFIGURE_SHELL_COMMANDS_ALL) && \
217 !defined(CONFIGURE_SHELL_NO_COMMAND_JOEL)) || \
218 defined(CONFIGURE_SHELL_COMMAND_JOEL)
219 &rtems_shell_JOEL_Command,
221 #if (defined(CONFIGURE_SHELL_COMMANDS_ALL) && \
222 !defined(CONFIGURE_SHELL_NO_COMMAND_DATE)) || \
223 defined(CONFIGURE_SHELL_COMMAND_DATE)
224 &rtems_shell_DATE_Command,
226 #if (defined(CONFIGURE_SHELL_COMMANDS_ALL) && \
227 !defined(CONFIGURE_SHELL_NO_COMMAND_ECHO)) || \
228 defined(CONFIGURE_SHELL_COMMAND_ECHO)
229 &rtems_shell_ECHO_Command,
231 #if (defined(CONFIGURE_SHELL_COMMANDS_ALL) && \
232 !defined(CONFIGURE_SHELL_NO_COMMAND_EDIT)) || \
233 defined(CONFIGURE_SHELL_COMMAND_EDIT)
234 &rtems_shell_EDIT_Command,
236 #if (defined(CONFIGURE_SHELL_COMMANDS_ALL) && \
237 !defined(CONFIGURE_SHELL_NO_COMMAND_SLEEP)) || \
238 defined(CONFIGURE_SHELL_COMMAND_SLEEP)
239 &rtems_shell_SLEEP_Command,
241 #if (defined(CONFIGURE_SHELL_COMMANDS_ALL) && \
242 !defined(CONFIGURE_SHELL_NO_COMMAND_ID)) || \
243 defined(CONFIGURE_SHELL_COMMAND_ID)
244 &rtems_shell_ID_Command,
246 #if (defined(CONFIGURE_SHELL_COMMANDS_ALL) && \
247 !defined(CONFIGURE_SHELL_NO_COMMAND_TTY)) || \
248 defined(CONFIGURE_SHELL_COMMAND_TTY)
249 &rtems_shell_TTY_Command,
251 #if (defined(CONFIGURE_SHELL_COMMANDS_ALL) && \
252 !defined(CONFIGURE_SHELL_NO_COMMAND_WHOAMI)) || \
253 defined(CONFIGURE_SHELL_COMMAND_WHOAMI)
254 &rtems_shell_WHOAMI_Command,
256 #if (defined(CONFIGURE_SHELL_COMMANDS_ALL) && \
257 !defined(CONFIGURE_SHELL_NO_COMMAND_LOGOFF)) || \
258 defined(CONFIGURE_SHELL_COMMAND_LOGOFF)
259 &rtems_shell_LOGOFF_Command,
261 #if (defined(CONFIGURE_SHELL_COMMANDS_ALL) && \
262 !defined(CONFIGURE_SHELL_NO_COMMAND_SETENV)) || \
263 defined(CONFIGURE_SHELL_COMMAND_SETENV)
264 &rtems_shell_SETENV_Command,
266 #if (defined(CONFIGURE_SHELL_COMMANDS_ALL) && \
267 !defined(CONFIGURE_SHELL_NO_COMMAND_GETENV)) || \
268 defined(CONFIGURE_SHELL_COMMAND_GETENV)
269 &rtems_shell_GETENV_Command,
271 #if (defined(CONFIGURE_SHELL_COMMANDS_ALL) && \
272 !defined(CONFIGURE_SHELL_NO_COMMAND_CRLENV)) || \
273 defined(CONFIGURE_SHELL_COMMAND_UNSETENV)
274 &rtems_shell_UNSETENV_Command,
280 #if (defined(CONFIGURE_SHELL_COMMANDS_ALL) && \
281 !defined(CONFIGURE_SHELL_NO_COMMAND_MDUMP)) || \
282 defined(CONFIGURE_SHELL_COMMAND_MDUMP)
283 &rtems_shell_MDUMP_Command,
285 #if (defined(CONFIGURE_SHELL_COMMANDS_ALL) && \
286 !defined(CONFIGURE_SHELL_NO_COMMAND_WDUMP)) || \
287 defined(CONFIGURE_SHELL_COMMAND_WDUMP)
288 &rtems_shell_WDUMP_Command,
290 #if (defined(CONFIGURE_SHELL_COMMANDS_ALL) && \
