RTEMS 6.1-rc2
lpc24xx.h
2
11/*
12 * Copyright (C) 2008, 2011 embedded brains GmbH & Co. KG
13 *
16 * are met:
22 *
34 */
35
36#ifndef LIBBSP_ARM_LPC24XX_LPC24XX_H
37#define LIBBSP_ARM_LPC24XX_LPC24XX_H
38
39#include <rtems/score/cpu.h>
40#include <bsp/utility.h>
41#include <bsp/lpc-i2s.h>
42
43#ifdef ARM_MULTILIB_ARCH_V7M
44 #include <bsp/lpc17xx.h>
45#endif
46
57#ifdef ARM_MULTILIB_ARCH_V4
58
59/* Vectored Interrupt Controller (VIC) */
60#define VIC_BASE_ADDR 0xFFFFF000
61#define VICIRQStatus (*(volatile uint32_t *) (VIC_BASE_ADDR + 0x000))
62#define VICFIQStatus (*(volatile uint32_t *) (VIC_BASE_ADDR + 0x004))
63#define VICRawIntr (*(volatile uint32_t *) (VIC_BASE_ADDR + 0x008))
64#define VICIntSelect (*(volatile uint32_t *) (VIC_BASE_ADDR + 0x00C))
65#define VICIntEnable (*(volatile uint32_t *) (VIC_BASE_ADDR + 0x010))
66#define VICIntEnClear (*(volatile uint32_t *) (VIC_BASE_ADDR + 0x014))
67#define VICSoftInt (*(volatile uint32_t *) (VIC_BASE_ADDR + 0x018))
68#define VICSoftIntClear (*(volatile uint32_t *) (VIC_BASE_ADDR + 0x01C))
69#define VICProtection (*(volatile uint32_t *) (VIC_BASE_ADDR + 0x020))
70#define VICSWPrioMask (*(volatile uint32_t *) (VIC_BASE_ADDR + 0x024))
71
72#define VICVectAddrBase ((volatile uint32_t *) (VIC_BASE_ADDR + 0x100))
73#define VICVectAddr0 (*(volatile uint32_t *) (VIC_BASE_ADDR + 0x100))
74#define VICVectAddr1 (*(volatile uint32_t *) (VIC_BASE_ADDR + 0x104))
75#define VICVectAddr2 (*(volatile uint32_t *) (VIC_BASE_ADDR + 0x108))
76#define VICVectAddr3 (*(volatile uint32_t *) (VIC_BASE_ADDR + 0x10C))
77#define VICVectAddr4 (*(volatile uint32_t *) (VIC_BASE_ADDR + 0x110))
78#define VICVectAddr5 (*(volatile uint32_t *) (VIC_BASE_ADDR + 0x114))
79#define VICVectAddr6 (*(volatile uint32_t *) (VIC_BASE_ADDR + 0x118))
80#define VICVectAddr7 (*(volatile uint32_t *) (VIC_BASE_ADDR + 0x11C))
81#define VICVectAddr8 (*(volatile uint32_t *) (VIC_BASE_ADDR + 0x120))
82#define VICVectAddr9 (*(volatile uint32_t *) (VIC_BASE_ADDR + 0x124))
83#define VICVectAddr10 (*(volatile uint32_t *) (VIC_BASE_ADDR + 0x128))
84#define VICVectAddr11 (*(volatile uint32_t *) (VIC_BASE_ADDR + 0x12C))
85#define VICVectAddr12 (*(volatile uint32_t *) (VIC_BASE_ADDR + 0x130))
86#define VICVectAddr13 (*(volatile uint32_t *) (VIC_BASE_ADDR + 0x134))
87#define VICVectAddr14 (*(volatile uint32_t *) (VIC_BASE_ADDR + 0x138))
88#define VICVectAddr15 (*(volatile uint32_t *) (VIC_BASE_ADDR + 0x13C))
89#define VICVectAddr16 (*(volatile uint32_t *) (VIC_BASE_ADDR + 0x140))
90#define VICVectAddr17 (*(volatile uint32_t *) (VIC_BASE_ADDR + 0x144))
91#define VICVectAddr18 (*(volatile uint32_t *) (VIC_BASE_ADDR + 0x148))
92#define VICVectAddr19 (*(volatile uint32_t *) (VIC_BASE_ADDR + 0x14C))
93#define VICVectAddr20 (*(volatile uint32_t *) (VIC_BASE_ADDR + 0x150))
94#define VICVectAddr21 (*(volatile uint32_t *) (VIC_BASE_ADDR + 0x154))
95#define VICVectAddr22 (*(volatile uint32_t *) (VIC_BASE_ADDR + 0x158))
96#define VICVectAddr23 (*(volatile uint32_t *) (VIC_BASE_ADDR + 0x15C))
97#define VICVectAddr24 (*(volatile uint32_t *) (VIC_BASE_ADDR + 0x160))
98#define VICVectAddr25 (*(volatile uint32_t *) (VIC_BASE_ADDR + 0x164))
99#define VICVectAddr26 (*(volatile uint32_t *) (VIC_BASE_ADDR + 0x168))
100#define VICVectAddr27 (*(volatile uint32_t *) (VIC_BASE_ADDR + 0x16C))
101#define VICVectAddr28 (*(volatile uint32_t *) (VIC_BASE_ADDR + 0x170))
102#define VICVectAddr29 (*(volatile uint32_t *) (VIC_BASE_ADDR + 0x174))
103#define VICVectAddr30 (*(volatile uint32_t *) (VIC_BASE_ADDR + 0x178))
104#define VICVectAddr31 (*(volatile uint32_t *) (VIC_BASE_ADDR + 0x17C))
105
106#define VICVectPriorityBase ((volatile uint32_t *) (VIC_BASE_ADDR + 0x200))
107#define VICVectPriority0 (*(volatile uint32_t *) (VIC_BASE_ADDR + 0x200))
108#define VICVectPriority1 (*(volatile uint32_t *) (VIC_BASE_ADDR + 0x204))
109#define VICVectPriority2 (*(volatile uint32_t *) (VIC_BASE_ADDR + 0x208))
110#define VICVectPriority3 (*(volatile uint32_t *) (VIC_BASE_ADDR + 0x20C))
111#define VICVectPriority4 (*(volatile uint32_t *) (VIC_BASE_ADDR + 0x210))
112#define VICVectPriority5 (*(volatile uint32_t *) (VIC_BASE_ADDR + 0x214))
113#define VICVectPriority6 (*(volatile uint32_t *) (VIC_BASE_ADDR + 0x218))
114#define VICVectPriority7 (*(volatile uint32_t *) (VIC_BASE_ADDR + 0x21C))
115#define VICVectPriority8 (*(volatile uint32_t *) (VIC_BASE_ADDR + 0x220))
116#define VICVectPriority9 (*(volatile uint32_t *) (VIC_BASE_ADDR + 0x224))
117#define VICVectPriority10 (*(volatile uint32_t *) (VIC_BASE_ADDR + 0x228))
118#define VICVectPriority11 (*(volatile uint32_t *) (VIC_BASE_ADDR + 0x22C))
119#define VICVectPriority12 (*(volatile uint32_t *) (VIC_BASE_ADDR + 0x230))
120#define VICVectPriority13 (*(volatile uint32_t *) (VIC_BASE_ADDR + 0x234))
121#define VICVectPriority14 (*(volatile uint32_t *) (VIC_BASE_ADDR + 0x238))
122#define VICVectPriority15 (*(volatile uint32_t *) (VIC_BASE_ADDR + 0x23C))
123#define VICVectPriority16 (*(volatile uint32_t *) (VIC_BASE_ADDR + 0x240))
124#define VICVectPriority17 (*(volatile uint32_t *) (VIC_BASE_ADDR + 0x244))
125#define VICVectPriority18 (*(volatile uint32_t *) (VIC_BASE_ADDR + 0x248))
126#define VICVectPriority19 (*(volatile uint32_t *) (VIC_BASE_ADDR + 0x24C))
127#define VICVectPriority20 (*(volatile uint32_t *) (VIC_BASE_ADDR + 0x250))
128#define VICVectPriority21 (*(volatile uint32_t *) (VIC_BASE_ADDR + 0x254))
129#define VICVectPriority22 (*(volatile uint32_t *) (VIC_BASE_ADDR + 0x258))
130#define VICVectPriority23 (*(volatile uint32_t *) (VIC_BASE_ADDR + 0x25C))
131#define VICVectPriority24 (*(volatile uint32_t *) (VIC_BASE_ADDR + 0x260))
132#define VICVectPriority25 (*(volatile uint32_t *) (VIC_BASE_ADDR + 0x264))
133#define VICVectPriority26 (*(volatile uint32_t *) (VIC_BASE_ADDR + 0x268))
134#define VICVectPriority27 (*(volatile uint32_t *) (VIC_BASE_ADDR + 0x26C))
135#define VICVectPriority28 (*(volatile uint32_t *) (VIC_BASE_ADDR + 0x270))
136#define VICVectPriority29 (*(volatile uint32_t *) (VIC_BASE_ADDR + 0x274))
137#define VICVectPriority30 (*(volatile uint32_t *) (VIC_BASE_ADDR + 0x278))
138#define VICVectPriority31 (*(volatile uint32_t *) (VIC_BASE_ADDR + 0x27C))
139
140#define VICVectAddr (*(volatile uint32_t *) (VIC_BASE_ADDR + 0xF00))
141
142#endif /* ARM_MULTILIB_ARCH_V4 */
143
144/* Pin Connect Block */
145#ifdef ARM_MULTILIB_ARCH_V4
146 #define PINSEL_BASE_ADDR 0xE002C000
147#else
148 #define PINSEL_BASE_ADDR 0x4002C000
149#endif
150
151#ifdef ARM_MULTILIB_ARCH_V4
152
153#define PINSEL0 (*(volatile uint32_t *) (PINSEL_BASE_ADDR + 0x00))
154#define PINSEL1 (*(volatile uint32_t *) (PINSEL_BASE_ADDR + 0x04))
155#define PINSEL2 (*(volatile uint32_t *) (PINSEL_BASE_ADDR + 0x08))
156#define PINSEL3 (*(volatile uint32_t *) (PINSEL_BASE_ADDR + 0x0C))
157#define PINSEL4 (*(volatile uint32_t *) (PINSEL_BASE_ADDR + 0x10))
158#define PINSEL5 (*(volatile uint32_t *) (PINSEL_BASE_ADDR + 0x14))
159#define PINSEL6 (*(volatile uint32_t *) (PINSEL_BASE_ADDR + 0x18))
160#define PINSEL7 (*(volatile uint32_t *) (PINSEL_BASE_ADDR + 0x1C))
161#define PINSEL8 (*(volatile uint32_t *) (PINSEL_BASE_ADDR + 0x20))
162#define PINSEL9 (*(volatile uint32_t *) (PINSEL_BASE_ADDR + 0x24))
163#define PINSEL10 (*(volatile uint32_t *) (PINSEL_BASE_ADDR + 0x28))
164#define PINSEL11 (*(volatile uint32_t *) (PINSEL_BASE_ADDR + 0x2C))
165
166#define PINMODE0 (*(volatile uint32_t *) (PINSEL_BASE_ADDR + 0x40))
167#define PINMODE1 (*(volatile uint32_t *) (PINSEL_BASE_ADDR + 0x44))
168#define PINMODE2 (*(volatile uint32_t *) (PINSEL_BASE_ADDR + 0x48))
169#define PINMODE3 (*(volatile uint32_t *) (PINSEL_BASE_ADDR + 0x4C))
170#define PINMODE4 (*(volatile uint32_t *) (PINSEL_BASE_ADDR + 0x50))
171#define PINMODE5 (*(volatile uint32_t *) (PINSEL_BASE_ADDR + 0x54))
172#define PINMODE6 (*(volatile uint32_t *) (PINSEL_BASE_ADDR + 0x58))
173#define PINMODE7 (*(volatile uint32_t *) (PINSEL_BASE_ADDR + 0x5C))
174#define PINMODE8 (*(volatile uint32_t *) (PINSEL_BASE_ADDR + 0x60))
175#define PINMODE9 (*(volatile uint32_t *) (PINSEL_BASE_ADDR + 0x64))
176
177#endif /* ARM_MULTILIB_ARCH_V4 */
178
179/* General Purpose Input/Output (GPIO) */
180#ifdef ARM_MULTILIB_ARCH_V4
181 #define GPIO_BASE_ADDR 0xE0028000
182#else
183 #define GPIO_BASE_ADDR 0x40028000
184#endif
185#define IOPIN0 (*(volatile uint32_t *) (GPIO_BASE_ADDR + 0x00))
186#define IOSET0 (*(volatile uint32_t *) (GPIO_BASE_ADDR + 0x04))
187#define IODIR0 (*(volatile uint32_t *) (GPIO_BASE_ADDR + 0x08))
188#define IOCLR0 (*(volatile uint32_t *) (GPIO_BASE_ADDR + 0x0C))
189#define IOPIN1 (*(volatile uint32_t *) (GPIO_BASE_ADDR + 0x10))
190#define IOSET1 (*(volatile uint32_t *) (GPIO_BASE_ADDR + 0x14))
191#define IODIR1 (*(volatile uint32_t *) (GPIO_BASE_ADDR + 0x18))
192#define IOCLR1 (*(volatile uint32_t *) (GPIO_BASE_ADDR + 0x1C))
193
194/* GPIO Interrupt Registers */
195#define IO0_INT_EN_R (*(volatile uint32_t *) (GPIO_BASE_ADDR + 0x90))
196#define IO0_INT_EN_F (*(volatile uint32_t *) (GPIO_BASE_ADDR + 0x94))
197#define IO0_INT_STAT_R (*(volatile uint32_t *) (GPIO_BASE_ADDR + 0x84))
198#define IO0_INT_STAT_F (*(volatile uint32_t *) (GPIO_BASE_ADDR + 0x88))
199#define IO0_INT_CLR (*(volatile uint32_t *) (GPIO_BASE_ADDR + 0x8C))
200
201#define IO2_INT_EN_R (*(volatile uint32_t *) (GPIO_BASE_ADDR + 0xB0))
202#define IO2_INT_EN_F (*(volatile uint32_t *) (GPIO_BASE_ADDR + 0xB4))
203#define IO2_INT_STAT_R (*(volatile uint32_t *) (GPIO_BASE_ADDR + 0xA4))
204#define IO2_INT_STAT_F (*(volatile uint32_t *) (GPIO_BASE_ADDR + 0xA8))
205#define IO2_INT_CLR (*(volatile uint32_t *) (GPIO_BASE_ADDR + 0xAC))
206
207#define IO_INT_STAT (*(volatile uint32_t *) (GPIO_BASE_ADDR + 0x80))
208
209#ifdef ARM_MULTILIB_ARCH_V4
210
211#define PARTCFG_BASE_ADDR 0x3FFF8000
212#define PARTCFG (*(volatile uint32_t *) (PARTCFG_BASE_ADDR + 0x00))
213
214#endif /* ARM_MULTILIB_ARCH_V4 */
215
216/* Fast I/O setup */
217#ifdef ARM_MULTILIB_ARCH_V4
218 #define FIO_BASE_ADDR 0x3FFFC000
219#else
220 #define FIO_BASE_ADDR 0x20098000
221#endif
222#define FIO0DIR (*(volatile uint32_t *) (FIO_BASE_ADDR + 0x00))
223#define FIO0MASK (*(volatile uint32_t *) (FIO_BASE_ADDR + 0x10))
224#define FIO0PIN (*(volatile uint32_t *) (FIO_BASE_ADDR + 0x14))
225#define FIO0SET (*(volatile uint32_t *) (FIO_BASE_ADDR + 0x18))
226#define FIO0CLR (*(volatile uint32_t *) (FIO_BASE_ADDR + 0x1C))
227
228#define FIO1DIR (*(volatile uint32_t *) (FIO_BASE_ADDR + 0x20))
229#define FIO1MASK (*(volatile uint32_t *) (FIO_BASE_ADDR + 0x30))
230#define FIO1PIN (*(volatile uint32_t *) (FIO_BASE_ADDR + 0x34))
231#define FIO1SET (*(volatile uint32_t *) (FIO_BASE_ADDR + 0x38))
232#define FIO1CLR (*(volatile uint32_t *) (FIO_BASE_ADDR + 0x3C))
233
234#define FIO2DIR (*(volatile uint32_t *) (FIO_BASE_ADDR + 0x40))
235#define FIO2MASK (*(volatile uint32_t *) (FIO_BASE_ADDR + 0x50))
236#define FIO2PIN (*(volatile uint32_t *) (FIO_BASE_ADDR + 0x54))
237#define FIO2SET (*(volatile uint32_t *) (FIO_BASE_ADDR + 0x58))
238#define FIO2CLR (*(volatile uint32_t *) (FIO_BASE_ADDR + 0x5C))
239
240#define FIO3DIR (*(volatile uint32_t *) (FIO_BASE_ADDR + 0x60))
241#define FIO3MASK (*(volatile uint32_t *) (FIO_BASE_ADDR + 0x70))
242#define FIO3PIN (*(volatile uint32_t *) (FIO_BASE_ADDR + 0x74))
243#define FIO3SET (*(volatile uint32_t *) (FIO_BASE_ADDR + 0x78))
244#define FIO3CLR (*(volatile uint32_t *) (FIO_BASE_ADDR + 0x7C))
245
246#define FIO4DIR (*(volatile uint32_t *) (FIO_BASE_ADDR + 0x80))
247#define FIO4MASK (*(volatile uint32_t *) (FIO_BASE_ADDR + 0x90))
248#define FIO4PIN (*(volatile uint32_t *) (FIO_BASE_ADDR + 0x94))
249#define FIO4SET (*(volatile uint32_t *) (FIO_BASE_ADDR + 0x98))
250#define FIO4CLR (*(volatile uint32_t *) (FIO_BASE_ADDR + 0x9C))
251
252#ifdef ARM_MULTILIB_ARCH_V7M
253
254#define FIO5DIR (*(volatile uint32_t *) (FIO_BASE_ADDR + 0xa0))
255#define FIO5MASK (*(volatile uint32_t *) (FIO_BASE_ADDR + 0xb0))
256#define FIO5PIN (*(volatile uint32_t *) (FIO_BASE_ADDR + 0xb4))
257#define FIO5SET (*(volatile uint32_t *) (FIO_BASE_ADDR + 0xb8))
258#define FIO5CLR (*(volatile uint32_t *) (FIO_BASE_ADDR + 0xbC))
259
260#endif /* ARM_MULTILIB_ARCH_V7M */
261
