RTEMS
6.1-rc2
bsps
arm
tms570
include
bsp
ti_herc
reg_rti.h
1
/* SPDX-License-Identifier: BSD-2-Clause */
2
11
/* The header file is generated by make_header.py from RTI.json */
12
/* Current script's version can be found at: */
13
/* https://github.com/AoLaD/rtems-tms570-utils/tree/headers/headers/python */
14
15
16
* Copyright (c) 2014-2015, Premysl Houdek <kom541000@gmail.com>
17
18
* Czech Technical University in Prague
19
* Zikova 1903/4
20
* 166 36 Praha 6
21
* Czech Republic
22
23
* All rights reserved.
24
25
26
* modification, are permitted provided that the following conditions are met:
27
28
* 1. Redistributions of source code must retain the above copyright notice, this
29
* list of conditions and the following disclaimer.
30
* 2. Redistributions in binary form must reproduce the above copyright notice,
31
* this list of conditions and the following disclaimer in the documentation
32
* and/or other materials provided with the distribution.
33
34
* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS" AND
35
* ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED
36
* WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE
37
* DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE LIABLE FOR
38
* ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES
39
* (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES;
40
* LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND
41
* ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
42
* (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS
43
* SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
44
45
* The views and conclusions contained in the software and documentation are those
46
* of the authors and should not be interpreted as representing official policies,
47
* either expressed or implied, of the FreeBSD Project.
48
49
#ifndef LIBBSP_ARM_TMS570_RTI
50
#define LIBBSP_ARM_TMS570_RTI
51
52
bsp/utility.h
53
54
typedef
struct
55
uint32_t COMPx;
/*RTI Compare x Register*/
56
uint32_t UDCPx;
/*RTI Update Compare x Register*/
57
tms570_rti_compare_t
58
59
typedef
struct
60
uint32_t FRCx;
/*RTI Free Running Counter x Register*/
61
uint32_t UCx;
/*RTI Up Counter x Register*/
62
uint32_t CPUCx;
/*RTI Compare Up Counter x Register*/
63
uint8_t reserved1 [4];
64
uint32_t CAFRCx;
/*RTI Capture Free Running Counter x Register*/
65
uint32_t CAUCx;
/*RTI Capture Up Counter x Register*/
66
uint32_t rsvd[2];
/*Reserved*/
67
tms570_rti_counter_t
68
69
typedef
struct
70
uint32_t GCTRL;
/*RTI Global Control Register*/
71
uint32_t TBCTRL;
/*RTI Timebase Control Register*/
72
uint32_t CAPCTRL;
/*RTI Capture Control Register*/
73
uint32_t COMPCTRL;
/*RTI Compare Control Register*/
74
CNT[2];
/*Counters*/
75
CMP[4];
/*Compares*/
76
uint32_t TBLCOMP;
/*RTI Timebase Low Compare Register*/
77
uint32_t TBHCOMP;
/*RTI Timebase High Compare Register*/
78
uint8_t reserved2 [8];
79
uint32_t SETINTENA;
/*RTI Set Interrupt Enable Register*/
80
uint32_t CLEARINTENA;
/*RTI Clear Interrupt Enable Register*/
81
uint32_t INTFLAG;
/*RTI Interrupt Flag Register*/
82
uint8_t reserved3 [4];
83
uint32_t DWDCTRL;
/*Digital Watchdog Control Register*/
84
