RTEMS 6.1-rc2
newlib.h
2
15/*
16 * Copyright (C) 2020 embedded brains GmbH & Co. KG
17 *
18 * Redistribution and use in source and binary forms, with or without
19 * modification, are permitted provided that the following conditions
20 * are met:
21 * 1. Redistributions of source code must retain the above copyright
22 * notice, this list of conditions and the following disclaimer.
23 * 2. Redistributions in binary form must reproduce the above copyright
24 * notice, this list of conditions and the following disclaimer in the
25 * documentation and/or other materials provided with the distribution.
26 *
27 * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
28 * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
29 * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
30 * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
31 * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
32 * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
33 * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
34 * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
35 * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
36 * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
37 * POSSIBILITY OF SUCH DAMAGE.
38 */
39
40#ifndef _RTEMS_CONFDEFS_NEWLIB_H
41#define _RTEMS_CONFDEFS_NEWLIB_H
42
43#ifndef __CONFIGURATION_TEMPLATE_h
44#error "Do not include this file directly, use <rtems/confdefs.h> instead"
45#endif
46
47#ifdef CONFIGURE_INIT
48
49#if defined(RTEMS_NEWLIB) && !defined(CONFIGURE_DISABLE_NEWLIB_REENTRANCY)
50 #include <rtems/score/percpu.h>
51 #include <rtems/score/thread.h>
52 #include <sys/reent.h>
53 #define _CONFIGURE_ENABLE_NEWLIB_REENTRANCY
54#endif
55
56#ifdef __cplusplus
57extern "C" {
58#endif
59
60#if defined(_CONFIGURE_ENABLE_NEWLIB_REENTRANCY) && \
61 !defined(_REENT_THREAD_LOCAL)
62 struct _reent *__getreent( void )
63 {
64 return _Thread_Get_executing()->libc_reent;
65 }
66#endif
67
68#ifdef __cplusplus
69}
70#endif
71
72#endif /* CONFIGURE_INIT */
73
74#endif /* _RTEMS_CONFDEFS_NEWLIB_H */
This header file provides the interfaces of the Per-CPU Information.
This header file provides interfaces of the Thread Handler which are used by the implementation and t...
