RTEMS 6.1-rc2
mcf5206e.h
1/*
2 * Coldfire MCF5206e on-chip peripherial definitions.
3 * Contents of this file based on information provided in
4 * Motorola MCF5206e User's Manual
5 *
6 * Copyright (C) 2000 OKTET Ltd., St.-Petersburg, Russia
7 * Author: Victor V. Vengerov <vvv@oktet.ru>
8 *
9 * The license and distribution terms for this file may be
10 * found in the file LICENSE in this distribution or at
11 * http://www.rtems.org/license/LICENSE.
12 */
13
14#ifndef __MCF5206E_H__
15#define __MCF5206E_H__
16
17#ifdef ASM
18#define MCF5206E_REG8(base,ofs) (ofs+base)
19#define MCF5206E_REG16(base,ofs) (ofs+base)
20#define MCF5206E_REG32(base,ofs) (ofs+base)
21#else
22#define MCF5206E_REG8(base,ofs) \
23 (volatile uint8_t*)((uint8_t*)(base) + (ofs))
24#define MCF5206E_REG16(base,ofs) \
25 (volatile uint16_t*)((uint8_t*)(base) + (ofs))
26#define MCF5206E_REG32(base,ofs) \
27 (volatile uint32_t*)((uint8_t*)(base) + (ofs))
28#endif
29
30/*** Instruction Cache -- MCF5206e User's Manual, Chapter 4 ***/
31
32/* CACR - Cache Control Register */
33#define MCF5206E_CACR_CENB (0x80000000) /* Cache Enable */
34#define MCF5206E_CACR_CPDI (0x10000000) /* Disable CPUSHL Invalidation */
35#define MCF5206E_CACR_CFRZ (0x08000000) /* Cache Freeze */
36#define MCF5206E_CACR_CINV (0x01000000) /* Cache Invalidate */
37#define MCF5206E_CACR_CEIB (0x00000400) /* Cache Enable Noncacheable
38 instruction bursting */
39#define MCF5206E_CACR_DCM (0x00000200) /* Default cache mode - noncacheable*/
40#define MCF5206E_CACR_DBWE (0x00000100) /* Default Buffered Write Enable */
41#define MCF5206E_CACR_DWP (0x00000020) /* Default Write Protection */
42#define MCF5206E_CACR_CLNF (0x00000003) /* Cache Line Fill */
43
44/* ACR0, ACR1 - Access Control Registers */
45#define MCF5206E_ACR_AB (0xff000000) /* Address Base */
46#define MCF5206E_ACR_AB_S (24)
47#define MCF5206E_ACR_AM (0x00ff0000) /* Address Mask */
48#define MCF5206E_ACR_AM_S (16)
49#define MCF5206E_ACR_EN (0x00008000) /* Enable ACR */
50#define MCF5206E_ACR_SM (0x00006000) /* Supervisor Mode */
51#define MCF5206E_ACR_SM_USR (0x00000000) /* Match if user mode */
52#define MCF5206E_ACR_SM_SVR (0x00002000) /* Match if supervisor mode */
53#define MCF5206E_ACR_SM_ANY (0x00004000) /* Match Always */
54#define MCF5206E_ACR_CM (0x00000040) /* Cache Mode (1 - noncacheable) */
55#define MCF5206E_ACR_BUFW (0x00000020) /* Buffered Write Enable */
56#define MCF5206E_ACR_WP (0x00000004) /* Write Protect */
57#define MCF5206E_ACR_BASE(base) ((base) & MCF5206E_ACR_AB)
58#define MCF5206E_ACR_MASK(mask) (((mask) >> 8) & MCF5206E_ACR_AM)
59
60/*** SRAM -- MCF5206e User's Manual, Chapter 5 ***/
61
62/* RAMBAR - SRAM Base Address Register */
63#define MCF5206E_RAMBAR_BA (0xffffe000) /* SRAM Base Address */
64#define MCF5206E_RAMBAR_WP (0x00000100) /* Write Protect */
65#define MCF5206E_RAMBAR_CI (0x00000020) /* CPU Space mask */
66#define MCF5206E_RAMBAR_SC (0x00000010) /* Supervisor Code Space Mask */
67#define MCF5206E_RAMBAR_SD (0x00000008) /* Supervisor Data Space Mask */
68#define MCF5206E_RAMBAR_UC (0x00000004) /* User Code Space Mask */
69#define MCF5206E_RAMBAR_UD (0x00000002) /* User Data Space Mask */
70#define MCF5206E_RAMBAR_V (0x00000001) /* Contents of RAMBAR are valid */
71
72/*** DMA Controller Module -- MCF5206e User's Manual, Chapter 7 ***/
73
74/* DMA Source Address Register */
75#define MCF5206E_SAR(mbar,chn) MCF5206E_REG32(mbar,0x200 + ((chn) * 0x40))
76
77/* DMA Destination Address Register */
78#define MCF5206E_DAR(mbar,chn) MCF5206E_REG32(mbar,0x204 + ((chn) * 0x40))
79
80/* DMA Byte Count Register */
81#define MCF5206E_BCR(mbar,chn) MCF5206E_REG16(mbar,0x20C + ((chn) * 0x40))
82
83/* DMA Control Register */
84#define MCF5206E_DCR(mbar,chn) MCF5206E_REG16(mbar,0x208 + ((chn) * 0x40))
85#define MCF5206E_DCR_INT (0x8000) /* Interrupt on completion of transfer */
