RTEMS 6.1-rc2
pxa255.h
1/*
2 * By Yang Xi <hiyangxi@gmail.com>.
3 *
4 * The license and distribution terms for this file may be
5 * found in the file LICENSE in this distribution or at
6 * http://www.rtems.org/license/LICENSE.
7 */
8
9#ifndef __PXA_255_H__
10#define __PXA_255_H__
11
12typedef unsigned int word_t;
13
14/*Interrupt*/
15
16#define PRIMARY_IRQS 32
17#define GPIO_IRQS (85 - 2) /* The first two IRQs have level
18 one interrupts */
19#define GPIO_IRQ 10
20
21#define IRQS (PRIMARY_IRQS + GPIO_IRQS)
22
23/* Interrupt Controller */
24#define INTERRUPT_OFFSET 0xd00000
25#define XSCALE_IRQ_OS_TIMER 26
26#define XSCALE_IRQ_PMU 12
27#define XSCALE_IRQ_STUART 20
28#define XSCALE_IRQ_NETWORK 16
29
30#define PMU_IRQ 12
31#define CCNT_IRQ_ENABLE 1UL << 6
32#define PMN1_IRQ_ENABLE 1UL << 5
33#define PMN0_IRQ_ENABLE 1UL << 4
34
35#define IODEVICE_VADDR 0x40000000
36#define XSCALE_INT (IODEVICE_VADDR + INTERRUPT_OFFSET)
37
38#define XSCALE_INT_ICMR (*(volatile word_t *)(XSCALE_INT + 0x04)) /* Mask register */
39#define XSCALE_INT_ICLR (*(volatile word_t *)(XSCALE_INT + 0x08)) /* FIQ / IRQ selection */
40#define XSCALE_INT_ICCR (*(volatile word_t *)(XSCALE_INT + 0x14)) /* Control register */
41#define XSCALE_INT_ICIP (*(volatile word_t *)(XSCALE_INT + 0x00)) /* IRQ pending */
42#define XSCALE_INT_ICFP (*(volatile word_t *)(XSCALE_INT + 0x0c)) /* FIQ pending */
43#define XSCALE_INT_ICPR (*(volatile word_t *)(XSCALE_INT + 0x10)) /* Pending (unmasked) */
44
45/* GPIO */
46#define GPIO_OFFSET 0xe00000
47#define PXA_GPIO (IODEVICE_VADDR + GPIO_OFFSET)
48
49#define PXA_GEDR0 (*(volatile word_t *)(PXA_GPIO + 0x48)) /* GPIO edge detect 0 */
50#define PXA_GEDR1 (*(volatile word_t *)(PXA_GPIO + 0x4C)) /* GPIO edge detect 1 */
51#define PXA_GEDR2 (*(volatile word_t *)(PXA_GPIO + 0x50)) /* GPIO edge detect 2 */
52
53
54/* PXA2XX Timer */
55
56#define TIMER_OFFSET 0x0a00000
57#define CLOCKS_OFFSET 0x1300000
58/*I change the TIMER_RATE to 36864,because when I use 3686400, the period will be calculate
59 to 30000*/
60#define TIMER_RATE 36864
61
62#define XSCALE_TIMERS (IODEVICE_VADDR + TIMER_OFFSET)
63
64/* Match registers */
65#define XSCALE_OS_TIMER_MR0 (*(volatile word_t *)(XSCALE_TIMERS + 0x00))
66#define XSCALE_OS_TIMER_MR1 (*(volatile word_t *)(XSCALE_TIMERS + 0x04))
67#define XSCALE_OS_TIMER_MR2 (*(volatile word_t *)(XSCALE_TIMERS + 0x08))
68#define XSCALE_OS_TIMER_MR3 (*(volatile word_t *)(XSCALE_TIMERS + 0x0c))
69
70/* Interrupt enable register */
71#define XSCALE_OS_TIMER_IER (*(volatile word_t *)(XSCALE_TIMERS + 0x1c))
72/* Watchdog match enable register */
73#define XSCALE_OS_TIMER_WMER (*(volatile word_t *)(XSCALE_TIMERS + 0x18))
74/* Timer count register */
75#define XSCALE_OS_TIMER_TCR (*(volatile word_t *)(XSCALE_TIMERS + 0x10))
76/* Timer status register */
77#define XSCALE_OS_TIMER_TSR (*(volatile word_t *)(XSCALE_TIMERS + 0x14))
78
79#define XSCALE_CLOCKS (IODEVICE_VADDR + CLOCKS_VOFFSET)
80
81#define XSCALE_CLOCKS_CCCR (*(volatile word_t *)(XSCALE_CLOCKS + 0x00))
82
83/*Use ffuart port as the console*/
84#define FFUART_BASE 0x40100000
85
86/*Write to SKYEYE_MAGIC_ADDRESS to make SKYEYE exit*/
87
88#define SKYEYE_MAGIC_ADDRESS (*(volatile word_t *)(0xb0000000))
89#define SKYEYE_MAGIC_NUMBER (0xf0f0f0f0)
90
91/*PMC*/
92#define PMC_PMNC 0
93#define PMC_CCNT 1
94#define PMC_INTEN 2
95#define PMC_FLAG 3
96#define PMC_EVTSEL 4
97#define PMC_PMN0 5
98#define PMC_PMN1 6
99#define PMC_PMN2 7
100#define PMC_PMN3 8
101
102#define PMC_PMNC_E (0x01)
103#define PMC_PMNC_PCR (0x01 << 1)
104#define PMC_PMNC_CCR (0x01 << 2)
105#define PMC_PMNC_CCD (0x01 << 3)
106#define PMC_PMNC_PCD (0x01 << 4)
107
108/*LCD*/
109#define LCCR0 (*(volatile word_t *)(0x44000000))
110#define LCCR1 (*(volatile word_t *)(0x44000004))
111#define LCCR2 (*(volatile word_t *)(0x44000008))
112#define LCCR3 (*(volatile word_t *)(0x4400000C))
113
114#define FDADR0 (*(volatile word_t *)(0x44000200))
115#define FSADR0 (*(volatile word_t *)(0x44000204))
116#define FIDR0 (*(volatile word_t *)(0x44000208))
117#define LDCMD0 (*(volatile word_t *)(0x4400020C))
118
119#define FDADR1 (*(volatile word_t *)(0x44000210))
120#define FSADR1 (*(volatile word_t *)(0x44000214))
121#define FIDR1 (*(volatile word_t *)(0x44000218))
122#define LDCMD1 (*(volatile word_t *)(0x4400021C))
123
124#define LCCR0_ENB 0x00000001
125#define LCCR1_PPL 0x000003FF
126#define LCCR2_LPP 0x000003FF
127#define LCCR3_BPP 0x07000000
128#endif