262/* FIOs can be accessed through WORD, HALF-WORD or BYTE. */
263#define FIO0DIR0 (*(volatile uint8_t *) (FIO_BASE_ADDR + 0x00))
264#define FIO1DIR0 (*(volatile uint8_t *) (FIO_BASE_ADDR + 0x20))
265#define FIO2DIR0 (*(volatile uint8_t *) (FIO_BASE_ADDR + 0x40))
266#define FIO3DIR0 (*(volatile uint8_t *) (FIO_BASE_ADDR + 0x60))
267#define FIO4DIR0 (*(volatile uint8_t *) (FIO_BASE_ADDR + 0x80))
268
269#define FIO0DIR1 (*(volatile uint8_t *) (FIO_BASE_ADDR + 0x01))
270#define FIO1DIR1 (*(volatile uint8_t *) (FIO_BASE_ADDR + 0x21))
271#define FIO2DIR1 (*(volatile uint8_t *) (FIO_BASE_ADDR + 0x41))
272#define FIO3DIR1 (*(volatile uint8_t *) (FIO_BASE_ADDR + 0x61))
273#define FIO4DIR1 (*(volatile uint8_t *) (FIO_BASE_ADDR + 0x81))
274
275#define FIO0DIR2 (*(volatile uint8_t *) (FIO_BASE_ADDR + 0x02))
276#define FIO1DIR2 (*(volatile uint8_t *) (FIO_BASE_ADDR + 0x22))
277#define FIO2DIR2 (*(volatile uint8_t *) (FIO_BASE_ADDR + 0x42))
278#define FIO3DIR2 (*(volatile uint8_t *) (FIO_BASE_ADDR + 0x62))
279#define FIO4DIR2 (*(volatile uint8_t *) (FIO_BASE_ADDR + 0x82))
280
281#define FIO0DIR3 (*(volatile uint8_t *) (FIO_BASE_ADDR + 0x03))
282#define FIO1DIR3 (*(volatile uint8_t *) (FIO_BASE_ADDR + 0x23))
283#define FIO2DIR3 (*(volatile uint8_t *) (FIO_BASE_ADDR + 0x43))
284#define FIO3DIR3 (*(volatile uint8_t *) (FIO_BASE_ADDR + 0x63))
285#define FIO4DIR3 (*(volatile uint8_t *) (FIO_BASE_ADDR + 0x83))
286
287#define FIO0DIRL (*(volatile uint16_t *) (FIO_BASE_ADDR + 0x00))
288#define FIO1DIRL (*(volatile uint16_t *) (FIO_BASE_ADDR + 0x20))
289#define FIO2DIRL (*(volatile uint16_t *) (FIO_BASE_ADDR + 0x40))
290#define FIO3DIRL (*(volatile uint16_t *) (FIO_BASE_ADDR + 0x60))
291#define FIO4DIRL (*(volatile uint16_t *) (FIO_BASE_ADDR + 0x80))
292
293#define FIO0DIRU (*(volatile uint16_t *) (FIO_BASE_ADDR + 0x02))
294#define FIO1DIRU (*(volatile uint16_t *) (FIO_BASE_ADDR + 0x22))
295#define FIO2DIRU (*(volatile uint16_t *) (FIO_BASE_ADDR + 0x42))
296#define FIO3DIRU (*(volatile uint16_t *) (FIO_BASE_ADDR + 0x62))
297#define FIO4DIRU (*(volatile uint16_t *) (FIO_BASE_ADDR + 0x82))
298
299#define FIO0MASK0 (*(volatile uint8_t *) (FIO_BASE_ADDR + 0x10))
300#define FIO1MASK0 (*(volatile uint8_t *) (FIO_BASE_ADDR + 0x30))
301#define FIO2MASK0 (*(volatile uint8_t *) (FIO_BASE_ADDR + 0x50))
302#define FIO3MASK0 (*(volatile uint8_t *) (FIO_BASE_ADDR + 0x70))
303#define FIO4MASK0 (*(volatile uint8_t *) (FIO_BASE_ADDR + 0x90))
304
305#define FIO0MASK1 (*(volatile uint8_t *) (FIO_BASE_ADDR + 0x11))
306#define FIO1MASK1 (*(volatile uint8_t *) (FIO_BASE_ADDR + 0x21))
307#define FIO2MASK1 (*(volatile uint8_t *) (FIO_BASE_ADDR + 0x51))
308#define FIO3MASK1 (*(volatile uint8_t *) (FIO_BASE_ADDR + 0x71))
309#define FIO4MASK1 (*(volatile uint8_t *) (FIO_BASE_ADDR + 0x91))
310
311#define FIO0MASK2 (*(volatile uint8_t *) (FIO_BASE_ADDR + 0x12))
312#define FIO1MASK2 (*(volatile uint8_t *) (FIO_BASE_ADDR + 0x32))
313#define FIO2MASK2 (*(volatile uint8_t *) (FIO_BASE_ADDR + 0x52))
314#define FIO3MASK2 (*(volatile uint8_t *) (FIO_BASE_ADDR + 0x72))
315#define FIO4MASK2 (*(volatile uint8_t *) (FIO_BASE_ADDR + 0x92))
316
317#define FIO0MASK3 (*(volatile uint8_t *) (FIO_BASE_ADDR + 0x13))
318#define FIO1MASK3 (*(volatile uint8_t *) (FIO_BASE_ADDR + 0x33))
319#define FIO2MASK3 (*(volatile uint8_t *) (FIO_BASE_ADDR + 0x53))
320#define FIO3MASK3 (*(volatile uint8_t *) (FIO_BASE_ADDR + 0x73))
321#define FIO4MASK3 (*(volatile uint8_t *) (FIO_BASE_ADDR + 0x93))
322
323#define FIO0MASKL (*(volatile uint16_t *) (FIO_BASE_ADDR + 0x10))
324#define FIO1MASKL (*(volatile uint16_t *) (FIO_BASE_ADDR + 0x30))
325#define FIO2MASKL (*(volatile uint16_t *) (FIO_BASE_ADDR + 0x50))
326#define FIO3MASKL (*(volatile uint16_t *) (FIO_BASE_ADDR + 0x70))
327#define FIO4MASKL (*(volatile uint16_t *) (FIO_BASE_ADDR + 0x90))
328
329#define FIO0MASKU (*(volatile uint16_t *) (FIO_BASE_ADDR + 0x12))
330#define FIO1MASKU (*(volatile uint16_t *) (FIO_BASE_ADDR + 0x32))
331#define FIO2MASKU (*(volatile uint16_t *) (FIO_BASE_ADDR + 0x52))
332#define FIO3MASKU (*(volatile uint16_t *) (FIO_BASE_ADDR + 0x72))
333#define FIO4MASKU (*(volatile uint16_t *) (FIO_BASE_ADDR + 0x92))
334
335#define FIO0PIN0 (*(volatile uint8_t *) (FIO_BASE_ADDR + 0x14))
336#define FIO1PIN0 (*(volatile uint8_t *) (FIO_BASE_ADDR + 0x34))
337#define FIO2PIN0 (*(volatile uint8_t *) (FIO_BASE_ADDR + 0x54))
338#define FIO3PIN0 (*(volatile uint8_t *) (FIO_BASE_ADDR + 0x74))
339#define FIO4PIN0 (*(volatile uint8_t *) (FIO_BASE_ADDR + 0x94))
340
341#define FIO0PIN1 (*(volatile uint8_t *) (FIO_BASE_ADDR + 0x15))
342#define FIO1PIN1 (*(volatile uint8_t *) (FIO_BASE_ADDR + 0x25))
343#define FIO2PIN1 (*(volatile uint8_t *) (FIO_BASE_ADDR + 0x55))
344#define FIO3PIN1 (*(volatile uint8_t *) (FIO_BASE_ADDR + 0x75))
345#define FIO4PIN1 (*(volatile uint8_t *) (FIO_BASE_ADDR + 0x95))
346
347#define FIO0PIN2 (*(volatile uint8_t *) (FIO_BASE_ADDR + 0x16))
348#define FIO1PIN2 (*(volatile uint8_t *) (FIO_BASE_ADDR + 0x36))
349#define FIO2PIN2 (*(volatile uint8_t *) (FIO_BASE_ADDR + 0x56))
350#define FIO3PIN2 (*(volatile uint8_t *) (FIO_BASE_ADDR + 0x76))
351#define FIO4PIN2 (*(volatile uint8_t *) (FIO_BASE_ADDR + 0x96))
352
353#define FIO0PIN3 (*(volatile uint8_t *) (FIO_BASE_ADDR + 0x17))
354#define FIO1PIN3 (*(volatile uint8_t *) (FIO_BASE_ADDR + 0x37))
355#define FIO2PIN3 (*(volatile uint8_t *) (FIO_BASE_ADDR + 0x57))
356#define FIO3PIN3 (*(volatile uint8_t *) (FIO_BASE_ADDR + 0x77))
357#define FIO4PIN3 (*(volatile uint8_t *) (FIO_BASE_ADDR + 0x97))
358
359#define FIO0PINL (*(volatile uint16_t *) (FIO_BASE_ADDR + 0x14))
360#define FIO1PINL (*(volatile uint16_t *) (FIO_BASE_ADDR + 0x34))
361#define FIO2PINL (*(volatile uint16_t *) (FIO_BASE_ADDR + 0x54))
362#define FIO3PINL (*(volatile uint16_t *) (FIO_BASE_ADDR + 0x74))
363#define FIO4PINL (*(volatile uint16_t *) (FIO_BASE_ADDR + 0x94))
364
365#define FIO0PINU (*(volatile uint16_t *) (FIO_BASE_ADDR + 0x16))
366#define FIO1PINU (*(volatile uint16_t *) (FIO_BASE_ADDR + 0x36))
367#define FIO2PINU (*(volatile uint16_t *) (FIO_BASE_ADDR + 0x56))
368#define FIO3PINU (*(volatile uint16_t *) (FIO_BASE_ADDR + 0x76))
369#define FIO4PINU (*(volatile uint16_t *) (FIO_BASE_ADDR + 0x96))
370
371#define FIO0SET0 (*(volatile uint8_t *) (FIO_BASE_ADDR + 0x18))
372#define FIO1SET0 (*(volatile uint8_t *) (FIO_BASE_ADDR + 0x38))
373#define FIO2SET0 (*(volatile uint8_t *) (FIO_BASE_ADDR + 0x58))
374#define FIO3SET0 (*(volatile uint8_t *) (FIO_BASE_ADDR + 0x78))
375#define FIO4SET0 (*(volatile uint8_t *) (FIO_BASE_ADDR + 0x98))
376
377#define FIO0SET1 (*(volatile uint8_t *) (FIO_BASE_ADDR + 0x19))
378#define FIO1SET1 (*(volatile uint8_t *) (FIO_BASE_ADDR + 0x29))
379#define FIO2SET1 (*(volatile uint8_t *) (FIO_BASE_ADDR + 0x59))
380#define FIO3SET1 (*(volatile uint8_t *) (FIO_BASE_ADDR + 0x79))
381#define FIO4SET1 (*(volatile uint8_t *) (FIO_BASE_ADDR + 0x99))
382
383#define FIO0SET2 (*(volatile uint8_t *) (FIO_BASE_ADDR + 0x1A))
384#define FIO1SET2 (*(volatile uint8_t *) (FIO_BASE_ADDR + 0x3A))
385#define FIO2SET2 (*(volatile uint8_t *) (FIO_BASE_ADDR + 0x5A))
386#define FIO3SET2 (*(volatile uint8_t *) (FIO_BASE_ADDR + 0x7A))
387#define FIO4SET2 (*(volatile uint8_t *) (FIO_BASE_ADDR + 0x9A))
388
389#define FIO0SET3 (*(volatile uint8_t *) (FIO_BASE_ADDR + 0x1B))
390#define FIO1SET3 (*(volatile uint8_t *) (FIO_BASE_ADDR + 0x3B))
391#define FIO2SET3 (*(volatile uint8_t *) (FIO_BASE_ADDR + 0x5B))
392#define FIO3SET3 (*(volatile uint8_t *) (FIO_BASE_ADDR + 0x7B))
393#define FIO4SET3 (*(volatile uint8_t *) (FIO_BASE_ADDR + 0x9B))
394
395#define FIO0SETL (*(volatile uint16_t *) (FIO_BASE_ADDR + 0x18))
396#define FIO1SETL (*(volatile uint16_t *) (FIO_BASE_ADDR + 0x38))
397#define FIO2SETL (*(volatile uint16_t *) (FIO_BASE_ADDR + 0x58))
398#define FIO3SETL (*(volatile uint16_t *) (FIO_BASE_ADDR + 0x78))
399#define FIO4SETL (*(volatile uint16_t *) (FIO_BASE_ADDR + 0x98))
400
401#define FIO0SETU (*(volatile uint16_t *) (FIO_BASE_ADDR + 0x1A))
402#define FIO1SETU (*(volatile uint16_t *) (FIO_BASE_ADDR + 0x3A))
403#define FIO2SETU (*(volatile uint16_t *) (FIO_BASE_ADDR + 0x5A))
404#define FIO3SETU (*(volatile uint16_t *) (FIO_BASE_ADDR + 0x7A))
405#define FIO4SETU (*(volatile uint16_t *) (FIO_BASE_ADDR + 0x9A))
406
407#define FIO0CLR0 (*(volatile uint8_t *) (FIO_BASE_ADDR + 0x1C))
408#define FIO1CLR0 (*(volatile uint8_t *) (FIO_BASE_ADDR + 0x3C))
409#define FIO2CLR0 (*(volatile uint8_t *) (FIO_BASE_ADDR + 0x5C))
410#define FIO3CLR0 (*(volatile uint8_t *) (FIO_BASE_ADDR + 0x7C))
411#define FIO4CLR0 (*(volatile uint8_t *) (FIO_BASE_ADDR + 0x9C))
412
413#define FIO0CLR1 (*(volatile uint8_t *) (FIO_BASE_ADDR + 0x1D))
414#define FIO1CLR1 (*(volatile uint8_t *) (FIO_BASE_ADDR + 0x2D))
415#define FIO2CLR1 (*(volatile uint8_t *) (FIO_BASE_ADDR + 0x5D))
416#define FIO3CLR1 (*(volatile uint8_t *) (FIO_BASE_ADDR + 0x7D))
417#define FIO4CLR1 (*(volatile uint8_t *) (FIO_BASE_ADDR + 0x9D))
418
419#define FIO0CLR2 (*(volatile uint8_t *) (FIO_BASE_ADDR + 0x1E))
420#define FIO1CLR2 (*(volatile uint8_t *) (FIO_BASE_ADDR + 0x3E))
421#define FIO2CLR2 (*(volatile uint8_t *) (FIO_BASE_ADDR + 0x5E))
422#define FIO3CLR2 (*(volatile uint8_t *) (FIO_BASE_ADDR + 0x7E))
423#define FIO4CLR2 (*(volatile uint8_t *) (FIO_BASE_ADDR + 0x9E))
424
425#define FIO0CLR3 (*(volatile uint8_t *) (FIO_BASE_ADDR + 0x1F))
426#define FIO1CLR3 (*(volatile uint8_t *) (FIO_BASE_ADDR + 0x3F))
427#define FIO2CLR3 (*(volatile uint8_t *) (FIO_BASE_ADDR + 0x5F))
428#define FIO3CLR3 (*(volatile uint8_t *) (FIO_BASE_ADDR + 0x7F))
429#define FIO4CLR3 (*(volatile uint8_t *) (FIO_BASE_ADDR + 0x9F))
430
431#define FIO0CLRL (*(volatile uint16_t *) (FIO_BASE_ADDR + 0x1C))
432#define FIO1CLRL (*(volatile uint16_t *) (FIO_BASE_ADDR + 0x3C))
433#define FIO2CLRL (*(volatile uint16_t *) (FIO_BASE_ADDR + 0x5C))
434#define FIO3CLRL (*(volatile uint16_t *) (FIO_BASE_ADDR + 0x7C))
435#define FIO4CLRL (*(volatile uint16_t *) (FIO_BASE_ADDR + 0x9C))
436
437#define FIO0CLRU (*(volatile uint16_t *) (FIO_BASE_ADDR + 0x1E))
438#define FIO1CLRU (*(volatile uint16_t *) (FIO_BASE_ADDR + 0x3E))
439#define FIO2CLRU (*(volatile uint16_t *) (FIO_BASE_ADDR + 0x5E))
440#define FIO3CLRU (*(volatile uint16_t *) (FIO_BASE_ADDR + 0x7E))
441#define FIO4CLRU (*(volatile uint16_t *) (FIO_BASE_ADDR + 0x9E))
442
443#ifdef ARM_MULTILIB_ARCH_V4
444
445/* System Control Block(SCB) modules include Memory Accelerator Module,
446Phase Locked Loop, VPB divider, Power Control, External Interrupt,
447Reset, and Code Security/Debugging */
448#define SCB_BASE_ADDR 0xE01FC000
449
450/* Memory Accelerator Module (MAM) */
451#define MAMCR (*(volatile uint32_t *) (SCB_BASE_ADDR + 0x000))
452#define MAMTIM (*(volatile uint32_t *) (SCB_BASE_ADDR + 0x004))
453#define MEMMAP (*(volatile uint32_t *) (SCB_BASE_ADDR + 0x040))
454
455/* Phase Locked Loop (PLL) */
456#define PLLCON (*(volatile uint32_t *) (SCB_BASE_ADDR + 0x080))
457#define PLLCFG (*(volatile uint32_t *) (SCB_BASE_ADDR + 0x084))
458#define PLLSTAT (*(volatile uint32_t *) (SCB_BASE_ADDR + 0x088))
459#define PLLFEED (*(volatile uint32_t *) (SCB_BASE_ADDR + 0x08C))
460
461/* Power Control */
462#define PCON (*(volatile uint32_t *) (SCB_BASE_ADDR + 0x0C0))
463#define PCONP (*(volatile uint32_t *) (SCB_BASE_ADDR + 0x0C4))
464
465/* Clock Divider */
466// #define APBDIV (*(volatile uint32_t *) (SCB_BASE_ADDR + 0x100))
467#define CCLKCFG (*(volatile uint32_t *) (SCB_BASE_ADDR + 0x104))
468#define USBCLKCFG (*(volatile uint32_t *) (SCB_BASE_ADDR + 0x108))
469#define CLKSRCSEL (*(volatile uint32_t *) (SCB_BASE_ADDR + 0x10C))
470#define PCLKSEL0 (*(volatile uint32_t *) (SCB_BASE_ADDR + 0x1A8))
471#define PCLKSEL1 (*(volatile uint32_t *) (SCB_BASE_ADDR + 0x1AC))
472
473/* External Interrupts */
474#define EXTINT (*(volatile uint32_t *) (SCB_BASE_ADDR + 0x140))
475#define INTWAKE (*(volatile uint32_t *) (SCB_BASE_ADDR + 0x144))
476#define EXTMODE (*(volatile uint32_t *) (SCB_BASE_ADDR + 0x148))
477#define EXTPOLAR (*(volatile uint32_t *) (SCB_BASE_ADDR + 0x14C))
478
479/* Reset, reset source identification */
480#define RSIR (*(volatile uint32_t *) (SCB_BASE_ADDR + 0x180))