86#define MCF5206E_DCR_EEXT (0x4000) /* Enable External DMA Request */
87#define MCF5206E_DCR_CS (0x2000) /* Cycle Steal */
88#define MCF5206E_DCR_AA (0x1000) /* Auto Align */
89#define MCF5206E_DCR_BWC (0x0E00) /* Bandwidth Control: */
90#define MCF5206E_DCR_BWC_DISABLE (0x0000) /* Bandwidth Control Disabled */
91#define MCF5206E_DCR_BWC_512 (0x0200) /* 512 bytes */
92#define MCF5206E_DCR_BWC_1024 (0x0400) /* 1024 bytes */
93#define MCF5206E_DCR_BWC_2048 (0x0600) /* 2048 bytes */
94#define MCF5206E_DCR_BWC_4096 (0x0800) /* 4096 bytes */
95#define MCF5206E_DCR_BWC_8192 (0x0A00) /* 8192 bytes */
96#define MCF5206E_DCR_BWC_16384 (0x0C00) /* 16384 bytes */
97#define MCF5206E_DCR_BWC_32768 (0x0E00) /* 32768 bytes */
98#define MCF5206E_DCR_SAA (0x0100) /* Single Address Access */
99#define MCF5206E_DCR_S_RW (0x0080) /* Single Address Access Read/Write Val */
100#define MCF5206E_DCR_SINC (0x0040) /* Source Increment */
101#define MCF5206E_DCR_SSIZE (0x0030) /* Source Size: */
102#define MCF5206E_DCR_SSIZE_LONG (0x0000) /* Longword (4 bytes) */
103#define MCF5206E_DCR_SSIZE_BYTE (0x0010) /* Byte */
104#define MCF5206E_DCR_SSIZE_WORD (0x0020) /* Word (2 bytes) */
105#define MCF5206E_DCR_SSIZE_LINE (0x0030) /* Line (16 bytes) */
106#define MCF5206E_DCR_DINC (0x0008) /* Destination Increment */
107#define MCF5206E_DCR_DSIZE (0x0006) /* Destination Size: */
108#define MCF5206E_DCR_DSIZE_LONG (0x0000) /* Longword (4 bytes) */
109#define MCF5206E_DCR_DSIZE_BYTE (0x0002) /* Byte */
110#define MCF5206E_DCR_DSIZE_WORD (0x0004) /* Word (2 bytes) */
111#define MCF5206E_DCR_DSIZE_LINE (0x0006) /* Line (16 bytes) */
112#define MCF5206E_DCR_START (0x0001) /* Start Transfer */
113
114/* DMA Status Register */
115#define MCF5206E_DSR(mbar,chn) MCF5206E_REG8(mbar,0x210 + ((chn) * 0x40))
116#define MCF5206E_DSR_CE (0x40) /* Configuration Error has occured */
117#define MCF5206E_DSR_BES (0x20) /* Bus Error on Source */
118#define MCF5206E_DSR_BED (0x10) /* Bus Error on Destination */
119#define MCF5206E_DSR_REQ (0x04) /* Request */
120#define MCF5206E_DSR_BSY (0x02) /* Busy */
121#define MCF5206E_DSR_DONE (0x01) /* Transaction Done */
122
123/* DMA Interrupt Vector Register */
124#define MCF5206E_DIVR(mbar,chn) MCF5206E_REG8(mbar,0x214 + ((chn) * 0x40))
125
126
127/*** System Integration Module -- MCF5206e User's Manual, Chapter 8 ***/
128
129/* MBAR - Module Base Address Register */
130#define MCF5206E_MBAR_BA (0xFFFFFC00) /* Base Address */
131#define MCF5206E_MBAR_SC (0x00000010) /* Supervisor Code Space Mask */
132#define MCF5206E_MBAR_SD (0x00000008) /* Supervisor Data Space Mask */
133#define MCF5206E_MBAR_UC (0x00000004) /* User Code Space Mask */
134#define MCF5206E_MBAR_UD (0x00000002) /* User Data Space Mask */
135#define MCF5206E_MBAR_V (0x00000001) /* Contents of MBAR are valid */
136
137/* SIM Configuration Register */
138#define MCF5206E_SIMR(mbar) MCF5206E_REG8(mbar,0x003)
139#define MCF5206E_SIMR_FRZ1 (0x80) /* Disable Soft Wdog Timer when FREEZE */
140#define MCF5206E_SIMR_FRZ0 (0x40) /* Disable Bus Timeout monitor when FREEZE*/
141#define MCF5206E_SIMR_BL (0x01) /* Bus Lock Enable */
142
143/* Interrupt numbers assignment */
144#define MCF5206E_INTR_EXT_IRQ1 (1) /* External IRQ1 */
145#define MCF5206E_INTR_EXT_IPL1 (1) /* External IPL1 */
146#define MCF5206E_INTR_EXT_IPL2 (2) /* External IPL2 */
147#define MCF5206E_INTR_EXT_IPL3 (3) /* External IPL3 */
148#define MCF5206E_INTR_EXT_IRQ4 (4) /* External IRQ4 */
149#define MCF5206E_INTR_EXT_IPL4 (4) /* External IPL4 */
150#define MCF5206E_INTR_EXT_IPL5 (5) /* External IPL5 */
151#define MCF5206E_INTR_EXT_IPL6 (6) /* External IPL6 */
152#define MCF5206E_INTR_EXT_IRQ7 (7) /* External IRQ7 */
153#define MCF5206E_INTR_EXT_IPL7 (7) /* External IPL7 */
154#define MCF5206E_INTR_SWT (8) /* Software Watchdog Timer */
