RTEMS 6.1-rc2
rwlockimpl.h
2
12/*
13 * COPYRIGHT (c) 1989-2011.
14 * On-Line Applications Research Corporation (OAR).
15 *
16 * Redistribution and use in source and binary forms, with or without
17 * modification, are permitted provided that the following conditions
18 * are met:
19 * 1. Redistributions of source code must retain the above copyright
20 * notice, this list of conditions and the following disclaimer.
21 * 2. Redistributions in binary form must reproduce the above copyright
22 * notice, this list of conditions and the following disclaimer in the
23 * documentation and/or other materials provided with the distribution.
24 *
25 * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
26 * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
27 * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
28 * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
29 * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
30 * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
31 * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
32 * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
33 * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
34 * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
35 * POSSIBILITY OF SUCH DAMAGE.
36 */
37
38#ifndef _RTEMS_POSIX_RWLOCKIMPL_H
39#define _RTEMS_POSIX_RWLOCKIMPL_H
40
42
43#include <errno.h>
44#include <pthread.h>
45
46#ifdef __cplusplus
47extern "C" {
48#endif
49
50#define POSIX_RWLOCK_MAGIC 0x9621dabdUL
51
52typedef struct {
53 unsigned long flags;
56
57static inline POSIX_RWLock_Control *_POSIX_RWLock_Get(
58 pthread_rwlock_t *rwlock
59)
60{
61 return (POSIX_RWLock_Control *) rwlock;
62}
63
64bool _POSIX_RWLock_Auto_initialization( POSIX_RWLock_Control *the_rwlock );
65
66#define POSIX_RWLOCK_VALIDATE_OBJECT( rw ) \
67 do { \
68 if ( ( rw ) == NULL ) { \
69 return EINVAL; \
70 } \
71 if ( ( (uintptr_t) ( rw ) ^ POSIX_RWLOCK_MAGIC ) != ( rw )->flags ) { \
72 if ( !_POSIX_RWLock_Auto_initialization( rw ) ) { \
73 return EINVAL; \
74 } \
75 } \
76 } while ( 0 )
77
78#ifdef __cplusplus
79}
80#endif
81
82#endif
83/* end of include file */
This header file provides interfaces of the Read-Write Lock which are only used by the implementation...
POSIX Threads Private Support.
Definition: corerwlockimpl.h:94
Definition: rwlockimpl.h:52
