RTEMS 6.1-rc2
regdef.h
1/*
2 * Copyright (c) 2005 Jakub Jermar
3 * All rights reserved.
4 *
5 * Redistribution and use in source and binary forms, with or without
6 * modification, are permitted provided that the following conditions
7 * are met:
8 *
9 * - Redistributions of source code must retain the above copyright
10 * notice, this list of conditions and the following disclaimer.
11 * - Redistributions in binary form must reproduce the above copyright
12 * notice, this list of conditions and the following disclaimer in the
13 * documentation and/or other materials provided with the distribution.
14 * - The name of the author may not be used to endorse or promote products
15 * derived from this software without specific prior written permission.
16 *
17 * THIS SOFTWARE IS PROVIDED BY THE AUTHOR ``AS IS'' AND ANY EXPRESS OR
18 * IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES
19 * OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE DISCLAIMED.
20 * IN NO EVENT SHALL THE AUTHOR BE LIABLE FOR ANY DIRECT, INDIRECT,
21 * INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT
22 * NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE,
23 * DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY
24 * THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
25 * (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF
26 * THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
27 */
28
35#ifndef KERN_sparc64_REGDEF_H_
36#define KERN_sparc64_REGDEF_H_
37
38#define PSTATE_IE_BIT (1 << 1)
39#define PSTATE_AM_BIT (1 << 3)
40
41#define PSTATE_AG_BIT (1 << 0)
42#define PSTATE_IG_BIT (1 << 11)
43#define PSTATE_MG_BIT (1 << 10)
44
45#define PSTATE_PRIV_BIT (1 << 2)
46#define PSTATE_PEF_BIT (1 << 4)
47
48#define TSTATE_PSTATE_SHIFT 8
49#define TSTATE_PRIV_BIT (PSTATE_PRIV_BIT << TSTATE_PSTATE_SHIFT)
50#define TSTATE_IE_BIT (PSTATE_IE_BIT << TSTATE_PSTATE_SHIFT)
51#define TSTATE_PEF_BIT (PSTATE_PEF_BIT << TSTATE_PSTATE_SHIFT)
52
53#define TSTATE_CWP_MASK 0x1f
54
55#define WSTATE_NORMAL(n) (n)
56#define WSTATE_OTHER(n) ((n) << 3)
57
58/*
59 * The following definitions concern the UPA_CONFIG register on US and the
60 * FIREPLANE_CONFIG register on US3.
61 */
62#define ICBUS_CONFIG_MID_SHIFT 17
63
64#endif
65