155#define MCF5206E_INTR_TIMER_1 (9) /* Timer 1 interrupt */
156#define MCF5206E_INTR_TIMER_2 (10) /* Timer 2 interrupt */
157#define MCF5206E_INTR_MBUS (11) /* MBUS interrupt */
158#define MCF5206E_INTR_UART_1 (12) /* UART 1 interrupt */
159#define MCF5206E_INTR_UART_2 (13) /* UART 2 interrupt */
160#define MCF5206E_INTR_DMA_0 (14) /* DMA channel 0 interrupt */
161#define MCF5206E_INTR_DMA_1 (15) /* DMA channel 1 interrupt */
162
163#define MCF5206E_INTR_BIT(n) (1 << (n))
164
165/* Interrupt Control Registers (ICR1 - ICR15) */
166#define MCF5206E_ICR(mbar,n) MCF5206E_REG8(mbar,0x014 + (n) - 1)
167
168#define MCF5206E_ICR_AVEC (0x80) /* Autovector Enable */
169#define MCF5206E_ICR_IL (0x1c) /* Interrupt Level */
170#define MCF5206E_ICR_IL_S (2)
171#define MCF5206E_ICR_IP (0x03) /* Interrupt Priority */
172#define MCF5206E_ICR_IP_S (0)
173
174/* Interrupt Mask Register */
175#define MCF5206E_IMR(mbar) MCF5206E_REG16(mbar,0x036)
176
177/* Interrupt Pending Register */
178#define MCF5206E_IPR(mbar) MCF5206E_REG16(mbar,0x03a)
179
180/* Reset Status Register */
181#define MCF5206E_RSR(mbar) MCF5206E_REG8(mbar,0x040)
182#define MCF5206E_RSR_HRST (0x80) /* Hard Reset or System Reset */
183#define MCF5206E_RSR_SWTR (0x20) /* Software Watchdog Timer Reset */
184
185/* System Protection Control Register */
186#define MCF5206E_SYPCR(mbar) MCF5206E_REG8(mbar,0x041)
187#define MCF5206E_SYPCR_SWE (0x80) /* Software Watchdog Enable */
188#define MCF5206E_SYPCR_SWRI (0x40) /* Software Watchdog Reset/Interrupt Sel.*/
189#define MCF5206E_SYPCR_SWP (0x20) /* Software Watchdog Prescaler */
190#define MCF5206E_SYPCR_SWT (0x18) /* Software Watchdog Timing: */
191#define MCF5206E_SYPCR_SWT_S (3)
192#define MCF5206E_SYPCR_SWT_9 (0x00) /* timeout = (1<<9)/sysfreq */
193#define MCF5206E_SYPCR_SWT_11 (0x08) /* timeout = (1<<11)/sysfreq */
194#define MCF5206E_SYPCR_SWT_13 (0x10) /* timeout = (1<<13)/sysfreq */
195#define MCF5206E_SYPCR_SWT_15 (0x18) /* timeout = (1<<15)/sysfreq */
196#define MCF5206E_SYPCR_SWT_18 (0x20) /* timeout = (1<<18)/sysfreq */
197#define MCF5206E_SYPCR_SWT_20 (0x28) /* timeout = (1<<20)/sysfreq */
198#define MCF5206E_SYPCR_SWT_22 (0x30) /* timeout = (1<<22)/sysfreq */
199#define MCF5206E_SYPCR_SWT_24 (0x38) /* timeout = (1<<24)/sysfreq */
200#define MCF5206E_SYPCR_BME (0x04) /* Bus Timeout Monitor Enable */
201#define MCF5206E_SYPCR_BMT (0x03) /* Bus Monitor Timing: */
202#define MCF5206E_SYPCR_BMT_1024 (0x00) /* timeout 1024 system clocks */
203#define MCF5206E_SYPCR_BMT_512 (0x01) /* timeout 512 system clocks */
204#define MCF5206E_SYPCR_BMT_256 (0x02) /* timeout 256 system clocks */
205#define MCF5206E_SYPCR_BMT_128 (0x03) /* timeout 128 system clocks */
206
207/* Software Watchdog Interrupt Vector Register */
208#define MCF5206E_SWIVR(mbar) MCF5206E_REG8(mbar,0x042)
209
210/* Software Watchdog Service Register */
211#define MCF5206E_SWSR(mbar) MCF5206E_REG8(mbar,0x043)
212#define MCF5206E_SWSR_KEY1 (0x55)
213#define MCF5206E_SWSR_KEY2 (0xAA)
214
215/* Pin Assignment Register */
216#define MCF5206E_PAR(mbar) MCF5206E_REG16(mbar,0x0CA)
217#define MCF5206E_PAR_PAR9 (0x200)
218#define MCF5206E_PAR_PAR9_TOUT (0x000) /* Timer 0 output */
219#define MCF5206E_PAR_PAR9_DREQ1 (0x200) /* DMA channel 1 request */
220#define MCF5206E_PAR_PAR8 (0x100)
221#define MCF5206E_PAR_PAR8_TIN0 (0x000) /* Timer 1 input */
222#define MCF5206E_PAR_PAR8_DREQ0 (0x100) /* DMA channel 0 request */
223#define MCF5206E_PAR_PAR7 (0x080)
224#define MCF5206E_PAR_PAR7_RSTO (0x000) /* Reset output */
225#define MCF5206E_PAR_PAR7_UART2 (0x080) /* UART 2 RTS output */
226#define MCF5206E_PAR_PAR6 (0x040)
227#define MCF5206E_PAR_PAR6_IRQ (0x000) /* IRQ7, IRQ4, IRQ1 */
228#define MCF5206E_PAR_PAR6_IPL (0x040) /* IPL2, IPL1, IPL0 */
229#define MCF5206E_PAR_PAR5 (0x020)
230#define MCF5206E_PAR_PAR5_GPIO (0x000) /* General purpose I/O PP7-PP4 */