uint32_t DWDPRLD;
/*Digital Watchdog Preload Register*/
85
uint32_t WDSTATUS;
/*Watchdog Status Register*/
86
uint32_t WDKEY;
/*RTI Watchdog Key Register*/
87
uint32_t DWDCNTR;
/*RTI Digital Watchdog Down Counter Register*/
88
uint32_t WWDRXNCTRL;
/*Digital Windowed Watchdog Reaction Control Register*/
89
uint32_t WWDSIZECTRL;
/*Digital Windowed Watchdog Window Size Control Register*/
90
uint32_t INTCLRENABLE;
/*RTI Compare Interrupt Clear Enable Register*/
91
uint32_t COMP0CLR;
/*RTI Compare 0 Clear Register*/
92
uint32_t COMP1CLR;
/*RTI Compare 1 Clear Register*/
93
uint32_t COMP2CLR;
/*RTI Compare 2 Clear Register*/
94
uint32_t COMP3CLR;
/*RTI Compare 3 Clear Register*/
95
tms570_rti_t
96
97
98
/*----------------------TMS570_RTI_COMPx----------------------*/
99
/* field: COMPx - Compare x. */
100
/* Whole 32 bits */
101
102
/*----------------------TMS570_RTI_UDCPx----------------------*/
103
/* field: UDCPx - Update compare x. */
104
/* Whole 32 bits */
105
106
/*----------------------TMS570_RTI_FRCx----------------------*/
107
/* field: FRC0 - FRC0 */
108
/* Whole 32 bits */
109
110
/*-----------------------TMS570_RTI_UCx-----------------------*/
111
/* field: UC0 - Up counter 0. */
112
/* Whole 32 bits */
113
114
/*----------------------TMS570_RTI_CPUCx----------------------*/
115
/* field: CPUC0 - Compare up counter 0. This register holds the value that is compared with the up counter 0. */
116
/* Whole 32 bits */
117
118
/*---------------------TMS570_RTI_CAFRCx---------------------*/
119
/* field: CAFRC0 - Capture free running counter 0. */
120
/* Whole 32 bits */
121
122
/*----------------------TMS570_RTI_CAUCx----------------------*/
123
/* field: CAUC0 - Capture up counter 0. */
124
/* Whole 32 bits */
125
126
/*----------------------TMS570_RTI_rsvd----------------------*/
127
128
/* Whole 32 bits */
129
130
/*----------------------TMS570_RTI_GCTRL----------------------*/
131
/* field: NTUSEL - Select NTU signal. */
132
#define TMS570_RTI_GCTRL_NTUSEL(val) BSP_FLD32(val,16, 19)
133
#define TMS570_RTI_GCTRL_NTUSEL_GET(reg) BSP_FLD32GET(reg,16, 19)
134
#define TMS570_RTI_GCTRL_NTUSEL_SET(reg,val) BSP_FLD32SET(reg, val,16, 19)
135
136
/* field: COS - Continue on suspend. */
137
#define TMS570_RTI_GCTRL_COS BSP_BIT32(15)
138
139
/* field: CNT1EN - Counter 1 enable. This bit starts and stops counter block 1 (RTIUC1 and RTIFRC1). */
140
#define TMS570_RTI_GCTRL_CNT1EN BSP_BIT32(1)
141
142
/* field: CNT0EN - Counter 0 enable. This bit starts and stops counter block 0 (RTIUC0 and RTIFRC0). */
143
#define TMS570_RTI_GCTRL_CNT0EN BSP_BIT32(0)
144
145
146
/*---------------------TMS570_RTI_TBCTRL---------------------*/
147
/* field: INC - Increment free running counter 0. */
148
#define TMS570_RTI_TBCTRL_INC BSP_BIT32(1)
149
150
/* field: TBEXT - Timebase external. */
151
#define TMS570_RTI_TBCTRL_TBEXT BSP_BIT32(0)
152
153
154
/*---------------------TMS570_RTI_CAPCTRL---------------------*/
155
/* field: CAPCNTR1 - Capture counter 1. */
156
#define TMS570_RTI_CAPCTRL_CAPCNTR1 BSP_BIT32(1)
157
158
/* field: CAPCNTR0 - Capture counter 0. */
159
#define TMS570_RTI_CAPCTRL_CAPCNTR0 BSP_BIT32(0)
