RTEMS 6.1-rc2
nios2-utility.h
2
8/*
9 * Copyright (c) 2011 embedded brains GmbH & Co. KG
10 *
11 * Redistribution and use in source and binary forms, with or without
12 * modification, are permitted provided that the following conditions
13 * are met:
14 * 1. Redistributions of source code must retain the above copyright
15 * notice, this list of conditions and the following disclaimer.
16 * 2. Redistributions in binary form must reproduce the above copyright
17 * notice, this list of conditions and the following disclaimer in the
18 * documentation and/or other materials provided with the distribution.
19 *
20 * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
21 * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
22 * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
23 * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
24 * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
25 * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
26 * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
27 * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
28 * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
29 * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
30 * POSSIBILITY OF SUCH DAMAGE.
31 */
32
33#ifndef _RTEMS_SCORE_NIOS2_UTILITY_H
34#define _RTEMS_SCORE_NIOS2_UTILITY_H
35
36#define NIOS2_CTLREG_INDEX_STATUS 0
37#define NIOS2_CTLREG_INDEX_ESTATUS 1
38#define NIOS2_CTLREG_INDEX_BSTATUS 2
39#define NIOS2_CTLREG_INDEX_IENABLE 3
40#define NIOS2_CTLREG_INDEX_IPENDING 4
41#define NIOS2_CTLREG_INDEX_CPUID 5
42#define NIOS2_CTLREG_INDEX_EXCEPTION 7
43#define NIOS2_CTLREG_INDEX_PTEADDR 8
44#define NIOS2_CTLREG_INDEX_TLBACC 9
45#define NIOS2_CTLREG_INDEX_TLBMISC 10
46#define NIOS2_CTLREG_INDEX_BADADDR 12
47#define NIOS2_CTLREG_INDEX_CONFIG 13
48#define NIOS2_CTLREG_INDEX_MPUBASE 14
49#define NIOS2_CTLREG_INDEX_MPUACC 15
50
51#define NIOS2_CONTEXT_OFFSET_R16 0
52#define NIOS2_CONTEXT_OFFSET_R17 4
53#define NIOS2_CONTEXT_OFFSET_R18 8
54#define NIOS2_CONTEXT_OFFSET_R19 12
55#define NIOS2_CONTEXT_OFFSET_R20 16
56#define NIOS2_CONTEXT_OFFSET_R21 20
57#define NIOS2_CONTEXT_OFFSET_R22 24
58#define NIOS2_CONTEXT_OFFSET_R23 28
59#define NIOS2_CONTEXT_OFFSET_FP 32
60#define NIOS2_CONTEXT_OFFSET_STATUS 36
61#define NIOS2_CONTEXT_OFFSET_SP 40
62#define NIOS2_CONTEXT_OFFSET_RA 44
63#define NIOS2_CONTEXT_OFFSET_ISR_DISPATCH_DISABLE 48
64#define NIOS2_CONTEXT_OFFSET_STACK_MPUBASE 52
65#define NIOS2_CONTEXT_OFFSET_STACK_MPUACC 56
66
67#define NIOS2_ISR_STATUS_MASK_IIC 0xfffffffe
68#define NIOS2_ISR_STATUS_BITS_IIC 0x00000000
69
70#define NIOS2_ISR_STATUS_MASK_EIC_IL 0xfffffc0f
71#define NIOS2_ISR_STATUS_BITS_EIC_IL 0x000003f0
72
73#define NIOS2_ISR_STATUS_MASK_EIC_RSIE 0xf7ffffff
74#define NIOS2_ISR_STATUS_BITS_EIC_RSIE 0x00000000
75
76#define NIOS2_STATUS_RSIE (1 << 23)
77#define NIOS2_STATUS_NMI (1 << 22)
78#define NIOS2_STATUS_PRS_OFFSET 16
