RTEMS
6.1-rc2
bsps
arm
tms570
include
bsp
ti_herc
reg_esm.h
1
/* SPDX-License-Identifier: BSD-2-Clause */
2
11
/* The header file is generated by make_header.py from ESM.json */
12
/* Current script's version can be found at: */
13
/* https://github.com/AoLaD/rtems-tms570-utils/tree/headers/headers/python */
14
15
16
* Copyright (c) 2014-2015, Premysl Houdek <kom541000@gmail.com>
17
18
* Czech Technical University in Prague
19
* Zikova 1903/4
20
* 166 36 Praha 6
21
* Czech Republic
22
23
* All rights reserved.
24
25
26
* modification, are permitted provided that the following conditions are met:
27
28
* 1. Redistributions of source code must retain the above copyright notice, this
29
* list of conditions and the following disclaimer.
30
* 2. Redistributions in binary form must reproduce the above copyright notice,
31
* this list of conditions and the following disclaimer in the documentation
32
* and/or other materials provided with the distribution.
33
34
* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS" AND
35
* ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED
36
* WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE
37
* DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE LIABLE FOR
38
* ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES
39
* (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES;
40
* LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND
41
* ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
42
* (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS
43
* SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
44
45
* The views and conclusions contained in the software and documentation are those
46
* of the authors and should not be interpreted as representing official policies,
47
* either expressed or implied, of the FreeBSD Project.
48
49
#ifndef LIBBSP_ARM_TMS570_ESM
50
#define LIBBSP_ARM_TMS570_ESM
51
52
bsp/utility.h
53
54
typedef
struct
55
uint32_t EEPAPR1;
/*ESM Enable ERROR Pin Action/Response Register 1*/
56
uint32_t DEPAPR1;
/*ESM Disable ERROR Pin Action/Response Register 1*/
57
uint32_t IESR1;
/*ESM Interrupt Enable Set/Status Register 1*/
58
uint32_t IECR1;
/*ESM Interrupt Enable Clear/Status Register 1*/
59
uint32_t ILSR1;
/*Interrupt Level Set/Status Register 1*/
60
uint32_t ILCR1;
/*Interrupt Level Clear/Status Register 1*/
61
uint32_t SR[3];
/*ESM Status Register*/
62
uint32_t EPSR;
/*ESM ERROR Pin Status Register*/
63
uint32_t IOFFHR;
/*ESM Interrupt Offset High Register*/
64
uint32_t IOFFLR;
/*ESM Interrupt Offset Low Register*/
65
uint32_t LTCR;
/*ESM Low-Time Counter Register*/
66
uint32_t LTCPR;
/*ESM Low-Time Counter Preload Register*/
67
uint32_t EKR;
/*ESM Error Key Register*/
68
uint32_t SSR2;
/*ESM Status Shadow Register 2*/
69
uint32_t IEPSR4;
/*ESM Influence ERROR Pin Set/Status Register 4*/
70
uint32_t IEPCR4;
/*ESM Influence ERROR Pin Clear/Status Register 4*/
71
uint32_t IESR4;
/*ESM Interrupt Enable Set/Status Register 4*/
72
uint32_t IECR4;
/*ESM Interrupt Enable Clear/Status Register 4*/
73
uint32_t ILSR4;
/*Interrupt Level Set/Status Register 4*/
74
uint32_t ILCR4;
/*Interrupt Level Clear/Status Register 4*/
75
uint32_t SR4;
/*ESM Status Register 4*/
76
tms570_esm_t
77
78
79
/*---------------------TMS570_ESM_EEPAPR1---------------------*/
80
/* field: IEPSET - Enable ERROR Pin Action/Response on Group 1. */
81
/* Whole 32 bits */
82
83
/*---------------------TMS570_ESM_DEPAPR1---------------------*/
84
/* field: IEPCLR - Disable ERROR Pin Action/Response on Group 1. */
85
/* Whole 32 bits */
86
87
/*----------------------TMS570_ESM_IESR1----------------------*/
88
/* field: INTENSET - Set interrupt Enable */
89
/* Whole 32 bits */
90
91
/*----------------------TMS570_ESM_IECR1----------------------*/
92
