RTEMS 6.1-rc2
rtl-chain-iterator.h
2
11/*
12 * COPYRIGHT (c) 2012 Chris Johns <chrisj@rtems.org>
13 *
16 * are met:
22 *
34 */
35
36#if !defined (_RTEMS_RTL_CHAIN_ITERATOR_H_)
37#define _RTEMS_RTL_CHAIN_ITERATOR_H_
38
39#ifdef __cplusplus
40extern "C" {
41#endif /* __cplusplus */
42
43#include <rtems/chain.h>
44
48typedef bool (*rtems_chain_iterator) (rtems_chain_node* node, void* data);
49
62bool
64 rtems_chain_iterator iterator,
65 void* data);
66
74
75#ifdef __cplusplus
76}
77#endif /* __cplusplus */
78
79#endif
This header file provides the Chains API.
bool(* rtems_chain_iterator)(rtems_chain_node *node, void *data)
Definition: rtl-chain-iterator.h:48
bool rtems_rtl_chain_iterate(rtems_chain_control *chain, rtems_chain_iterator iterator, void *data)
Definition: rtl-chain-iterator.c:45
int rtems_rtl_chain_count(rtems_chain_control *chain)
Definition: rtl-chain-iterator.c:72
This structure represents a chain node.
Definition: chain.h:78
This union represents a chain control block.
Definition: chain.h:96