79#define NIOS2_STATUS_PRS_MASK (0x3f << NIOS2_STATUS_PRS_OFFSET)
80#define NIOS2_STATUS_CRS_OFFSET 10
81#define NIOS2_STATUS_CRS_MASK (0x3f << NIOS2_STATUS_CRS_OFFSET)
82#define NIOS2_STATUS_IL_OFFSET 4
83#define NIOS2_STATUS_IL_MASK (0x3f << NIOS2_STATUS_IL_OFFSET)
84#define NIOS2_STATUS_IH (1 << 3)
85#define NIOS2_STATUS_EH (1 << 2)
86#define NIOS2_STATUS_U (1 << 1)
87#define NIOS2_STATUS_PIE (1 << 0)
88
89#define NIOS2_EXCEPTION_CAUSE_OFFSET 2
90#define NIOS2_EXCEPTION_CAUSE_MASK (0x1f << NIOS2_EXCEPTION_CAUSE_OFFSET)
91
92#define NIOS2_PTEADDR_PTBASE_OFFSET 22
93#define NIOS2_PTEADDR_PTBASE_MASK (0x3ff << NIOS2_PTEADDR_PTBASE_OFFSET)
94#define NIOS2_PTEADDR_VPN_OFFSET 2
95#define NIOS2_PTEADDR_VPN_MASK (0xfffff << NIOS2_PTEADDR_VPN_OFFSET)
96
97#define NIOS2_TLBACC_IG_OFFSET 25
98#define NIOS2_TLBACC_IG_MASK (0x3ff << NIOS2_TLBACC_IG_OFFSET)
99#define NIOS2_TLBACC_C (1 << 24)
100#define NIOS2_TLBACC_R (1 << 23)
101#define NIOS2_TLBACC_W (1 << 22)
102#define NIOS2_TLBACC_X (1 << 21)
103#define NIOS2_TLBACC_G (1 << 20)
104#define NIOS2_TLBACC_PFN_OFFSET 2
105#define NIOS2_TLBACC_PFN_MASK (0xfffff << NIOS2_TLBACC_PFN_OFFSET)
106
107#define NIOS2_TLBMISC_WAY_OFFSET 20
108#define NIOS2_TLBMISC_WAY_MASK (0xf << NIOS2_TLBMISC_WAY_OFFSET)
109#define NIOS2_TLBMISC_RD (1 << 19)
110#define NIOS2_TLBMISC_WE (1 << 18)
111#define NIOS2_TLBMISC_PID_OFFSET 5
112#define NIOS2_TLBMISC_PID_MASK (0x3fff << NIOS2_TLBMISC_PID_OFFSET)
113#define NIOS2_TLBMISC_DBL (1 << 3)
114#define NIOS2_TLBMISC_BAD (1 << 2)
115#define NIOS2_TLBMISC_PERM (1 << 1)
116#define NIOS2_TLBMISC_D (1 << 0)
117
118#define NIOS2_CONFIG_ANI (1 << 1)
119#define NIOS2_CONFIG_PE (1 << 0)
120
121#define NIOS2_MPUBASE_BASE_OFFSET 6
122#define NIOS2_MPUBASE_BASE_MASK (0x1ffffff << NIOS2_MPUBASE_BASE_OFFSET)
123#define NIOS2_MPUBASE_INDEX_OFFSET 1
124
125/* Avoid redefines with Altera HAL */
126#define NIOS2_MPUBASE_INDEX_MASK (0x0000003e)
127
128#define NIOS2_MPUBASE_D (1 << 0)
129
130#define NIOS2_MPUACC_MASK_OFFSET 6
131
132/* Avoid redefines with Altera HAL */
133#define NIOS2_MPUACC_MASK_MASK (0x7fffffc0)
134
135#define NIOS2_MPUACC_LIMIT_OFFSET 6
136
137/* Avoid redefines with Altera HAL */
138#define NIOS2_MPUACC_LIMIT_MASK (0xffffffc0)
139
140#define NIOS2_MPUACC_C (1 << 5)
141#define NIOS2_MPUACC_PERM_OFFSET 2
142
143/* Avoid redefines with Altera HAL */
144#define NIOS2_MPUACC_PERM_MASK (0x0000001c)
145
146#define NIOS2_MPUACC_RD (1 << 1)
147#define NIOS2_MPUACC_WR (1 << 0)
148
149#ifndef ASM
150
151#include <stddef.h>
152#include <stdint.h>
153#include <stdbool.h>
154
155#ifdef __cplusplus
156extern "C" {
157#endif /* __cplusplus */
158
166extern char _Nios2_ISR_Status_mask [];
167
175extern char _Nios2_ISR_Status_bits [];
176
177static inline void _Nios2_Flush_pipeline( void )
178{
179 __asm__ volatile ("flushp");
180}
181
182static inline uint32_t _Nios2_Get_ctlreg_status( void )
183{