481
482/* RSID, code security protection */
483#define CSPR (*(volatile uint32_t *) (SCB_BASE_ADDR + 0x184))
484
485/* AHB configuration */
486#define AHBCFG1 (*(volatile uint32_t *) (SCB_BASE_ADDR + 0x188))
487#define AHBCFG2 (*(volatile uint32_t *) (SCB_BASE_ADDR + 0x18C))
488
489/* System Controls and Status */
490#define SCS (*(volatile uint32_t *) (SCB_BASE_ADDR + 0x1A0))
491
492#endif /* ARM_MULTILIB_ARCH_V4 */
493
494/* External Memory Controller (EMC) */
495#ifdef ARM_MULTILIB_ARCH_V4
496 #define EMC_BASE_ADDR 0xFFE08000
497#else
498 #define EMC_BASE_ADDR 0x2009c000
499#endif
500#define EMC_CTRL (*(volatile uint32_t *) (EMC_BASE_ADDR + 0x000))
501#define EMC_STAT (*(volatile uint32_t *) (EMC_BASE_ADDR + 0x004))
502#define EMC_CONFIG (*(volatile uint32_t *) (EMC_BASE_ADDR + 0x008))
503
504/* Dynamic RAM access registers */
505#define EMC_DYN_CTRL (*(volatile uint32_t *) (EMC_BASE_ADDR + 0x020))
506#define EMC_DYN_RFSH (*(volatile uint32_t *) (EMC_BASE_ADDR + 0x024))
507#define EMC_DYN_RD_CFG (*(volatile uint32_t *) (EMC_BASE_ADDR + 0x028))
508#define EMC_DYN_RP (*(volatile uint32_t *) (EMC_BASE_ADDR + 0x030))
509#define EMC_DYN_RAS (*(volatile uint32_t *) (EMC_BASE_ADDR + 0x034))
510#define EMC_DYN_SREX (*(volatile uint32_t *) (EMC_BASE_ADDR + 0x038))
511#define EMC_DYN_APR (*(volatile uint32_t *) (EMC_BASE_ADDR + 0x03C))
512#define EMC_DYN_DAL (*(volatile uint32_t *) (EMC_BASE_ADDR + 0x040))
513#define EMC_DYN_WR (*(volatile uint32_t *) (EMC_BASE_ADDR + 0x044))
514#define EMC_DYN_RC (*(volatile uint32_t *) (EMC_BASE_ADDR + 0x048))
515#define EMC_DYN_RFC (*(volatile uint32_t *) (EMC_BASE_ADDR + 0x04C))
516#define EMC_DYN_XSR (*(volatile uint32_t *) (EMC_BASE_ADDR + 0x050))
517#define EMC_DYN_RRD (*(volatile uint32_t *) (EMC_BASE_ADDR + 0x054))
518#define EMC_DYN_MRD (*(volatile uint32_t *) (EMC_BASE_ADDR + 0x058))
519
520#define EMC_DYN_CFG0 (*(volatile uint32_t *) (EMC_BASE_ADDR + 0x100))
521#define EMC_DYN_RASCAS0 (*(volatile uint32_t *) (EMC_BASE_ADDR + 0x104))
522#define EMC_DYN_CFG1 (*(volatile uint32_t *) (EMC_BASE_ADDR + 0x140))
523#define EMC_DYN_RASCAS1 (*(volatile uint32_t *) (EMC_BASE_ADDR + 0x144))
524#define EMC_DYN_CFG2 (*(volatile uint32_t *) (EMC_BASE_ADDR + 0x160))
525#define EMC_DYN_RASCAS2 (*(volatile uint32_t *) (EMC_BASE_ADDR + 0x164))
526#define EMC_DYN_CFG3 (*(volatile uint32_t *) (EMC_BASE_ADDR + 0x180))
527#define EMC_DYN_RASCAS3 (*(volatile uint32_t *) (EMC_BASE_ADDR + 0x184))
528
529/* static RAM access registers */
530#define EMC_STA_BASE_0 ((uint32_t *) (EMC_BASE_ADDR + 0x200))
531#define EMC_STA_CFG0 (*(volatile uint32_t *) (EMC_BASE_ADDR + 0x200))
532#define EMC_STA_WAITWEN0 (*(volatile uint32_t *) (EMC_BASE_ADDR + 0x204))
533#define EMC_STA_WAITOEN0 (*(volatile uint32_t *) (EMC_BASE_ADDR + 0x208))
534#define EMC_STA_WAITRD0 (*(volatile uint32_t *) (EMC_BASE_ADDR + 0x20C))
535#define EMC_STA_WAITPAGE0 (*(volatile uint32_t *) (EMC_BASE_ADDR + 0x210))
536#define EMC_STA_WAITWR0 (*(volatile uint32_t *) (EMC_BASE_ADDR + 0x214))
537#define EMC_STA_WAITTURN0 (*(volatile uint32_t *) (EMC_BASE_ADDR + 0x218))
538
539#define EMC_STA_BASE_1 ((uint32_t *) (EMC_BASE_ADDR + 0x220))
540#define EMC_STA_CFG1 (*(volatile uint32_t *) (EMC_BASE_ADDR + 0x220))
541#define EMC_STA_WAITWEN1 (*(volatile uint32_t *) (EMC_BASE_ADDR + 0x224))
542#define EMC_STA_WAITOEN1 (*(volatile uint32_t *) (EMC_BASE_ADDR + 0x228))
543#define EMC_STA_WAITRD1 (*(volatile uint32_t *) (EMC_BASE_ADDR + 0x22C))
544#define EMC_STA_WAITPAGE1 (*(volatile uint32_t *) (EMC_BASE_ADDR + 0x230))
545#define EMC_STA_WAITWR1 (*(volatile uint32_t *) (EMC_BASE_ADDR + 0x234))
546#define EMC_STA_WAITTURN1 (*(volatile uint32_t *) (EMC_BASE_ADDR + 0x238))
547
548#define EMC_STA_BASE_2 ((uint32_t *) (EMC_BASE_ADDR + 0x240))
549#define EMC_STA_CFG2 (*(volatile uint32_t *) (EMC_BASE_ADDR + 0x240))
550#define EMC_STA_WAITWEN2 (*(volatile uint32_t *) (EMC_BASE_ADDR + 0x244))
551#define EMC_STA_WAITOEN2 (*(volatile uint32_t *) (EMC_BASE_ADDR + 0x248))
552#define EMC_STA_WAITRD2 (*(volatile uint32_t *) (EMC_BASE_ADDR + 0x24C))
553#define EMC_STA_WAITPAGE2 (*(volatile uint32_t *) (EMC_BASE_ADDR + 0x250))
554#define EMC_STA_WAITWR2 (*(volatile uint32_t *) (EMC_BASE_ADDR + 0x254))
555#define EMC_STA_WAITTURN2 (*(volatile uint32_t *) (EMC_BASE_ADDR + 0x258))
556
557#define EMC_STA_BASE_3 ((uint32_t *) (EMC_BASE_ADDR + 0x260))
558#define EMC_STA_CFG3 (*(volatile uint32_t *) (EMC_BASE_ADDR + 0x260))
559#define EMC_STA_WAITWEN3 (*(volatile uint32_t *) (EMC_BASE_ADDR + 0x264))
560#define EMC_STA_WAITOEN3 (*(volatile uint32_t *) (EMC_BASE_ADDR + 0x268))
561#define EMC_STA_WAITRD3 (*(volatile uint32_t *) (EMC_BASE_ADDR + 0x26C))
562#define EMC_STA_WAITPAGE3 (*(volatile uint32_t *) (EMC_BASE_ADDR + 0x270))
563#define EMC_STA_WAITWR3 (*(volatile uint32_t *) (EMC_BASE_ADDR + 0x274))
564#define EMC_STA_WAITTURN3 (*(volatile uint32_t *) (EMC_BASE_ADDR + 0x278))
565
566#define EMC_STA_EXT_WAIT (*(volatile uint32_t *) (EMC_BASE_ADDR + 0x880))
567
568
569/* Timer 0 */
570#ifdef ARM_MULTILIB_ARCH_V4
571 #define TMR0_BASE_ADDR 0xE0004000
572#else
573 #define TMR0_BASE_ADDR 0x40004000
574#endif
575#define T0IR (*(volatile uint32_t *) (TMR0_BASE_ADDR + 0x00))
576#define T0TCR (*(volatile uint32_t *) (TMR0_BASE_ADDR + 0x04))
577#define T0TC (*(volatile uint32_t *) (TMR0_BASE_ADDR + 0x08))
578#define T0PR (*(volatile uint32_t *) (TMR0_BASE_ADDR + 0x0C))
579#define T0PC (*(volatile uint32_t *) (TMR0_BASE_ADDR + 0x10))
580#define T0MCR (*(volatile uint32_t *) (TMR0_BASE_ADDR + 0x14))
581#define T0MR0 (*(volatile uint32_t *) (TMR0_BASE_ADDR + 0x18))
582#define T0MR1 (*(volatile uint32_t *) (TMR0_BASE_ADDR + 0x1C))
583#define T0MR2 (*(volatile uint32_t *) (TMR0_BASE_ADDR + 0x20))
584#define T0MR3 (*(volatile uint32_t *) (TMR0_BASE_ADDR + 0x24))
585#define T0CCR (*(volatile uint32_t *) (TMR0_BASE_ADDR + 0x28))
586#define T0CR0 (*(volatile uint32_t *) (TMR0_BASE_ADDR + 0x2C))
587#define T0CR1 (*(volatile uint32_t *) (TMR0_BASE_ADDR + 0x30))
588#define T0CR2 (*(volatile uint32_t *) (TMR0_BASE_ADDR + 0x34))
589#define T0CR3 (*(volatile uint32_t *) (TMR0_BASE_ADDR + 0x38))
590#define T0EMR (*(volatile uint32_t *) (TMR0_BASE_ADDR + 0x3C))
591#define T0CTCR (*(volatile uint32_t *) (TMR0_BASE_ADDR + 0x70))
592
593/* Timer 1 */
594#ifdef ARM_MULTILIB_ARCH_V4
595 #define TMR1_BASE_ADDR 0xE0008000
596#else
597 #define TMR1_BASE_ADDR 0x40008000
598#endif
599#define T1IR (*(volatile uint32_t *) (TMR1_BASE_ADDR + 0x00))
600#define T1TCR (*(volatile uint32_t *) (TMR1_BASE_ADDR + 0x04))
601#define T1TC (*(volatile uint32_t *) (TMR1_BASE_ADDR + 0x08))
602#define T1PR (*(volatile uint32_t *) (TMR1_BASE_ADDR + 0x0C))
603#define T1PC (*(volatile uint32_t *) (TMR1_BASE_ADDR + 0x10))
604#define T1MCR (*(volatile uint32_t *) (TMR1_BASE_ADDR + 0x14))
605#define T1MR0 (*(volatile uint32_t *) (TMR1_BASE_ADDR + 0x18))
606#define T1MR1 (*(volatile uint32_t *) (TMR1_BASE_ADDR + 0x1C))
607#define T1MR2 (*(volatile uint32_t *) (TMR1_BASE_ADDR + 0x20))
608#define T1MR3 (*(volatile uint32_t *) (TMR1_BASE_ADDR + 0x24))
609#define T1CCR (*(volatile uint32_t *) (TMR1_BASE_ADDR + 0x28))
610#define T1CR0 (*(volatile uint32_t *) (TMR1_BASE_ADDR + 0x2C))
611#define T1CR1 (*(volatile uint32_t *) (TMR1_BASE_ADDR + 0x30))
612#define T1CR2 (*(volatile uint32_t *) (TMR1_BASE_ADDR + 0x34))
613#define T1CR3 (*(volatile uint32_t *) (TMR1_BASE_ADDR + 0x38))
614#define T1EMR (*(volatile uint32_t *) (TMR1_BASE_ADDR + 0x3C))
615#define T1CTCR (*(volatile uint32_t *) (TMR1_BASE_ADDR + 0x70))
616
617/* Timer 2 */
618#ifdef ARM_MULTILIB_ARCH_V4
619 #define TMR2_BASE_ADDR 0xE0070000
620#else
621 #define TMR2_BASE_ADDR 0x40090000
622#endif
623#define T2IR (*(volatile uint32_t *) (TMR2_BASE_ADDR + 0x00))
624#define T2TCR (*(volatile uint32_t *) (TMR2_BASE_ADDR + 0x04))
625#define T2TC (*(volatile uint32_t *) (TMR2_BASE_ADDR + 0x08))
626#define T2PR (*(volatile uint32_t *) (TMR2_BASE_ADDR + 0x0C))
627#define T2PC (*(volatile uint32_t *) (TMR2_BASE_ADDR + 0x10))
628#define T2MCR (*(volatile uint32_t *) (TMR2_BASE_ADDR + 0x14))
629#define T2MR0 (*(volatile uint32_t *) (TMR2_BASE_ADDR + 0x18))
630#define T2MR1 (*(volatile uint32_t *) (TMR2_BASE_ADDR + 0x1C))
631#define T2MR2 (*(volatile uint32_t *) (TMR2_BASE_ADDR + 0x20))
632#define T2MR3 (*(volatile uint32_t *) (TMR2_BASE_ADDR + 0x24))
633#define T2CCR (*(volatile uint32_t *) (TMR2_BASE_ADDR + 0x28))
634#define T2CR0 (*(volatile uint32_t *) (TMR2_BASE_ADDR + 0x2C))
635#define T2CR1 (*(volatile uint32_t *) (TMR2_BASE_ADDR + 0x30))
636#define T2CR2 (*(volatile uint32_t *) (TMR2_BASE_ADDR + 0x34))
637#define T2CR3 (*(volatile uint32_t *) (TMR2_BASE_ADDR + 0x38))
638#define T2EMR (*(volatile uint32_t *) (TMR2_BASE_ADDR + 0x3C))
639#define T2CTCR (*(volatile uint32_t *) (TMR2_BASE_ADDR + 0x70))
640
641/* Timer 3 */
642#ifdef ARM_MULTILIB_ARCH_V4
643 #define TMR3_BASE_ADDR 0xE0074000
644#else
645 #define TMR3_BASE_ADDR 0x40094000
646#endif
647#define T3IR (*(volatile uint32_t *) (TMR3_BASE_ADDR + 0x00))
648#define T3TCR (*(volatile uint32_t *) (TMR3_BASE_ADDR + 0x04))
649#define T3TC (*(volatile uint32_t *) (TMR3_BASE_ADDR + 0x08))
650#define T3PR (*(volatile uint32_t *) (TMR3_BASE_ADDR + 0x0C))
651#define T3PC (*(volatile uint32_t *) (TMR3_BASE_ADDR + 0x10))
652#define T3MCR (*(volatile uint32_t *) (TMR3_BASE_ADDR + 0x14))
653#define T3MR0 (*(volatile uint32_t *) (TMR3_BASE_ADDR + 0x18))
654#define T3MR1 (*(volatile uint32_t *) (TMR3_BASE_ADDR + 0x1C))
655#define T3MR2 (*(volatile uint32_t *) (TMR3_BASE_ADDR + 0x20))
656#define T3MR3 (*(volatile uint32_t *) (TMR3_BASE_ADDR + 0x24))
657#define T3CCR (*(volatile uint32_t *) (TMR3_BASE_ADDR + 0x28))
658#define T3CR0 (*(volatile uint32_t *) (TMR3_BASE_ADDR + 0x2C))
659#define T3CR1 (*(volatile uint32_t *) (TMR3_BASE_ADDR + 0x30))
660#define T3CR2 (*(volatile uint32_t *) (TMR3_BASE_ADDR + 0x34))
661#define T3CR3 (*(volatile uint32_t *) (TMR3_BASE_ADDR + 0x38))
662#define T3EMR (*(volatile uint32_t *) (TMR3_BASE_ADDR + 0x3C))
663#define T3CTCR (*(volatile uint32_t *) (TMR3_BASE_ADDR + 0x70))
664
665
666/* Pulse Width Modulator (PWM) */
667#ifdef ARM_MULTILIB_ARCH_V4
668 #define PWM0_BASE_ADDR 0xE0014000
669#else
670 #define PWM0_BASE_ADDR 0x40014000
671#endif
672#define PWM0IR (*(volatile uint32_t *) (PWM0_BASE_ADDR + 0x00))
673#define PWM0TCR (*(volatile uint32_t *) (PWM0_BASE_ADDR + 0x04))
674#define PWM0TC (*(volatile uint32_t *) (PWM0_BASE_ADDR + 0x08))
675#define PWM0PR (*(volatile uint32_t *) (PWM0_BASE_ADDR + 0x0C))
676#define PWM0PC (*(volatile uint32_t *) (PWM0_BASE_ADDR + 0x10))
677#define PWM0MCR (*(volatile uint32_t *) (PWM0_BASE_ADDR + 0x14))
678#define PWM0MR0 (*(volatile uint32_t *) (PWM0_BASE_ADDR + 0x18))
679#define PWM0MR1 (*(volatile uint32_t *) (PWM0_BASE_ADDR + 0x1C))
680#define PWM0MR2 (*(volatile uint32_t *) (PWM0_BASE_ADDR + 0x20))
681#define PWM0MR3 (*(volatile uint32_t *) (PWM0_BASE_ADDR + 0x24))
682#define PWM0CCR (*(volatile uint32_t *) (PWM0_BASE_ADDR + 0x28))
683#define PWM0CR0 (*(volatile uint32_t *) (PWM0_BASE_ADDR + 0x2C))
684#define PWM0CR1 (*(volatile uint32_t *) (PWM0_BASE_ADDR + 0x30))
685#define PWM0CR2 (*(volatile uint32_t *) (PWM0_BASE_ADDR + 0x34))
686#define PWM0CR3 (*(volatile uint32_t *) (PWM0_BASE_ADDR + 0x38))
687#define PWM0EMR (*(volatile uint32_t *) (PWM0_BASE_ADDR + 0x3C))
688#define PWM0MR4 (*(volatile uint32_t *) (PWM0_BASE_ADDR + 0x40))
689#define PWM0MR5 (*(volatile uint32_t *) (PWM0_BASE_ADDR + 0x44))
690#define PWM0MR6 (*(volatile uint32_t *) (PWM0_BASE_ADDR + 0x48))
691#define PWM0PCR (*(volatile uint32_t *) (PWM0_BASE_ADDR + 0x4C))
692#define PWM0LER (*(volatile uint32_t *) (PWM0_BASE_ADDR + 0x50))
693#define PWM0CTCR (*(volatile uint32_t *) (PWM0_BASE_ADDR + 0x70))
694
695#ifdef ARM_MULTILIB_ARCH_V4
696 #define PWM1_BASE_ADDR 0xE0018000
697#else
698 #define PWM1_BASE_ADDR 0x40018000
699#endif
700#define PWM1IR (*(volatile uint32_t *) (PWM1_BASE_ADDR + 0x00))
701#define PWM1TCR (*(volatile uint32_t *) (PWM1_BASE_ADDR + 0x04))
702#define PWM1TC (*(volatile uint32_t *) (PWM1_BASE_ADDR + 0x08))
703#define PWM1PR (*(volatile uint32_t *) (PWM1_BASE_ADDR + 0x0C))
