RTEMS 6.1-rc2
Data Structures | Macros | Variables
Register base addresses. More...
#include <stdint.h>
#include <bsp/utility.h>
#include <bsp/lpc-timer.h>
#include <bsp/lpc-dma.h>
#include <bsp/lpc-i2s.h>
#include <bsp/lpc-emc.h>
struct  lpc32xx_nand_slc
struct  lpc32xx_ssp
struct  lpc32xx_spi
struct  lpc32xx_sd_card
struct  lpc32xx_usb
struct  lpc32xx_lcd
struct  lpc32xx_etb
struct  lpc32xx_syscon
struct  lpc32xx_uart_ctrl
struct  lpc32xx_uart
struct  lpc32xx_ms_timer
struct  lpc32xx_hs_timer
struct  lpc32xx_wdt
struct  lpc32xx_debug
struct  lpc32xx_adc
struct  lpc32xx_keyscan
struct  lpc32xx_pwm
struct  lpc32xx_mcpwm
struct  lpc32xx_eth
struct  lpc32xx_irq
struct  lpc32xx_gpio
struct  lpc32xx_i2c
struct  lpc32xx_rtc
struct  lpc32xx_emc_ahb
struct  lpc32xx_nand_mlc
struct  lpc32xx_registers
#define LPC32XX_FILL(a, b, s)   uint8_t reserved_ ## b [b - a - sizeof(s)]
#define LPC32XX_RESERVE(a, b)   uint8_t reserved_ ## b [b - a]
Register Base Addresses
#define LPC32XX_BASE_ADC   0x40048000
#define LPC32XX_BASE_SYSCON   0x40004000
#define LPC32XX_BASE_DEBUG_CTRL   0x40040000
#define LPC32XX_BASE_DMA   0x31000000
#define LPC32XX_BASE_EMC   0x31080000
#define LPC32XX_BASE_EMC_CS_0   0xe0000000
#define LPC32XX_BASE_EMC_CS_1   0xe1000000
#define LPC32XX_BASE_EMC_CS_2   0xe2000000
#define LPC32XX_BASE_EMC_CS_3   0xe3000000
#define LPC32XX_BASE_EMC_DYCS_0   0x80000000
#define LPC32XX_BASE_EMC_DYCS_1   0xa0000000
#define LPC32XX_BASE_ETB_CFG   0x310c0000
#define LPC32XX_BASE_ETB_DATA   0x310e0000
#define LPC32XX_BASE_ETHERNET   0x31060000
#define LPC32XX_BASE_GPIO   0x40028000
#define LPC32XX_BASE_I2C_1   0x400a0000
#define LPC32XX_BASE_I2C_2   0x400a8000
#define LPC32XX_BASE_I2S_0   0x20094000
#define LPC32XX_BASE_I2S_1   0x2009c000
#define LPC32XX_BASE_IRAM   0x08000000
#define LPC32XX_BASE_IROM   0x0c000000
#define LPC32XX_BASE_KEYSCAN   0x40050000
#define LPC32XX_BASE_LCD   0x31040000
#define LPC32XX_BASE_MCPWM   0x400e8000
#define LPC32XX_BASE_MIC   0x40008000
#define LPC32XX_BASE_NAND_MLC   0x200a8000
#define LPC32XX_BASE_NAND_SLC   0x20020000
#define LPC32XX_BASE_PWM_1   0x4005c000
#define LPC32XX_BASE_PWM_2   0x4005c004
#define LPC32XX_BASE_PWM_3   0x4002c000
#define LPC32XX_BASE_PWM_4   0x40030000
#define LPC32XX_BASE_RTC   0x40024000
#define LPC32XX_BASE_RTC_RAM   0x40024080
#define LPC32XX_BASE_SDCARD   0x20098000
#define LPC32XX_BASE_SIC_1   0x4000c000
