RTEMS 6.1-rc2
m48t08.h
2
3/*
4 * This file contains the definitions for the following real-time clocks:
5 *
6 * + Mostek M48T08
7 * + Mostek M48T18
8 * + Dallas Semiconductor DS1643
9 *
10 * COPYRIGHT (c) 1989-1999.
11 * On-Line Applications Research Corporation (OAR).
12 *
13 * Redistribution and use in source and binary forms, with or without
14 * modification, are permitted provided that the following conditions
15 * are met:
16 * 1. Redistributions of source code must retain the above copyright
17 * notice, this list of conditions and the following disclaimer.
18 * 2. Redistributions in binary form must reproduce the above copyright
19 * notice, this list of conditions and the following disclaimer in the
20 * documentation and/or other materials provided with the distribution.
21 *
22 * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
23 * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
24 * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
25 * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
26 * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
27 * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
28 * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
29 * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
30 * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
31 * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
32 * POSSIBILITY OF SUCH DAMAGE.
33 */
34
35#ifndef __LIBCHIP_M48T08_h
36#define __LIBCHIP_M48T08_h
37
38/*
39 * Register indices
40 */
41
42#define M48T08_CONTROL 0
43#define M48T08_SECOND 1
44#define M48T08_MINUTE 2
45#define M48T08_HOUR 3
46#define M48T08_DAY_OF_WEEK 4
47#define M48T08_DATE 5
48#define M48T08_MONTH 6
49#define M48T08_YEAR 7
50
51/*
52 * Driver function table
53 */
54
55extern rtc_fns m48t08_fns;
56
57/*
58 * Default register access routines
59 */
60
61uint32_t m48t08_get_register( /* registers are at 1 byte boundaries */
62 uintptr_t ulCtrlPort, /* and accessed as bytes */
63 uint8_t ucRegNum
64);
65
66void m48t08_set_register(
67 uintptr_t ulCtrlPort,
68 uint8_t ucRegNum,
69 uint32_t ucData
70);
71
72uint32_t m48t08_get_register_2( /* registers are at 2 byte boundaries */
73 uintptr_t ulCtrlPort, /* and accessed as bytes */
74 uint8_t ucRegNum
75);
76
77void m48t08_set_register_2(
78 uintptr_t ulCtrlPort,
79 uint8_t ucRegNum,
80 uint32_t ucData
81);
82
83uint32_t m48t08_get_register_4( /* registers are at 4 byte boundaries */
84 uintptr_t ulCtrlPort, /* and accessed as bytes */
85 uint8_t ucRegNum
86);
87
88void m48t08_set_register_4(
89 uintptr_t ulCtrlPort,
90 uint8_t ucRegNum,
91 uint32_t ucData
92);
93
94uint32_t m48t08_get_register_8( /* registers are at 8 byte boundaries */
95 uintptr_t ulCtrlPort, /* and accessed as bytes */
96 uint8_t ucRegNum
97);
98
99void m48t08_set_register_8(
100 uintptr_t ulCtrlPort,
101 uint8_t ucRegNum,
102 uint32_t ucData
103);
104
105#endif
106/* end of include file */
Definition: rtc.h:46
