RTEMS
6.1-rc2
score
cpu
or1k
include
score
or1k.h
1
/* SPDX-License-Identifier: BSD-2-Clause */
2
7
8
* This file contains information pertaining to the OR1K processor.
9
10
* COPYRIGHT (c) 2014 Hesham ALMatary <heshamelmatary@gmail.com>
11
12
* Based on code with the following copyright...
13
* COPYRIGHT (c) 1989-1999, 2010.
14
* On-Line Applications Research Corporation (OAR).
15
16
17
* modification, are permitted provided that the following conditions
18
* are met:
19
* 1. Redistributions of source code must retain the above copyright
20
* notice, this list of conditions and the following disclaimer.
21
* 2. Redistributions in binary form must reproduce the above copyright
22
* notice, this list of conditions and the following disclaimer in the
23
* documentation and/or other materials provided with the distribution.
24
25
* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
26
* AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
27
* IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
28
* ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
29
* LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
30
* CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
31
* SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
32
* INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
33
* CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
34
* ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
35
* POSSIBILITY OF SUCH DAMAGE.
36
37
38
#ifndef _RTEMS_SCORE_OR1K_H
39
#define _RTEMS_SCORE_OR1K_H
40
41
#ifdef __cplusplus
42
extern
"C"
43
#endif
44
45
46
* This file contains the information required to build
47
* RTEMS for a particular member of the OR1K family.
48
* It does this by setting variables to indicate which
49
* implementation dependent features are present in a particular
50
* member of the family.
51
52
* This is a good place to list all the known CPU models
53
* that this port supports and which RTEMS CPU model they correspond
54
* to.
55
56
57
58
* Define the name of the CPU family and specific model.
59
60
61
#define CPU_NAME "OR1K"
62
#define CPU_MODEL_NAME "OR1200"
63
64
#ifdef __cplusplus
65
66
#endif
67
68
#endif
/* _RTEMS_SCORE_OR1K_H */
