RTEMS 6.1-rc2
memlimits.h
1
7/*
8 * limits.h - definition of machine & system dependent address limits
9 *
10 * THIS SOFTWARE IS NOT COPYRIGHTED
11 *
12 * The following software is offered for use in the public domain.
13 * There is no warranty with regard to this software or its performance
14 * and the user must accept the software "AS IS" with all faults.
15 *
16 * THE CONTRIBUTORS DISCLAIM ANY WARRANTIES, EXPRESS OR IMPLIED, WITH
17 * REGARD TO THIS SOFTWARE INCLUDING BUT NOT LIMITED TO THE WARRANTIES
18 * OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE.
19 */
20
21#ifndef _MEMLIMITS_H_
22#define _MEMLIMITS_H_
23
24/*
25 * The macros in this file are specific to a given implementation.
26 * The general rules for their construction are as follows:
27 *
28 * 1.) is_readable(addr,length) should be true if and only if the
29 * region starting at the given virtual address can be read
30 * _without_ causing an exception or other fatal error. Note
31 * that the stub will use the strictest alignment satisfied
32 * by _both_ addr and length (e.g., if both are divisible by
33 * 8 then the region will be read in double-word chunks).
34 *
35 * 2.) is_writeable(addr,length) should be true if and only if the
36 * region starting at the given virtual address can be written
37 * _without_ causing an exception or other fatal error. Note
38 * that the stub will use the strictest alignment satisfied
39 * by _both_ addr and length (e.g., if both are divisible by
40 * 8 then the region will be written in double-word chunks).
41 *
42 * 3.) is-steppable(ptr) whould be true if and only if ptr is the
43 * address of a writeable region of memory which may contain
44 * an executable instruction. At a minimum this requires that
45 * ptr be word-aligned (divisible by 4) and not point to EPROM
46 * or memory-mapped I/O.
47 *
48 * Note: in order to satisfy constraints related to cacheability
49 * of certain memory subsystems it may be necessary for regions
50 * of kseg0 and kseg1 which map to the same physical addresses
51 * to have different readability and/or writeability attributes.
52 */
53
61/*
62#define K0_LIMIT_FOR_READ (K0BASE+0x18000000)
63#define K1_LIMIT_FOR_READ (K1BASE+K1SIZE)
64
65#define is_readable(addr,length) \
66 (((K0BASE <= addr) && ((addr + length) <= K0_LIMIT_FOR_READ)) \
67 || ((K1BASE <= addr) && ((addr + length) <= K1_LIMIT_FOR_READ)))
68
69#define K0_LIMIT_FOR_WRITE (K0BASE+0x08000000)
70#define K1_LIMIT_FOR_WRITE (K1BASE+0x1e000000)
71
72#define is_writeable(addr,length) \
73 (((K0BASE <= addr) && ((addr + length) <= K0_LIMIT_FOR_WRITE)) \
74 || ((K1BASE <= addr) && ((addr + length) <= K1_LIMIT_FOR_WRITE)))
75
76#define K0_LIMIT_FOR_STEP (K0BASE+0x08000000)
77#define K1_LIMIT_FOR_STEP (K1BASE+0x08000000)
78
79#define is_steppable(ptr) \
80 ((((int)ptr & 0x3) == 0) \
81 && (((K0BASE <= (int)ptr) && ((int)ptr < K0_LIMIT_FOR_STEP)) \
82 || ((K1BASE <= (int)ptr) && ((int)ptr < K1_LIMIT_FOR_STEP))))
83
84struct memseg
85{
86 unsigned begin, end, opts;
87};
88
89#define MEMOPT_READABLE 1
90#define MEMOPT_WRITEABLE 2
91
92#define NUM_MEMSEGS 10
93
94int add_memsegment(unsigned,unsigned,int);
95int is_readable(unsigned,unsigned);
96int is_writeable(unsigned,unsigned);
97int is_steppable(unsigned);
98*/
99
100#endif /* _MEMLIMITS_H_ */
