RTEMS 6.1-rc2
lm32.h
1
11/*
12 * COPYRIGHT (c) 1989-1999.
13 * On-Line Applications Research Corporation (OAR).
14 *
15 * The license and distribution terms for this file may be
16 * found in the file LICENSE in this distribution or at
17 * http://www.rtems.org/license/LICENSE.
18 *
19 * Jukka Pietarinen <jukka.pietarinen@mrf.fi>, 2008,
20 * Micro-Research Finland Oy
21 */
22
23#ifndef _RTEMS_SCORE_LM32_H
24#define _RTEMS_SCORE_LM32_H
25
26#ifdef __cplusplus
27extern "C" {
28#endif
29
30/*
31 * This file contains the information required to build
32 * RTEMS for a particular member of the NO CPU family.
33 * It does this by setting variables to indicate which
34 * implementation dependent features are present in a particular
35 * member of the family.
36 *
37 * This is a good place to list all the known CPU models
38 * that this port supports and which RTEMS CPU model they correspond
39 * to.
40 */
41
42#if defined(rtems_multilib)
43/*
44 * Figure out all CPU Model Feature Flags based upon compiler
45 * predefines.
46 */
47
48#define CPU_MODEL_NAME "rtems_multilib"
49#define LM32_HAS_FPU 0
50
51#elif defined(__lm32__)
52
53#define CPU_MODEL_NAME "lm32"
54#define LM32_HAS_FPU 0
55
56#else
57
58#error "Unsupported CPU Model"
59
60#endif
61
62/*
63 * Define the name of the CPU family.
64 */
65
66#define CPU_NAME "LM32"
67
68#ifdef __cplusplus
69}
70#endif
71
72#define lm32_read_interrupts( _ip) \
73 __asm__ volatile ("rcsr %0, ip":"=r"(_ip));
74
75#define lm32_disable_interrupts( _level ) \
76 do { uint32_t ie; \
77 __asm__ volatile ("rcsr %0,ie":"=r"(ie)); \
78 (_level) = ie; \
79 ie &= (~0x0001); \
80 __asm__ volatile ("wcsr ie,%0"::"r"(ie)); \
81 } while (0)
82
83#define lm32_enable_interrupts( _level ) \
84 __asm__ volatile ("wcsr ie,%0"::"r"(_level));
85
86#define lm32_flash_interrupts( _level ) \
87 do { uint32_t ie; \
88 __asm__ volatile ("wcsr ie,%0"::"r"(_level)); \
89 ie = (_level) & (~0x0001); \
90 __asm__ volatile ("wcsr ie,%0"::"r"(ie)); \
91 } while (0)
92
93#define lm32_interrupt_unmask( _mask ) \
94 do { uint32_t im; \
95 __asm__ volatile ("rcsr %0,im":"=r"(im)); \
96 im |= _mask; \
97 __asm__ volatile ("wcsr im,%0"::"r"(im)); \
98 } while (0)
99
100#define lm32_interrupt_mask( _mask ) \
101 do { uint32_t im; \
102 __asm__ volatile ("rcsr %0,im":"=r"(im)); \
103 im &= ~(_mask); \
104 __asm__ volatile ("wcsr im,%0"::"r"(im)); \
105 } while (0)
106
107#define lm32_interrupt_ack( _mask ) \
108 do { uint32_t ip = _mask; \
109 __asm__ volatile ("wcsr ip,%0"::"r"(ip)); \
110 } while (0)
111
112#endif /* _RTEMS_SCORE_LM32_H */