/* field: INTENCLR - Clear Interrupt Enable */
93
/* Whole 32 bits */
94
95
/*----------------------TMS570_ESM_ILSR1----------------------*/
96
/* field: INTLVLSET - Set Interrupt Priority */
97
/* Whole 32 bits */
98
99
/*----------------------TMS570_ESM_ILCR1----------------------*/
100
/* field: INTLVLCLR - Clear Interrupt Priority. */
101
/* Whole 32 bits */
102
103
/*-----------------------TMS570_ESM_SR-----------------------*/
104
/* field: ESF - Error Status Flag. Provides status information on a pending error. */
105
/* Whole 32 bits */
106
107
/*----------------------TMS570_ESM_EPSR----------------------*/
108
/* field: EPSF - ERROR Pin Status Flag. Provides status information for the ERROR Pin. */
109
#define TMS570_ESM_EPSR_EPSF BSP_BIT32(0)
110
111
112
/*---------------------TMS570_ESM_IOFFHR---------------------*/
113
/* field: INTOFFH - Offset High Level Interrupt. */
114
#define TMS570_ESM_IOFFHR_INTOFFH(val) BSP_FLD32(val,0, 6)
115
#define TMS570_ESM_IOFFHR_INTOFFH_GET(reg) BSP_FLD32GET(reg,0, 6)
116
#define TMS570_ESM_IOFFHR_INTOFFH_SET(reg,val) BSP_FLD32SET(reg, val,0, 6)
117
118
119
/*---------------------TMS570_ESM_IOFFLR---------------------*/
120
/* field: INTOFFL - Offset Low Level Interrupt. */
121
#define TMS570_ESM_IOFFLR_INTOFFL(val) BSP_FLD32(val,0, 6)
122
#define TMS570_ESM_IOFFLR_INTOFFL_GET(reg) BSP_FLD32GET(reg,0, 6)
123
#define TMS570_ESM_IOFFLR_INTOFFL_SET(reg,val) BSP_FLD32SET(reg, val,0, 6)
124
125
126
/*----------------------TMS570_ESM_LTCR----------------------*/
127
/* field: LTC - ERROR Pin Low-Time Counter */
128
#define TMS570_ESM_LTCR_LTC(val) BSP_FLD32(val,0, 15)
129
#define TMS570_ESM_LTCR_LTC_GET(reg) BSP_FLD32GET(reg,0, 15)
130
#define TMS570_ESM_LTCR_LTC_SET(reg,val) BSP_FLD32SET(reg, val,0, 15)
131
132
133
/*----------------------TMS570_ESM_LTCPR----------------------*/
134
/* field: LTCP - ERROR Pin Low-Time Counter Pre-load Value */
135
#define TMS570_ESM_LTCPR_LTCP(val) BSP_FLD32(val,0, 15)
136
#define TMS570_ESM_LTCPR_LTCP_GET(reg) BSP_FLD32GET(reg,0, 15)
137
#define TMS570_ESM_LTCPR_LTCP_SET(reg,val) BSP_FLD32SET(reg, val,0, 15)
138
139
140
/*-----------------------TMS570_ESM_EKR-----------------------*/
141
/* field: EKEY - Error Key. The key to reset the ERROR pin or to force an error on the ERROR pin. */
142
#define TMS570_ESM_EKR_EKEY(val) BSP_FLD32(val,0, 3)
143
#define TMS570_ESM_EKR_EKEY_GET(reg) BSP_FLD32GET(reg,0, 3)
144
#define TMS570_ESM_EKR_EKEY_SET(reg,val) BSP_FLD32SET(reg, val,0, 3)
145
146
147
/*----------------------TMS570_ESM_SSR2----------------------*/
148
/* field: ESF - Error Status Flag. Shadow register for status information on pending error. */
149
/* Whole 32 bits */
150
151
/*---------------------TMS570_ESM_IEPSR4---------------------*/
152
/* field: IEPSET - Set Influence on ERROR Pin */
153
/* Whole 32 bits */
154
155
/*---------------------TMS570_ESM_IEPCR4---------------------*/
156
/* field: IEPCLR - Clear Influence on ERROR Pin */
157
/* Whole 32 bits */
158
159
/*----------------------TMS570_ESM_IESR4----------------------*/
160
/* field: INTENSET - Set Interrupt Enable */
161
/* Whole 32 bits */
162
163
/*----------------------TMS570_ESM_IECR4----------------------*/
164
165
/* Whole 32 bits */
166
167
/*----------------------TMS570_ESM_ILSR4----------------------*/
168
/* field: INTLVLSET - Set Interrupt Level */
169
/* Whole 32 bits */
170
171
/*----------------------TMS570_ESM_ILCR4----------------------*/
172
/* field: INTLVLCLR - Clear Interrupt Level */
173
/* Whole 32 bits */
174
175
/*-----------------------TMS570_ESM_SR4-----------------------*/
176
177
/* Whole 32 bits */
178
179
180
#endif
/* LIBBSP_ARM_TMS570_ESM */
utility.h
This header file provides utility macros for BSPs.
tms570_esm_t
Definition:
reg_esm.h:54