#define LPC32XX_BASE_SIC_2   0x40010000
#define LPC32XX_BASE_SPI_1   0x20088000
#define LPC32XX_BASE_SPI_2   0x20090000
#define LPC32XX_BASE_SSP_0   0x20084000
#define LPC32XX_BASE_SSP_1   0x2008c000
#define LPC32XX_BASE_TIMER_0   0x40044000
#define LPC32XX_BASE_TIMER_1   0x4004c000
#define LPC32XX_BASE_TIMER_2   0x40058000
#define LPC32XX_BASE_TIMER_3   0x40060000
#define LPC32XX_BASE_TIMER_5   0x4002c000
#define LPC32XX_BASE_TIMER_6   0x40030000
#define LPC32XX_BASE_TIMER_HS   0x40038000
#define LPC32XX_BASE_TIMER_MS   0x40034000
#define LPC32XX_BASE_UART_1   0x40014000
#define LPC32XX_BASE_UART_2   0x40018000
#define LPC32XX_BASE_UART_3   0x40080000
#define LPC32XX_BASE_UART_4   0x40088000
#define LPC32XX_BASE_UART_5   0x40090000
#define LPC32XX_BASE_UART_6   0x40098000
#define LPC32XX_BASE_UART_7   0x4001c000
#define LPC32XX_BASE_USB   0x31020000
#define LPC32XX_BASE_USB_OTG_I2C   0x31020300
#define LPC32XX_BASE_WDT   0x4003c000
Miscanellanous Registers
#define LPC32XX_U3CLK   (*(volatile uint32_t *) 0x400040d0)
#define LPC32XX_U4CLK   (*(volatile uint32_t *) 0x400040d4)
#define LPC32XX_U5CLK   (*(volatile uint32_t *) 0x400040d8)
#define LPC32XX_U6CLK   (*(volatile uint32_t *) 0x400040dc)
#define LPC32XX_IRDACLK   (*(volatile uint32_t *) 0x400040e0)
#define LPC32XX_UART_CTRL   (*(volatile uint32_t *) 0x40054000)
#define LPC32XX_UART_CLKMODE   (*(volatile uint32_t *) 0x40054004)
#define LPC32XX_UART_LOOP   (*(volatile uint32_t *) 0x40054008)
#define LPC32XX_SW_INT   (*(volatile uint32_t *) 0x400040a8)
#define LPC32XX_MAC_CLK_CTRL   (*(volatile uint32_t *) 0x40004090)
#define LPC32XX_USB_DIV   (*(volatile uint32_t *) 0x4000401c)
#define LPC32XX_OTG_CLK_CTRL   (*(volatile uint32_t *) 0x31020ff4)
#define LPC32XX_OTG_CLK_STAT   (*(volatile uint32_t *) 0x31020ff8)
#define LPC32XX_OTG_STAT_CTRL   (*(volatile uint32_t *) 0x31020110)
#define LPC32XX_I2C_RX   (*(volatile uint32_t *) 0x31020300)
#define LPC32XX_I2C_TX   (*(volatile uint32_t *) 0x31020300)
#define LPC32XX_I2C_STS   (*(volatile uint32_t *) 0x31020304)
#define LPC32XX_I2C_CTL   (*(volatile uint32_t *) 0x31020308)
#define LPC32XX_I2C_CLKHI   (*(volatile uint32_t *) 0x3102030c)
#define LPC32XX_I2C_CLKLO   (*(volatile uint32_t *) 0x31020310)
#define LPC32XX_PWR_CTRL   (*(volatile uint32_t *) 0x40004044)
#define LPC32XX_OSC_CTRL   (*(volatile uint32_t *) 0x4000404c)
#define LPC32XX_SYSCLK_CTRL   (*(volatile uint32_t *) 0x40004050)