704#define PWM1PC (*(volatile uint32_t *) (PWM1_BASE_ADDR + 0x10))
705#define PWM1MCR (*(volatile uint32_t *) (PWM1_BASE_ADDR + 0x14))
706#define PWM1MR0 (*(volatile uint32_t *) (PWM1_BASE_ADDR + 0x18))
707#define PWM1MR1 (*(volatile uint32_t *) (PWM1_BASE_ADDR + 0x1C))
708#define PWM1MR2 (*(volatile uint32_t *) (PWM1_BASE_ADDR + 0x20))
709#define PWM1MR3 (*(volatile uint32_t *) (PWM1_BASE_ADDR + 0x24))
710#define PWM1CCR (*(volatile uint32_t *) (PWM1_BASE_ADDR + 0x28))
711#define PWM1CR0 (*(volatile uint32_t *) (PWM1_BASE_ADDR + 0x2C))
712#define PWM1CR1 (*(volatile uint32_t *) (PWM1_BASE_ADDR + 0x30))
713#define PWM1CR2 (*(volatile uint32_t *) (PWM1_BASE_ADDR + 0x34))
714#define PWM1CR3 (*(volatile uint32_t *) (PWM1_BASE_ADDR + 0x38))
715#define PWM1EMR (*(volatile uint32_t *) (PWM1_BASE_ADDR + 0x3C))
716#define PWM1MR4 (*(volatile uint32_t *) (PWM1_BASE_ADDR + 0x40))
717#define PWM1MR5 (*(volatile uint32_t *) (PWM1_BASE_ADDR + 0x44))
718#define PWM1MR6 (*(volatile uint32_t *) (PWM1_BASE_ADDR + 0x48))
719#define PWM1PCR (*(volatile uint32_t *) (PWM1_BASE_ADDR + 0x4C))
720#define PWM1LER (*(volatile uint32_t *) (PWM1_BASE_ADDR + 0x50))
721#define PWM1CTCR (*(volatile uint32_t *) (PWM1_BASE_ADDR + 0x70))
722
723
724/* Universal Asynchronous Receiver Transmitter 0 (UART0) */
725#ifdef ARM_MULTILIB_ARCH_V4
726 #define UART0_BASE_ADDR 0xE000C000
727#else
728 #define UART0_BASE_ADDR 0x4000C000
729#endif
730#define U0RBR (*(volatile uint32_t *) (UART0_BASE_ADDR + 0x00))
731#define U0THR (*(volatile uint32_t *) (UART0_BASE_ADDR + 0x00))
732#define U0DLL (*(volatile uint32_t *) (UART0_BASE_ADDR + 0x00))
733#define U0DLM (*(volatile uint32_t *) (UART0_BASE_ADDR + 0x04))
734#define U0IER (*(volatile uint32_t *) (UART0_BASE_ADDR + 0x04))
735#define U0IIR (*(volatile uint32_t *) (UART0_BASE_ADDR + 0x08))
736#define U0FCR (*(volatile uint32_t *) (UART0_BASE_ADDR + 0x08))
737#define U0LCR (*(volatile uint32_t *) (UART0_BASE_ADDR + 0x0C))
738#define U0LSR (*(volatile uint32_t *) (UART0_BASE_ADDR + 0x14))
739#define U0SCR (*(volatile uint32_t *) (UART0_BASE_ADDR + 0x1C))
740#define U0ACR (*(volatile uint32_t *) (UART0_BASE_ADDR + 0x20))
741#define U0ICR (*(volatile uint32_t *) (UART0_BASE_ADDR + 0x24))
742#define U0FDR (*(volatile uint32_t *) (UART0_BASE_ADDR + 0x28))
743#define U0TER (*(volatile uint32_t *) (UART0_BASE_ADDR + 0x30))
744
745/* Universal Asynchronous Receiver Transmitter 1 (UART1) */
746#ifdef ARM_MULTILIB_ARCH_V4
747 #define UART1_BASE_ADDR 0xE0010000
748#else
749 #define UART1_BASE_ADDR 0x40010000
750#endif
751#define U1RBR (*(volatile uint32_t *) (UART1_BASE_ADDR + 0x00))
752#define U1THR (*(volatile uint32_t *) (UART1_BASE_ADDR + 0x00))
753#define U1DLL (*(volatile uint32_t *) (UART1_BASE_ADDR + 0x00))
754#define U1DLM (*(volatile uint32_t *) (UART1_BASE_ADDR + 0x04))
755#define U1IER (*(volatile uint32_t *) (UART1_BASE_ADDR + 0x04))
756#define U1IIR (*(volatile uint32_t *) (UART1_BASE_ADDR + 0x08))
757#define U1FCR (*(volatile uint32_t *) (UART1_BASE_ADDR + 0x08))
758#define U1LCR (*(volatile uint32_t *) (UART1_BASE_ADDR + 0x0C))
759#define U1MCR (*(volatile uint32_t *) (UART1_BASE_ADDR + 0x10))
760#define U1LSR (*(volatile uint32_t *) (UART1_BASE_ADDR + 0x14))
761#define U1MSR (*(volatile uint32_t *) (UART1_BASE_ADDR + 0x18))
762#define U1SCR (*(volatile uint32_t *) (UART1_BASE_ADDR + 0x1C))
763#define U1ACR (*(volatile uint32_t *) (UART1_BASE_ADDR + 0x20))
764#define U1FDR (*(volatile uint32_t *) (UART1_BASE_ADDR + 0x28))
765#define U1TER (*(volatile uint32_t *) (UART1_BASE_ADDR + 0x30))
766
767/* Universal Asynchronous Receiver Transmitter 2 (UART2) */
768#ifdef ARM_MULTILIB_ARCH_V4
769 #define UART2_BASE_ADDR 0xE0078000
770#else
771 #define UART2_BASE_ADDR 0x40098000
772#endif
773#define U2RBR (*(volatile uint32_t *) (UART2_BASE_ADDR + 0x00))
774#define U2THR (*(volatile uint32_t *) (UART2_BASE_ADDR + 0x00))
775#define U2DLL (*(volatile uint32_t *) (UART2_BASE_ADDR + 0x00))
776#define U2DLM (*(volatile uint32_t *) (UART2_BASE_ADDR + 0x04))
777#define U2IER (*(volatile uint32_t *) (UART2_BASE_ADDR + 0x04))
778#define U2IIR (*(volatile uint32_t *) (UART2_BASE_ADDR + 0x08))
779#define U2FCR (*(volatile uint32_t *) (UART2_BASE_ADDR + 0x08))
780#define U2LCR (*(volatile uint32_t *) (UART2_BASE_ADDR + 0x0C))
781#define U2LSR (*(volatile uint32_t *) (UART2_BASE_ADDR + 0x14))
782#define U2SCR (*(volatile uint32_t *) (UART2_BASE_ADDR + 0x1C))
783#define U2ACR (*(volatile uint32_t *) (UART2_BASE_ADDR + 0x20))
784#define U2ICR (*(volatile uint32_t *) (UART2_BASE_ADDR + 0x24))
785#define U2FDR (*(volatile uint32_t *) (UART2_BASE_ADDR + 0x28))
786#define U2TER (*(volatile uint32_t *) (UART2_BASE_ADDR + 0x30))
787
788/* Universal Asynchronous Receiver Transmitter 3 (UART3) */
789#ifdef ARM_MULTILIB_ARCH_V4
790 #define UART3_BASE_ADDR 0xE007C000
791#else
792 #define UART3_BASE_ADDR 0x4009C000
793#endif
794#define U3RBR (*(volatile uint32_t *) (UART3_BASE_ADDR + 0x00))
795#define U3THR (*(volatile uint32_t *) (UART3_BASE_ADDR + 0x00))
796#define U3DLL (*(volatile uint32_t *) (UART3_BASE_ADDR + 0x00))
797#define U3DLM (*(volatile uint32_t *) (UART3_BASE_ADDR + 0x04))
798#define U3IER (*(volatile uint32_t *) (UART3_BASE_ADDR + 0x04))
799#define U3IIR (*(volatile uint32_t *) (UART3_BASE_ADDR + 0x08))
800#define U3FCR (*(volatile uint32_t *) (UART3_BASE_ADDR + 0x08))
801#define U3LCR (*(volatile uint32_t *) (UART3_BASE_ADDR + 0x0C))
802#define U3LSR (*(volatile uint32_t *) (UART3_BASE_ADDR + 0x14))
803#define U3SCR (*(volatile uint32_t *) (UART3_BASE_ADDR + 0x1C))
804#define U3ACR (*(volatile uint32_t *) (UART3_BASE_ADDR + 0x20))
805#define U3ICR (*(volatile uint32_t *) (UART3_BASE_ADDR + 0x24))
806#define U3FDR (*(volatile uint32_t *) (UART3_BASE_ADDR + 0x28))
807#define U3TER (*(volatile uint32_t *) (UART3_BASE_ADDR + 0x30))
808
809/* I2C Interface 0 */
810#ifdef ARM_MULTILIB_ARCH_V4
811 #define I2C0_BASE_ADDR 0xE001C000
812#else
813 #define I2C0_BASE_ADDR 0x4001C000
814#endif
815#define I20CONSET (*(volatile uint32_t *) (I2C0_BASE_ADDR + 0x00))
816#define I20STAT (*(volatile uint32_t *) (I2C0_BASE_ADDR + 0x04))
817#define I20DAT (*(volatile uint32_t *) (I2C0_BASE_ADDR + 0x08))
818#define I20ADR (*(volatile uint32_t *) (I2C0_BASE_ADDR + 0x0C))
819#define I20SCLH (*(volatile uint32_t *) (I2C0_BASE_ADDR + 0x10))
820#define I20SCLL (*(volatile uint32_t *) (I2C0_BASE_ADDR + 0x14))
821#define I20CONCLR (*(volatile uint32_t *) (I2C0_BASE_ADDR + 0x18))
822
823/* I2C Interface 1 */
824#ifdef ARM_MULTILIB_ARCH_V4
825 #define I2C1_BASE_ADDR 0xE005C000
826#else
827 #define I2C1_BASE_ADDR 0x4005C000
828#endif
829#define I21CONSET (*(volatile uint32_t *) (I2C1_BASE_ADDR + 0x00))
830#define I21STAT (*(volatile uint32_t *) (I2C1_BASE_ADDR + 0x04))
831#define I21DAT (*(volatile uint32_t *) (I2C1_BASE_ADDR + 0x08))
832#define I21ADR (*(volatile uint32_t *) (I2C1_BASE_ADDR + 0x0C))
833#define I21SCLH (*(volatile uint32_t *) (I2C1_BASE_ADDR + 0x10))
834#define I21SCLL (*(volatile uint32_t *) (I2C1_BASE_ADDR + 0x14))
835#define I21CONCLR (*(volatile uint32_t *) (I2C1_BASE_ADDR + 0x18))
836
837/* I2C Interface 2 */
838#ifdef ARM_MULTILIB_ARCH_V4
839 #define I2C2_BASE_ADDR 0xE0080000
840#else
841 #define I2C2_BASE_ADDR 0x400a0000
842#endif
843#define I22CONSET (*(volatile uint32_t *) (I2C2_BASE_ADDR + 0x00))
844#define I22STAT (*(volatile uint32_t *) (I2C2_BASE_ADDR + 0x04))
845#define I22DAT (*(volatile uint32_t *) (I2C2_BASE_ADDR + 0x08))
846#define I22ADR (*(volatile uint32_t *) (I2C2_BASE_ADDR + 0x0C))
847#define I22SCLH (*(volatile uint32_t *) (I2C2_BASE_ADDR + 0x10))
848#define I22SCLL (*(volatile uint32_t *) (I2C2_BASE_ADDR + 0x14))
849#define I22CONCLR (*(volatile uint32_t *) (I2C2_BASE_ADDR + 0x18))
850
851/* SPI0 (Serial Peripheral Interface 0) */
852#define SPI0_BASE_ADDR 0xE0020000
853#define S0SPCR (*(volatile uint32_t *) (SPI0_BASE_ADDR + 0x00))
854#define S0SPSR (*(volatile uint32_t *) (SPI0_BASE_ADDR + 0x04))
855#define S0SPDR (*(volatile uint32_t *) (SPI0_BASE_ADDR + 0x08))
856#define S0SPCCR (*(volatile uint32_t *) (SPI0_BASE_ADDR + 0x0C))
857#define S0SPINT (*(volatile uint32_t *) (SPI0_BASE_ADDR + 0x1C))
858
859/* SSP0 Controller */
860#ifdef ARM_MULTILIB_ARCH_V4
861 #define SSP0_BASE_ADDR 0xE0068000
862#else
863 #define SSP0_BASE_ADDR 0x40088000
864#endif
865#define SSP0CR0 (*(volatile uint32_t *) (SSP0_BASE_ADDR + 0x00))
866#define SSP0CR1 (*(volatile uint32_t *) (SSP0_BASE_ADDR + 0x04))
867#define SSP0DR (*(volatile uint32_t *) (SSP0_BASE_ADDR + 0x08))
868#define SSP0SR (*(volatile uint32_t *) (SSP0_BASE_ADDR + 0x0C))
869#define SSP0CPSR (*(volatile uint32_t *) (SSP0_BASE_ADDR + 0x10))
870#define SSP0IMSC (*(volatile uint32_t *) (SSP0_BASE_ADDR + 0x14))
871#define SSP0RIS (*(volatile uint32_t *) (SSP0_BASE_ADDR + 0x18))
872#define SSP0MIS (*(volatile uint32_t *) (SSP0_BASE_ADDR + 0x1C))
873#define SSP0ICR (*(volatile uint32_t *) (SSP0_BASE_ADDR + 0x20))
874#define SSP0DMACR (*(volatile uint32_t *) (SSP0_BASE_ADDR + 0x24))
875
876/* SSP1 Controller */
877#ifdef ARM_MULTILIB_ARCH_V4
878 #define SSP1_BASE_ADDR 0xE0030000
879#else
880 #define SSP1_BASE_ADDR 0x40030000
881#endif
882#define SSP1CR0 (*(volatile uint32_t *) (SSP1_BASE_ADDR + 0x00))
883#define SSP1CR1 (*(volatile uint32_t *) (SSP1_BASE_ADDR + 0x04))
884#define SSP1DR (*(volatile uint32_t *) (SSP1_BASE_ADDR + 0x08))
885#define SSP1SR (*(volatile uint32_t *) (SSP1_BASE_ADDR + 0x0C))
886#define SSP1CPSR (*(volatile uint32_t *) (SSP1_BASE_ADDR + 0x10))
887#define SSP1IMSC (*(volatile uint32_t *) (SSP1_BASE_ADDR + 0x14))
888#define SSP1RIS (*(volatile uint32_t *) (SSP1_BASE_ADDR + 0x18))
889#define SSP1MIS (*(volatile uint32_t *) (SSP1_BASE_ADDR + 0x1C))
890#define SSP1ICR (*(volatile uint32_t *) (SSP1_BASE_ADDR + 0x20))
891#define SSP1DMACR (*(volatile uint32_t *) (SSP1_BASE_ADDR + 0x24))
892
893#ifdef ARM_MULTILIB_ARCH_V7M
894
895/* SSP2 Controller */
896#define SSP2_BASE_ADDR 0x400ac000
897#define SSP2CR0 (*(volatile uint32_t *) (SSP2_BASE_ADDR + 0x00))
898#define SSP2CR1 (*(volatile uint32_t *) (SSP2_BASE_ADDR + 0x04))
899#define SSP2DR (*(volatile uint32_t *) (SSP2_BASE_ADDR + 0x08))
900#define SSP2SR (*(volatile uint32_t *) (SSP2_BASE_ADDR + 0x0C))
901#define SSP2CPSR (*(volatile uint32_t *) (SSP2_BASE_ADDR + 0x10))
902#define SSP2IMSC (*(volatile uint32_t *) (SSP2_BASE_ADDR + 0x14))
903#define SSP2RIS (*(volatile uint32_t *) (SSP2_BASE_ADDR + 0x18))
904#define SSP2MIS (*(volatile uint32_t *) (SSP2_BASE_ADDR + 0x1C))
905#define SSP2ICR (*(volatile uint32_t *) (SSP2_BASE_ADDR + 0x20))
906#define SSP2DMACR (*(volatile uint32_t *) (SSP2_BASE_ADDR + 0x24))
907
908#endif /* ARM_MULTILIB_ARCH_V4 */
909
910/* Real Time Clock */
911#ifdef ARM_MULTILIB_ARCH_V4
912 #define RTC_BASE_ADDR 0xE0024000
913#else
914 #define RTC_BASE_ADDR 0x40024000
915#endif
916#define RTC_ILR (*(volatile uint32_t *) (RTC_BASE_ADDR + 0x00))
917#define RTC_CTC (*(volatile uint32_t *) (RTC_BASE_ADDR + 0x04))
918#define RTC_CCR (*(volatile uint32_t *) (RTC_BASE_ADDR + 0x08))
919#define RTC_CIIR (*(volatile uint32_t *) (RTC_BASE_ADDR + 0x0C))
920#define RTC_AMR (*(volatile uint32_t *) (RTC_BASE_ADDR + 0x10))
921#define RTC_CTIME0 (*(volatile uint32_t *) (RTC_BASE_ADDR + 0x14))
922#define RTC_CTIME1 (*(volatile uint32_t *) (RTC_BASE_ADDR + 0x18))
923#define RTC_CTIME2 (*(volatile uint32_t *) (RTC_BASE_ADDR + 0x1C))
924#define RTC_SEC (*(volatile uint32_t *) (RTC_BASE_ADDR + 0x20))
925#define RTC_MIN (*(volatile uint32_t *) (RTC_BASE_ADDR + 0x24))
926#define RTC_HOUR (*(volatile uint32_t *) (RTC_BASE_ADDR + 0x28))
927#define RTC_DOM (*(volatile uint32_t *) (RTC_BASE_ADDR + 0x2C))
928#define RTC_DOW (*(volatile uint32_t *) (RTC_BASE_ADDR + 0x30))
929#define RTC_DOY (*(volatile uint32_t *) (RTC_BASE_ADDR + 0x34))
930#define RTC_MONTH (*(volatile uint32_t *) (RTC_BASE_ADDR + 0x38))
931#define RTC_YEAR (*(volatile uint32_t *) (RTC_BASE_ADDR + 0x3C))
932#define RTC_CISS (*(volatile uint32_t *) (RTC_BASE_ADDR + 0x40))
933#define RTC_ALSEC (*(volatile uint32_t *) (RTC_BASE_ADDR + 0x60))
934#define RTC_ALMIN (*(volatile uint32_t *) (RTC_BASE_ADDR + 0x64))