291 !defined(CONFIGURE_SHELL_NO_COMMAND_LDUMP)) || \
292 defined(CONFIGURE_SHELL_COMMAND_LDUMP)
293 &rtems_shell_LDUMP_Command,
295 #if (defined(CONFIGURE_SHELL_COMMANDS_ALL) && \
296 !defined(CONFIGURE_SHELL_NO_COMMAND_MEDIT)) || \
297 defined(CONFIGURE_SHELL_COMMAND_MEDIT)
298 &rtems_shell_MEDIT_Command,
300 #if (defined(CONFIGURE_SHELL_COMMANDS_ALL) && \
301 !defined(CONFIGURE_SHELL_NO_COMMAND_MFILL)) || \
302 defined(CONFIGURE_SHELL_COMMAND_MFILL)
303 &rtems_shell_MFILL_Command,
305 #if (defined(CONFIGURE_SHELL_COMMANDS_ALL) && \
306 !defined(CONFIGURE_SHELL_NO_COMMAND_MMOVE)) || \
307 defined(CONFIGURE_SHELL_COMMAND_MMOVE)
308 &rtems_shell_MMOVE_Command,
314 #if (defined(CONFIGURE_SHELL_COMMANDS_ALL) && \
315 !defined(CONFIGURE_SHELL_NO_COMMAND_CP)) || \
316 defined(CONFIGURE_SHELL_COMMAND_CP)
317 &rtems_shell_CP_Command,
319 #if (defined(CONFIGURE_SHELL_COMMANDS_ALL) && \
320 !defined(CONFIGURE_SHELL_NO_COMMAND_PWD)) || \
321 defined(CONFIGURE_SHELL_COMMAND_PWD)
322 &rtems_shell_PWD_Command,
324 #if (defined(CONFIGURE_SHELL_COMMANDS_ALL) && \
325 !defined(CONFIGURE_SHELL_NO_COMMAND_LS)) || \
326 defined(CONFIGURE_SHELL_COMMAND_LS)
327 &rtems_shell_LS_Command,
329 #if (defined(CONFIGURE_SHELL_COMMANDS_ALL) && \
330 !defined(CONFIGURE_SHELL_NO_COMMAND_CHDIR)) || \
331 defined(CONFIGURE_SHELL_COMMAND_CHDIR)
332 &rtems_shell_CHDIR_Command,
334 #if (defined(CONFIGURE_SHELL_COMMANDS_ALL) && \
335 !defined(CONFIGURE_SHELL_NO_COMMAND_MKDIR)) || \
336 defined(CONFIGURE_SHELL_COMMAND_MKDIR)
337 &rtems_shell_MKDIR_Command,
339 #if (defined(CONFIGURE_SHELL_COMMANDS_ALL) && \
340 !defined(CONFIGURE_SHELL_NO_COMMAND_RMDIR)) || \
341 defined(CONFIGURE_SHELL_COMMAND_RMDIR)
342 &rtems_shell_RMDIR_Command,
344 #if (defined(CONFIGURE_SHELL_COMMANDS_ALL) && \
345 !defined(CONFIGURE_SHELL_NO_COMMAND_CHROOT)) || \
346 defined(CONFIGURE_SHELL_COMMAND_CHROOT)
347 &rtems_shell_CHROOT_Command,
349 #if (defined(CONFIGURE_SHELL_COMMANDS_ALL) && \
350 !defined(CONFIGURE_SHELL_NO_COMMAND_CHMOD)) || \
351 defined(CONFIGURE_SHELL_COMMAND_CHMOD)
352 &rtems_shell_CHMOD_Command,
354 #if (defined(CONFIGURE_SHELL_COMMANDS_ALL) && \
355 !defined(CONFIGURE_SHELL_NO_COMMAND_CAT)) || \
356 defined(CONFIGURE_SHELL_COMMAND_CAT)
357 &rtems_shell_CAT_Command,
359 #if (defined(CONFIGURE_SHELL_COMMANDS_ALL) && \
360 !defined(CONFIGURE_SHELL_NO_COMMAND_MKRFS)) || \
361 defined(CONFIGURE_SHELL_COMMAND_MKRFS)
362 &rtems_shell_MKRFS_Command,
364 #if (defined(CONFIGURE_SHELL_COMMANDS_ALL) && \
365 !defined(CONFIGURE_SHELL_NO_COMMAND_MSDOSFMT)) || \