#define LPC32XX_PLL397_CTRL   (*(volatile uint32_t *) 0x40004048)
#define LPC32XX_HCLKPLL_CTRL   (*(volatile uint32_t *) 0x40004058)
#define LPC32XX_HCLKDIV_CTRL   (*(volatile uint32_t *) 0x40004040)
#define LPC32XX_TEST_CLK   (*(volatile uint32_t *) 0x400040a4)
#define LPC32XX_AUTOCLK_CTRL   (*(volatile uint32_t *) 0x400040ec)
#define LPC32XX_START_ER_PIN   (*(volatile uint32_t *) 0x40004030)
#define LPC32XX_START_ER_INT   (*(volatile uint32_t *) 0x40004020)
#define LPC32XX_P0_INTR_ER   (*(volatile uint32_t *) 0x40004018)
#define LPC32XX_START_SR_PIN   (*(volatile uint32_t *) 0x40004038)
#define LPC32XX_START_SR_INT   (*(volatile uint32_t *) 0x40004028)
#define LPC32XX_START_RSR_PIN   (*(volatile uint32_t *) 0x40004034)
#define LPC32XX_START_RSR_INT   (*(volatile uint32_t *) 0x40004024)
#define LPC32XX_START_APR_PIN   (*(volatile uint32_t *) 0x4000403c)
#define LPC32XX_START_APR_INT   (*(volatile uint32_t *) 0x4000402c)
#define LPC32XX_USB_CTRL   (*(volatile uint32_t *) 0x40004064)
#define LPC32XX_USBDIV_CTRL   (*(volatile uint32_t *) 0x4000401c)
#define LPC32XX_MS_CTRL   (*(volatile uint32_t *) 0x40004080)
#define LPC32XX_DMACLK_CTRL   (*(volatile uint32_t *) 0x400040e8)
#define LPC32XX_FLASHCLK_CTRL   (*(volatile uint32_t *) 0x400040c8)
#define LPC32XX_MACCLK_CTRL   (*(volatile uint32_t *) 0x40004090)
#define LPC32XX_LCDCLK_CTRL   (*(volatile uint32_t *) 0x40004054)
#define LPC32XX_I2S_CTRL   (*(volatile uint32_t *) 0x4000407c)
#define LPC32XX_SSP_CTRL   (*(volatile uint32_t *) 0x40004078)
#define LPC32XX_SPI_CTRL   (*(volatile uint32_t *) 0x400040c4)
#define LPC32XX_I2CCLK_CTRL   (*(volatile uint32_t *) 0x400040ac)
#define LPC32XX_TIMCLK_CTRL1   (*(volatile uint32_t *) 0x400040c0)
#define LPC32XX_TIMCLK_CTRL   (*(volatile uint32_t *) 0x400040bc)
#define LPC32XX_ADCLK_CTRL   (*(volatile uint32_t *) 0x400040b4)
#define LPC32XX_ADCLK_CTRL1   (*(volatile uint32_t *) 0x40004060)
#define LPC32XX_KEYCLK_CTRL   (*(volatile uint32_t *) 0x400040b0)
#define LPC32XX_PWMCLK_CTRL   (*(volatile uint32_t *) 0x400040b8)
#define LPC32XX_UARTCLK_CTRL   (*(volatile uint32_t *) 0x400040e4)
#define LPC32XX_POS0_IRAM_CTRL   (*(volatile uint32_t *) 0x40004110)
#define LPC32XX_POS1_IRAM_CTRL   (*(volatile uint32_t *) 0x40004114)
#define LPC32XX_SDRAMCLK_CTRL   (*(volatile uint32_t *) 0x40004068)
Power Control Register (PWR_CTRL)
#define PWR_STOP   BSP_BIT32(0)
#define PWR_HIGHCORE_ALWAYS   BSP_BIT32(1)
