RTEMS 6.1-rc2
moxie.h
2
7/*
8 * This file contains information pertaining to the Moxie processor.
9 *
10 * COPYRIGHT (c) 2011, 2013
11 * Anthony Green
12 *
13 * Based on code with the following copyright...
14 * COPYRIGHT (c) 1989-1999, 2010.
15 * On-Line Applications Research Corporation (OAR).
16 *
17 * Redistribution and use in source and binary forms, with or without
18 * modification, are permitted provided that the following conditions
19 * are met:
20 * 1. Redistributions of source code must retain the above copyright
21 * notice, this list of conditions and the following disclaimer.
22 * 2. Redistributions in binary form must reproduce the above copyright
23 * notice, this list of conditions and the following disclaimer in the
24 * documentation and/or other materials provided with the distribution.
25 *
26 * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
27 * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
28 * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
29 * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
30 * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
31 * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
32 * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
33 * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
34 * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
35 * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
36 * POSSIBILITY OF SUCH DAMAGE.
37 */
38
39#ifndef _RTEMS_SCORE_MOXIE_H
40#define _RTEMS_SCORE_MOXIE_H
41
42#ifdef __cplusplus
43extern "C" {
44#endif
45
46/*
47 * This file contains the information required to build
48 * RTEMS for a particular member of the "moxie"
49 * family when executing in protected mode. It does
50 * this by setting variables to indicate which implementation
51 * dependent features are present in a particular member
52 * of the family.
53 */
54
55#define CPU_NAME "Moxie"
56#define CPU_MODEL_NAME "MoxieLite"
57
58#ifdef __cplusplus
59}
60#endif
61
62#endif