935#define RTC_ALHOUR (*(volatile uint32_t *) (RTC_BASE_ADDR + 0x68))
936#define RTC_ALDOM (*(volatile uint32_t *) (RTC_BASE_ADDR + 0x6C))
937#define RTC_ALDOW (*(volatile uint32_t *) (RTC_BASE_ADDR + 0x70))
938#define RTC_ALDOY (*(volatile uint32_t *) (RTC_BASE_ADDR + 0x74))
939#define RTC_ALMON (*(volatile uint32_t *) (RTC_BASE_ADDR + 0x78))
940#define RTC_ALYEAR (*(volatile uint32_t *) (RTC_BASE_ADDR + 0x7C))
941#define RTC_PREINT (*(volatile uint32_t *) (RTC_BASE_ADDR + 0x80))
942#define RTC_PREFRAC (*(volatile uint32_t *) (RTC_BASE_ADDR + 0x84))
943
944
945/* A/D Converter 0 (AD0) */
946#ifdef ARM_MULTILIB_ARCH_V4
947 #define AD0_BASE_ADDR 0xE0034000
948#else
949 #define AD0_BASE_ADDR 0x40034000
950#endif
951#define AD0CR (*(volatile uint32_t *) (AD0_BASE_ADDR + 0x00))
952#define AD0GDR (*(volatile uint32_t *) (AD0_BASE_ADDR + 0x04))
953#define AD0INTEN (*(volatile uint32_t *) (AD0_BASE_ADDR + 0x0C))
954#define AD0_DATA_START ((volatile uint32_t *) (AD0_BASE_ADDR + 0x10))
955#define AD0DR0 (*(volatile uint32_t *) (AD0_BASE_ADDR + 0x10))
956#define AD0DR1 (*(volatile uint32_t *) (AD0_BASE_ADDR + 0x14))
957#define AD0DR2 (*(volatile uint32_t *) (AD0_BASE_ADDR + 0x18))
958#define AD0DR3 (*(volatile uint32_t *) (AD0_BASE_ADDR + 0x1C))
959#define AD0DR4 (*(volatile uint32_t *) (AD0_BASE_ADDR + 0x20))
960#define AD0DR5 (*(volatile uint32_t *) (AD0_BASE_ADDR + 0x24))
961#define AD0DR6 (*(volatile uint32_t *) (AD0_BASE_ADDR + 0x28))
962#define AD0DR7 (*(volatile uint32_t *) (AD0_BASE_ADDR + 0x2C))
963#define AD0STAT (*(volatile uint32_t *) (AD0_BASE_ADDR + 0x30))
964
965
966/* D/A Converter */
967#ifdef ARM_MULTILIB_ARCH_V4
968 #define DAC_BASE_ADDR 0xE006C000
969#else
970 #define DAC_BASE_ADDR 0x4008C000
971#endif
972#define DACR (*(volatile uint32_t *) (DAC_BASE_ADDR + 0x00))
973
974
975/* Watchdog */
976#ifdef ARM_MULTILIB_ARCH_V4
977 #define WDG_BASE_ADDR 0xE0000000
978#else
979 #define WDG_BASE_ADDR 0x40000000
980#endif
981#define WDMOD (*(volatile uint32_t *) (WDG_BASE_ADDR + 0x00))
982#define WDTC (*(volatile uint32_t *) (WDG_BASE_ADDR + 0x04))
983#define WDFEED (*(volatile uint32_t *) (WDG_BASE_ADDR + 0x08))
984#define WDTV (*(volatile uint32_t *) (WDG_BASE_ADDR + 0x0C))
985#define WDCLKSEL (*(volatile uint32_t *) (WDG_BASE_ADDR + 0x10))
986
987/* CAN CONTROLLERS AND ACCEPTANCE FILTER */
988#ifdef ARM_MULTILIB_ARCH_V4
989 #define CAN_ACCEPT_BASE_ADDR 0xE003C000
990#else
991 #define CAN_ACCEPT_BASE_ADDR 0x4003C000
992#endif
993#define CAN_AFMR (*(volatile uint32_t *) (CAN_ACCEPT_BASE_ADDR + 0x00))
994#define CAN_SFF_SA (*(volatile uint32_t *) (CAN_ACCEPT_BASE_ADDR + 0x04))
995#define CAN_SFF_GRP_SA (*(volatile uint32_t *) (CAN_ACCEPT_BASE_ADDR + 0x08))
996#define CAN_EFF_SA (*(volatile uint32_t *) (CAN_ACCEPT_BASE_ADDR + 0x0C))
997#define CAN_EFF_GRP_SA (*(volatile uint32_t *) (CAN_ACCEPT_BASE_ADDR + 0x10))
998#define CAN_EOT (*(volatile uint32_t *) (CAN_ACCEPT_BASE_ADDR + 0x14))
999#define CAN_LUT_ERR_ADR (*(volatile uint32_t *) (CAN_ACCEPT_BASE_ADDR + 0x18))
1000#define CAN_LUT_ERR (*(volatile uint32_t *) (CAN_ACCEPT_BASE_ADDR + 0x1C))
1001
1002#ifdef ARM_MULTILIB_ARCH_V4
1003 #define CAN_CENTRAL_BASE_ADDR 0xE0040000
1004#else
1005 #define CAN_CENTRAL_BASE_ADDR 0x40040000
1006#endif
1007#define CAN_TX_SR (*(volatile uint32_t *) (CAN_CENTRAL_BASE_ADDR + 0x00))
1008#define CAN_RX_SR (*(volatile uint32_t *) (CAN_CENTRAL_BASE_ADDR + 0x04))
1009#define CAN_MSR (*(volatile uint32_t *) (CAN_CENTRAL_BASE_ADDR + 0x08))
1010
1011#ifdef ARM_MULTILIB_ARCH_V4
1012 #define CAN1_BASE_ADDR 0xE0044000
1013#else
1014 #define CAN1_BASE_ADDR 0x40044000
1015#endif
1016#define CAN1MOD (*(volatile uint32_t *) (CAN1_BASE_ADDR + 0x00))
1017#define CAN1CMR (*(volatile uint32_t *) (CAN1_BASE_ADDR + 0x04))
1018#define CAN1GSR (*(volatile uint32_t *) (CAN1_BASE_ADDR + 0x08))
1019#define CAN1ICR (*(volatile uint32_t *) (CAN1_BASE_ADDR + 0x0C))
1020#define CAN1IER (*(volatile uint32_t *) (CAN1_BASE_ADDR + 0x10))
1021#define CAN1BTR (*(volatile uint32_t *) (CAN1_BASE_ADDR + 0x14))
1022#define CAN1EWL (*(volatile uint32_t *) (CAN1_BASE_ADDR + 0x18))
1023#define CAN1SR (*(volatile uint32_t *) (CAN1_BASE_ADDR + 0x1C))
1024#define CAN1RFS (*(volatile uint32_t *) (CAN1_BASE_ADDR + 0x20))
1025#define CAN1RID (*(volatile uint32_t *) (CAN1_BASE_ADDR + 0x24))
1026#define CAN1RDA (*(volatile uint32_t *) (CAN1_BASE_ADDR + 0x28))
1027#define CAN1RDB (*(volatile uint32_t *) (CAN1_BASE_ADDR + 0x2C))
1028
1029#define CAN1TFI1 (*(volatile uint32_t *) (CAN1_BASE_ADDR + 0x30))
1030#define CAN1TID1 (*(volatile uint32_t *) (CAN1_BASE_ADDR + 0x34))
1031#define CAN1TDA1 (*(volatile uint32_t *) (CAN1_BASE_ADDR + 0x38))
1032#define CAN1TDB1 (*(volatile uint32_t *) (CAN1_BASE_ADDR + 0x3C))
1033#define CAN1TFI2 (*(volatile uint32_t *) (CAN1_BASE_ADDR + 0x40))
1034#define CAN1TID2 (*(volatile uint32_t *) (CAN1_BASE_ADDR + 0x44))
1035#define CAN1TDA2 (*(volatile uint32_t *) (CAN1_BASE_ADDR + 0x48))
1036#define CAN1TDB2 (*(volatile uint32_t *) (CAN1_BASE_ADDR + 0x4C))
1037#define CAN1TFI3 (*(volatile uint32_t *) (CAN1_BASE_ADDR + 0x50))
1038#define CAN1TID3 (*(volatile uint32_t *) (CAN1_BASE_ADDR + 0x54))
1039#define CAN1TDA3 (*(volatile uint32_t *) (CAN1_BASE_ADDR + 0x58))
1040#define CAN1TDB3 (*(volatile uint32_t *) (CAN1_BASE_ADDR + 0x5C))
1041
1042#ifdef ARM_MULTILIB_ARCH_V4
1043 #define CAN2_BASE_ADDR 0xE0048000
1044#else
1045 #define CAN2_BASE_ADDR 0x40048000
1046#endif
1047#define CAN2MOD (*(volatile uint32_t *) (CAN2_BASE_ADDR + 0x00))
1048#define CAN2CMR (*(volatile uint32_t *) (CAN2_BASE_ADDR + 0x04))
1049#define CAN2GSR (*(volatile uint32_t *) (CAN2_BASE_ADDR + 0x08))
1050#define CAN2ICR (*(volatile uint32_t *) (CAN2_BASE_ADDR + 0x0C))
1051#define CAN2IER (*(volatile uint32_t *) (CAN2_BASE_ADDR + 0x10))
1052#define CAN2BTR (*(volatile uint32_t *) (CAN2_BASE_ADDR + 0x14))
1053#define CAN2EWL (*(volatile uint32_t *) (CAN2_BASE_ADDR + 0x18))
1054#define CAN2SR (*(volatile uint32_t *) (CAN2_BASE_ADDR + 0x1C))
1055#define CAN2RFS (*(volatile uint32_t *) (CAN2_BASE_ADDR + 0x20))
1056#define CAN2RID (*(volatile uint32_t *) (CAN2_BASE_ADDR + 0x24))
1057#define CAN2RDA (*(volatile uint32_t *) (CAN2_BASE_ADDR + 0x28))
1058#define CAN2RDB (*(volatile uint32_t *) (CAN2_BASE_ADDR + 0x2C))
1059
1060#define CAN2TFI1 (*(volatile uint32_t *) (CAN2_BASE_ADDR + 0x30))
1061#define CAN2TID1 (*(volatile uint32_t *) (CAN2_BASE_ADDR + 0x34))
1062#define CAN2TDA1 (*(volatile uint32_t *) (CAN2_BASE_ADDR + 0x38))
1063#define CAN2TDB1 (*(volatile uint32_t *) (CAN2_BASE_ADDR + 0x3C))
1064#define CAN2TFI2 (*(volatile uint32_t *) (CAN2_BASE_ADDR + 0x40))
1065#define CAN2TID2 (*(volatile uint32_t *) (CAN2_BASE_ADDR + 0x44))
1066#define CAN2TDA2 (*(volatile uint32_t *) (CAN2_BASE_ADDR + 0x48))
1067#define CAN2TDB2 (*(volatile uint32_t *) (CAN2_BASE_ADDR + 0x4C))
1068#define CAN2TFI3 (*(volatile uint32_t *) (CAN2_BASE_ADDR + 0x50))
1069#define CAN2TID3 (*(volatile uint32_t *) (CAN2_BASE_ADDR + 0x54))
1070#define CAN2TDA3 (*(volatile uint32_t *) (CAN2_BASE_ADDR + 0x58))
1071#define CAN2TDB3 (*(volatile uint32_t *) (CAN2_BASE_ADDR + 0x5C))
1072
1073
1074/* MultiMedia Card Interface(MCI) Controller */
1075#ifdef ARM_MULTILIB_ARCH_V4
1076 #define MCI_BASE_ADDR 0xE008C000
1077#else
1078 #define MCI_BASE_ADDR 0x400c0000
1079#endif
1080#define MCI_POWER (*(volatile uint32_t *) (MCI_BASE_ADDR + 0x00))
1081#define MCI_CLOCK (*(volatile uint32_t *) (MCI_BASE_ADDR + 0x04))
1082#define MCI_ARGUMENT (*(volatile uint32_t *) (MCI_BASE_ADDR + 0x08))
1083#define MCI_COMMAND (*(volatile uint32_t *) (MCI_BASE_ADDR + 0x0C))
1084#define MCI_RESP_CMD (*(volatile uint32_t *) (MCI_BASE_ADDR + 0x10))
1085#define MCI_RESP0 (*(volatile uint32_t *) (MCI_BASE_ADDR + 0x14))
1086#define MCI_RESP1 (*(volatile uint32_t *) (MCI_BASE_ADDR + 0x18))
1087#define MCI_RESP2 (*(volatile uint32_t *) (MCI_BASE_ADDR + 0x1C))
1088#define MCI_RESP3 (*(volatile uint32_t *) (MCI_BASE_ADDR + 0x20))
1089#define MCI_DATA_TMR (*(volatile uint32_t *) (MCI_BASE_ADDR + 0x24))
1090#define MCI_DATA_LEN (*(volatile uint32_t *) (MCI_BASE_ADDR + 0x28))
1091#define MCI_DATA_CTRL (*(volatile uint32_t *) (MCI_BASE_ADDR + 0x2C))
1092#define MCI_DATA_CNT (*(volatile uint32_t *) (MCI_BASE_ADDR + 0x30))
1093#define MCI_STATUS (*(volatile uint32_t *) (MCI_BASE_ADDR + 0x34))
1094#define MCI_CLEAR (*(volatile uint32_t *) (MCI_BASE_ADDR + 0x38))
1095#define MCI_MASK0 (*(volatile uint32_t *) (MCI_BASE_ADDR + 0x3C))
1096#define MCI_MASK1 (*(volatile uint32_t *) (MCI_BASE_ADDR + 0x40))
1097#define MCI_FIFO_CNT (*(volatile uint32_t *) (MCI_BASE_ADDR + 0x48))
1098#define MCI_FIFO (*(volatile uint32_t *) (MCI_BASE_ADDR + 0x80))
1099
1100
1101/* I2S Interface Controller (I2S) */
1102#ifdef ARM_MULTILIB_ARCH_V4
1103 #define I2S_BASE_ADDR 0xE0088000
1104#else
1105 #define I2S_BASE_ADDR 0x400a8000
1106#endif
1107#define I2S_DAO (*(volatile uint32_t *) (I2S_BASE_ADDR + 0x00))
1108#define I2S_DAI (*(volatile uint32_t *) (I2S_BASE_ADDR + 0x04))
1109#define I2S_TX_FIFO (*(volatile uint32_t *) (I2S_BASE_ADDR + 0x08))
1110#define I2S_RX_FIFO (*(volatile uint32_t *) (I2S_BASE_ADDR + 0x0C))
1111#define I2S_STATE (*(volatile uint32_t *) (I2S_BASE_ADDR + 0x10))
1112#define I2S_DMA1 (*(volatile uint32_t *) (I2S_BASE_ADDR + 0x14))
1113#define I2S_DMA2 (*(volatile uint32_t *) (I2S_BASE_ADDR + 0x18))
1114#define I2S_IRQ (*(volatile uint32_t *) (I2S_BASE_ADDR + 0x1C))
1115#define I2S_TXRATE (*(volatile uint32_t *) (I2S_BASE_ADDR + 0x20))
1116#define I2S_RXRATE (*(volatile uint32_t *) (I2S_BASE_ADDR + 0x24))
1117
1118
1119/* General-purpose DMA Controller */
1120#ifdef ARM_MULTILIB_ARCH_V4
1121 #define DMA_BASE_ADDR 0xFFE04000
1122#else
1123 #define DMA_BASE_ADDR 0x20080000
1124#endif
1125#define GPDMA_INT_STAT (*(volatile uint32_t *) (DMA_BASE_ADDR + 0x000))
1126#define GPDMA_INT_TCSTAT (*(volatile uint32_t *) (DMA_BASE_ADDR + 0x004))
1127#define GPDMA_INT_TCCLR (*(volatile uint32_t *) (DMA_BASE_ADDR + 0x008))
1128#define GPDMA_INT_ERR_STAT (*(volatile uint32_t *) (DMA_BASE_ADDR + 0x00C))
1129#define GPDMA_INT_ERR_CLR (*(volatile uint32_t *) (DMA_BASE_ADDR + 0x010))
1130#define GPDMA_RAW_INT_TCSTAT (*(volatile uint32_t *) (DMA_BASE_ADDR + 0x014))
1131#define GPDMA_RAW_INT_ERR_STAT (*(volatile uint32_t *) (DMA_BASE_ADDR + 0x018))
1132#define GPDMA_ENABLED_CHNS (*(volatile uint32_t *) (DMA_BASE_ADDR + 0x01C))
1133#define GPDMA_SOFT_BREQ (*(volatile uint32_t *) (DMA_BASE_ADDR + 0x020))
1134#define GPDMA_SOFT_SREQ (*(volatile uint32_t *) (DMA_BASE_ADDR + 0x024))
1135#define GPDMA_SOFT_LBREQ (*(volatile uint32_t *) (DMA_BASE_ADDR + 0x028))
1136#define GPDMA_SOFT_LSREQ (*(volatile uint32_t *) (DMA_BASE_ADDR + 0x02C))
1137#define GPDMA_CONFIG (*(volatile uint32_t *) (DMA_BASE_ADDR + 0x030))
1138#define GPDMA_SYNC (*(volatile uint32_t *) (DMA_BASE_ADDR + 0x034))
1139
1140/* DMA channel 0 registers */
1141#define GPDMA_CH0_BASE_ADDR (DMA_BASE_ADDR + 0x100)
1142#define GPDMA_CH0_SRC (*(volatile uint32_t *) (DMA_BASE_ADDR + 0x100))
1143#define GPDMA_CH0_DEST (*(volatile uint32_t *) (DMA_BASE_ADDR + 0x104))
1144#define GPDMA_CH0_LLI (*(volatile uint32_t *) (DMA_BASE_ADDR + 0x108))
1145#define GPDMA_CH0_CTRL (*(volatile uint32_t *) (DMA_BASE_ADDR + 0x10C))
1146#define GPDMA_CH0_CFG (*(volatile uint32_t *) (DMA_BASE_ADDR + 0x110))
1147
1148/* DMA channel 1 registers */
1149#define GPDMA_CH1_BASE_ADDR (DMA_BASE_ADDR + 0x120)
1150#define GPDMA_CH1_SRC (*(volatile uint32_t *) (DMA_BASE_ADDR + 0x120))
1151#define GPDMA_CH1_DEST (*(volatile uint32_t *) (DMA_BASE_ADDR + 0x124))
1152#define GPDMA_CH1_LLI (*(volatile uint32_t *) (DMA_BASE_ADDR + 0x128))
1153#define GPDMA_CH1_CTRL (*(volatile uint32_t *) (DMA_BASE_ADDR + 0x12C))
1154#define GPDMA_CH1_CFG (*(volatile uint32_t *) (DMA_BASE_ADDR + 0x130))
1155
1156/* USB Controller */
1157#ifdef ARM_MULTILIB_ARCH_V4
1158 #define USB_INT_BASE_ADDR 0xE01FC1C0
1159 #define USB_BASE_ADDR 0xFFE0C200 /* USB Base Address */
1160#else
1161 #define USB_INT_BASE_ADDR 0x400fc1c0
1162 #define USB_BASE_ADDR 0x2008c200
1163#endif
1164
1165#define USB_INT_STAT (*(volatile uint32_t *) (USB_INT_BASE_ADDR + 0x00))
1166
1167/* USB Device Interrupt Registers */
