RTEMS 6.1-rc2
passwd.h
2
9/*
10 * COPYRIGHT (C) 2007 On-Line Applications Research Corporation (OAR).
11 *
12 * Redistribution and use in source and binary forms, with or without
13 * modification, are permitted provided that the following conditions
14 * are met:
15 * 1. Redistributions of source code must retain the above copyright
16 * notice, this list of conditions and the following disclaimer.
17 * 2. Redistributions in binary form must reproduce the above copyright
18 * notice, this list of conditions and the following disclaimer in the
19 * documentation and/or other materials provided with the distribution.
20 *
21 * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
22 * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
23 * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
24 * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
25 * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
26 * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
27 * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
28 * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
29 * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
30 * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
31 * POSSIBILITY OF SUCH DAMAGE.
32 */
33
34/* Define a default password for telnetd here.
35 * NOTES:
36 * - this can be overridden at run-time by setting
37 * the "TELNETD_PASSWD" environment variable.
38 * As soon as that variable is set, the new password
39 * is effective - no need to restart telnetd.
40 * - this must be set to an _encrypted_ password, NOT
41 * the cleartext. Use the 'genpw' utility to generate
42 * a password string:
43 *
44 * 1) Compile 'genpw.c' for the HOST, i.e.
45 * cc -o genpw genpw.c -lcrypt
46 * 1) delete an old password definition from this file.
47 * 2) run './genpw >> passwd.h'. This will append
48 * a new definition to this file.
49 *
50 * - if no password is defined here, no authentication
51 * is needed, i.e. telnet is open to the world.
52 *
53 * T. Straumann <strauman@slac.stanford.edu>
54 */
55
56/* #undef TELNETD_DEFAULT_PASSWD */
57/* Default password: 'rtems' */
58#define TELNETD_DEFAULT_PASSWD "tduDcyLX12owo"
