RTEMS
6.1-rc2
include
rtems-rfs-format.h
1
/* SPDX-License-Identifier: BSD-2-Clause */
2
13
14
* COPYRIGHT (c) 2010 Chris Johns <chrisj@rtems.org>
15
16
17
* modification, are permitted provided that the following conditions
18
* are met:
19
* 1. Redistributions of source code must retain the above copyright
20
* notice, this list of conditions and the following disclaimer.
21
* 2. Redistributions in binary form must reproduce the above copyright
22
* notice, this list of conditions and the following disclaimer in the
23
* documentation and/or other materials provided with the distribution.
24
25
* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
26
* AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
27
* IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
28
* ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
29
* LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
30
* CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
31
* SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
32
* INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
33
* CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
34
* ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
35
* POSSIBILITY OF SUCH DAMAGE.
36
37
38
#if !defined (_RTEMS_RFS_FORMAT_H_)
39
#define _RTEMS_RFS_FORMAT_H_
40
41
#include <stddef.h>
42
#include <stdbool.h>
43
#include <stdint.h>
44
45
#ifdef __cplusplus
46
extern
"C"
47
#endif
48
49
rtems/rfs/rtems-rfs-trace.h
50
55
typedef
struct
_rtems_rfs_format_config
56
60
size_t
block_size
61
65
size_t
group_blocks
66
70
size_t
group_inodes
71
75
int
inode_overhead
76
80
size_t
max_name_length
81
85
bool
initialise_inodes
86
90
bool
verbose
91
92
93
103
int
rtems_rfs_format
const
char
* name,
const
config
104
105
#ifdef __cplusplus
106
107
#endif
108
109
#endif
rtems_rfs_format
int rtems_rfs_format(const char *name, const rtems_rfs_format_config *config)
Definition:
rtems-rfs-format.c:559
struct _rtems_rfs_format_config rtems_rfs_format_config
rtems-rfs-trace.h
Manages the Trace and Debugging Features of the RTEMS RFS File System.
Definition:
rtems-rfs-format.h:56
_rtems_rfs_format_config::verbose
bool verbose
Definition:
rtems-rfs-format.h:90
_rtems_rfs_format_config::group_inodes
size_t group_inodes
Definition:
rtems-rfs-format.h:70
_rtems_rfs_format_config::block_size
size_t block_size
Definition:
rtems-rfs-format.h:60
_rtems_rfs_format_config::initialise_inodes
bool initialise_inodes
Definition:
rtems-rfs-format.h:85
_rtems_rfs_format_config::max_name_length
size_t max_name_length
Definition:
rtems-rfs-format.h:80
_rtems_rfs_format_config::group_blocks
size_t group_blocks
Definition:
rtems-rfs-format.h:65
_rtems_rfs_format_config::inode_overhead
int inode_overhead
Definition:
rtems-rfs-format.h:75
config_s
Definition:
deflate.c:114