231#define MCF5206E_PAR_PAR5_PST (0x020) /* BDM signals PST3-PST0 */
232#define MCF5206E_PAR_PAR4 (0x010)
233#define MCF5206E_PAR_PAR4_GPIO (0x000) /* General purpose I/O PP3-PP0 */
234#define MCF5206E_PAR_PAR4_DDATA (0x010) /* BDM signals DDATA3-DDATA0 */
235#define MCF5206E_PAR_PAR3 (0x008)
236#define MCF5206E_PAR_PAR2 (0x004)
237#define MCF5206E_PAR_PAR1 (0x002)
238#define MCF5206E_PAR_PAR0 (0x001)
239#define MCF5206E_PAR_WE0_WE1_WE2_WE3 (0x000)
240#define MCF5206E_PAR_WE0_WE1_CS5_CS4 (0x001)
241#define MCF5206E_PAR_WE0_WE1_CS5_A24 (0x002)
242#define MCF5206E_PAR_WE0_WE1_A25_A24 (0x003)
243#define MCF5206E_PAR_WE0_CS6_CS5_CS4 (0x004)
244#define MCF5206E_PAR_WE0_CS6_CS5_A24 (0x005)
245#define MCF5206E_PAR_WE0_CS6_A25_A24 (0x006)
246#define MCF5206E_PAR_WE0_A26_A25_A24 (0x007)
247#define MCF5206E_PAR_CS7_CS6_CS5_CS4 (0x008)
248#define MCF5206E_PAR_CS7_CS6_CS4_A24 (0x009)
249#define MCF5206E_PAR_CS7_CS6_A25_A24 (0x00A)
250#define MCF5206E_PAR_CS7_A26_A25_A24 (0x00B)
251#define MCF5206E_PAR_A27_A26_A25_A24 (0x00C)
252
253/* Bus Master Arbitration Control */
254#define MCF5206E_MARB(mbar) MCF5206E_REG8(mbar,0x007)
255#define MCF5206E_MARB_NOARB (0x08) /* Arbiter operation disable */
256#define MCF5206E_MARB_ARBCTRL (0x04) /* Arb. order: Internal DMA, Coldfire */
257
258/*** Chip Select Module -- MCF5206e User's Manual, Chapter 9 ***/
259
260/* Chip Select Address Register */
261#define MCF5206E_CSAR(mbar,bank) MCF5206E_REG16(mbar,0x064 + ((bank) * 12))
262
263/* Chip Select Mask Register */
264#define MCF5206E_CSMR(mbar,bank) MCF5206E_REG32(mbar,0x068 + ((bank) * 12))
265#define MCF5206E_CSMR_BAM (0xffff0000) /* Base Address Mask */
266#define MCF5206E_CSMR_BAM_S (16)
267#define MCF5206E_CSMR_MASK_256M (0x0FFF0000)
268#define MCF5206E_CSMR_MASK_128M (0x07FF0000)
269#define MCF5206E_CSMR_MASK_64M (0x03FF0000)
270#define MCF5206E_CSMR_MASK_32M (0x01FF0000)
271#define MCF5206E_CSMR_MASK_16M (0x00FF0000)
272#define MCF5206E_CSMR_MASK_8M (0x007F0000)
273#define MCF5206E_CSMR_MASK_4M (0x003F0000)
274#define MCF5206E_CSMR_MASK_2M (0x001F0000)
275#define MCF5206E_CSMR_MASK_1M (0x000F0000)
276#define MCF5206E_CSMR_MASK_1024K (0x000F0000)
277#define MCF5206E_CSMR_MASK_512K (0x00070000)
278#define MCF5206E_CSMR_MASK_256K (0x00030000)
279#define MCF5206E_CSMR_MASK_128K (0x00010000)
280#define MCF5206E_CSMR_MASK_64K (0x00000000)
281#define MCF5206E_CSMR_CI (0x00000020) /* CPU Space Mask (CSMR1 only) */
282#define MCF5206E_CSMR_SC (0x00000010) /* Supervisor Code Space Mask */
283#define MCF5206E_CSMR_SD (0x00000008) /* Supervisor Data Space Mask */
284#define MCF5206E_CSMR_UC (0x00000004) /* User Code Space Mask */
285#define MCF5206E_CSMR_UD (0x00000002) /* User Data Space Mask */
286
287/* Chip Select Control Register */
288#define MCF5206E_CSCR(mbar,bank) MCF5206E_REG16(mbar,0x6E + ((bank) * 12))
289#define MCF5206E_CSCR_WS (0x3c00) /* Wait States */
290#define MCF5206E_CSCR_WS_S (10)
291#define MCF5206E_CSCR_WS0 (0x0000) /* 0 Wait States */
292#define MCF5206E_CSCR_WS1 (0x0400) /* 1 Wait States */
293#define MCF5206E_CSCR_WS2 (0x0800) /* 2 Wait States */
294#define MCF5206E_CSCR_WS3 (0x0C00) /* 3 Wait States */
295#define MCF5206E_CSCR_WS4 (0x1000) /* 4 Wait States */
296#define MCF5206E_CSCR_WS5 (0x1400) /* 5 Wait States */
297#define MCF5206E_CSCR_WS6 (0x1800) /* 6 Wait States */
298#define MCF5206E_CSCR_WS7 (0x1C00) /* 7 Wait States */
299#define MCF5206E_CSCR_WS8 (0x2000) /* 8 Wait States */
300#define MCF5206E_CSCR_WS9 (0x2400) /* 9 Wait States */
301#define MCF5206E_CSCR_WS10 (0x2800) /* 10 Wait States */
302#define MCF5206E_CSCR_WS11 (0x2C00) /* 11 Wait States */
303#define MCF5206E_CSCR_WS12 (0x3000) /* 12 Wait States */
304#define MCF5206E_CSCR_WS13 (0x3400) /* 13 Wait States */
305#define MCF5206E_CSCR_WS14 (0x3800) /* 14 Wait States */
306#define MCF5206E_CSCR_WS15 (0x3C00) /* 15 Wait States */
