RTEMS 6.1-rc2
mqueue.h
2
24/*
25 * COPYRIGHT (c) 1989-2011.
26 * On-Line Applications Research Corporation (OAR).
27 *
28 * Redistribution and use in source and binary forms, with or without
29 * modification, are permitted provided that the following conditions
30 * are met:
31 * 1. Redistributions of source code must retain the above copyright
32 * notice, this list of conditions and the following disclaimer.
33 * 2. Redistributions in binary form must reproduce the above copyright
34 * notice, this list of conditions and the following disclaimer in the
35 * documentation and/or other materials provided with the distribution.
36 *
37 * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
38 * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
39 * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
40 * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
41 * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
42 * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
43 * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
44 * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
45 * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
46 * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
47 * POSSIBILITY OF SUCH DAMAGE.
48 */
49
50#ifndef _RTEMS_POSIX_MQUEUE_H
51#define _RTEMS_POSIX_MQUEUE_H
52
53#include <rtems/score/coremsg.h>
55
56#include <limits.h>
57#include <mqueue.h>
58#include <signal.h>
59
60#ifdef __cplusplus
61extern "C" {
62#endif
63
72/*
73 * Data Structure used to manage a POSIX message queue
74 */
75
76typedef struct {
77 Objects_Control Object;
78 CORE_message_queue_Control Message_queue;
79 bool linked;
80 uint32_t open_count;
81 struct sigevent notification;
82 int oflag;
84
89
99#define POSIX_MESSAGE_QUEUE_INFORMATION_DEFINE( max ) \
100 OBJECTS_INFORMATION_DEFINE( \
101 _POSIX_Message_queue, \
102 OBJECTS_POSIX_API, \
103 OBJECTS_POSIX_MESSAGE_QUEUES, \
104 POSIX_Message_queue_Control, \
105 max, \
106 _POSIX_PATH_MAX, \
107 NULL \
108 )
109
112#ifdef __cplusplus
113}
114#endif
115
116#endif
117/* end of include file */
This header file provides interfaces of the Message Queue Handler which are only used by the implemen...
Objects_Information _POSIX_Message_queue_Information
The POSIX Message Queue objects information.
This header file provides data structures used by the implementation and the Application Configuratio...
POSIX Message Queues Private Private Support.
Control block used to manage each message queue.
Definition: coremsg.h:113
Definition: objectdata.h:61
The information structure used to manage each API class of objects.
Definition: objectdata.h:198
Definition: mqueue.h:76
