RTEMS 6.1-rc2
mscan.h
2
3/*
4 * RTEMS generic MPC5200 BSP
5 *
6 * This file has to be included by application when using mscan.
7 */
8
9/*
10 * Copyright (c) 2005 embedded brains GmbH & Co. KG
11 *
12 * Redistribution and use in source and binary forms, with or without
13 * modification, are permitted provided that the following conditions
14 * are met:
15 * 1. Redistributions of source code must retain the above copyright
16 * notice, this list of conditions and the following disclaimer.
17 * 2. Redistributions in binary form must reproduce the above copyright
18 * notice, this list of conditions and the following disclaimer in the
19 * documentation and/or other materials provided with the distribution.
20 *
21 * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
22 * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
23 * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
24 * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
25 * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
26 * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
27 * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
28 * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
29 * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
30 * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
31 * POSSIBILITY OF SUCH DAMAGE.
32 */
33
34#ifndef __MSCAN_H__
35#define __MSCAN_H__
36
37#ifdef __cplusplus
38extern "C" {
39#endif
40
41#define MSCAN_A_DEV_NAME "/dev/mscana"
42#define MSCAN_B_DEV_NAME "/dev/mscanb"
43#define MSCAN_0_DEV_NAME "/dev/mscan0"
44#define MSCAN_1_DEV_NAME "/dev/mscan1"
45#define MSCAN_A 0
46#define MSCAN_B 1
47
48#define MSCAN_MAX_DATA_BYTES 8
49
50#define MSCAN_MESS_ID_RTR (1 << 15)
51#define MSCAN_MESS_ID_RTR_MASK (1 << 15)
52#define MSCAN_MESS_ID_ID_MASK ((1 << 11)-1)
53#define MSCAN_MESS_ID_HAS_RTR(id) (((id)&MSCAN_MESS_ID_RTR_MASK)==MSCAN_MESS_ID_RTR)
54
55#define MSCAN_SET_RX_ID 1
56#define MSCAN_GET_RX_ID 2
57#define MSCAN_SET_RX_ID_MASK 3
58#define MSCAN_GET_RX_ID_MASK 4
59#define MSCAN_SET_TX_ID 5
60#define MSCAN_GET_TX_ID 6
61#define TOUCAN_MSCAN_INIT 7
62#define MSCAN_SET_BAUDRATE 8
63#define SET_TX_BUF_NO 9
64
65struct can_message
66 {
67 /* uint16_t mess_len; */
68 uint16_t mess_id;
69 uint16_t mess_time_stamp;
70 uint8_t mess_data[MSCAN_MAX_DATA_BYTES];
71 uint8_t mess_len;
72 uint8_t mess_rtr;
73 uint32_t toucan_tx_idx;
74 };
75
77 {
78 struct can_message *rx_mess;
79 uint32_t rx_timeout;
80 uint8_t rx_flags;
81 };
82
84 {
85 struct can_message *tx_mess;
86 uint32_t tx_idx;
87 };
88
90 {
91 uint32_t ctrl_id;
92 uint32_t ctrl_id_mask;
93 uint8_t ctrl_reg_no;
94 uint8_t ctrl_tx_buf_no;
95 uint32_t ctrl_can_bitrate;
96 void (*toucan_cb_fnc)(int16_t);
97 };
98
99
102 void *
103 );
104
107 void *
108 );
109
112 void *
113 );
114
117 void *
118 );
119
122 void *
123 );
124
127 void *
128 );
129
130
131#define MSCAN_DRIVER_TABLE_ENTRY \
132 { mscan_initialize, mscan_open, mscan_close, \
133 mscan_read, mscan_write, mscan_control }
134
135#ifdef __cplusplus
136}
137#endif
138
139#endif /* __MSCAN_H__ */
uint32_t rtems_device_major_number
This integer type represents the major number of devices.
Definition: io.h:103
uint32_t rtems_device_minor_number
This integer type represents the minor number of devices.
Definition: io.h:115
rtems_status_code
Definition: status.h:85
Definition: mscan.h:90
Definition: mscan.h:77
Definition: mscan.h:84
A CAN message represented of both forms.
Definition: can.h:66