307#define MCF5206E_CSCR_BRST (0x0200) /* Burst Enable */
308#define MCF5206E_CSCR_AA (0x0100) /* Coldfire Core Auto Acknowledge
309 Enable */
310#define MCF5206E_CSCR_PS (0x00C0) /* Port Size */
311#define MCF5206E_CSCR_PS_S (6)
312#define MCF5206E_CSCR_PS_32 (0x0000) /* Port Size = 32 bits */
313#define MCF5206E_CSCR_PS_8 (0x0040) /* Port Size = 8 bits */
314#define MCF5206E_CSCR_PS_16 (0x0080) /* Port Size = 16 bits */
315#define MCF5206E_CSCR_EMAA (0x0020) /* External Master Automatic Acknowledge
316 Enable */
317#define MCF5206E_CSCR_ASET (0x0010) /* Address Setup Enable */
318#define MCF5206E_CSCR_WRAH (0x0008) /* Write Address Hold Enable */
319#define MCF5206E_CSCR_RDAH (0x0004) /* Read Address Hold Enable */
320#define MCF5206E_CSCR_WR (0x0002) /* Write Enable */
321#define MCF5206E_CSCR_RD (0x0001) /* Read Enable */
322
323/* Default Memory Control Register */
324#define MCF5206E_DMCR(mbar) MCF5206E_REG16(mbar, 0x0C6)
325
326/*** Parallel Port (GPIO) Module -- MCF5206e User's Manual, Chapter 10 ***/
327
328/* Port A Data Direction Register */
329#define MCF5206E_PPDDR(mbar) MCF5206E_REG8(mbar,0x1C5)
330
331/* Port A Data Register */
332#define MCF5206E_PPDAT(mbar) MCF5206E_REG8(mbar,0x1C9)
333
334#define MCF5206E_PP_DAT0 (0x01)
335#define MCF5206E_PP_DAT1 (0x02)
336#define MCF5206E_PP_DAT2 (0x04)
337#define MCF5206E_PP_DAT3 (0x08)
338#define MCF5206E_PP_DAT4 (0x10)
339#define MCF5206E_PP_DAT5 (0x20)
340#define MCF5206E_PP_DAT6 (0x40)
341#define MCF5206E_PP_DAT7 (0x80)
342
343/*** DRAM Controller -- MCF5206e User's Manual, Chapter 11 ***/
344
345/* DRAM Controller Refresh Register */
346#define MCF5206E_DCRR(mbar) MCF5206E_REG16(mbar,0x046)
347
348/* DRAM Controller Timing Register */
349#define MCF5206E_DCTR(mbar) MCF5206E_REG16(mbar,0x04A)
350#define MCF5206E_DCTR_DAEM (0x8000) /* Drive Multiplexed Address During
351 External Master DRAM Transfers */
352#define MCF5206E_DCTR_EDO (0x4000) /* Extended Data-Out Enable */
353#define MCF5206E_DCTR_RCD (0x1000) /* RAS-to-CAS Delay Time */
354#define MCF5206E_DCTR_RSH (0x0600) /* RAS Hold Time */
355#define MCF5206E_DCTR_RSH_0 (0x0000) /* See User's Manual for details */
356#define MCF5206E_DCTR_RSH_1 (0x0200)
357#define MCF5206E_DCTR_RSH_2 (0x0400)
358#define MCF5206E_DCTR_RP (0x0060) /* RAS Precharge Time */
359#define MCF5206E_DCTR_RP_15 (0x0000) /* RAS Precharges for 1.5 system clks */
360#define MCF5206E_DCTR_RP_25 (0x0020) /* RAS Precharges for 2.5 system clks */
361#define MCF5206E_DCTR_RP_35 (0x0040) /* RAS Precharges for 3.5 system clks */
362#define MCF5206E_DCTR_CAS (0x0008) /* Column Address Strobe Time */
363#define MCF5206E_DCTR_CP (0x0002) /* CAS Precharge Time */
364#define MCF5206E_DCTR_CSR (0x0001) /* CAS Setup Time for CAS before RAS
365 refresh */
366
367/* DRAM Controller Address Registers */
368#define MCF5206E_DCAR(mbar,bank) MCF5206E_REG16(mbar,0x4C + ((bank) * 12))
369
370/* DRAM Controller Mask Registers */
371#define MCF5206E_DCMR(mbar,bank) MCF5206E_REG32(mbar,0x50 + ((bank) * 12))
372#define MCF5206E_DCMR_BAM (0xffff0000) /* Base Address Mask */
373#define MCF5206E_DCMR_BAM_S (16)
374#define MCF5206E_DCMR_MASK_256M (0x0FFE0000)
375#define MCF5206E_DCMR_MASK_128M (0x07FE0000)
376#define MCF5206E_DCMR_MASK_64M (0x03FE0000)
377#define MCF5206E_DCMR_MASK_32M (0x01FE0000)
378#define MCF5206E_DCMR_MASK_16M (0x00FE0000)
379#define MCF5206E_DCMR_MASK_8M (0x007E0000)
380#define MCF5206E_DCMR_MASK_4M (0x003E0000)
381#define MCF5206E_DCMR_MASK_2M (0x001E0000)
382#define MCF5206E_DCMR_MASK_1M (0x000E0000)
383#define MCF5206E_DCMR_MASK_1024K (0x000E0000)
384#define MCF5206E_DCMR_MASK_512K (0x00060000)
385#define MCF5206E_DCMR_MASK_256K (0x00020000)
386#define MCF5206E_DCMR_MASK_128K (0x00000000)
387#define MCF5206E_DCMR_SC (0x00000010) /* Supervisor Code Space Mask */