366 defined(CONFIGURE_SHELL_COMMAND_MSDOSFMT)
367 &rtems_shell_MSDOSFMT_Command,
368 &rtems_shell_MSDOSFMT_Alias,
370 #if (defined(CONFIGURE_SHELL_COMMANDS_ALL) && \
371 !defined(CONFIGURE_SHELL_NO_COMMAND_MV)) || \
372 defined(CONFIGURE_SHELL_COMMAND_MV)
373 &rtems_shell_MV_Command,
375 #if (defined(CONFIGURE_SHELL_COMMANDS_ALL) && \
376 !defined(CONFIGURE_SHELL_NO_COMMAND_RM)) || \
377 defined(CONFIGURE_SHELL_COMMAND_RM)
378 &rtems_shell_RM_Command,
380 #if (defined(CONFIGURE_SHELL_COMMANDS_ALL) && \
381 !defined(CONFIGURE_SHELL_NO_COMMAND_LN)) || \
382 defined(CONFIGURE_SHELL_COMMAND_LN)
383 &rtems_shell_LN_Command,
385 #if (defined(CONFIGURE_SHELL_COMMANDS_ALL) && \
386 !defined(CONFIGURE_SHELL_NO_COMMAND_MKNOD)) || \
387 defined(CONFIGURE_SHELL_COMMAND_MKNOD)
388 &rtems_shell_MKNOD_Command,
390 #if (defined(CONFIGURE_SHELL_COMMANDS_ALL) && \
391 !defined(CONFIGURE_SHELL_NO_COMMAND_UMASK)) || \
392 defined(CONFIGURE_SHELL_COMMAND_UMASK)
393 &rtems_shell_UMASK_Command,
395 #if (defined(CONFIGURE_SHELL_COMMANDS_ALL) && \
396 !defined(CONFIGURE_SHELL_NO_COMMAND_LSOF)) || \
397 defined(CONFIGURE_SHELL_COMMAND_LSOF)
398 &rtems_shell_LSOF_Command,
400 #if (defined(CONFIGURE_SHELL_COMMANDS_ALL) && \
401 !defined(CONFIGURE_SHELL_NO_COMMAND_MOUNT)) || \
402 defined(CONFIGURE_SHELL_COMMAND_MOUNT)
403 &rtems_shell_MOUNT_Command,
405 #if (defined(CONFIGURE_SHELL_COMMANDS_ALL) && \
406 !defined(CONFIGURE_SHELL_NO_COMMAND_UNMOUNT)) || \
407 defined(CONFIGURE_SHELL_COMMAND_UNMOUNT)
408 &rtems_shell_UNMOUNT_Command,
410 #if (defined(CONFIGURE_SHELL_COMMANDS_ALL) && \
411 !defined(CONFIGURE_SHELL_NO_COMMAND_BLKSYNC)) || \
412 defined(CONFIGURE_SHELL_COMMAND_BLKSYNC)
413 &rtems_shell_BLKSYNC_Command,
415 #if (defined(CONFIGURE_SHELL_COMMANDS_ALL) && \
416 !defined(CONFIGURE_SHELL_NO_COMMAND_BLKSTATS)) || \
417 defined(CONFIGURE_SHELL_COMMAND_BLKSTATS)
418 &rtems_shell_BLKSTATS_Command,
420 #if (defined(CONFIGURE_SHELL_COMMANDS_ALL) && \
421 !defined(CONFIGURE_SHELL_NO_COMMAND_FDISK)) || \
422 defined(CONFIGURE_SHELL_COMMAND_FDISK)
423 &rtems_shell_FDISK_Command,
425 #if (defined(CONFIGURE_SHELL_COMMANDS_ALL) && \
426 !defined(CONFIGURE_SHELL_NO_COMMAND_DD)) || \
427 defined(CONFIGURE_SHELL_COMMAND_DD)
428 &rtems_shell_DD_Command,
430 #if (defined(CONFIGURE_SHELL_COMMANDS_ALL) && \
431 !defined(CONFIGURE_SHELL_NO_COMMAND_HEXDUMP)) || \
432 defined(CONFIGURE_SHELL_COMMAND_HEXDUMP)
433 &rtems_shell_HEXDUMP_Command,
435 #if (defined(CONFIGURE_SHELL_COMMANDS_ALL) && \