160
161
162
/*--------------------TMS570_RTI_COMPCTRL--------------------*/
163
/* field: COMPSEL3 - Compare select 3. */
164
#define TMS570_RTI_COMPCTRL_COMPSEL3 BSP_BIT32(12)
165
166
/* field: COMPSEL2 - Compare select 2. */
167
#define TMS570_RTI_COMPCTRL_COMPSEL2 BSP_BIT32(8)
168
169
/* field: COMPSEL1 - Compare select 1. */
170
#define TMS570_RTI_COMPCTRL_COMPSEL1 BSP_BIT32(4)
171
172
/* field: COMPSEL0 - Compare select 0. */
173
#define TMS570_RTI_COMPCTRL_COMPSEL0 BSP_BIT32(0)
174
175
176
/*---------------------TMS570_RTI_TBLCOMP---------------------*/
177
/* field: TBLCOMP - Timebase low compare value. */
178
/* Whole 32 bits */
179
180
/*---------------------TMS570_RTI_TBHCOMP---------------------*/
181
/* field: TBHCOMP - Timebase high compare value. */
182
/* Whole 32 bits */
183
184
/*--------------------TMS570_RTI_SETINTENA--------------------*/
185
/* field: SETOVL1INT - Set free running counter 1 overflow interrupt. */
186
#define TMS570_RTI_SETINTENA_SETOVL1INT BSP_BIT32(18)
187
188
/* field: SETOVL0INT - Set free running counter 0 overflow interrupt. */
189
#define TMS570_RTI_SETINTENA_SETOVL0INT BSP_BIT32(17)
190
191
/* field: SETTBINT - Set timebase interrupt. */
192
#define TMS570_RTI_SETINTENA_SETTBINT BSP_BIT32(16)
193
194
/* field: SETDMA3 - Set compare DMA request 3. */
195
#define TMS570_RTI_SETINTENA_SETDMA3 BSP_BIT32(11)
196
197
/* field: SETDMA2 - Set compare DMA request 2. */
198
#define TMS570_RTI_SETINTENA_SETDMA2 BSP_BIT32(10)
199
200
/* field: SETDMA1 - Set compare DMA request 1. */
201
#define TMS570_RTI_SETINTENA_SETDMA1 BSP_BIT32(9)
202
203
/* field: SETDMA0 - Set compare DMA request 0. */
204
#define TMS570_RTI_SETINTENA_SETDMA0 BSP_BIT32(8)
205
206
/* field: SETINT3 - Set compare interrupt 3. */
207
#define TMS570_RTI_SETINTENA_SETINT3 BSP_BIT32(3)
208
209
/* field: SETINT2 - Set compare interrupt 2. */
210
#define TMS570_RTI_SETINTENA_SETINT2 BSP_BIT32(2)
211
212
/* field: SETINT1 - Set compare interrupt 1. */
213
#define TMS570_RTI_SETINTENA_SETINT1 BSP_BIT32(1)
214
215
/* field: SETINT0 - Set compare interrupt 0. */
216
#define TMS570_RTI_SETINTENA_SETINT0 BSP_BIT32(0)
217
218
219
/*-------------------TMS570_RTI_CLEARINTENA-------------------*/
220
/* field: CLEAROVL1INT - Clear free running counter 1 overflow interrupt. */
221
#define TMS570_RTI_CLEARINTENA_CLEAROVL1INT BSP_BIT32(18)
222
223
/* field: CLEAROVL0INT - Clear free running counter 0 overflow interrupt. */
224
#define TMS570_RTI_CLEARINTENA_CLEAROVL0INT BSP_BIT32(17)
225
226
/* field: CLEARTBINT - Clear timebase interrupt. */
227
#define TMS570_RTI_CLEARINTENA_CLEARTBINT BSP_BIT32(16)
228
229
/* field: CLEARDMA3 - Clear compare DMA request 3. */
230
#define TMS570_RTI_CLEARINTENA_CLEARDMA3 BSP_BIT32(11)
231
232
/* field: CLEARDMA2 - Clear compare DMA request 2. */
233
#define TMS570_RTI_CLEARINTENA_CLEARDMA2 BSP_BIT32(10)
234
235
/* field: CLEARDMA1 - Clear compare DMA request 1. */
236
#define TMS570_RTI_CLEARINTENA_CLEARDMA1 BSP_BIT32(9)
237
238
/* field: CLEARDMA0 - Clear compare DMA request 0. */
239
#define TMS570_RTI_CLEARINTENA_CLEARDMA0 BSP_BIT32(8)
240
241