184 return (uint32_t) __builtin_rdctl( NIOS2_CTLREG_INDEX_STATUS );
185}
186
187static inline void _Nios2_Set_ctlreg_status( uint32_t value )
188{
189 __builtin_wrctl( NIOS2_CTLREG_INDEX_STATUS, (int) value );
190}
191
192static inline uint32_t _Nios2_Get_ctlreg_estatus( void )
193{
194 return (uint32_t) __builtin_rdctl( NIOS2_CTLREG_INDEX_ESTATUS );
195}
196
197static inline void _Nios2_Set_ctlreg_estatus( uint32_t value )
198{
199 __builtin_wrctl( NIOS2_CTLREG_INDEX_ESTATUS, (int) value );
200}
201
202static inline uint32_t _Nios2_Get_ctlreg_bstatus( void )
203{
204 return (uint32_t) __builtin_rdctl( NIOS2_CTLREG_INDEX_BSTATUS );
205}
206
207static inline void _Nios2_Set_ctlreg_bstatus( uint32_t value )
208{
209 __builtin_wrctl( NIOS2_CTLREG_INDEX_BSTATUS, (int) value );
210}
211
212static inline uint32_t _Nios2_Get_ctlreg_ienable( void )
213{
214 return (uint32_t) __builtin_rdctl( NIOS2_CTLREG_INDEX_IENABLE );
215}
216
217static inline void _Nios2_Set_ctlreg_ienable( uint32_t value )
218{
219 __builtin_wrctl( NIOS2_CTLREG_INDEX_IENABLE, (int) value );
220}
221
222static inline uint32_t _Nios2_Get_ctlreg_ipending( void )
223{
224 return (uint32_t) __builtin_rdctl( NIOS2_CTLREG_INDEX_IPENDING );
225}
226
227static inline uint32_t _Nios2_Get_ctlreg_cpuid( void )
228{
229 return (uint32_t) __builtin_rdctl( NIOS2_CTLREG_INDEX_CPUID );
230}
231
232static inline uint32_t _Nios2_Get_ctlreg_exception( void )
233{
234 return (uint32_t) __builtin_rdctl( NIOS2_CTLREG_INDEX_EXCEPTION );
235}
236
237static inline uint32_t _Nios2_Get_ctlreg_pteaddr( void )
238{
239 return (uint32_t) __builtin_rdctl( NIOS2_CTLREG_INDEX_PTEADDR );
240}
241
242static inline void _Nios2_Set_ctlreg_pteaddr( uint32_t value )
243{
244 __builtin_wrctl( NIOS2_CTLREG_INDEX_PTEADDR, (int) value );
245}
246
247static inline uint32_t _Nios2_Get_ctlreg_tlbacc( void )
248{
249 return (uint32_t) __builtin_rdctl( NIOS2_CTLREG_INDEX_TLBACC );
250}
251
252static inline void _Nios2_Set_ctlreg_tlbacc( uint32_t value )
253{
254 __builtin_wrctl( NIOS2_CTLREG_INDEX_TLBACC, (int) value );
255}
256
257static inline uint32_t _Nios2_Get_ctlreg_tlbmisc( void )
258{
259 return (uint32_t) __builtin_rdctl( NIOS2_CTLREG_INDEX_TLBMISC );
260}
261
262static inline void _Nios2_Set_ctlreg_tlbmisc( uint32_t value )
263{
264 __builtin_wrctl( NIOS2_CTLREG_INDEX_TLBMISC, (int) value );
265}
266
267static inline uint32_t _Nios2_Get_ctlreg_badaddr( void )
268{
269 return (uint32_t) __builtin_rdctl( NIOS2_CTLREG_INDEX_BADADDR );
270}
271
272static inline uint32_t _Nios2_Get_ctlreg_config( void )
273{
274 return (uint32_t) __builtin_rdctl( NIOS2_CTLREG_INDEX_CONFIG );
275}
276
277static inline void _Nios2_Set_ctlreg_config( uint32_t value )
278{
279 __builtin_wrctl( NIOS2_CTLREG_INDEX_CONFIG, (int) value );
280}
281
282static inline uint32_t _Nios2_Get_ctlreg_mpubase( void )
283{
284 return (uint32_t) __builtin_rdctl( NIOS2_CTLREG_INDEX_MPUBASE );
285}
286
