RTEMS 6.1-rc2
mrsp.h
2
13/*
14 * Copyright (C) 2014, 2016 embedded brains GmbH & Co. KG
15 *
16 * Redistribution and use in source and binary forms, with or without
17 * modification, are permitted provided that the following conditions
18 * are met:
19 * 1. Redistributions of source code must retain the above copyright
20 * notice, this list of conditions and the following disclaimer.
21 * 2. Redistributions in binary form must reproduce the above copyright
22 * notice, this list of conditions and the following disclaimer in the
23 * documentation and/or other materials provided with the distribution.
24 *
25 * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
26 * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
27 * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
28 * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
29 * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
30 * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
31 * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
32 * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
33 * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
34 * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
35 * POSSIBILITY OF SUCH DAMAGE.
36 */
37
38#ifndef _RTEMS_SCORE_MRSP_H
39#define _RTEMS_SCORE_MRSP_H
40
41#include <rtems/score/cpuopts.h>
42#include <rtems/score/threadq.h>
43
44#ifdef __cplusplus
45extern "C" {
46#endif /* __cplusplus */
47
72#if defined(RTEMS_SMP)
73
77typedef struct {
81 Thread_queue_Control Wait_queue;
82
86 Priority_Node Ceiling_priority;
87
91 Priority_Control ceiling_priorities[ RTEMS_ZERO_LENGTH_ARRAY ];
92} MRSP_Control;
93
94#endif /* RTEMS_SMP */
95
98#ifdef __cplusplus
99}
100#endif /* __cplusplus */
101
102#endif /* _RTEMS_SCORE_MRSP_H */
#define RTEMS_ZERO_LENGTH_ARRAY
This constant represents the element count of a zero-length array.
Definition: basedefs.h:1032
uint64_t Priority_Control
The thread priority control.
Definition: priority.h:91
The priority node to build up a priority aggregation.
Definition: priority.h:112
Definition: threadq.h:609
This header file provides interfaces of the Thread Queue Handler which are used by the implementation...
