RTEMS 6.1-rc2
reg_tcr.h
2
11/* The header file is generated by make_header.py from TCR.json */
12/* Current script's version can be found at: */
13/* https://github.com/AoLaD/rtems-tms570-utils/tree/headers/headers/python */
14
15/*
16 * Copyright (c) 2014-2015, Premysl Houdek <kom541000@gmail.com>
17 *
18 * Czech Technical University in Prague
19 * Zikova 1903/4
20 * 166 36 Praha 6
21 * Czech Republic
22 *
23 * All rights reserved.
24 *
25 * Redistribution and use in source and binary forms, with or without
26 * modification, are permitted provided that the following conditions are met:
27 *
28 * 1. Redistributions of source code must retain the above copyright notice, this
29 * list of conditions and the following disclaimer.
30 * 2. Redistributions in binary form must reproduce the above copyright notice,
31 * this list of conditions and the following disclaimer in the documentation
32 * and/or other materials provided with the distribution.
33 *
34 * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS" AND
35 * ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED
36 * WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE
37 * DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE LIABLE FOR
38 * ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES
39 * (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES;
40 * LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND
41 * ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
42 * (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS
43 * SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
44 *
45 * The views and conclusions contained in the software and documentation are those
46 * of the authors and should not be interpreted as representing official policies,
47 * either expressed or implied, of the FreeBSD Project.
48*/
49#ifndef LIBBSP_ARM_TMS570_TCR
50#define LIBBSP_ARM_TMS570_TCR
51
52#include <bsp/utility.h>
53
54typedef struct{
55 uint32_t TCR[128]; /*Transfer Configuration RAM*/
56 uint32_t TCR_Parity[128]; /*TCR Parity Test Mode*/
58
59
60/*-----------------------TMS570_TCR_TCR-----------------------*/
61/* field: STXR - Set Transmit Request. */
62#define TMS570_TCR_TCR_STXR BSP_BIT32(18)
63
64/* field: THTSM - Transfer Header to System Memory. */
65#define TMS570_TCR_TCR_THTSM BSP_BIT32(17)
66
67/* field: TPTSM - Transfer Payload to System Memory. */
68#define TMS570_TCR_TCR_TPTSM BSP_BIT32(16)
69
70/* field: THTCC - Transfer Header to Communication Controller. */
71#define TMS570_TCR_TCR_THTCC BSP_BIT32(15)
72
73/* field: TPTCC - Transfer Payload to Communication Controller. */
74#define TMS570_TCR_TCR_TPTCC BSP_BIT32(14)
75
76/* field: TSO - Transfer Start Offset. */
77#define TMS570_TCR_TCR_TSO(val) BSP_FLD32(val,0, 13)
78#define TMS570_TCR_TCR_TSO_GET(reg) BSP_FLD32GET(reg,0, 13)
79#define TMS570_TCR_TCR_TSO_SET(reg,val) BSP_FLD32SET(reg, val,0, 13)
80
81
82/*-------------------TMS570_TCR_TCR_Parity-------------------*/
83/* field: PAB2 - Parity Bit for TCRx Byte 2. Parity information for byte 2 of TCRx(18-16). */
84#define TMS570_TCR_TCR_Parity_PAB2 BSP_BIT32(16)
85
86/* field: PAB1 - Parity Bit for TCRx Byte 1. Parity information for byte 1 of TCRx(15:8). */
87#define TMS570_TCR_TCR_Parity_PAB1 BSP_BIT32(8)
88
89/* field: PAB0 - Parity Bit for Byte 0. */
90#define TMS570_TCR_TCR_Parity_PAB0 BSP_BIT32(0)
91
92
93
94#endif /* LIBBSP_ARM_TMS570_TCR */
This header file provides utility macros for BSPs.
Definition: reg_tcr.h:54