287static inline void _Nios2_Set_ctlreg_mpubase( uint32_t value )
288{
289 __builtin_wrctl( NIOS2_CTLREG_INDEX_MPUBASE, (int) value );
290}
291
292static inline uint32_t _Nios2_Get_ctlreg_mpuacc( void )
293{
294 return (uint32_t) __builtin_rdctl( NIOS2_CTLREG_INDEX_MPUACC );
295}
296
297static inline void _Nios2_Set_ctlreg_mpuacc( uint32_t value )
298{
299 __builtin_wrctl( NIOS2_CTLREG_INDEX_MPUACC, (int) value );
300}
301
302static inline uint32_t _Nios2_ISR_Get_status_mask( void )
303{
304 return (uint32_t) &_Nios2_ISR_Status_mask [0];
305}
306
307static inline uint32_t _Nios2_ISR_Get_status_bits( void )
308{
309 return (uint32_t) &_Nios2_ISR_Status_bits [0];
310}
311
312static inline bool _Nios2_Has_internal_interrupt_controller( void )
313{
314 return _Nios2_ISR_Get_status_mask() == NIOS2_ISR_STATUS_MASK_IIC;
315}
316
317uint32_t _Nios2_ISR_Set_level( uint32_t new_level, uint32_t status );
318
319typedef struct {
320 int data_address_width;
321 int instruction_address_width;
322 int data_region_size_log2;
323 int instruction_region_size_log2;
324 int data_region_count;
325 int instruction_region_count;
326 int data_index_for_stack_protection;
327 bool region_uses_limit;
328 bool enable_data_cache_for_stack;
330
331void _Nios2_MPU_Set_configuration( const Nios2_MPU_Configuration *config );
332
333const Nios2_MPU_Configuration *_Nios2_MPU_Get_configuration( void );
334
335typedef enum {
336 NIOS2_MPU_INST_PERM_SVR_NONE_USER_NONE = 0,
337 NIOS2_MPU_INST_PERM_SVR_EXECUTE_USER_NONE,
338 NIOS2_MPU_INST_PERM_SVR_EXECUTE_USER_EXECUTE,
339 NIOS2_MPU_DATA_PERM_SVR_NONE_USER_NONE = 0,
340 NIOS2_MPU_DATA_PERM_SVR_READONLY_USER_NONE,
341 NIOS2_MPU_DATA_PERM_SVR_READONLY_USER_READONLY,
342 NIOS2_MPU_DATA_PERM_SVR_READWRITE_USER_NONE = 4,
343 NIOS2_MPU_DATA_PERM_SVR_READWRITE_USER_READONLY,
344 NIOS2_MPU_DATA_PERM_SVR_READWRITE_USER_READWRITE
345} Nios2_MPU_Region_permissions;
346
347typedef struct {
348 int index;
349 const void *base;
350 const void *end;
351 Nios2_MPU_Region_permissions perm;
352 bool data;
353 bool cacheable;
354 bool read;
355 bool write;
357
358#define NIOS2_MPU_REGION_DESC_INST( index, base, end ) \
359 { \
360 (index), (base), (end), NIOS2_MPU_INST_PERM_SVR_EXECUTE_USER_NONE, \
361 false, false, false, true \
362 }
363
364#define NIOS2_MPU_REGION_DESC_DATA_RO( index, base, end ) \
365 { \
366 (index), (base), (end), NIOS2_MPU_DATA_PERM_SVR_READONLY_USER_NONE, \
367 true, true, false, true \
368 }
369
370#define NIOS2_MPU_REGION_DESC_DATA_RW( index, base, end ) \
371 { \
372 (index), (base), (end), NIOS2_MPU_DATA_PERM_SVR_READWRITE_USER_NONE, \
373 true, true, false, true \
374 }
375
376#define NIOS2_MPU_REGION_DESC_DATA_IO( index, base, end ) \
377 { \
378 (index), (base), (end), NIOS2_MPU_DATA_PERM_SVR_READWRITE_USER_NONE, \
379 true, false, false, true \
380 }
381
382static inline int _Nios2_MPU_Get_region_count(
384 bool data
385)
386{
387 return data ?
