RTEMS 6.1-rc2
scheduler.h
2
11/*
12 * Copyright (C) 2013, 2021 embedded brains GmbH & Co. KG
13 * Copyright (C) 1988, 2017 On-Line Applications Research Corporation (OAR)
14 *
16 * modification, are permitted provided that the following conditions
17 * are met:
18 * 1. Redistributions of source code must retain the above copyright
19 * notice, this list of conditions and the following disclaimer.
20 * 2. Redistributions in binary form must reproduce the above copyright
21 * notice, this list of conditions and the following disclaimer in the
22 * documentation and/or other materials provided with the distribution.
23 *
24 * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
25 * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
26 * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
27 * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
28 * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
29 * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
30 * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
31 * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
32 * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
33 * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
34 * POSSIBILITY OF SUCH DAMAGE.
35 */
36
37/*
38 * This file is part of the RTEMS quality process and was automatically
39 * generated. If you find something that needs to be fixed or
40 * worded better please post a report or patch to an RTEMS mailing list
41 * or raise a bug report:
42 *
43 * https://www.rtems.org/bugs.html
44 *
45 * For information on updating and regenerating please refer to the How-To
46 * section in the Software Requirements Engineering chapter of the
47 * RTEMS Software Engineering manual. The manual is provided as a part of
48 * a release. For development sources please refer to the online
49 * documentation at:
50 *
51 * https://docs.rtems.org
52 */
53
54/* Generated from spec:/rtems/scheduler/if/header */
55
56#ifndef _RTEMS_RTEMS_SCHEDULER_H
57#define _RTEMS_RTEMS_SCHEDULER_H
58
59#include <stddef.h>
60#include <stdint.h>
61#include <sys/cpuset.h>
62#include <rtems/rtems/status.h>
63#include <rtems/rtems/types.h>
64#include <rtems/score/smp.h>
65
66#ifdef __cplusplus
67extern "C" {
68#endif
69
70/* Generated from spec:/rtems/scheduler/if/group */
71
93/* Generated from spec:/rtems/scheduler/if/ident */
94
134
135/* Generated from spec:/rtems/scheduler/if/ident-by-processor */
136
167 uint32_t cpu_index,
168 rtems_id *id
169);
170
171/* Generated from spec:/rtems/scheduler/if/ident-by-processor-set */
172
216 size_t cpusetsize,
217 const cpu_set_t *cpuset,
218 rtems_id *id
219);
220
221/* Generated from spec:/rtems/scheduler/if/get-maximum-priority */
222
251 rtems_id scheduler_id,
252 rtems_task_priority *priority
253);
254
255/* Generated from spec:/rtems/scheduler/if/map-priority-to-posix */
256
291 rtems_id scheduler_id,
292 rtems_task_priority priority,
293 int *posix_priority
294);
295
296/* Generated from spec:/rtems/scheduler/if/map-priority-from-posix */
297
332 rtems_id scheduler_id,
333 int posix_priority,
334 rtems_task_priority *priority
335);
336
337/* Generated from spec:/rtems/scheduler/if/get-processor */
338
369uint32_t rtems_scheduler_get_processor( void );
370
371/* Generated from spec:/rtems/scheduler/if/get-processor-macro */
372#define rtems_scheduler_get_processor() _SMP_Get_current_processor()
373
374/* Generated from spec:/rtems/scheduler/if/get-processor-maximum */
375
404
405/* Generated from spec:/rtems/scheduler/if/get-processor-maximum-macro */
406#define rtems_scheduler_get_processor_maximum() _SMP_Get_processor_maximum()
407
408/* Generated from spec:/rtems/scheduler/if/get-processor-set */
409
445 rtems_id scheduler_id,
446 size_t cpusetsize,
447 cpu_set_t *cpuset
448);
449
450/* Generated from spec:/rtems/scheduler/if/add-processor */
451
492 rtems_id scheduler_id,
493 uint32_t cpu_index
494);
495
496/* Generated from spec:/rtems/scheduler/if/remove-processor */
497
543 rtems_id scheduler_id,
544 uint32_t cpu_index
545);
546
547#ifdef __cplusplus
548}
549#endif
550
551#endif /* _RTEMS_RTEMS_SCHEDULER_H */
This header file provides types used by the Classic API.
rtems_status_code rtems_scheduler_remove_processor(rtems_id scheduler_id, uint32_t cpu_index)
Removes the processor from the set of processors owned by the scheduler.
Definition: schedulerremoveprocessor.c:125
Returns the processor maximum supported by the system.
Definition: scheduler.h:406
rtems_status_code rtems_scheduler_add_processor(rtems_id scheduler_id, uint32_t cpu_index)
Adds the processor to the set of processors owned by the scheduler.
Definition: scheduleraddprocessor.c:46
rtems_status_code rtems_scheduler_map_priority_from_posix(rtems_id scheduler_id, int posix_priority, rtems_task_priority *priority)
Maps a POSIX thread priority to the corresponding Classic API task priority.
Definition: schedulermapfromposix.c:44
rtems_status_code rtems_scheduler_get_processor_set(rtems_id scheduler_id, size_t cpusetsize, cpu_set_t *cpuset)
Gets the set of processors owned by the scheduler.
Definition: schedulergetprocessorset.c:44
rtems_status_code rtems_scheduler_ident_by_processor_set(size_t cpusetsize, const cpu_set_t *cpuset, rtems_id *id)
Identifies a scheduler by the processor set.
Definition: scheduleridentbyprocessorset.c:45
rtems_status_code rtems_scheduler_ident(rtems_name name, rtems_id *id)
Identifies a scheduler by the object name.
Definition: schedulerident.c:44
rtems_status_code rtems_scheduler_map_priority_to_posix(rtems_id scheduler_id, rtems_task_priority priority, int *posix_priority)
Maps a Classic API task priority to the corresponding POSIX thread priority.
Definition: schedulermaptoposix.c:44
rtems_status_code rtems_scheduler_get_maximum_priority(rtems_id scheduler_id, rtems_task_priority *priority)
Gets the maximum task priority of the scheduler.
Definition: schedulergetmaxprio.c:44
rtems_status_code rtems_scheduler_ident_by_processor(uint32_t cpu_index, rtems_id *id)
Identifies a scheduler by the processor index.
Definition: scheduleridentbyprocessor.c:45
Returns the index of the current processor.
Definition: scheduler.h:372
rtems_status_code
Definition: status.h:85
uint32_t rtems_name
This type represents Classic API object names.
Definition: types.h:226
uint32_t rtems_task_priority
This integer type represents task priorities of the Classic API.
Definition: types.h:257
Objects_Id rtems_id
This type represents RTEMS object identifiers.
Definition: types.h:94
This header file provides the status codes of Classic API directives and support functions.
This header file provides interfaces of the SMP Support which are used by the implementation and the ...