#define PWR_NORMAL_RUN_MODE   BSP_BIT32(2)
#define PWR_SYSCLKEN_ALWAYS   BSP_BIT32(3)
#define PWR_SYSCLKEN_HIGH   BSP_BIT32(4)
#define PWR_HIGHCORE_HIGH   BSP_BIT32(5)
#define PWR_SDRAM_AUTO_REFRESH   BSP_BIT32(7)
#define PWR_UPDATE_EMCSREFREQ   BSP_BIT32(8)
#define PWR_EMCSREFREQ   BSP_BIT32(9)
#define PWR_HCLK_USES_PERIPH_CLK   BSP_BIT32(10)
HCLK PLL Control Register (HCLKPLL_CTRL)
#define HCLK_PLL_LOCK   BSP_BIT32(0)
#define HCLK_PLL_M(val)   BSP_FLD32(val, 1, 8)
#define HCLK_PLL_M_GET(reg)   BSP_FLD32GET(reg, 1, 8)
#define HCLK_PLL_N(val)   BSP_FLD32(val, 9, 10)
#define HCLK_PLL_N_GET(reg)   BSP_FLD32GET(reg, 9, 10)
#define HCLK_PLL_P(val)   BSP_FLD32(val, 11, 12)
#define HCLK_PLL_P_GET(reg)   BSP_FLD32GET(reg, 11, 12)
#define HCLK_PLL_FBD_FCLKOUT   BSP_BIT32(13)
#define HCLK_PLL_DIRECT   BSP_BIT32(14)
#define HCLK_PLL_BYPASS   BSP_BIT32(15)
#define HCLK_PLL_POWER   BSP_BIT32(16)
HCLK Divider Control Register (HCLKDIV_CTRL)
#define HCLK_DIV_HCLK(val)   BSP_FLD32(val, 0, 1)
#define HCLK_DIV_HCLK_GET(reg)   BSP_FLD32GET(reg, 0, 1)
#define HCLK_DIV_PERIPH_CLK(val)   BSP_FLD32(val, 2, 6)
#define HCLK_DIV_PERIPH_CLK_GET(reg)   BSP_FLD32GET(reg, 2, 6)
#define HCLK_DIV_DDRAM_CLK(val)   BSP_FLD32(val, 7, 8)
#define HCLK_DIV_DDRAM_CLK_GET(reg)   BSP_FLD32GET(reg, 7, 8)
Timer Clock Control Register (TIMCLK_CTRL)
#define TIMCLK_CTRL_WDT   BSP_BIT32(0)
#define TIMCLK_CTRL_HST   BSP_BIT32(1)
Watchdog Timer Interrupt Status Register (WDTIM_INT)
#define WDTTIM_INT_MATCH_INT   BSP_BIT32(0)
Watchdog Timer Control Register (WDTIM_CTRL)
#define WDTTIM_CTRL_COUNT_ENAB   BSP_BIT32(0)
#define WDTTIM_CTRL_RESET_COUNT   BSP_BIT32(1)
#define WDTTIM_CTRL_PAUSE_EN   BSP_BIT32(2)
Watchdog Timer Match Control Register (WDTIM_MCTRL)
#define WDTTIM_MCTRL_MR0_INT   BSP_BIT32(0)
#define WDTTIM_MCTRL_RESET_COUNT0   BSP_BIT32(1)
#define WDTTIM_MCTRL_STOP_COUNT0   BSP_BIT32(2)
#define WDTTIM_MCTRL_M_RES1   BSP_BIT32(3)
#define WDTTIM_MCTRL_M_RES2   BSP_BIT32(4)
#define WDTTIM_MCTRL_RESFRC1   BSP_BIT32(5)
#define WDTTIM_MCTRL_RESFRC2   BSP_BIT32(6)
Watchdog Timer External Match Control Register (WDTIM_EMR)
#define WDTTIM_EMR_EXT_MATCH0   BSP_BIT32(0)
#define WDTTIM_EMR_MATCH_CTRL(val)   BSP_FLD32(val, 4, 5)
#define WDTTIM_EMR_MATCH_CTRL_SET(reg, val)   BSP_FLD32SET(reg, val, 4, 5)
Watchdog Timer Reset Source Register (WDTIM_RES)
#define WDTTIM_RES_WDT   BSP_BIT32(0)
volatile lpc32xx_registers lpc32xx
