RTEMS 6.1-rc2
list.h
1/*
2 * JFFS2 -- Journalling Flash File System, Version 2.
3 *
4 *
5 * Created by Jonathan Larmour <jlarmour@redhat.com>
6 *
7 *===========================================================================
8 * ####ECOSGPLCOPYRIGHTBEGIN####
9 * -------------------------------------------
10 * This file is part of eCos, the Embedded Configurable Operating System.
11 * Copyright (C) 2002, 2003 Free Software Foundation, Inc.
12 *
13 * eCos is free software; you can redistribute it and/or modify it under
14 * the terms of the GNU General Public License as published by the Free
15 * Software Foundation; either version 2 or (at your option) any later
16 * version.
17 *
18 * eCos is distributed in the hope that it will be useful, but WITHOUT
19 * ANY WARRANTY; without even the implied warranty of MERCHANTABILITY or
20 * FITNESS FOR A PARTICULAR PURPOSE. See the GNU General Public License
21 * for more details.
22 *
23 * You should have received a copy of the GNU General Public License
24 * along with eCos; if not, write to the Free Software Foundation, Inc.,
25 * 51 Franklin Street, Fifth Floor, Boston, MA 02110-1301, USA.
26 *
27 * As a special exception, if other files instantiate templates or use
28 * macros or inline functions from this file, or you compile this file
29 * and link it with other works to produce a work based on this file,
30 * this file does not by itself cause the resulting work to be covered by
31 * the GNU General Public License. However the source code for this file
32 * must still be made available in accordance with section (3) of the GNU
33 * General Public License v2.
34 *
35 * This exception does not invalidate any other reasons why a work based
36 * on this file might be covered by the GNU General Public License.
37 * -------------------------------------------
38 * ####ECOSGPLCOPYRIGHTEND####
39 *===========================================================================
40 *
41 */
42
43#ifndef CYGONCE_FS_JFFS2_LIST_H
44#define CYGONCE_FS_JFFS2_LIST_H
45
46
47/* -----------------------------------------------------------------------*/
48
49/* Doubly linked list implementation to replace the GPL'd one used in
50 the Linux kernel. */
51
52#include <stddef.h>
53#include <cyg/infra/cyg_type.h>
54
55/* TYPES */
56
57struct list_head {
58 struct list_head *next;
59 struct list_head *prev;
60};
61
62/* MACROS */
63
64#define LIST_HEAD_INIT(name) { &(name), &(name) }
65
66#define LIST_HEAD(name) \
67 struct list_head name = LIST_HEAD_INIT(name)
68
69#define INIT_LIST_HEAD( _list_ ) \
70CYG_MACRO_START \
71(_list_)->next = (_list_)->prev = (_list_); \
72CYG_MACRO_END
73
74/* FUNCTIONS */
75
76/* Insert an entry _after_ the specified entry */
77static __inline__ void
78list_add( struct list_head *newent, struct list_head *afterthisent )
79{
80 struct list_head *next = afterthisent->next;
81 newent->next = next;
82 newent->prev = afterthisent;
83 afterthisent->next = newent;
84 next->prev = newent;
85} /* list_add() */
86
87/* Insert an entry _before_ the specified entry */
88static __inline__ void
89list_add_tail( struct list_head *newent, struct list_head *beforethisent )
90{
91 struct list_head *prev = beforethisent->prev;
92 newent->prev = prev;
93 newent->next = beforethisent;
94 beforethisent->prev = newent;
95 prev->next = newent;
96} /* list_add_tail() */
97
98/* Delete the specified entry */
99static __inline__ void
100list_del( struct list_head *ent )
101{
102 ent->prev->next = ent->next;
103 ent->next->prev = ent->prev;
104} /* list_del() */
105
106static __inline__ void
107list_move( struct list_head *list, struct list_head *head )
108{
109 list_del( list );
110 list_add( list, head );
111}
112
113static __inline__ void
114list_move_tail( struct list_head *list, struct list_head *head )
115{
116 list_del( list );
117 list_add_tail( list, head );
118}
119
120/* Is this list empty? */
121static __inline__ int
122list_empty( struct list_head *list )
123{
124 return ( list->next == list );
125} /* list_empty() */
126
127/* list_entry - Assuming you have a struct of type _type_ that contains a
128 list which has the name _member_ in that struct type, then given the
129 address of that list in the struct, _list_, this returns the address
130 of the container structure */
131
132#define list_entry( _list_, _type_, _member_ ) \
133 ((_type_ *)((char *)(_list_)-(char *)(offsetof(_type_,_member_))))
134
135/* list_for_each - using _ent_, iterate through list _list_ */
136
137#define list_for_each( _ent_, _list_ ) \
138 for ( (_ent_) = (_list_)->next; \
139 (_ent_) != (_list_); \
140 (_ent_) = (_ent_)->next )
141
142/* list_for_each_safe - using _ent_, iterate through list _list_
143 while protecting against removal of list elements */
144
145#define list_for_each_safe( _ent_, _tmp_, _list_ ) \
146 for ( (_ent_) = (_list_)->next, (_tmp_) = (_ent_)->next; \
147 (_ent_) != (_list_); \
148 (_ent_) = (_tmp_), (_tmp_) = (_ent_)->next )
149
150/*
151 * list_for_each_entry - this function can be use to iterate over all
152 * items in a list* _list_ with it's head at _head_ and link _item_
153 */
154#define list_for_each_entry(_list_, _head_, _item_) \
155for ((_list_) = list_entry((_head_)->next, typeof(*_list_), _item_); \
156 &((_list_)->_item_) != (_head_); \
157 (_list_) = list_entry((_list_)->_item_.next, typeof(*_list_), _item_))
158
159/* -----------------------------------------------------------------------*/
160#endif /* #ifndef CYGONCE_FS_JFFS2_LIST_H */
161/* EOF list.h */
Definition: list.h:57