1168#define DEV_INT_STAT (*(volatile uint32_t *) (USB_BASE_ADDR + 0x00))
1169#define DEV_INT_EN (*(volatile uint32_t *) (USB_BASE_ADDR + 0x04))
1170#define DEV_INT_CLR (*(volatile uint32_t *) (USB_BASE_ADDR + 0x08))
1171#define DEV_INT_SET (*(volatile uint32_t *) (USB_BASE_ADDR + 0x0C))
1172#define DEV_INT_PRIO (*(volatile uint32_t *) (USB_BASE_ADDR + 0x2C))
1173
1174/* USB Device Endpoint Interrupt Registers */
1175#define EP_INT_STAT (*(volatile uint32_t *) (USB_BASE_ADDR + 0x30))
1176#define EP_INT_EN (*(volatile uint32_t *) (USB_BASE_ADDR + 0x34))
1177#define EP_INT_CLR (*(volatile uint32_t *) (USB_BASE_ADDR + 0x38))
1178#define EP_INT_SET (*(volatile uint32_t *) (USB_BASE_ADDR + 0x3C))
1179#define EP_INT_PRIO (*(volatile uint32_t *) (USB_BASE_ADDR + 0x40))
1180
1181/* USB Device Endpoint Realization Registers */
1182#define REALIZE_EP (*(volatile uint32_t *) (USB_BASE_ADDR + 0x44))
1183#define EP_INDEX (*(volatile uint32_t *) (USB_BASE_ADDR + 0x48))
1184#define MAXPACKET_SIZE (*(volatile uint32_t *) (USB_BASE_ADDR + 0x4C))
1185
1186/* USB Device Command Reagisters */
1187#define CMD_CODE (*(volatile uint32_t *) (USB_BASE_ADDR + 0x10))
1188#define CMD_DATA (*(volatile uint32_t *) (USB_BASE_ADDR + 0x14))
1189
1190/* USB Device Data Transfer Registers */
1191#define RX_DATA (*(volatile uint32_t *) (USB_BASE_ADDR + 0x18))
1192#define TX_DATA (*(volatile uint32_t *) (USB_BASE_ADDR + 0x1C))
1193#define RX_PLENGTH (*(volatile uint32_t *) (USB_BASE_ADDR + 0x20))
1194#define TX_PLENGTH (*(volatile uint32_t *) (USB_BASE_ADDR + 0x24))
1195#define USB_CTRL (*(volatile uint32_t *) (USB_BASE_ADDR + 0x28))
1196
1197/* USB Device DMA Registers */
1198#define DMA_REQ_STAT (*(volatile uint32_t *) (USB_BASE_ADDR + 0x50))
1199#define DMA_REQ_CLR (*(volatile uint32_t *) (USB_BASE_ADDR + 0x54))
1200#define DMA_REQ_SET (*(volatile uint32_t *) (USB_BASE_ADDR + 0x58))
1201#define UDCA_HEAD (*(volatile uint32_t *) (USB_BASE_ADDR + 0x80))
1202#define EP_DMA_STAT (*(volatile uint32_t *) (USB_BASE_ADDR + 0x84))
1203#define EP_DMA_EN (*(volatile uint32_t *) (USB_BASE_ADDR + 0x88))
1204#define EP_DMA_DIS (*(volatile uint32_t *) (USB_BASE_ADDR + 0x8C))
1205#define DMA_INT_STAT (*(volatile uint32_t *) (USB_BASE_ADDR + 0x90))
1206#define DMA_INT_EN (*(volatile uint32_t *) (USB_BASE_ADDR + 0x94))
1207#define EOT_INT_STAT (*(volatile uint32_t *) (USB_BASE_ADDR + 0xA0))
1208#define EOT_INT_CLR (*(volatile uint32_t *) (USB_BASE_ADDR + 0xA4))
1209#define EOT_INT_SET (*(volatile uint32_t *) (USB_BASE_ADDR + 0xA8))
1210#define NDD_REQ_INT_STAT (*(volatile uint32_t *) (USB_BASE_ADDR + 0xAC))
1211#define NDD_REQ_INT_CLR (*(volatile uint32_t *) (USB_BASE_ADDR + 0xB0))
1212#define NDD_REQ_INT_SET (*(volatile uint32_t *) (USB_BASE_ADDR + 0xB4))
1213#define SYS_ERR_INT_STAT (*(volatile uint32_t *) (USB_BASE_ADDR + 0xB8))
1214#define SYS_ERR_INT_CLR (*(volatile uint32_t *) (USB_BASE_ADDR + 0xBC))
1215#define SYS_ERR_INT_SET (*(volatile uint32_t *) (USB_BASE_ADDR + 0xC0))
1216
1217/* USB Host Controller */
1218#ifdef ARM_MULTILIB_ARCH_V4
1219 #define USBHC_BASE_ADDR 0xFFE0C000
1220#else
1221 #define USBHC_BASE_ADDR 0x2008c000
1222#endif
1223#define HC_REVISION (*(volatile uint32_t *) (USBHC_BASE_ADDR + 0x00))
1224#define HC_CONTROL (*(volatile uint32_t *) (USBHC_BASE_ADDR + 0x04))
1225#define HC_CMD_STAT (*(volatile uint32_t *) (USBHC_BASE_ADDR + 0x08))
1226#define HC_INT_STAT (*(volatile uint32_t *) (USBHC_BASE_ADDR + 0x0C))
1227#define HC_INT_EN (*(volatile uint32_t *) (USBHC_BASE_ADDR + 0x10))
1228#define HC_INT_DIS (*(volatile uint32_t *) (USBHC_BASE_ADDR + 0x14))
1229#define HC_HCCA (*(volatile uint32_t *) (USBHC_BASE_ADDR + 0x18))
1230#define HC_PERIOD_CUR_ED (*(volatile uint32_t *) (USBHC_BASE_ADDR + 0x1C))
1231#define HC_CTRL_HEAD_ED (*(volatile uint32_t *) (USBHC_BASE_ADDR + 0x20))
1232#define HC_CTRL_CUR_ED (*(volatile uint32_t *) (USBHC_BASE_ADDR + 0x24))
1233#define HC_BULK_HEAD_ED (*(volatile uint32_t *) (USBHC_BASE_ADDR + 0x28))
1234#define HC_BULK_CUR_ED (*(volatile uint32_t *) (USBHC_BASE_ADDR + 0x2C))
1235#define HC_DONE_HEAD (*(volatile uint32_t *) (USBHC_BASE_ADDR + 0x30))
1236#define HC_FM_INTERVAL (*(volatile uint32_t *) (USBHC_BASE_ADDR + 0x34))
1237#define HC_FM_REMAINING (*(volatile uint32_t *) (USBHC_BASE_ADDR + 0x38))
1238#define HC_FM_NUMBER (*(volatile uint32_t *) (USBHC_BASE_ADDR + 0x3C))
1239#define HC_PERIOD_START (*(volatile uint32_t *) (USBHC_BASE_ADDR + 0x40))
1240#define HC_LS_THRHLD (*(volatile uint32_t *) (USBHC_BASE_ADDR + 0x44))
1241#define HC_RH_DESCA (*(volatile uint32_t *) (USBHC_BASE_ADDR + 0x48))
1242#define HC_RH_DESCB (*(volatile uint32_t *) (USBHC_BASE_ADDR + 0x4C))
1243#define HC_RH_STAT (*(volatile uint32_t *) (USBHC_BASE_ADDR + 0x50))
1244#define HC_RH_PORT_STAT1 (*(volatile uint32_t *) (USBHC_BASE_ADDR + 0x54))
1245#define HC_RH_PORT_STAT2 (*(volatile uint32_t *) (USBHC_BASE_ADDR + 0x58))
1246
1247/* USB OTG Controller */
1248#ifdef ARM_MULTILIB_ARCH_V4
1249 #define USBOTG_BASE_ADDR 0xFFE0C100
1250#else
1251 #define USBOTG_BASE_ADDR 0x2008c100
1252#endif
1253#define OTG_INT_STAT (*(volatile uint32_t *) (USBOTG_BASE_ADDR + 0x00))
1254#define OTG_INT_EN (*(volatile uint32_t *) (USBOTG_BASE_ADDR + 0x04))
1255#define OTG_INT_SET (*(volatile uint32_t *) (USBOTG_BASE_ADDR + 0x08))
1256#define OTG_INT_CLR (*(volatile uint32_t *) (USBOTG_BASE_ADDR + 0x0C))
1257#define OTG_STAT_CTRL (*(volatile uint32_t *) (USBOTG_BASE_ADDR + 0x10))
1258#define OTG_TIMER (*(volatile uint32_t *) (USBOTG_BASE_ADDR + 0x14))
1259
1260#ifdef ARM_MULTILIB_ARCH_V4
1261 #define USBOTG_I2C_BASE_ADDR 0xFFE0C300
1262#else
1263 #define USBOTG_I2C_BASE_ADDR 0x2008c300
1264#endif
1265#define OTG_I2C_RX (*(volatile uint32_t *) (USBOTG_I2C_BASE_ADDR + 0x00))
1266#define OTG_I2C_TX (*(volatile uint32_t *) (USBOTG_I2C_BASE_ADDR + 0x00))
1267#define OTG_I2C_STS (*(volatile uint32_t *) (USBOTG_I2C_BASE_ADDR + 0x04))
1268#define OTG_I2C_CTL (*(volatile uint32_t *) (USBOTG_I2C_BASE_ADDR + 0x08))
1269#define OTG_I2C_CLKHI (*(volatile uint32_t *) (USBOTG_I2C_BASE_ADDR + 0x0C))
1270#define OTG_I2C_CLKLO (*(volatile uint32_t *) (USBOTG_I2C_BASE_ADDR + 0x10))
1271
1272#ifdef ARM_MULTILIB_ARCH_V4
1273 #define USBOTG_CLK_BASE_ADDR 0xFFE0CFF0
1274#else
1275 #define USBOTG_CLK_BASE_ADDR 0x2008cff0
1276#endif
1277#define OTG_CLK_CTRL (*(volatile uint32_t *) (USBOTG_CLK_BASE_ADDR + 0x04))
1278#define OTG_CLK_STAT (*(volatile uint32_t *) (USBOTG_CLK_BASE_ADDR + 0x08))
1279
1280/* Ethernet MAC (32 bit data bus) -- all registers are RW unless indicated in parentheses */
1281#ifdef ARM_MULTILIB_ARCH_V4
1282 #define MAC_BASE_ADDR 0xFFE00000 /* AHB Peripheral # 0 */
1283#else
1284 #define MAC_BASE_ADDR 0x20084000
1285#endif
1286#define MAC_MAC1 (*(volatile uint32_t *) (MAC_BASE_ADDR + 0x000)) /* MAC config reg 1 */
1287#define MAC_MAC2 (*(volatile uint32_t *) (MAC_BASE_ADDR + 0x004)) /* MAC config reg 2 */
1288#define MAC_IPGT (*(volatile uint32_t *) (MAC_BASE_ADDR + 0x008)) /* b2b InterPacketGap reg */
1289#define MAC_IPGR (*(volatile uint32_t *) (MAC_BASE_ADDR + 0x00C)) /* non b2b InterPacketGap reg */
1290#define MAC_CLRT (*(volatile uint32_t *) (MAC_BASE_ADDR + 0x010)) /* CoLlision window/ReTry reg */
1291#define MAC_MAXF (*(volatile uint32_t *) (MAC_BASE_ADDR + 0x014)) /* MAXimum Frame reg */
1292#define MAC_SUPP (*(volatile uint32_t *) (MAC_BASE_ADDR + 0x018)) /* PHY SUPPort reg */
1293#define MAC_TEST (*(volatile uint32_t *) (MAC_BASE_ADDR + 0x01C)) /* TEST reg */
1294#define MAC_MCFG (*(volatile uint32_t *) (MAC_BASE_ADDR + 0x020)) /* MII Mgmt ConFiG reg */
1295#define MAC_MCMD (*(volatile uint32_t *) (MAC_BASE_ADDR + 0x024)) /* MII Mgmt CoMmanD reg */
1296#define MAC_MADR (*(volatile uint32_t *) (MAC_BASE_ADDR + 0x028)) /* MII Mgmt ADdRess reg */
1297#define MAC_MWTD (*(volatile uint32_t *) (MAC_BASE_ADDR + 0x02C)) /* MII Mgmt WriTe Data reg (WO) */
1298#define MAC_MRDD (*(volatile uint32_t *) (MAC_BASE_ADDR + 0x030)) /* MII Mgmt ReaD Data reg (RO) */
1299#define MAC_MIND (*(volatile uint32_t *) (MAC_BASE_ADDR + 0x034)) /* MII Mgmt INDicators reg (RO) */
1300
1301#define MAC_SA0 (*(volatile uint32_t *) (MAC_BASE_ADDR + 0x040)) /* Station Address 0 reg */
1302#define MAC_SA1 (*(volatile uint32_t *) (MAC_BASE_ADDR + 0x044)) /* Station Address 1 reg */
1303#define MAC_SA2 (*(volatile uint32_t *) (MAC_BASE_ADDR + 0x048)) /* Station Address 2 reg */
1304
1305#define MAC_COMMAND (*(volatile uint32_t *) (MAC_BASE_ADDR + 0x100)) /* Command reg */
1306#define MAC_STATUS (*(volatile uint32_t *) (MAC_BASE_ADDR + 0x104)) /* Status reg (RO) */
1307#define MAC_RXDESCRIPTOR (*(volatile uint32_t *) (MAC_BASE_ADDR + 0x108)) /* Rx descriptor base address reg */
1308#define MAC_RXSTATUS (*(volatile uint32_t *) (MAC_BASE_ADDR + 0x10C)) /* Rx status base address reg */
1309#define MAC_RXDESCRIPTORNUM (*(volatile uint32_t *) (MAC_BASE_ADDR + 0x110)) /* Rx number of descriptors reg */
1310#define MAC_RXPRODUCEINDEX (*(volatile uint32_t *) (MAC_BASE_ADDR + 0x114)) /* Rx produce index reg (RO) */
1311#define MAC_RXCONSUMEINDEX (*(volatile uint32_t *) (MAC_BASE_ADDR + 0x118)) /* Rx consume index reg */
1312#define MAC_TXDESCRIPTOR (*(volatile uint32_t *) (MAC_BASE_ADDR + 0x11C)) /* Tx descriptor base address reg */
1313#define MAC_TXSTATUS (*(volatile uint32_t *) (MAC_BASE_ADDR + 0x120)) /* Tx status base address reg */
1314#define MAC_TXDESCRIPTORNUM (*(volatile uint32_t *) (MAC_BASE_ADDR + 0x124)) /* Tx number of descriptors reg */
1315#define MAC_TXPRODUCEINDEX (*(volatile uint32_t *) (MAC_BASE_ADDR + 0x128)) /* Tx produce index reg */
1316#define MAC_TXCONSUMEINDEX (*(volatile uint32_t *) (MAC_BASE_ADDR + 0x12C)) /* Tx consume index reg (RO) */
1317
1318#define MAC_TSV0 (*(volatile uint32_t *) (MAC_BASE_ADDR + 0x158)) /* Tx status vector 0 reg (RO) */
1319#define MAC_TSV1 (*(volatile uint32_t *) (MAC_BASE_ADDR + 0x15C)) /* Tx status vector 1 reg (RO) */
1320#define MAC_RSV (*(volatile uint32_t *) (MAC_BASE_ADDR + 0x160)) /* Rx status vector reg (RO) */
1321
1322#define MAC_FLOWCONTROLCNT (*(volatile uint32_t *) (MAC_BASE_ADDR + 0x170)) /* Flow control counter reg */
1323#define MAC_FLOWCONTROLSTS (*(volatile uint32_t *) (MAC_BASE_ADDR + 0x174)) /* Flow control status reg */
1324
1325#define MAC_RXFILTERCTRL (*(volatile uint32_t *) (MAC_BASE_ADDR + 0x200)) /* Rx filter ctrl reg */
1326#define MAC_RXFILTERWOLSTS (*(volatile uint32_t *) (MAC_BASE_ADDR + 0x204)) /* Rx filter WoL status reg (RO) */
1327#define MAC_RXFILTERWOLCLR (*(volatile uint32_t *) (MAC_BASE_ADDR + 0x208)) /* Rx filter WoL clear reg (WO) */
1328
1329#define MAC_HASHFILTERL (*(volatile uint32_t *) (MAC_BASE_ADDR + 0x210)) /* Hash filter LSBs reg */
1330#define MAC_HASHFILTERH (*(volatile uint32_t *) (MAC_BASE_ADDR + 0x214)) /* Hash filter MSBs reg */
1331
1332#define MAC_INTSTATUS (*(volatile uint32_t *) (MAC_BASE_ADDR + 0xFE0)) /* Interrupt status reg (RO) */
1333#define MAC_INTENABLE (*(volatile uint32_t *) (MAC_BASE_ADDR + 0xFE4)) /* Interrupt enable reg */
1334#define MAC_INTCLEAR (*(volatile uint32_t *) (MAC_BASE_ADDR + 0xFE8)) /* Interrupt clear reg (WO) */
1335#define MAC_INTSET (*(volatile uint32_t *) (MAC_BASE_ADDR + 0xFEC)) /* Interrupt set reg (WO) */
1336
1337#define MAC_POWERDOWN (*(volatile uint32_t *) (MAC_BASE_ADDR + 0xFF4)) /* Power-down reg */
1338#define MAC_MODULEID (*(volatile uint32_t *) (MAC_BASE_ADDR + 0xFFC)) /* Module ID reg (RO) */
1339
1340/* LCD Controller */
1341
1342#ifdef ARM_MULTILIB_ARCH_V4
1343 #define LCD_CFG (*(volatile uint32_t *) 0xE01FC1B8)
1344 #define LCD_BASE_ADDR 0xFFE10000
1345#else
1346 #define LCD_CFG (*(volatile uint32_t *) 0x400FC1B8)
1347 #define LCD_BASE_ADDR 0x20088000
1348#endif
1349#define LCD_TIMH (*(volatile uint32_t *) (LCD_BASE_ADDR + 0x000))
1350#define LCD_TIMV (*(volatile uint32_t *) (LCD_BASE_ADDR + 0x004))
1351#define LCD_POL (*(volatile uint32_t *) (LCD_BASE_ADDR + 0x008))
1352#define LCD_LE (*(volatile uint32_t *) (LCD_BASE_ADDR + 0x00C))
1353#define LCD_UPBASE (*(volatile uint32_t *) (LCD_BASE_ADDR + 0x010))
1354#define LCD_LPBASE (*(volatile uint32_t *) (LCD_BASE_ADDR + 0x014))