388 config->data_region_count
389 : config->instruction_region_count;
390}
391
392static inline bool _Nios2_MPU_Is_valid_index(
394 int index,
395 bool data
396)
397{
398 return 0 <= index
399 && index < _Nios2_MPU_Get_region_count( config, data );
400}
401
402bool _Nios2_MPU_Setup_region_registers(
404 const Nios2_MPU_Region_descriptor *desc,
405 uint32_t *mpubase,
406 uint32_t *mpuacc
407);
408
409bool _Nios2_MPU_Get_region_descriptor(
411 int index,
412 bool data,
414);
415
429 bool data,
430 int begin,
431 int end
432);
433
444 const Nios2_MPU_Region_descriptor *desc,
445 bool force
446);
447
448static inline void _Nios2_MPU_Get_region_registers(
449 int index,
450 bool data,
451 uint32_t *mpubase,
452 uint32_t *mpuacc
453)
454{
455 uint32_t base = (uint32_t)
456 (((index << NIOS2_MPUBASE_INDEX_OFFSET) & NIOS2_MPUBASE_INDEX_MASK)
457 | (data ? NIOS2_MPUBASE_D : 0));
458
459 _Nios2_Set_ctlreg_mpubase( base );
460 _Nios2_Set_ctlreg_mpuacc( NIOS2_MPUACC_RD );
461 _Nios2_Flush_pipeline();
462 *mpubase = _Nios2_Get_ctlreg_mpubase() | base;
463 *mpuacc = _Nios2_Get_ctlreg_mpuacc();
464}
465
466static inline void _Nios2_MPU_Set_region_registers(
467 uint32_t mpubase,
468 uint32_t mpuacc
469)
470{
471 _Nios2_Set_ctlreg_mpubase( mpubase );
472 _Nios2_Set_ctlreg_mpuacc( mpuacc );
473 _Nios2_Flush_pipeline();
474}
475
476static inline void _Nios2_MPU_Enable( void )
477{
478 uint32_t config = _Nios2_Get_ctlreg_config();
479
480 _Nios2_Set_ctlreg_config( config | NIOS2_CONFIG_PE );
481}
482
483static inline uint32_t _Nios2_MPU_Disable( void )
484{
485 uint32_t config = _Nios2_Get_ctlreg_config();
486 uint32_t config_pe = NIOS2_CONFIG_PE;
487
488 _Nios2_Set_ctlreg_config( config & ~config_pe );
489
490 return config;
491}
492
493static inline void _Nios2_MPU_Restore( uint32_t config )
494{
495 _Nios2_Set_ctlreg_config( config );
496}
497
498uint32_t _Nios2_MPU_Disable_protected( void );
499
500void _Nios2_MPU_Reset( const Nios2_MPU_Configuration *config );
501
502#ifdef __cplusplus
503}
504#endif /* __cplusplus */
505
506#else /* ASM */
507
508 .macro NIOS2_ASM_DISABLE_INTERRUPTS new_status, current_status
509 movhi \new_status, %hiadj(_Nios2_ISR_Status_mask)
510 addi \new_status, \new_status, %lo(_Nios2_ISR_Status_mask)
511 and \new_status, \current_status, \new_status
512 ori \new_status, \new_status, %lo(_Nios2_ISR_Status_bits)
513 wrctl status, \new_status
514 .endm
515
516#endif /* ASM */
517
518#endif /* _RTEMS_SCORE_NIOS2_UTILITY_H */
ssize_t read(int fd, void *buffer, size_t count)
Definition: read.c:46
ssize_t write(int fd, const void *buffer, size_t count)
Definition: write.c:49
bool _Nios2_MPU_Add_region(const Nios2_MPU_Configuration *config, const Nios2_MPU_Region_descriptor *desc, bool force)
Adds a region according to region descriptor desc.
Definition: nios2-mpu-add-region.c:84
char _Nios2_ISR_Status_bits[]
This symbol specifies the status register bits used to disable interrupts.
char _Nios2_ISR_Status_mask[]
This global symbol specifies the status register mask used to disable interrupts.
int _Nios2_MPU_Get_disabled_region_index(const Nios2_MPU_Configuration *config, bool data, int begin, int end)
Searches the region table part for a disabled region.
Definition: nios2-mpu-add-region.c:52
Definition: nios2-utility.h:319
Definition: nios2-utility.h:347
Definition: deflate.c:114