/* field: CLEARINT3 - Clear compare interrupt 3. */
242
#define TMS570_RTI_CLEARINTENA_CLEARINT3 BSP_BIT32(3)
243
244
/* field: CLEARINT2 - Clear compare interrupt 2. */
245
#define TMS570_RTI_CLEARINTENA_CLEARINT2 BSP_BIT32(2)
246
247
/* field: CLEARINT1 - Clear compare interrupt 1. */
248
#define TMS570_RTI_CLEARINTENA_CLEARINT1 BSP_BIT32(1)
249
250
/* field: CLEARINT0 - Clear compare interrupt 0. */
251
#define TMS570_RTI_CLEARINTENA_CLEARINT0 BSP_BIT32(0)
252
253
254
/*---------------------TMS570_RTI_INTFLAG---------------------*/
255
/* field: OVL1INT - Free running counter 1 overflow interrupt flag. This bit determines if an interrupt is pending. */
256
#define TMS570_RTI_INTFLAG_OVL1INT BSP_BIT32(18)
257
258
/* field: OVL0INT - Free running counter 0 overflow interrupt flag. This bit determines if an interrupt is pending. */
259
#define TMS570_RTI_INTFLAG_OVL0INT BSP_BIT32(17)
260
261
/* field: TBINT - Timebase interrupt flag. */
262
#define TMS570_RTI_INTFLAG_TBINT BSP_BIT32(16)
263
264
/* field: INT3 - Interrupt flag 3. These bits determine if an interrupt due to a Compare 3 match is pending. */
265
#define TMS570_RTI_INTFLAG_INT3 BSP_BIT32(3)
266
267
/* field: INT2 - Interrupt flag 2. These bits determine if an interrupt due to a Compare 2 match is pending. */
268
#define TMS570_RTI_INTFLAG_INT2 BSP_BIT32(2)
269
270
/* field: INT1 - Interrupt flag 1. These bits determine if an interrupt due to a Compare 1 match is pending. */
271
#define TMS570_RTI_INTFLAG_INT1 BSP_BIT32(1)
272
273
/* field: INT0 - Interrupt flag 0. These bits determine if an interrupt due to a Compare 0 match is pending. */
274
#define TMS570_RTI_INTFLAG_INT0 BSP_BIT32(0)
275
276
277
/*---------------------TMS570_RTI_DWDCTRL---------------------*/
278
/* field: DWDCTRL - DWDCTRL Digital Watchdog Control. */
279
/* Whole 32 bits */
280
281
/*---------------------TMS570_RTI_DWDPRLD---------------------*/
282
/* field: DWDPRLD - Digital Watchdog Preload Value. */
283
#define TMS570_RTI_DWDPRLD_DWDPRLD(val) BSP_FLD32(val,0, 15)
284
#define TMS570_RTI_DWDPRLD_DWDPRLD_GET(reg) BSP_FLD32GET(reg,0, 15)
285
#define TMS570_RTI_DWDPRLD_DWDPRLD_SET(reg,val) BSP_FLD32SET(reg, val,0, 15)
286
287
288
/*--------------------TMS570_RTI_WDSTATUS--------------------*/
289
/* field: DWWD_ST - Windowed Watchdog Status */
290
#define TMS570_RTI_WDSTATUS_DWWD_ST BSP_BIT32(5)
291
292
/* field: END_TIME_VIOL - Windowed Watchdog End Time Violation Status. */
293
#define TMS570_RTI_WDSTATUS_END_TIME_VIOL BSP_BIT32(4)
294
295
/* field: START_TIME_VIOL - Windowed Watchdog Start Time Violation Status. */
296
#define TMS570_RTI_WDSTATUS_START_TIME_VIOL BSP_BIT32(3)
297
298
/* field: KEY_ST - Watchdog key status. */
299
#define TMS570_RTI_WDSTATUS_KEY_ST BSP_BIT32(2)
300
301
/* field: DWD_ST - DWD status. */
302
#define TMS570_RTI_WDSTATUS_DWD_ST BSP_BIT32(1)
303
304
305
/*----------------------TMS570_RTI_WDKEY----------------------*/
306
/* field: WDKEY - Watchdog key. These bits provide the key sequence location. */
307
#define TMS570_RTI_WDKEY_WDKEY(val) BSP_FLD32(val,0, 15)
308
#define TMS570_RTI_WDKEY_WDKEY_GET(reg) BSP_FLD32GET(reg,0, 15)
309
