RTEMS
6.1-rc2
bsps
powerpc
beatnik
pci
pci_io_remap.h
1
#ifndef RTEMS_PCI_IO_REMAP_H
2
#define RTEMS_PCI_IO_REMAP_H
3
/* Reconfigure all I/O base address registers for a range of PCI busses
4
* (from and including 'bus_from' up to and not including 'bus_to').
5
* adding an offset. This involves adjusting the base and limit registers
6
* of PCI-PCI bridges, too.
7
8
* RESTRICTIONS: 'offset' must be 4k aligned (PCI req.); no argument check
9
* on the bus numbers is done.
10
11
* RETURNS: 0 on success and a number > 0 indicating the number of
12
* non-32bit bridges found where the offset couldn't be added.
13
* Devices behind such a bridge are not accessible through I/O
14
* and should probably be switched off (not done by this code).
15
16
17
int
18
rtems_pci_io_remap(
int
bus_from,
int
bus_to, uint32_t offset);
19
20
21
* Authorship
22
23
* This software ('beatnik' RTEMS BSP for MVME6100 and MVME5500) was
24
* created by Till Straumann <strauman@slac.stanford.edu>, 2005-2007,
25
* Stanford Linear Accelerator Center, Stanford University.
26
27
* Acknowledgement of sponsorship
28
29
* The 'beatnik' BSP was produced by
30
* the Stanford Linear Accelerator Center, Stanford University,
31
* under Contract DE-AC03-76SFO0515 with the Department of Energy.
32
33
* Government disclaimer of liability
34
35
* Neither the United States nor the United States Department of Energy,
36
* nor any of their employees, makes any warranty, express or implied, or
37
* assumes any legal liability or responsibility for the accuracy,
38
* completeness, or usefulness of any data, apparatus, product, or process
39
* disclosed, or represents that its use would not infringe privately owned
40
* rights.
41
42
* Stanford disclaimer of liability
43
44
* Stanford University makes no representations or warranties, express or
45
* implied, nor assumes any liability for the use of this software.
46
47
* Stanford disclaimer of copyright
48
49
* Stanford University, owner of the copyright, hereby disclaims its
50
* copyright and all other rights in this software. Hence, anyone may
51
* freely use it for any purpose without restriction.
52
53
* Maintenance of notices
54
55
* In the interest of clarity regarding the origin and status of this
56
* SLAC software, this and all the preceding Stanford University notices
57
* are to remain affixed to any copy or derivative of this software made
58
* or distributed by the recipient and are to be affixed to any copy of
59
* software made or distributed by the recipient that contains a copy or
60
* derivative of this software.
61
62
* ------------------ SLAC Software Notices, Set 4 OTT.002a, 2004 FEB 03
63
64
65
#endif
66