388#define MCF5206E_DCMR_SD (0x00000008) /* Supervisor Data Space Mask */
389#define MCF5206E_DCMR_UC (0x00000004) /* User Code Space Mask */
390#define MCF5206E_DCMR_UD (0x00000002) /* User Data Space Mask */
391
392/* DRAM Controller Control Register */
393#define MCF5206E_DCCR(mbar,bank) MCF5206E_REG8(mbar, 0x57 + ((bank) * 12))
394#define MCF5206E_DCCR_PS (0xC0) /* Port Size */
395#define MCF5206E_DCCR_PS_32 (0x00) /* 32 bit Port Size */
396#define MCF5206E_DCCR_PS_8 (0x40) /* 8 bit Port Size */
397#define MCF5206E_DCCR_PS_16 (0x80) /* 16 bit Port Size */
398#define MCF5206E_DCCR_BPS (0x30) /* Bank Page Size */
399#define MCF5206E_DCCR_BPS_512 (0x00) /* 512 Byte Page Size */
400#define MCF5206E_DCCR_BPS_1K (0x10) /* 1 KByte Page Size */
401#define MCF5206E_DCCR_BPS_2K (0x20) /* 2 KByte Page Size */
402#define MCF5206E_DCCR_PM (0x0C) /* Page Mode Select */
403#define MCF5206E_DCCR_PM_NORMAL (0x00) /* Normal Mode */
404#define MCF5206E_DCCR_PM_BURSTP (0x04) /* Burst Page Mode */
405#define MCF5206E_DCCR_PM_FASTP (0x0C) /* Fast Page Mode */
406#define MCF5206E_DCCR_WR (0x02) /* Write Enable */
407#define MCF5206E_DCCR_RD (0x01) /* Read Enable */
408
409/*** UART Module -- MCF5206e User's Manual, Chapter 12 ***/
410
411#define MCF5206E_UART_CHANNELS (2)
412/* UART Mode Register */
413#define MCF5206E_UMR(mbar,n) MCF5206E_REG8(mbar,0x140 + (((n)-1) * 0x40))
414#define MCF5206E_UMR1_RXRTS (0x80) /* Receiver Request-to-Send
415 Control */
416#define MCF5206E_UMR1_RXIRQ (0x40) /* Receiver Interrupt Select */
417#define MCF5206E_UMR1_ERR (0x20) /* Error Mode */
418#define MCF5206E_UMR1_PM (0x1C) /* Parity Mode, Parity Type */
419#define MCF5206E_UMR1_PM_EVEN (0x00) /* Even Parity */
420#define MCF5206E_UMR1_PM_ODD (0x04) /* Odd Parity */
421#define MCF5206E_UMR1_PM_FORCE_LOW (0x08) /* Force parity low */
422#define MCF5206E_UMR1_PM_FORCE_HIGH (0x0C) /* Force parity high */
423#define MCF5206E_UMR1_PM_NO_PARITY (0x10) /* No Parity */
424#define MCF5206E_UMR1_PM_MULTI_DATA (0x18) /* Multidrop mode - data char */
425#define MCF5206E_UMR1_PM_MULTI_ADDR (0x1C) /* Multidrop mode - addr char */
426#define MCF5206E_UMR1_BC (0x03) /* Bits per Character */
427#define MCF5206E_UMR1_BC_5 (0x00) /* 5 bits per character */
428#define MCF5206E_UMR1_BC_6 (0x01) /* 6 bits per character */
429#define MCF5206E_UMR1_BC_7 (0x02) /* 7 bits per character */
430#define MCF5206E_UMR1_BC_8 (0x03) /* 8 bits per character */
431
432#define MCF5206E_UMR2_CM (0xC0) /* Channel Mode */
433#define MCF5206E_UMR2_CM_NORMAL (0x00) /* Normal Mode */
434#define MCF5206E_UMR2_CM_AUTO_ECHO (0x40) /* Automatic Echo Mode */
435#define MCF5206E_UMR2_CM_LOCAL_LOOP (0x80) /* Local Loopback Mode */
436#define MCF5206E_UMR2_CM_REMOTE_LOOP (0xC0) /* Remote Loopback Modde */
437#define MCF5206E_UMR2_TXRTS (0x20) /* Transmitter Ready-to-Send op */
438#define MCF5206E_UMR2_TXCTS (0x10) /* Transmitter Clear-to-Send op */
439#define MCF5206E_UMR2_SB (0x0F) /* Stop Bit Length */
440#define MCF5206E_UMR2_SB_1 (0x07) /* 1 Stop Bit for 6-8 bits char */
441#define MCF5206E_UMR2_SB_15 (0x08) /* 1.5 Stop Bits for 6-8 bits chr*/
442#define MCF5206E_UMR2_SB_2 (0x0F) /* 2 Stop Bits for 6-8 bits char */
443#define MCF5206E_UMR2_SB5_1 (0x00) /* 1 Stop Bits for 5 bit char */
444#define MCF5206E_UMR2_SB5_15 (0x07) /* 1.5 Stop Bits for 5 bit char */
445#define MCF5206E_UMR2_SB5_2 (0x0F) /* 2 Stop Bits for 5 bit char */
446
447/* UART Status Register (read only) */
448#define MCF5206E_USR(mbar,n) MCF5206E_REG8(mbar,0x144 + (((n)-1) * 0x40))
449#define MCF5206E_USR_RB (0x80) /* Received Break */
450#define MCF5206E_USR_FE (0x40) /* Framing Error */
451#define MCF5206E_USR_PE (0x20) /* Parity Error */
452#define MCF5206E_USR_OE (0x10) /* Overrun Error */
453#define MCF5206E_USR_TXEMP (0x08) /* Transmitter Empty */
454#define MCF5206E_USR_TXRDY (0x04) /* Transmitter Ready */
