RTEMS 6.1-rc2
optionsimpl.h
2
12/* COPYRIGHT (c) 1989-2008.
13 * On-Line Applications Research Corporation (OAR).
14 *
16 * modification, are permitted provided that the following conditions
17 * are met:
18 * 1. Redistributions of source code must retain the above copyright
19 * notice, this list of conditions and the following disclaimer.
20 * 2. Redistributions in binary form must reproduce the above copyright
21 * notice, this list of conditions and the following disclaimer in the
22 * documentation and/or other materials provided with the distribution.
23 *
24 * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
25 * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
26 * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
27 * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
28 * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
29 * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
30 * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
31 * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
32 * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
33 * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
34 * POSSIBILITY OF SUCH DAMAGE.
35 */
36
37#ifndef _RTEMS_RTEMS_OPTIONSIMPL_H
38#define _RTEMS_RTEMS_OPTIONSIMPL_H
39
40#include <rtems/rtems/options.h>
41
42#ifdef __cplusplus
43extern "C" {
44#endif
45
62static inline bool _Options_Is_no_wait (
63 rtems_option option_set
64)
65{
66 return (option_set & RTEMS_NO_WAIT) ? true : false;
67}
68
75static inline bool _Options_Is_any (
76 rtems_option option_set
77)
78{
79 return (option_set & RTEMS_EVENT_ANY) ? true : false;
80}
81
84#ifdef __cplusplus
85}
86#endif
87
88#endif
89/* end of include file */
#define RTEMS_EVENT_ANY
This option constant indicates that the task wishes to wait until at least one of the events of inter...
Definition: options.h:104
uint32_t rtems_option
This type represents a Classic API directive option set.
Definition: options.h:126
#define RTEMS_NO_WAIT
This option constant indicates that the task does not want to wait on the resource.
Definition: options.h:117
This header file provides the Classic API directive options.
