RTEMS 6.1-rc2
rtems-debugger.h
1/*
2 * Copyright (c) 2016 Chris Johns <chrisj@rtems.org>. All rights reserved.
3 *
4 * Redistribution and use in source and binary forms, with or without
5 * modification, are permitted provided that the following conditions
6 * are met:
7 * 1. Redistributions of source code must retain the above copyright
8 * notice, this list of conditions and the following disclaimer.
9 * 2. Redistributions in binary form must reproduce the above copyright
10 * notice, this list of conditions and the following disclaimer in the
11 * documentation and/or other materials provided with the distribution.
12 *
13 * THIS SOFTWARE IS PROVIDED BY THE AUTHOR AND CONTRIBUTORS ``AS IS'' AND
14 * ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
15 * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
16 * ARE DISCLAIMED. IN NO EVENT SHALL THE AUTHOR OR CONTRIBUTORS BE LIABLE
17 * FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
18 * DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS
19 * OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION)
20 * HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT
21 * LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY
22 * OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF
23 * SUCH DAMAGE.
24 */
25
26/*
27 * Debugger for RTEMS.
28 */
29
30#ifndef _RTEMS_DEBUGGER_h
31#define _RTEMS_DEBUGGER_h
32
33#include <stdbool.h>
34
35#include <rtems.h>
36#include <rtems/printer.h>
37
38#ifdef __cplusplus
39extern "C" {
40#endif /* __cplusplus */
41
45#define RTEMS_DEBUGGER_TIMEOUT (3)
46
50extern int rtems_debugger_start(const char* remote,
51 const char* device,
52 int timeout,
53 rtems_task_priority priority,
54 const rtems_printer* printer);
55
62extern int rtems_debugger_break(bool wait);
63
67extern int rtems_debugger_stop(void);
68
72extern bool rtems_debugger_running(void);
73
77extern void rtems_debugger_set_verbose(bool on);
78
82extern int rtems_debugger_remote_debug(bool state);
83
84#ifdef __cplusplus
85}
86#endif /* __cplusplus */
87
88
89#endif
uint32_t rtems_task_priority
This integer type represents task priorities of the Classic API.
Definition: types.h:257
User print interface to the bspIO print plug in.
Definition: printer.h:76