455#define MCF5206E_USR_FFULL (0x02) /* FIFO Full */
456#define MCF5206E_USR_RXRDY (0x01) /* Receiver Ready */
457
458/* UART Clock Select Register (write only) */
459#define MCF5206E_UCSR(mbar,n) MCF5206E_REG8(mbar,0x144 + (((n)-1) * 0x40))
460#define MCF5206E_UCSR_RCS (0xF0) /* Receiver Clock Select */
461#define MCF5206E_UCSR_RCS_TIMER (0xD0) /* Timer */
462#define MCF5206E_UCSR_RCS_EXT16 (0xE0) /* External clk x16 */
463#define MCF5206E_UCSR_RCS_EXT (0xF0) /* External clk x1 */
464#define MCF5206E_UCSR_TCS (0x0F) /* Transmitter Clock Select */
465#define MCF5206E_UCSR_TCS_TIMER (0x0D) /* Timer */
466#define MCF5206E_UCSR_TCS_EXT16 (0x0E) /* External clk x16 */
467#define MCF5206E_UCSR_TCS_EXT (0x0F) /* External clk x1 */
468
469/* UART Command Register (write only) */
470#define MCF5206E_UCR(mbar,n) MCF5206E_REG8(mbar,0x148 + (((n)-1) * 0x40))
471#define MCF5206E_UCR_MISC (0x70) /* Miscellaneous Commands: */
472#define MCF5206E_UCR_MISC_NOP (0x00) /* No Command */
473#define MCF5206E_UCR_MISC_RESET_MR (0x10) /* Reset Mode Register Ptr */
474#define MCF5206E_UCR_MISC_RESET_RX (0x20) /* Reset Receiver */
475#define MCF5206E_UCR_MISC_RESET_TX (0x30) /* Reset Transmitter */
476#define MCF5206E_UCR_MISC_RESET_ERR (0x40) /* Reset Error Status */
477#define MCF5206E_UCR_MISC_RESET_BRK (0x50) /* Reset Break-Change Interrupt */
478#define MCF5206E_UCR_MISC_START_BRK (0x60) /* Start Break */
479#define MCF5206E_UCR_MISC_STOP_BRK (0x70) /* Stop Break */
480#define MCF5206E_UCR_TC (0x0C) /* Transmitter Commands: */
481#define MCF5206E_UCR_TC_NOP (0x00) /* No Action Taken */
482#define MCF5206E_UCR_TC_ENABLE (0x04) /* Transmitter Enable */
483#define MCF5206E_UCR_TC_DISABLE (0x08) /* Transmitter Disable */
484#define MCF5206E_UCR_RC (0x03) /* Receiver Commands: */
485#define MCF5206E_UCR_RC_NOP (0x00) /* No Action Taken */
486#define MCF5206E_UCR_RC_ENABLE (0x01) /* Receiver Enable */
487#define MCF5206E_UCR_RC_DISABLE (0x02) /* Receiver Disable */
488
489/* UART Receive Buffer (read only) */
490#define MCF5206E_URB(mbar,n) MCF5206E_REG8(mbar,0x14C + (((n)-1) * 0x40))
491
492/* UART Transmit Buffer (write only) */
493#define MCF5206E_UTB(mbar,n) MCF5206E_REG8(mbar,0x14C + (((n)-1) * 0x40))
494
495/* UART Input Port Change Register (read only) */
496#define MCF5206E_UIPCR(mbar,n) MCF5206E_REG8(mbar,0x150 + (((n)-1) * 0x40))
497#define MCF5206E_UIPCR_COS (0x10) /* Change of State at CTS input */
498#define MCF5206E_UIPCR_CTS (0x01) /* Current State of CTS */
499
500/* UART Auxiliary Control Register (write only) */
501#define MCF5206E_UACR(mbar,n) MCF5206E_REG8(mbar,0x150 + (((n)-1) * 0x40))
502#define MCF5206E_UACR_IEC (0x01) /* Input Enable Control - generate interrupt
503 on CTS change */
504
505/* UART Interrupt Status Register (read only) */
506#define MCF5206E_UISR(mbar,n) MCF5206E_REG8(mbar,0x154 + (((n)-1) * 0x40))
507#define MCF5206E_UISR_COS (0x80) /* Change of State has occured at CTS */
508#define MCF5206E_UISR_DB (0x04) /* Delta Break */
509#define MCF5206E_UISR_RXRDY (0x02) /* Receiver Ready or FIFO Full */
510#define MCF5206E_UISR_TXRDY (0x01) /* Transmitter Ready */
511
512/* UART Interrupt Mask Register (write only) */
513#define MCF5206E_UIMR(mbar,n) MCF5206E_REG8(mbar,0x154 + (((n)-1) * 0x40))
514#define MCF5206E_UIMR_COS (0x80) /* Change of State interrupt enable */
515#define MCF5206E_UIMR_DB (0x04) /* Delta Break interrupt enable */
516#define MCF5206E_UIMR_FFULL (0x02) /* FIFO Full interrupt enable */
517#define MCF5206E_UIMR_TXRDY (0x01) /* Transmitter Ready Interrupt enable */
518
519/* UART Baud Rate Generator Prescale MSB Register */
520#define MCF5206E_UBG1(mbar,n) MCF5206E_REG8(mbar,0x158 + (((n)-1) * 0x40))
521
522/* UART Baud Rate Generator Prescale LSB Register */
523#define MCF5206E_UBG2(mbar,n) MCF5206E_REG8(mbar,0x15C + (((n)-1) * 0x40))
524
525/* UART Interrupt Vector Register */
