RTEMS 6.1-rc2
rtl-bit-alloc.h
2
11/*
12 * COPYRIGHT (c) 2019 Chris Johns <chrisj@rtems.org>
13 *
16 * are met:
22 *
34 */
35
36#if !defined (_RTEMS_RTL_BIT_ALLOC_H_)
37#define _RTEMS_RTL_BIT_ALLOC_H_
38
39#include <rtems/rtl/rtl-fwd.h>
41
42#ifdef __cplusplus
43extern "C" {
44#endif /* __cplusplus */
45
49typedef struct rtems_rtl_bit_alloc
50{
51 uint8_t* base;
52 size_t size;
53 uint32_t* bits;
54 size_t block_size;
55 size_t blocks;
57
69 size_t size,
70 size_t block_size,
71 size_t used);
72
80
90void* rtems_rtl_bit_alloc_balloc (rtems_rtl_bit_alloc* balloc, size_t size);
91
96void rtems_rtl_bit_alloc_bfree (rtems_rtl_bit_alloc* balloc, void* addr, size_t size);
97
98#ifdef __cplusplus
99}
100#endif /* __cplusplus */
101
102#endif
rtems_rtl_bit_alloc * rtems_rtl_bit_alloc_open(void *base, size_t size, size_t block_size, size_t used)
Definition: rtl-bit-alloc.c:139
void rtems_rtl_bit_alloc_bfree(rtems_rtl_bit_alloc *balloc, void *addr, size_t size)
Definition: rtl-bit-alloc.c:208
void * rtems_rtl_bit_alloc_balloc(rtems_rtl_bit_alloc *balloc, size_t size)
Definition: rtl-bit-alloc.c:194
void rtems_rtl_bit_alloc_close(rtems_rtl_bit_alloc *balloc)
Definition: rtl-bit-alloc.c:185
RTEMS Run-Time Linker ELF Headers.
Definition: rtl-bit-alloc.h:50
uint8_t * base
Definition: rtl-bit-alloc.h:51
uint32_t * bits
Definition: rtl-bit-alloc.h:53
size_t block_size
Definition: rtl-bit-alloc.h:54
size_t blocks
Definition: rtl-bit-alloc.h:55
size_t size
Definition: rtl-bit-alloc.h:52
