RTEMS 6.1-rc2
semaphore.h
2
12/*
13 * COPYRIGHT (c) 1989-2011.
14 * On-Line Applications Research Corporation (OAR).
15 *
16 * Redistribution and use in source and binary forms, with or without
17 * modification, are permitted provided that the following conditions
18 * are met:
19 * 1. Redistributions of source code must retain the above copyright
20 * notice, this list of conditions and the following disclaimer.
21 * 2. Redistributions in binary form must reproduce the above copyright
22 * notice, this list of conditions and the following disclaimer in the
23 * documentation and/or other materials provided with the distribution.
24 *
25 * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
26 * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
27 * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
28 * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
29 * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
30 * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
31 * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
32 * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
33 * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
34 * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
35 * POSSIBILITY OF SUCH DAMAGE.
36 */
37
38#ifndef _RTEMS_POSIX_SEMAPHORE_H
39#define _RTEMS_POSIX_SEMAPHORE_H
40
42
43#include <limits.h>
44#include <semaphore.h>
45
46#ifdef __cplusplus
47extern "C" {
48#endif
49
59/*
60 * Data Structure used to manage a POSIX semaphore
61 */
62
63typedef struct {
64 Objects_Control Object;
65 sem_t Semaphore;
66 bool linked;
67 uint32_t open_count;
69
74
84#define POSIX_SEMAPHORE_INFORMATION_DEFINE( max ) \
85 OBJECTS_INFORMATION_DEFINE( \
86 _POSIX_Semaphore, \
87 OBJECTS_POSIX_API, \
88 OBJECTS_POSIX_SEMAPHORES, \
89 POSIX_Semaphore_Control, \
90 max, \
91 _POSIX_PATH_MAX, \
92 NULL \
93 )
94
97#ifdef __cplusplus
98}
99#endif
100
101#endif
102/* end of include file */
Objects_Information _POSIX_Semaphore_Information
The POSIX Semaphore objects information.
This header file provides data structures used by the implementation and the Application Configuratio...
Private Support Information for POSIX Semaphores.
Definition: objectdata.h:61
The information structure used to manage each API class of objects.
Definition: objectdata.h:198
Definition: semaphore.h:63