526#define MCF5206E_UIVR(mbar,n) MCF5206E_REG8(mbar,0x170 + (((n)-1) * 0x40))
527
528/* UART Input Port Register (read only) */
529#define MCF5206E_UIP(mbar,n) MCF5206E_REG8(mbar,0x174 + (((n)-1) * 0x40))
530#define MCF5206E_UIP_CTS (0x01) /* Current state of CTS input */
531
532/* UART Output Port Bit Set Command (address-triggered command, write) */
533#define MCF5206E_UOP1(mbar,n) MCF5206E_REG8(mbar,0x178 + (((n)-1) * 0x40))
534
535/* UART Output Port Bit Reset Command (address-triggered command, write */
536#define MCF5206E_UOP0(mbar,n) MCF5206E_REG8(mbar,0x17C + (((n)-1) * 0x40))
537
538/*** M-BUS (I2C) Module -- MCF5206e User's Manual, Chapter 13 ***/
539
540/* M-Bus Address Register */
541#define MCF5206E_MADR(mbar) MCF5206E_REG8(mbar, 0x1E0)
542
543/* M-Bus Frequency Divider Register */
544#define MCF5206E_MFDR(mbar) MCF5206E_REG8(mbar, 0x1E4)
545
546/* M-Bus Control Register */
547#define MCF5206E_MBCR(mbar) MCF5206E_REG8(mbar, 0x1E8)
548#define MCF5206E_MBCR_MEN (0x80) /* M-Bus Enable */
549#define MCF5206E_MBCR_MIEN (0x40) /* M-Bus Interrupt Enable */
550#define MCF5206E_MBCR_MSTA (0x20) /* Master Mode Selection */
551#define MCF5206E_MBCR_MTX (0x10) /* Transmit Mode Selection */
552#define MCF5206E_MBCR_TXAK (0x08) /* Transmit Acknowledge Enable */
553#define MCF5206E_MBCR_RSTA (0x04) /* Repeat Start */
554
555/* M-Bus Status Register */
556#define MCF5206E_MBSR(mbar) MCF5206E_REG8(mbar, 0x1EC)
557#define MCF5206E_MBSR_MCF (0x80) /* Data Transferring Bit */
558#define MCF5206E_MBSR_MAAS (0x40) /* Addressed as a Slave Bit */
559#define MCF5206E_MBSR_MBB (0x20) /* Bus Busy Bit */
560#define MCF5206E_MBSR_MAL (0x10) /* Arbitration Lost */
561#define MCF5206E_MBSR_SRW (0x04) /* Slave Read/Write */
562#define MCF5206E_MBSR_MIF (0x02) /* MBus Interrupt pending */
563#define MCF5206E_MBSR_RXAK (0x01) /* Received Acknowledge */
564
565/* M-Bus Data I/O Register */
566#define MCF5206E_MBDR(mbar) MCF5206E_REG8(mbar, 0x1F0)
567
568/*** Timer Module -- MCF5206e User's Manual, Chapter 14 ***/
569
570/* Timer Mode Register */
571#define MCF5206E_TMR(mbar,n) MCF5206E_REG16(mbar, 0x100 + (((n)-1)*0x20))
572#define MCF5206E_TMR_PS (0xFF00) /* Prescaler Value */
573#define MCF5206E_TMR_PS_S (8)
574#define MCF5206E_TMR_CE (0x00C0) /* Capture Edge and Enable
575 Interrupt */
576#define MCF5206E_TMR_CE_ANY (0x00C0) /* Capture on any edge */
577#define MCF5206E_TMR_CE_FALL (0x0080) /* Capture on falling edge only */
578#define MCF5206E_TMR_CE_RISE (0x0040) /* Capture on rising edge only */
579#define MCF5206E_TMR_CE_NONE (0x0000) /* Disable Interrupt on capture
580 event */
581#define MCF5206E_TMR_OM (0x0020) /* Output Mode - Toggle output */
582#define MCF5206E_TMR_ORI (0x0010) /* Output Reference Interrupt
583 Enable */
584#define MCF5206E_TMR_FRR (0x0008) /* Free Run/Restart */
585#define MCF5206E_TMR_ICLK (0x0006) /* Input Clock Source */
586#define MCF5206E_TMR_ICLK_TIN (0x0006) /* TIN pin (falling edge) */
587#define MCF5206E_TMR_ICLK_DIV16 (0x0004) /* Master system clock divided
588 by 16 */
589#define MCF5206E_TMR_ICLK_MSCLK (0x0002) /* Master System Clock */
590#define MCF5206E_TMR_ICLK_STOP (0x0000) /* Stops counter */
591#define MCF5206E_TMR_RST (0x0001) /* Reset/Enable Timer */
592
593/* Timer Reference Register */
594#define MCF5206E_TRR(mbar,n) MCF5206E_REG16(mbar, 0x104 + (((n)-1)*0x20))
595
596/* Timer Capture Register */
597#define MCF5206E_TCR(mbar,n) MCF5206E_REG16(mbar, 0x108 + (((n)-1)*0x20))
598
599/* Timer Counter Register */
600#define MCF5206E_TCN(mbar,n) MCF5206E_REG16(mbar, 0x10C + (((n)-1)*0x20))
601
602/* Timer Event Register */
603#define MCF5206E_TER(mbar,n) MCF5206E_REG8(mbar, 0x111 + (((n)-1)*0x20))
604#define MCF5206E_TER_REF (0x02) /* Output Reference Event */
605#define MCF5206E_TER_CAP (0x01) /* Capture Event */
606
607
608
609#endif