1355#define LCD_CTRL (*(volatile uint32_t *) (LCD_BASE_ADDR + 0x018))
1356#define LCD_INTMSK (*(volatile uint32_t *) (LCD_BASE_ADDR + 0x01C))
1357#define LCD_INTRAW (*(volatile uint32_t *) (LCD_BASE_ADDR + 0x020))
1358#define LCD_INTSTAT (*(volatile uint32_t *) (LCD_BASE_ADDR + 0x024))
1359#define LCD_INTCLR (*(volatile uint32_t *) (LCD_BASE_ADDR + 0x028))
1360#define LCD_UPCURR (*(volatile uint32_t *) (LCD_BASE_ADDR + 0x02C))
1361#define LCD_LPCURR (*(volatile uint32_t *) (LCD_BASE_ADDR + 0x030))
1362#define LCD_PAL_ADDR (*(volatile uint32_t *) (LCD_BASE_ADDR + 0x200))
1363#define CRSR_IMG (*(volatile uint32_t *) (LCD_BASE_ADDR + 0x800))
1364#define CRSR_CTLR (*(volatile uint32_t *) (LCD_BASE_ADDR + 0xC00))
1365#define CRSR_CFG (*(volatile uint32_t *) (LCD_BASE_ADDR + 0xC04))
1366#define CRSR_PAL0 (*(volatile uint32_t *) (LCD_BASE_ADDR + 0xC08))
1367#define CRSR_PAL1 (*(volatile uint32_t *) (LCD_BASE_ADDR + 0xC0C))
1368#define CRSR_XY (*(volatile uint32_t *) (LCD_BASE_ADDR + 0xC10))
1369#define CRSR_CLIP (*(volatile uint32_t *) (LCD_BASE_ADDR + 0xC14))
1370#define CRSR_INTMSK (*(volatile uint32_t *) (LCD_BASE_ADDR + 0xC20))
1371#define CRSR_INTCLR (*(volatile uint32_t *) (LCD_BASE_ADDR + 0xC24))
1372#define CRSR_INTRAW (*(volatile uint32_t *) (LCD_BASE_ADDR + 0xC28))
1373#define CRSR_INTSTAT (*(volatile uint32_t *) (LCD_BASE_ADDR + 0xC2C))
1374
1375/* Register Fields */
1376
1377#define GET_FIELD( val, mask, shift) \
1378 (((val) & (mask)) >> (shift))
1379
1380#define SET_FIELD( val, field, mask, shift) \
1381 (((val) & ~(mask)) | (((field) << (shift)) & (mask)))
1382
1383/* CLKSRCSEL */
1384
1385#define CLKSRCSEL_CLKSRC_MASK 0x00000003U
1386
1387#define GET_CLKSRCSEL_CLKSRC(reg) \
1388 GET_FIELD(reg, CLKSRCSEL_CLKSRC_MASK, 0)
1389
1390#define SET_CLKSRCSEL_CLKSRC(reg, val) \
1391 SET_FIELD(reg, val, CLKSRCSEL_CLKSRC_MASK, 0)
1392
1393/* PLLCON */
1394
1395#define PLLCON_PLLE 0x00000001U
1396
1397#define PLLCON_PLLC 0x00000002U
1398
1399/* PLLCFG */
1400
1401#define PLLCFG_MSEL_MASK 0x00007fffU
1402
1403#define GET_PLLCFG_MSEL(reg) \
1404 GET_FIELD(reg, PLLCFG_MSEL_MASK, 0)
1405
1406#define SET_PLLCFG_MSEL(reg, val) \
1407 SET_FIELD(reg, val, PLLCFG_MSEL_MASK, 0)
1408
1409#define PLLCFG_NSEL_MASK 0x00ff0000U
1410
1411#define GET_PLLCFG_NSEL(reg) \
1412 GET_FIELD(reg, PLLCFG_NSEL_MASK, 16)
1413
1414#define SET_PLLCFG_NSEL(reg, val) \
1415 SET_FIELD(reg, val, PLLCFG_NSEL_MASK, 16)
1416
1417/* PLLSTAT */
1418
1419#define PLLSTAT_MSEL_MASK 0x00007fffU
1420
1421#define GET_PLLSTAT_MSEL(reg) \
1422 GET_FIELD(reg, PLLSTAT_MSEL_MASK, 0)
1423
1424#define SET_PLLSTAT_MSEL(reg, val) \
1425 SET_FIELD(reg, val, PLLSTAT_MSEL_MASK, 0)
1426
1427#define PLLSTAT_NSEL_MASK 0x00ff0000U
1428
1429#define GET_PLLSTAT_NSEL(reg) \
1430 GET_FIELD(reg, PLLSTAT_NSEL_MASK, 16)
1431
1432#define SET_PLLSTAT_NSEL(reg, val) \
1433 SET_FIELD(reg, val, PLLSTAT_NSEL_MASK, 16)
1434
1435#define PLLSTAT_PLLE 0x01000000U
1436
1437#define PLLSTAT_PLLC 0x02000000U
1438
1439#define PLLSTAT_PLOCK 0x04000000U
1440
1441/* CCLKCFG */
1442
1443#define CCLKCFG_CCLKSEL_MASK 0x000000ffU
1444
1445#define GET_CCLKCFG_CCLKSEL(reg) \
1446 GET_FIELD(reg, CCLKCFG_CCLKSEL_MASK, 0)
1447
1448#define SET_CCLKCFG_CCLKSEL(reg, val) \
1449 SET_FIELD(reg, val, CCLKCFG_CCLKSEL_MASK, 0)
1450
1451/* MEMMAP */
1452
1453#define MEMMAP_MAP_MASK 0x00000003U
1454
1455#define GET_MEMMAP_MAP(reg) \
1456 GET_FIELD(reg, MEMMAP_MAP_MASK, 0)
1457
1458#define SET_MEMMAP_MAP(reg, val) \
1459 SET_FIELD(reg, val, MEMMAP_MAP_MASK, 0)
1460
1461/* TIR */
1462
1463#define TIR_MR0 0x00000001U
1464
1465#define TIR_MR1 0x00000002U
1466
1467#define TIR_MR2 0x00000004U
1468
1469#define TIR_MR3 0x00000008U
1470
1471#define TIR_CR0 0x00000010U
1472
1473#define TIR_CR1 0x00000020U
1474
1475#define TIR_CR2 0x00000040U
1476
1477#define TIR_CR3 0x00000080U
1478
1479/* TCR */
1480
1481#define TCR_EN 0x00000001U
1482
1483#define TCR_RST 0x00000002U
1484
1485/* TMCR */
1486
1487#define TMCR_MR0I 0x00000001U
1488
1489#define TMCR_MR0R 0x00000002U
1490
1491#define TMCR_MR0S 0x00000004U
1492
1493#define TMCR_MR1I 0x00000008U
1494
1495#define TMCR_MR1R 0x00000010U
1496
1497#define TMCR_MR1S 0x00000020U
1498
1499#define TMCR_MR2I 0x00000040U
1500
1501#define TMCR_MR2R 0x00000080U
1502
1503#define TMCR_MR2S 0x00000100U
1504
1505#define TMCR_MR3I 0x00000200U
1506
1507#define TMCR_MR3R 0x00000400U
1508
1509#define TMCR_MR3S 0x00000800U
1510
1511/* PCLKSEL0 */
1512
1513#define PCLKSEL0_PCLK_WDT_MASK 0x00000003U
1514
1515#define GET_PCLKSEL0_PCLK_WDT(reg) \
1516 GET_FIELD(reg, PCLKSEL0_PCLK_WDT_MASK, 0)
1517
1518#define SET_PCLKSEL0_PCLK_WDT(reg, val) \
1519 SET_FIELD(reg, val, PCLKSEL0_PCLK_WDT_MASK, 0)
1520
1521#define PCLKSEL0_PCLK_TIMER0_MASK 0x0000000cU
1522
1523#define GET_PCLKSEL0_PCLK_TIMER0(reg) \
1524 GET_FIELD(reg, PCLKSEL0_PCLK_TIMER0_MASK, 2)
1525
1526#define SET_PCLKSEL0_PCLK_TIMER0(reg, val) \
1527 SET_FIELD(reg, val, PCLKSEL0_PCLK_TIMER0_MASK, 2)
1528
1529#define PCLKSEL0_PCLK_TIMER1_MASK 0x00000030U
1530
1531#define GET_PCLKSEL0_PCLK_TIMER1(reg) \
1532 GET_FIELD(reg, PCLKSEL0_PCLK_TIMER1_MASK, 4)
1533
1534#define SET_PCLKSEL0_PCLK_TIMER1(reg, val) \
1535 SET_FIELD(reg, val, PCLKSEL0_PCLK_TIMER1_MASK, 4)
1536
1537#define PCLKSEL0_PCLK_UART0_MASK 0x000000c0U
1538
1539#define GET_PCLKSEL0_PCLK_UART0(reg) \
1540 GET_FIELD(reg, PCLKSEL0_PCLK_UART0_MASK, 6)
1541
1542#define SET_PCLKSEL0_PCLK_UART0(reg, val) \
1543 SET_FIELD(reg, val, PCLKSEL0_PCLK_UART0_MASK, 6)
1544
1545#define PCLKSEL0_PCLK_UART1_MASK 0x00000300U
1546
1547#define GET_PCLKSEL0_PCLK_UART1(reg) \
1548 GET_FIELD(reg, PCLKSEL0_PCLK_UART1_MASK, 8)
1549
1550#define SET_PCLKSEL0_PCLK_UART1(reg, val) \
1551 SET_FIELD(reg, val, PCLKSEL0_PCLK_UART1_MASK, 8)
1552
1553#define PCLKSEL0_PCLK_PWM0_MASK 0x00000c00U
1554
1555#define GET_PCLKSEL0_PCLK_PWM0(reg) \
1556 GET_FIELD(reg, PCLKSEL0_PCLK_PWM0_MASK, 10)
1557
1558#define SET_PCLKSEL0_PCLK_PWM0(reg, val) \
1559 SET_FIELD(reg, val, PCLKSEL0_PCLK_PWM0_MASK, 10)
1560
1561#define PCLKSEL0_PCLK_PWM1_MASK 0x00003000U
1562
1563#define GET_PCLKSEL0_PCLK_PWM1(reg) \
1564 GET_FIELD(reg, PCLKSEL0_PCLK_PWM1_MASK, 12)
1565
1566#define SET_PCLKSEL0_PCLK_PWM1(reg, val) \
1567 SET_FIELD(reg, val, PCLKSEL0_PCLK_PWM1_MASK, 12)
1568
1569#define PCLKSEL0_PCLK_I2C0_MASK 0x0000c000U
1570
1571#define GET_PCLKSEL0_PCLK_I2C0(reg) \
1572 GET_FIELD(reg, PCLKSEL0_PCLK_I2C0_MASK, 14)
1573
1574#define SET_PCLKSEL0_PCLK_I2C0(reg, val) \
1575 SET_FIELD(reg, val, PCLKSEL0_PCLK_I2C0_MASK, 14)
1576
1577#define PCLKSEL0_PCLK_SPI_MASK 0x00030000U
1578
1579#define GET_PCLKSEL0_PCLK_SPI(reg) \
1580 GET_FIELD(reg, PCLKSEL0_PCLK_SPI_MASK, 16)
1581
1582#define SET_PCLKSEL0_PCLK_SPI(reg, val) \
1583 SET_FIELD(reg, val, PCLKSEL0_PCLK_SPI_MASK, 16)
1584
1585#define PCLKSEL0_PCLK_RTC_MASK 0x000c0000U
1586
1587#define GET_PCLKSEL0_PCLK_RTC(reg) \
1588 GET_FIELD(reg, PCLKSEL0_PCLK_RTC_MASK, 18)
1589
1590#define SET_PCLKSEL0_PCLK_RTC(reg, val) \
1591 SET_FIELD(reg, val, PCLKSEL0_PCLK_RTC_MASK, 18)
1592
1593#define PCLKSEL0_PCLK_SSP1_MASK 0x00300000U
1594
1595#define GET_PCLKSEL0_PCLK_SSP1(reg) \
1596 GET_FIELD(reg, PCLKSEL0_PCLK_SSP1_MASK, 20)
1597
1598#define SET_PCLKSEL0_PCLK_SSP1(reg, val) \
1599 SET_FIELD(reg, val, PCLKSEL0_PCLK_SSP1_MASK, 20)
1600
1601#define PCLKSEL0_PCLK_DAC_MASK 0x00c00000U
1602
1603#define GET_PCLKSEL0_PCLK_DAC(reg) \
1604 GET_FIELD(reg, PCLKSEL0_PCLK_DAC_MASK, 22)
1605
1606#define SET_PCLKSEL0_PCLK_DAC(reg, val) \
1607 SET_FIELD(reg, val, PCLKSEL0_PCLK_DAC_MASK, 22)
1608
1609#define PCLKSEL0_PCLK_ADC_MASK 0x03000000U
1610
1611#define GET_PCLKSEL0_PCLK_ADC(reg) \
1612 GET_FIELD(reg, PCLKSEL0_PCLK_ADC_MASK, 24)
1613
1614#define SET_PCLKSEL0_PCLK_ADC(reg, val) \
1615 SET_FIELD(reg, val, PCLKSEL0_PCLK_ADC_MASK, 24)
1616
1617#define PCLKSEL0_PCLK_CAN1_MASK 0x0c000000U
1618
1619#define GET_PCLKSEL0_PCLK_CAN1(reg) \
1620 GET_FIELD(reg, PCLKSEL0_PCLK_CAN1_MASK, 26)
1621
1622#define SET_PCLKSEL0_PCLK_CAN1(reg, val) \
1623 SET_FIELD(reg, val, PCLKSEL0_PCLK_CAN1_MASK, 26)
1624
1625#define PCLKSEL0_PCLK_CAN2_MASK 0x30000000U
1626
1627#define GET_PCLKSEL0_PCLK_CAN2(reg) \
1628 GET_FIELD(reg, PCLKSEL0_PCLK_CAN2_MASK, 28)
1629
1630#define SET_PCLKSEL0_PCLK_CAN2(reg, val) \
1631 SET_FIELD(reg, val, PCLKSEL0_PCLK_CAN2_MASK, 28)
1632
1633/* PCLKSEL1 */
1634
1635#define PCLKSEL1_PCLK_BAT_RAM_MASK 0x00000003U
1636
1637#define GET_PCLKSEL1_PCLK_BAT_RAM(reg) \
1638 GET_FIELD(reg, PCLKSEL1_PCLK_BAT_RAM_MASK, 0)
1639
1640#define SET_PCLKSEL1_PCLK_BAT_RAM(reg, val) \
1641 SET_FIELD(reg, val, PCLKSEL1_PCLK_BAT_RAM_MASK, 0)
1642
1643#define PCLKSEL1_PCLK_GPIO_MASK 0x0000000cU
1644
1645#define GET_PCLKSEL1_PCLK_GPIO(reg) \
1646 GET_FIELD(reg, PCLKSEL1_PCLK_GPIO_MASK, 2)
1647
1648#define SET_PCLKSEL1_PCLK_GPIO(reg, val) \
1649 SET_FIELD(reg, val, PCLKSEL1_PCLK_GPIO_MASK, 2)
1650
1651#define PCLKSEL1_PCLK_PCB_MASK 0x00000030U
1652
1653#define GET_PCLKSEL1_PCLK_PCB(reg) \
1654 GET_FIELD(reg, PCLKSEL1_PCLK_PCB_MASK, 4)
1655
1656#define SET_PCLKSEL1_PCLK_PCB(reg, val) \
1657 SET_FIELD(reg, val, PCLKSEL1_PCLK_PCB_MASK, 4)
1658
1659#define PCLKSEL1_PCLK_I2C1_MASK 0x000000c0U
1660
1661#define GET_PCLKSEL1_PCLK_I2C1(reg) \
1662 GET_FIELD(reg, PCLKSEL1_PCLK_I2C1_MASK, 6)
1663
1664#define SET_PCLKSEL1_PCLK_I2C1(reg, val) \
1665 SET_FIELD(reg, val, PCLKSEL1_PCLK_I2C1_MASK, 6)
1666
1667#define PCLKSEL1_PCLK_SSP0_MASK 0x00000c00U
1668
1669#define GET_PCLKSEL1_PCLK_SSP0(reg) \
1670 GET_FIELD(reg, PCLKSEL1_PCLK_SSP0_MASK, 10)
1671
1672#define SET_PCLKSEL1_PCLK_SSP0(reg, val) \
1673 SET_FIELD(reg, val, PCLKSEL1_PCLK_SSP0_MASK, 10)
1674
1675#define PCLKSEL1_PCLK_TIMER2_MASK 0x00003000U
1676
1677#define GET_PCLKSEL1_PCLK_TIMER2(reg) \
1678 GET_FIELD(reg, PCLKSEL1_PCLK_TIMER2_MASK, 12)
1679
1680#define SET_PCLKSEL1_PCLK_TIMER2(reg, val) \
1681 SET_FIELD(reg, val, PCLKSEL1_PCLK_TIMER2_MASK, 12)
1682
1683#define PCLKSEL1_PCLK_TIMER3_MASK 0x0000c000U
1684
1685#define GET_PCLKSEL1_PCLK_TIMER3(reg) \
1686 GET_FIELD(reg, PCLKSEL1_PCLK_TIMER3_MASK, 14)
1687
1688#define SET_PCLKSEL1_PCLK_TIMER3(reg, val) \
1689 SET_FIELD(reg, val, PCLKSEL1_PCLK_TIMER3_MASK, 14)
1690
1691#define PCLKSEL1_PCLK_UART2_MASK 0x00030000U
1692
1693#define GET_PCLKSEL1_PCLK_UART2(reg) \
1694 GET_FIELD(reg, PCLKSEL1_PCLK_UART2_MASK, 16)
1695
1696#define SET_PCLKSEL1_PCLK_UART2(reg, val) \
1697 SET_FIELD(reg, val, PCLKSEL1_PCLK_UART2_MASK, 16)
1698
1699#define PCLKSEL1_PCLK_UART3_MASK 0x000c0000U
1700
1701#define GET_PCLKSEL1_PCLK_UART3(reg) \
1702 GET_FIELD(reg, PCLKSEL1_PCLK_UART3_MASK, 18)
1703
1704#define SET_PCLKSEL1_PCLK_UART3(reg, val) \
1705 SET_FIELD(reg, val, PCLKSEL1_PCLK_UART3_MASK, 18)
1706
1707#define PCLKSEL1_PCLK_I2C2_MASK 0x00300000U
1708
1709#define GET_PCLKSEL1_PCLK_I2C2(reg) \
1710 GET_FIELD(reg, PCLKSEL1_PCLK_I2C2_MASK, 20)
1711
1712#define SET_PCLKSEL1_PCLK_I2C2(reg, val) \
1713 SET_FIELD(reg, val, PCLKSEL1_PCLK_I2C2_MASK, 20)
1714
1715#define PCLKSEL1_PCLK_I2S_MASK 0x00c00000U
1716
1717#define GET_PCLKSEL1_PCLK_I2S(reg) \
1718 GET_FIELD(reg, PCLKSEL1_PCLK_I2S_MASK, 22)
1719
1720#define SET_PCLKSEL1_PCLK_I2S(reg, val) \
1721 SET_FIELD(reg, val, PCLKSEL1_PCLK_I2S_MASK, 22)
1722
1723#define PCLKSEL1_PCLK_MCI_MASK 0x03000000U
1724
1725#define GET_PCLKSEL1_PCLK_MCI(reg) \
1726 GET_FIELD(reg, PCLKSEL1_PCLK_MCI_MASK, 24)
1727
1728#define SET_PCLKSEL1_PCLK_MCI(reg, val) \
1729 SET_FIELD(reg, val, PCLKSEL1_PCLK_MCI_MASK, 24)
1730
1731#define PCLKSEL1_PCLK_SYSCON_MASK 0x30000000U
1732
1733#define GET_PCLKSEL1_PCLK_SYSCON(reg) \
1734 GET_FIELD(reg, PCLKSEL1_PCLK_SYSCON_MASK, 28)
1735
1736#define SET_PCLKSEL1_PCLK_SYSCON(reg, val) \
1737 SET_FIELD(reg, val, PCLKSEL1_PCLK_SYSCON_MASK, 28)
1738
1739/* RTC_ILR */
1740
1741#define RTC_ILR_RTCCIF 0x00000001U
1742
1743#define RTC_ILR_RTCALF 0x00000002U
1744
1745#define RTC_ILR_RTSSF 0x00000004U
1746
1747/* RTC_CCR */
1748
1749#define RTC_CCR_CLKEN 0x00000001U
1750
1751#define RTC_CCR_CTCRST 0x00000002U
1752
1753#define RTC_CCR_CLKSRC 0x00000010U
1754
1755/* SSP */
1756
1757typedef struct {
1758 uint32_t cr0;
1759 uint32_t cr1;
1760 uint32_t dr;
1761 uint32_t sr;
1762 uint32_t cpsr;
1763 uint32_t imsc;
1764 uint32_t ris;
1765 uint32_t mis;
1766 uint32_t icr;
