RTEMS
6.1-rc2
libfs
src
jffs2
include
linux
mtd
mtd.h
1
#ifndef __LINUX_MTD_MTD_H__
2
#define __LINUX_MTD_MTD_H__
3
4
#include <linux/slab.h>
5
7
#define MTD_FAIL_ADDR_UNKNOWN -1LL
8
9
struct
mtd_info
10
uint32_t oobavail;
11
uint32_t oobsize;
12
uint32_t size;
13
uint32_t erasesize;
14
uint32_t writesize;
15
16
17
static
inline
int
do_mtd_point(
size_t
*retlen,
void
**ebuf)
18
19
*retlen = 0;
20
*ebuf =
NULL
21
22
return
-EOPNOTSUPP;
23
24
25
#define mtd_point(a, b, c, d, e, f) do_mtd_point(d, e)
26
27
#define mtd_unpoint(a, b, c) do { } while (0)
28
29
#define mtd_kmalloc_up_to(a, b) kmalloc(*(b), GFP_KERNEL)
30
31
struct
mtd_oob_ops
32
uint32_t mode;
33
size_t
len;
34
size_t
retlen;
35
size_t
ooblen;
36
size_t
oobretlen;
37
uint32_t ooboffs;
38
uint8_t *datbuf;
39
uint8_t *oobbuf;
40
41
42
#define EUCLEAN EAGAIN
43
static
inline
int
mtd_is_bitflip(
int
err) {
return
(err == -EUCLEAN); }
44
45
#define mtd_block_isbad(mtd_sp, offset) ({ \
46
bool bad; \
47
int sc = jffs2_flash_block_is_bad(RTEMS_CONTAINER_OF(&(mtd_sp), struct jffs2_sb_info, mtd), offset, &bad); \
48
if (sc) { \
49
return sc; \
50
51
bad; \
52
53
#define mtd_block_markbad(mtd_sp, offset) \
54
jffs2_flash_block_mark_bad(RTEMS_CONTAINER_OF(&(mtd_sp), struct jffs2_sb_info, mtd), offset)
55
#define mtd_write(mtd_sp, ofs, len, retlen, buf) \
56
jffs2_flash_direct_write(RTEMS_CONTAINER_OF(&(mtd_sp), struct jffs2_sb_info, mtd), ofs, len, retlen, buf)
57
#define mtd_read(mtd_sp, ofs, len, retlen, buf) \
58
jffs2_flash_direct_read(RTEMS_CONTAINER_OF(&(mtd_sp), struct jffs2_sb_info, mtd), ofs, len, retlen, buf)
59
60
#endif
/* __LINUX_MTD_MTD_H__ */
NULL
#define NULL
Requests a GPIO pin group configuration.
Definition:
xil_types.h:54
mtd_info
Definition:
mtd.h:9
mtd_oob_ops
Definition:
mtd.h:31