436 !defined(CONFIGURE_SHELL_NO_COMMAND_DEBUGRFS)) || \
437 defined(CONFIGURE_SHELL_COMMAND_DEBUGRFS)
438 &rtems_shell_DEBUGRFS_Command,
440 #if (defined(CONFIGURE_SHELL_COMMANDS_ALL) && \
441 !defined(CONFIGURE_SHELL_NO_COMMAND_DF)) || \
442 defined(CONFIGURE_SHELL_COMMAND_DF)
443 &rtems_shell_DF_Command,
445 #if (defined(CONFIGURE_SHELL_COMMANDS_ALL) && \
446 !defined(CONFIGURE_SHELL_NO_COMMAND_MD5)) || \
447 defined(CONFIGURE_SHELL_COMMAND_MD5)
448 &rtems_shell_MD5_Command,
454 #if (defined(CONFIGURE_SHELL_COMMANDS_ALL) && \
455 !defined(CONFIGURE_SHELL_NO_COMMAND_SHUTDOWN)) || \
456 defined(CONFIGURE_SHELL_COMMAND_SHUTDOWN)
457 &rtems_shell_SHUTDOWN_Command,
459 #if (defined(CONFIGURE_SHELL_COMMANDS_ALL) && \
460 !defined(CONFIGURE_SHELL_NO_COMMAND_CPUINFO)) || \
461 defined(CONFIGURE_SHELL_COMMAND_CPUINFO)
462 &rtems_shell_CPUINFO_Command,
464 #if (defined(CONFIGURE_SHELL_COMMANDS_ALL) && \
465 !defined(CONFIGURE_SHELL_NO_COMMAND_CPUUSE)) || \
466 defined(CONFIGURE_SHELL_COMMAND_CPUUSE)
467 &rtems_shell_CPUUSE_Command,
469 #if (defined(CONFIGURE_SHELL_COMMANDS_ALL) && \
470 !defined(CONFIGURE_SHELL_NO_COMMAND_TOP)) || \
471 defined(CONFIGURE_SHELL_COMMAND_TOP)
472 &rtems_shell_TOP_Command,
474 #if (defined(CONFIGURE_SHELL_COMMANDS_ALL) && \
475 !defined(CONFIGURE_SHELL_NO_COMMAND_STACKUSE)) || \
476 defined(CONFIGURE_SHELL_COMMAND_STACKUSE)
477 &rtems_shell_STACKUSE_Command,
479 #if (defined(CONFIGURE_SHELL_COMMANDS_ALL) && \
480 !defined(CONFIGURE_SHELL_NO_COMMAND_PERIODUSE)) || \
481 defined(CONFIGURE_SHELL_COMMAND_PERIODUSE)
482 &rtems_shell_PERIODUSE_Command,
484 #if (defined(CONFIGURE_SHELL_COMMANDS_ALL) && \
485 !defined(CONFIGURE_SHELL_NO_COMMAND_PROFREPORT)) || \
486 defined(CONFIGURE_SHELL_COMMAND_PROFREPORT)
487 &rtems_shell_PROFREPORT_Command,
489 #if (defined(CONFIGURE_SHELL_COMMANDS_ALL) && \
490 !defined(CONFIGURE_SHELL_NO_COMMAND_WKSPACE_INFO)) || \
491 defined(CONFIGURE_SHELL_COMMAND_WKSPACE_INFO)
492 &rtems_shell_WKSPACE_INFO_Command,
494 #if (defined(CONFIGURE_SHELL_COMMANDS_ALL) && \
495 !defined(CONFIGURE_SHELL_NO_COMMAND_RTEMS)) || \
496 defined(CONFIGURE_SHELL_COMMAND_RTEMS)
497 &rtems_shell_RTEMS_Command,
503 #if (defined(CONFIGURE_SHELL_COMMANDS_ALL) && \
504 !defined(CONFIGURE_SHELL_NO_COMMAND_MALLOC_INFO)) || \
505 defined(CONFIGURE_SHELL_COMMAND_MALLOC_INFO)
506 &rtems_shell_MALLOC_INFO_Command,
512 #if (defined(CONFIGURE_SHELL_COMMANDS_ALL) && \
513 !defined(CONFIGURE_SHELL_NO_COMMAND_RTRACE)) || \
514 defined(CONFIGURE_SHELL_COMMAND_RTRACE)
515 &rtems_shell_RTRACE_Command,