1767 uint32_t dmacr;
1768} lpc24xx_ssp;
1769
1770/* SSP_CR0 */
1771
1772#define SSP_CR0_DSS_MASK 0x0000000fU
1773
1774#define GET_SSP_CR0_DSS(reg) \
1775 GET_FIELD(reg, SSP_CR0_DSS_MASK, 0)
1776
1777#define SET_SSP_CR0_DSS(reg, val) \
1778 SET_FIELD(reg, val, SSP_CR0_DSS_MASK, 0)
1779
1780#define SSP_CR0_FRF_MASK 0x00000030U
1781
1782#define GET_SSP_CR0_FRF(reg) \
1783 GET_FIELD(reg, SSP_CR0_FRF_MASK, 4)
1784
1785#define SET_SSP_CR0_FRF(reg, val) \
1786 SET_FIELD(reg, val, SSP_CR0_FRF_MASK, 4)
1787
1788#define SSP_CR0_CPOL 0x00000040U
1789
1790#define SSP_CR0_CPHA 0x00000080U
1791
1792#define SSP_CR0_SCR_MASK 0x0000ff00U
1793
1794#define GET_SSP_CR0_SCR(reg) \
1795 GET_FIELD(reg, SSP_CR0_SCR_MASK, 8)
1796
1797#define SET_SSP_CR0_SCR(reg, val) \
1798 SET_FIELD(reg, val, SSP_CR0_SCR_MASK, 8)
1799
1800/* SSP_CR1 */
1801
1802#define SSP_CR1_LBM 0x00000001U
1803
1804#define SSP_CR1_SSE 0x00000002U
1805
1806#define SSP_CR1_MS 0x00000004U
1807
1808#define SSP_CR1_SOD 0x00000008U
1809
1810/* SSP_SR */
1811
1812#define SSP_SR_TFE 0x00000001U
1813
1814#define SSP_SR_TNF 0x00000002U
1815
1816#define SSP_SR_RNE 0x00000004U
1817
1818#define SSP_SR_RFF 0x00000008U
1819
1820#define SSP_SR_BSY 0x00000010U
1821
1822/* SSP_IMSC */
1823
1824#define SSP_IMSC_RORIM 0x00000001U
1825
1826#define SSP_IMSC_RTIM 0x00000002U
1827
1828#define SSP_IMSC_RXIM 0x00000004U
1829
1830#define SSP_IMSC_TXIM 0x00000008U
1831
1832/* SSP_RIS */
1833
1834#define SSP_RIS_RORRIS 0x00000001U
1835
1836#define SSP_RIS_RTRIS 0x00000002U
1837
1838#define SSP_RIS_RXRIS 0x00000004U
1839
1840#define SSP_RIS_TXRIS 0x00000008U
1841
1842/* SSP_MIS */
1843
1844#define SSP_MIS_RORRIS 0x00000001U
1845
1846#define SSP_MIS_RTRIS 0x00000002U
1847
1848#define SSP_MIS_RXRIS 0x00000004U
1849
1850#define SSP_MIS_TXRIS 0x00000008U
1851
1852/* SSP_ICR */
1853
1854#define SSP_ICR_RORRIS 0x00000001U
1855
1856#define SSP_ICR_RTRIS 0x00000002U
1857
1858#define SSP_ICR_RXRIS 0x00000004U
1859
1860#define SSP_ICR_TXRIS 0x00000008U
1861
1862/* SSP_DMACR */
1863
1864#define SSP_DMACR_RXDMAE 0x00000001U
1865
1866#define SSP_DMACR_TXDMAE 0x00000002U
1867
1868/* GPDMA */
1869
1870typedef struct {
1871 uint32_t src;
1872 uint32_t dest;
1873 uint32_t lli;
1874 uint32_t ctrl;
1876
1877typedef struct {
1879 uint32_t cfg;
1881
1882#define GPDMA_CH_NUMBER 2
1883
1884#define GPDMA_STATUS_CH_0 0x00000001U
1885
1886#define GPDMA_STATUS_CH_1 0x00000002U
1887
1888#define GPDMA_CH_BASE_ADDR(i) \
1889 ((volatile lpc24xx_dma_channel *) \
1890 ((i) ? GPDMA_CH1_BASE_ADDR : GPDMA_CH0_BASE_ADDR))
1891
1892/* GPDMA_CONFIG */
1893
1894#define GPDMA_CONFIG_EN 0x00000001U
1895
1896#define GPDMA_CONFIG_MODE 0x00000002U
1897
1898/* GPDMA_ENABLED_CHNS */
1899
1900#define GPDMA_ENABLED_CHNS_CH0 0x00000001U
1901
1902#define GPDMA_ENABLED_CHNS_CH1 0x00000002U
1903
1904/* GPDMA_CH_CTRL */
1905
1906#define GPDMA_CH_CTRL_TSZ_MASK 0x00000fffU
1907
1908#define GET_GPDMA_CH_CTRL_TSZ(reg) \
1909 GET_FIELD(reg, GPDMA_CH_CTRL_TSZ_MASK, 0)
1910
1911#define SET_GPDMA_CH_CTRL_TSZ(reg, val) \
1912 SET_FIELD(reg, val, GPDMA_CH_CTRL_TSZ_MASK, 0)
1913
1914#define GPDMA_CH_CTRL_TSZ_MAX 0x00000fffU
1915
1916#define GPDMA_CH_CTRL_SBSZ_MASK 0x00007000U
1917
1918#define GET_GPDMA_CH_CTRL_SBSZ(reg) \
1919 GET_FIELD(reg, GPDMA_CH_CTRL_SBSZ_MASK, 12)
1920
1921#define SET_GPDMA_CH_CTRL_SBSZ(reg, val) \
1922 SET_FIELD(reg, val, GPDMA_CH_CTRL_SBSZ_MASK, 12)
1923
1924#define GPDMA_CH_CTRL_DBSZ_MASK 0x00038000U
1925
1926#define GET_GPDMA_CH_CTRL_DBSZ(reg) \
1927 GET_FIELD(reg, GPDMA_CH_CTRL_DBSZ_MASK, 15)
1928
1929#define SET_GPDMA_CH_CTRL_DBSZ(reg, val) \
1930 SET_FIELD(reg, val, GPDMA_CH_CTRL_DBSZ_MASK, 15)
1931
1932#define GPDMA_CH_CTRL_BSZ_1 0x00000000U
1933
1934#define GPDMA_CH_CTRL_BSZ_4 0x00000001U
1935
1936#define GPDMA_CH_CTRL_BSZ_8 0x00000002U
1937
1938#define GPDMA_CH_CTRL_BSZ_16 0x00000003U
1939
1940#define GPDMA_CH_CTRL_BSZ_32 0x00000004U
1941
1942#define GPDMA_CH_CTRL_BSZ_64 0x00000005U
1943
1944#define GPDMA_CH_CTRL_BSZ_128 0x00000006U
1945
1946#define GPDMA_CH_CTRL_BSZ_256 0x00000007U
1947
1948#define GPDMA_CH_CTRL_SW_MASK 0x001c0000U
1949
1950#define GET_GPDMA_CH_CTRL_SW(reg) \
1951 GET_FIELD(reg, GPDMA_CH_CTRL_SW_MASK, 18)
1952
1953#define SET_GPDMA_CH_CTRL_SW(reg, val) \
1954 SET_FIELD(reg, val, GPDMA_CH_CTRL_SW_MASK, 18)
1955
1956#define GPDMA_CH_CTRL_DW_MASK 0x00e00000U
1957
1958#define GET_GPDMA_CH_CTRL_DW(reg) \
1959 GET_FIELD(reg, GPDMA_CH_CTRL_DW_MASK, 21)
1960
1961#define SET_GPDMA_CH_CTRL_DW(reg, val) \
1962 SET_FIELD(reg, val, GPDMA_CH_CTRL_DW_MASK, 21)
1963
1964#define GPDMA_CH_CTRL_W_8 0x00000000U
1965
1966#define GPDMA_CH_CTRL_W_16 0x00000001U
1967
1968#define GPDMA_CH_CTRL_W_32 0x00000002U
1969
1970#define GPDMA_CH_CTRL_SI 0x04000000U
1971
1972#define GPDMA_CH_CTRL_DI 0x08000000U
1973
1974#define GPDMA_CH_CTRL_PROT_MASK 0x70000000U
1975
1976#define GET_GPDMA_CH_CTRL_PROT(reg) \
1977 GET_FIELD(reg, GPDMA_CH_CTRL_PROT_MASK, 28)
1978
1979#define SET_GPDMA_CH_CTRL_PROT(reg, val) \
1980 SET_FIELD(reg, val, GPDMA_CH_CTRL_PROT_MASK, 28)
1981
1982#define GPDMA_CH_CTRL_ITC 0x80000000U
1983
1984/* GPDMA_CH_CFG */
1985
1986#define GPDMA_CH_CFG_EN 0x00000001U
1987
1988#define GPDMA_CH_CFG_SRCPER_MASK 0x0000001eU
1989
1990#define GET_GPDMA_CH_CFG_SRCPER(reg) \
1991 GET_FIELD(reg, GPDMA_CH_CFG_SRCPER_MASK, 1)
1992
1993#define SET_GPDMA_CH_CFG_SRCPER(reg, val) \
1994 SET_FIELD(reg, val, GPDMA_CH_CFG_SRCPER_MASK, 1)
1995
1996#define GPDMA_CH_CFG_DESTPER_MASK 0x000003c0U
1997
1998#define GET_GPDMA_CH_CFG_DESTPER(reg) \
1999 GET_FIELD(reg, GPDMA_CH_CFG_DESTPER_MASK, 6)
2000
2001#define SET_GPDMA_CH_CFG_DESTPER(reg, val) \
2002 SET_FIELD(reg, val, GPDMA_CH_CFG_DESTPER_MASK, 6)
2003
2004#define GPDMA_CH_CFG_PER_SSP0_TX 0x00000000U
2005
2006#define GPDMA_CH_CFG_PER_SSP0_RX 0x00000001U
2007
2008#define GPDMA_CH_CFG_PER_SSP1_TX 0x00000002U
2009
2010#define GPDMA_CH_CFG_PER_SSP1_RX 0x00000003U
2011
2012#define GPDMA_CH_CFG_PER_SD_MMC 0x00000004U
2013
2014#define GPDMA_CH_CFG_PER_I2S_CH0 0x00000005U
2015
2016#define GPDMA_CH_CFG_PER_I2S_CH1 0x00000006U
2017
2018#define GPDMA_CH_CFG_FLOW_MASK 0x00003800U
2019
2020#define GET_GPDMA_CH_CFG_FLOW(reg) \
2021 GET_FIELD(reg, GPDMA_CH_CFG_FLOW_MASK, 11)
2022
2023#define SET_GPDMA_CH_CFG_FLOW(reg, val) \
2024 SET_FIELD(reg, val, GPDMA_CH_CFG_FLOW_MASK, 11)
2025
2026#define GPDMA_CH_CFG_FLOW_MEM_TO_MEM_DMA 0x00000000U
2027
2028#define GPDMA_CH_CFG_FLOW_MEM_TO_PER_DMA 0x00000001U
2029
2030#define GPDMA_CH_CFG_FLOW_PER_TO_MEM_DMA 0x00000002U
2031
2032#define GPDMA_CH_CFG_FLOW_PER_TO_PER_DMA 0x00000003U
2033
2034#define GPDMA_CH_CFG_FLOW_PER_TO_PER_DEST 0x00000004U
2035
2036#define GPDMA_CH_CFG_FLOW_MEM_TO_PER_PER 0x00000005U
2037
2038#define GPDMA_CH_CFG_FLOW_PER_TO_MEM_PER 0x00000006U
2039
2040#define GPDMA_CH_CFG_FLOW_PER_TO_PER_SRC 0x00000007U
2041
2042#define GPDMA_CH_CFG_IE 0x00004000U
2043
2044#define GPDMA_CH_CFG_ITC 0x00008000U
2045
2046#define GPDMA_CH_CFG_LOCK 0x00010000U
2047
2048#define GPDMA_CH_CFG_ACTIVE 0x00020000U
2049
2050#define GPDMA_CH_CFG_HALT 0x00040000U
2051
2052/* AHBCFG */
2053
2054#define AHBCFG_SCHEDULER_UNIFORM 0x00000001U
2055
2056#define AHBCFG_BREAK_BURST_MASK 0x00000006U
2057
2058#define GET_AHBCFG_BREAK_BURST(reg) \
2059 GET_FIELD(reg, AHBCFG_BREAK_BURST_MASK, 1)
2060
2061#define SET_AHBCFG_BREAK_BURST(reg, val) \
2062 SET_FIELD(reg, val, AHBCFG_BREAK_BURST_MASK, 1)
2063
2064#define AHBCFG_QUANTUM_BUS_CYCLE 0x00000008U
2065
2066#define AHBCFG_QUANTUM_SIZE_MASK 0x000000f0U
2067
2068#define GET_AHBCFG_QUANTUM_SIZE(reg) \
2069 GET_FIELD(reg, AHBCFG_QUANTUM_SIZE_MASK, 4)
2070
2071#define SET_AHBCFG_QUANTUM_SIZE(reg, val) \
2072 SET_FIELD(reg, val, AHBCFG_QUANTUM_SIZE_MASK, 4)
2073
2074#define AHBCFG_DEFAULT_MASTER_MASK 0x00000700U
2075
2076#define GET_AHBCFG_DEFAULT_MASTER(reg) \
2077 GET_FIELD(reg, AHBCFG_DEFAULT_MASTER_MASK, 8)
2078
2079#define SET_AHBCFG_DEFAULT_MASTER(reg, val) \
2080 SET_FIELD(reg, val, AHBCFG_DEFAULT_MASTER_MASK, 8)
2081
2082#define AHBCFG_EP1_MASK 0x00007000U
2083
2084#define GET_AHBCFG_EP1(reg) \
2085 GET_FIELD(reg, AHBCFG_EP1_MASK, 12)
2086
2087#define SET_AHBCFG_EP1(reg, val) \
2088 SET_FIELD(reg, val, AHBCFG_EP1_MASK, 12)
2089
2090#define AHBCFG_EP2_MASK 0x00070000U
2091
2092#define GET_AHBCFG_EP2(reg) \
2093 GET_FIELD(reg, AHBCFG_EP2_MASK, 16)
2094
2095#define SET_AHBCFG_EP2(reg, val) \
2096 SET_FIELD(reg, val, AHBCFG_EP2_MASK, 16)
2097
2098#define AHBCFG_EP3_MASK 0x00700000U
2099
2100#define GET_AHBCFG_EP3(reg) \
2101 GET_FIELD(reg, AHBCFG_EP3_MASK, 20)
2102
2103#define SET_AHBCFG_EP3(reg, val) \
2104 SET_FIELD(reg, val, AHBCFG_EP3_MASK, 20)
2105
2106#define AHBCFG_EP4_MASK 0x07000000U
2107
2108#define GET_AHBCFG_EP4(reg) \
2109 GET_FIELD(reg, AHBCFG_EP4_MASK, 24)
2110
2111#define SET_AHBCFG_EP4(reg, val) \
2112 SET_FIELD(reg, val, AHBCFG_EP4_MASK, 24)
2113
2114#define AHBCFG_EP5_MASK 0x70000000U
2115
2116#define GET_AHBCFG_EP5(reg) \
2117 GET_FIELD(reg, AHBCFG_EP5_MASK, 28)
2118
2119#define SET_AHBCFG_EP5(reg, val) \
2120 SET_FIELD(reg, val, AHBCFG_EP5_MASK, 28)
2121
2122/* I2C */
2123
2124typedef struct {
2125 uint32_t conset;
2126 uint32_t stat;
2127 uint32_t dat;
2128 uint32_t adr;
2129 uint32_t sclh;
2130 uint32_t scll;
2131 uint32_t conclr;
2132} lpc24xx_i2c;
2133
2134#define LPC24XX_I2C_AA (1U << 2U)
2135
2136#define LPC24XX_I2C_SI (1U << 3U)
2137
2138#define LPC24XX_I2C_STO (1U << 4U)
2139
2140#define LPC24XX_I2C_STA (1U << 5U)
2141
2142#define LPC24XX_I2C_EN (1U << 6U)
2143
2144/* IO */
2145
2146#ifdef ARM_MULTILIB_ARCH_V4
2147 #define LPC24XX_PINSEL ((volatile uint32_t *) &PINSEL0)
2148 #define LPC24XX_PINMODE ((volatile uint32_t *) &PINMODE0)
2149#else
2150 #define IOCON_FUNC(val) BSP_FLD32(val, 0, 2)
2151 #define IOCON_FUNC_GET(reg) BSP_FLD32GET(reg, 0, 2)
2152 #define IOCON_FUNC_SET(reg, val) BSP_FLD32SET(reg, val, 0, 2)
2153 #define IOCON_MODE(val) BSP_FLD32(val, 3, 4)
2154 #define IOCON_MODE_GET(reg) BSP_FLD32GET(reg, 3, 4)
2155 #define IOCON_MODE_SET(reg, val) BSP_FLD32SET(reg, val, 3, 4)
2156 #define IOCON_HYS BSP_BIT32(5)
2157 #define IOCON_INV BSP_BIT32(6)
2158 #define IOCON_ADMODE BSP_BIT32(7)
2159 #define IOCON_FILTER BSP_BIT32(8)
2160 #define IOCON_HS BSP_BIT32(8)
2161 #define IOCON_SLEW BSP_BIT32(9)
2162 #define IOCON_HIDRIVE BSP_BIT32(9)
2163 #define IOCON_OD BSP_BIT32(10)
2164 #define IOCON_DACEN BSP_BIT32(16)
2165 #define LPC17XX_IOCON ((volatile uint32_t *) PINSEL_BASE_ADDR)
2166#endif
2167
2168typedef struct {
2169 uint32_t dir;
2170 uint32_t reserved [3];
2171 uint32_t mask;
2172 uint32_t pin;
2173 uint32_t set;
2174 uint32_t clr;
2175} lpc24xx_fio;
2176
2177#define LPC24XX_FIO ((volatile lpc24xx_fio *) FIO_BASE_ADDR)
2178
2179#ifdef ARM_MULTILIB_ARCH_V4
2180
2181/* PCONP */
2182
2183#define PCONP_GPDMA (1U << 29)
2184#define PCONP_ETHERNET (1U << 30)
2185#define PCONP_USB (1U << 31)
2186
2187#endif /* ARM_MULTILIB_ARCH_V4 */
2188
2189/* I2S */
2190
2191static volatile lpc_i2s *const lpc24xx_i2s = (lpc_i2s *) I2S_BASE_ADDR;
2192
2193/* ADC */
2194
2195#define ADC_CR_SEL(val) BSP_FLD32(val, 0, 7)
2196#define ADC_CR_SEL_GET(val) BSP_FLD32GET(val, 0, 7)
2197#define ADC_CR_SEL_SET(reg, val) BSP_FLD32SET(reg, val, 0, 7)
2198#define ADC_CR_CLKDIV(val) BSP_FLD32(val, 8, 15)
2199#define ADC_CR_CLKDIV_GET(reg) BSP_FLD32GET(reg, 8, 15)
2200#define ADC_CR_CLKDIV_SET(reg, val) BSP_FLD32SET(reg, val, 8, 15)
2201#define ADC_CR_BURST BSP_BIT32(16)
2202#define ADC_CR_CLKS(val) BSP_FLD32(val, 17, 19)
2203#define ADC_CR_PDN BSP_BIT32(21)
2204#define ADC_CR_START(val) BSP_FLD32(val, 24, 26)
2205#define ADC_CR_EDGE BSP_BIT32(27)
2206
2207#define ADC_DR_VALUE(reg) BSP_FLD32GET(reg, 6, 15)
2208#define ADC_DR_OVERRUN BSP_BIT32(30)
2209#define ADC_DR_DONE BSP_BIT32(31)
2210
2211/* DAC */
2212
2213#define DAC_STEPS 1024
2214#define DAC_VALUE(val) BSP_FLD32(val, 6, 15)
2215#define DAC_BIAS BSP_BIT32(16)
2216
2219#endif /* LIBBSP_ARM_LPC24XX_LPC24XX_H */
This header file provides utility macros for BSPs.
I2S API.
Register definitions.
Definition: lpc24xx.h:1877
Definition: lpc24xx.h:1870
Definition: lpc24xx.h:2168
Definition: lpc24xx.h:2124
Definition: lpc24xx.h:1757
I2S control block.
Definition: lpc-i2s.h:59
