RTEMS 6.1-rc2
pwmss.h
1
9/*
10 * SPDX-License-Identifier: BSD-2-Clause
11 *
12 * Copyright (c) 2020, 2021 James Fitzsimons <james.fitzsimons@gmail.com>
13 *
16 * are met:
22 *
34 */
35
36#ifndef LIBBSP_ARM_BEAGLE_PWMSS_H
37#define LIBBSP_ARM_BEAGLE_PWMSS_H
38
39#ifdef __cplusplus
40extern "C" {
41#endif /* __cplusplus */
42
43/* The following definitions are bitmasks for the clk control registers for
44 * the PWMSS module clocks. All three modules have the same clock control
45 * hence the EPMSSx to signify these values are consistent across all
46 * EPWMSS instances. */
47#define AM335X_CM_PER_EPWMSSx_CLKCTRL_MODULEMODE_ENABLE (0x2u)
48#define AM335X_CM_PER_EPWMSSx_CLKCTRL_MODULEMODE (0x00000003u)
49#define AM335X_CM_PER_EPWMSSx_CLKCTRL_IDLEST_FUNC (0x0u)
50#define AM335X_CM_PER_EPWMSSx_CLKCTRL_IDLEST_SHIFT (0x00000010u)
51#define AM335X_CM_PER_EPWMSSx_CLKCTRL_IDLEST (0x00030000u)
52
58typedef enum {
59 BBB_PWMSS0 = 0,
60 BBB_PWMSS1,
61 BBB_PWMSS2,
62 BBB_PWMSS_COUNT
63} BBB_PWMSS;
64
65
67
68#ifdef __cplusplus
69}
70#endif /* __cplusplus */
71
72#endif /* LIBBSP_ARM_BEAGLE_PWMSS_H */
rtems_status_code
Definition: status.h:85
BBB_PWMSS
The set of possible PWM subsystem module.
Definition: pwmss.h:58
rtems_status_code pwmss_module_clk_config(BBB_PWMSS pwmss_id)
This function configures the L3 and L4_PER system clocks. It also configures the system clocks for th...
Definition: pwmss.c:57