522 #if (defined(CONFIGURE_SHELL_COMMANDS_ALL_NETWORKING) && \
523 !defined(CONFIGURE_SHELL_NO_COMMAND_IFCONFIG)) || \
524 defined(CONFIGURE_SHELL_COMMAND_IFCONFIG)
525 &rtems_shell_IFCONFIG_Command,
528 #if (defined(CONFIGURE_SHELL_COMMANDS_ALL_NETWORKING) && \
529 !defined(CONFIGURE_SHELL_NO_COMMAND_ROUTE)) || \
530 defined(CONFIGURE_SHELL_COMMAND_ROUTE)
531 &rtems_shell_ROUTE_Command,
534 #if (defined(CONFIGURE_SHELL_COMMANDS_ALL_NETWORKING) && \
535 !defined(CONFIGURE_SHELL_NO_COMMAND_NETSTATS)) || \
536 defined(CONFIGURE_SHELL_COMMAND_NETSTATS)
537 &rtems_shell_NETSTATS_Command,
540 #if (defined(CONFIGURE_SHELL_COMMANDS_ALL_NETWORKING) && \
541 !defined(CONFIGURE_SHELL_NO_COMMAND_PING)) || \
542 defined(CONFIGURE_SHELL_COMMAND_PING)
543 &rtems_shell_PING_Command,
548 #if (defined(CONFIGURE_SHELL_COMMANDS_ALL) \
549 && !defined(CONFIGURE_SHELL_NO_COMMAND_RTC)) \
550 || defined(CONFIGURE_SHELL_COMMAND_RTC)
551 &rtems_shell_RTC_Command,
554 #if (defined(CONFIGURE_SHELL_COMMANDS_ALL) \
555 && !defined(CONFIGURE_SHELL_NO_COMMAND_SPI)) \
556 || defined(CONFIGURE_SHELL_COMMAND_SPI)
557 &rtems_shell_SPI_Command,
560 #if (defined(CONFIGURE_SHELL_COMMANDS_ALL) \
561 && !defined(CONFIGURE_SHELL_NO_COMMAND_FLASHDEV)) \
562 || defined(CONFIGURE_SHELL_COMMAND_FLASHDEV)
563 &rtems_shell_FLASHDEV_Command,
566 #if (defined(CONFIGURE_SHELL_COMMANDS_ALL) \
567 && !defined(CONFIGURE_SHELL_NO_COMMAND_I2CDETECT)) \
568 || defined(CONFIGURE_SHELL_COMMAND_I2CDETECT)
569 &rtems_shell_I2CDETECT_Command,
572 #if (defined(CONFIGURE_SHELL_COMMANDS_ALL) \
573 && !defined(CONFIGURE_SHELL_NO_COMMAND_I2CGET)) \
574 || defined(CONFIGURE_SHELL_COMMAND_I2CGET)
575 &rtems_shell_I2CGET_Command,
578 #if (defined(CONFIGURE_SHELL_COMMANDS_ALL) \
579 && !defined(CONFIGURE_SHELL_NO_COMMAND_I2CSET)) \
580 || defined(CONFIGURE_SHELL_COMMAND_I2CSET)
581 &rtems_shell_I2CSET_Command,
587 #if defined(RTEMS_DRVMGR_STARTUP) || defined(CONFIGURE_SHELL_COMMAND_DRVMGR)
588 #if (defined(CONFIGURE_SHELL_COMMANDS_ALL) && \
589 !defined(CONFIGURE_SHELL_NO_COMMAND_DRVMGR)) || \
590 defined(CONFIGURE_SHELL_COMMAND_DRVMGR)
591 &rtems_shell_DRVMGR_Command,
595 #if defined(RTEMS_PCI_CONFIG_LIB)
596 #if (defined(CONFIGURE_SHELL_COMMANDS_ALL) && \
597 !defined(CONFIGURE_SHELL_NO_COMMAND_PCI)) || \
598 defined(CONFIGURE_SHELL_COMMAND_PCI)
599 &rtems_shell_PCI_Command,
606 #if defined(CONFIGURE_SHELL_USER_COMMANDS)
607 CONFIGURE_SHELL_USER_COMMANDS,
#define NULL
Requests a GPIO pin group configuration.
Definition: xil_types.h:54
Instantatiate a New Terminal Shell.