#define TMS570_RTI_WDKEY_WDKEY_SET(reg,val) BSP_FLD32SET(reg, val,0, 15)
310
311
312
/*---------------------TMS570_RTI_DWDCNTR---------------------*/
313
/* field: DWDCNTR - DWD down counter. */
314
#define TMS570_RTI_DWDCNTR_DWDCNTR(val) BSP_FLD32(val,0, 24)
315
#define TMS570_RTI_DWDCNTR_DWDCNTR_GET(reg) BSP_FLD32GET(reg,0, 24)
316
#define TMS570_RTI_DWDCNTR_DWDCNTR_SET(reg,val) BSP_FLD32SET(reg, val,0, 24)
317
318
319
/*-------------------TMS570_RTI_WWDRXNCTRL-------------------*/
320
/* field: WWDRXN - The DWWD reaction */
321
#define TMS570_RTI_WWDRXNCTRL_WWDRXN(val) BSP_FLD32(val,0, 3)
322
#define TMS570_RTI_WWDRXNCTRL_WWDRXN_GET(reg) BSP_FLD32GET(reg,0, 3)
323
#define TMS570_RTI_WWDRXNCTRL_WWDRXN_SET(reg,val) BSP_FLD32SET(reg, val,0, 3)
324
325
326
/*-------------------TMS570_RTI_WWDSIZECTRL-------------------*/
327
/* field: WWDSIZE - The DWWD window size */
328
/* Whole 32 bits */
329
330
/*------------------TMS570_RTI_INTCLRENABLE------------------*/
331
/* field: INTCLRENABLE3 - Enables the auto-clear functionality on the compare 3 interrupt. */
332
#define TMS570_RTI_INTCLRENABLE_INTCLRENABLE3(val) BSP_FLD32(val,24, 27)
333
#define TMS570_RTI_INTCLRENABLE_INTCLRENABLE3_GET(reg) BSP_FLD32GET(reg,24, 27)
334
#define TMS570_RTI_INTCLRENABLE_INTCLRENABLE3_SET(reg,val) BSP_FLD32SET(reg, val,24, 27)
335
336
/* field: INTCLRENABLE2 - Enables the auto-clear functionality on the compare 2 interrupt. */
337
#define TMS570_RTI_INTCLRENABLE_INTCLRENABLE2(val) BSP_FLD32(val,16, 19)
338
#define TMS570_RTI_INTCLRENABLE_INTCLRENABLE2_GET(reg) BSP_FLD32GET(reg,16, 19)
339
#define TMS570_RTI_INTCLRENABLE_INTCLRENABLE2_SET(reg,val) BSP_FLD32SET(reg, val,16, 19)
340
341
/* field: INTCLRENABLE1 - Enables the auto-clear functionality on the compare 1 interrupt. */
342
#define TMS570_RTI_INTCLRENABLE_INTCLRENABLE1(val) BSP_FLD32(val,8, 11)
343
#define TMS570_RTI_INTCLRENABLE_INTCLRENABLE1_GET(reg) BSP_FLD32GET(reg,8, 11)
344
#define TMS570_RTI_INTCLRENABLE_INTCLRENABLE1_SET(reg,val) BSP_FLD32SET(reg, val,8, 11)
345
346
/* field: INTCLRENABLE0 - Enables the auto-clear functionality on the compare 0 interrupt. */
347
#define TMS570_RTI_INTCLRENABLE_INTCLRENABLE0(val) BSP_FLD32(val,0, 3)
348
#define TMS570_RTI_INTCLRENABLE_INTCLRENABLE0_GET(reg) BSP_FLD32GET(reg,0, 3)
349
#define TMS570_RTI_INTCLRENABLE_INTCLRENABLE0_SET(reg,val) BSP_FLD32SET(reg, val,0, 3)
350
351
352
/*--------------------TMS570_RTI_COMP0CLR--------------------*/
353
/* field: CMP0CLR - Compare 0 clear. */
354
/* Whole 32 bits */
355
356
/*--------------------TMS570_RTI_COMP1CLR--------------------*/
357
/* field: CMP0CLR - Compare 1 clear. */
358
/* Whole 32 bits */
359
360
/*--------------------TMS570_RTI_COMP2CLR--------------------*/
361
/* field: CMP2CLR - Compare 2 clear. */
362
/* Whole 32 bits */
363
364
/*--------------------TMS570_RTI_COMP3CLR--------------------*/
365
/* field: CMP3CLR - Compare 3 clear. */
366
/* Whole 32 bits */
367
368
369
#endif
/* LIBBSP_ARM_TMS570_RTI */
utility.h
This header file provides utility macros for BSPs.
Definition:
reg_rti.h:54
Definition:
reg_rti.h:59
tms570_rti_t
Definition:
reg_rti.h:69
