RTEMS 6.1-rc2
m340uart.h File Reference
UART console driver definitions. More...
#include <sys/types.h>
struct  uart_termios_config
struct  uart_channel_config
struct  t_baud_speed
struct  t_baud_speed_table
#define UART_CHANNEL_A   0
#define UART_CHANNEL_B   1
#define UART_NUMBER_OF_CHANNELS   2
#define UART_CONSOLE_NAME   "/dev/console"
#define UART_RAW_IO_NAME   "/dev/tty1"
#define UART_FIFO_FULL   0
#define UART_CRR   1
#define UART_INTERRUPTS   0
#define UART_POLLING   1
#define UART_TERMIOS_CONSOLE   0
#define UART_TERMIOS_RAW   1
#define UART_TERMIOS_MIN_DEFAULT   1
#define UART_TERMIOS_TIME_DEFAULT   0
#define m340_Rx_RDY   1
#define m340_FFULL   (1<<1)
#define m340_Tx_RDY   (1<<2)
#define m340_TxEMP   (1<<3)
#define m340_OE   (1<<4)
#define m340_PE   (1<<5)
#define m340_FE   (1<<6)
#define m340_RB   (1<<7)
#define m340_TxRDYA   1
#define m340_RxRDYA   (1<<1)
#define m340_TxRxRDYA   0x3
#define m340_TxRDYB   (1<<4)
#define m340_RxRDYB   (1<<5)
#define m340_TxRxRDYB   0x30
#define m340_Reset_Error_Status   0x40
#define m340_Reset_Receiver   0x20
#define m340_Reset_Transmitter   0x30
#define m340_Transmitter_Enable   (1<<2)
#define m340_Receiver_Enable   1
#define m340_Transmitter_Disable   (2<<2)
#define m340_Receiver_Disable   2
#define m340_BRG_Set1   0
#define m340_BRG_Set2   (1<<7)
#define m340_OPCR_Gal   0x0
#define m340_OPCR_Aux   0xFF
#define m340_COS   (1<<7)
#define m340_DBB   (1<<6)
#define m340_XTAL_RDY   (1<<3)
#define m340_DBA   (1<<2)
#define m340_RxRTS   (1<<7)
#define m340_R_F   (1<<6) /* character or block mode */
#define m340_ERR   (1<<5)
#define m340_RxRTX   (1<<7)
#define m340_Even_Parity   0
#define m340_Odd_Parity   (1<<2)
#define m340_Low_Parity   (2<<2)
#define m340_High_Parity   (3<<2)
#define m340_No_Parity   (4<<2)
#define m340_Data_Character   (6<<2)
#define m340_Address_Character   (7<<2)
#define m340_5bpc   0x0
#define m340_6bpc   0x1
#define m340_7bpc   0x2
#define m340_8bpc   0x3
#define m340_normal   (0<<6)
#define m340_automatic_echo   (1<<6)
#define m340_local_loopback   (2<<6)
#define m340_remote_loopback   (3<<6)
#define m340_TxRTS   (1<<5)
#define m340_TxCTS   (1<<4)
#define SCLK   1 /* put your own SCLK value here */
void Init_UART_Table (void)
t_baud_speed_table Find_Right_m340_UART_Config (float ChannelA_ReceiverBaudRate, float ChannelA_TransmitterBaudRate, uint8_t enableA, float ChannelB_ReceiverBaudRate, float ChannelB_TransmitterBaudRate, uint8_t enableB)
rtems_isr InterruptHandler (rtems_vector_number v)
int dbugRead (int minor)
ssize_t dbugWrite (int minor, const char *buf, size_t len)
uart_channel_config m340_uart_config [UART_NUMBER_OF_CHANNELS]
float m340_Baud_Rates_Table [16][2]
