RTEMS 6.1-rc2
lcd.h
2
11/*
12 * Copyright (C) 2010, 2012 embedded brains GmbH & Co. KG
13 *
16 * are met:
22 *
34 */
35
36#ifndef LIBBSP_ARM_LPC24XX_LCD_H
37#define LIBBSP_ARM_LPC24XX_LCD_H
38
39#include <rtems.h>
40
41#include <bsp/io.h>
42
43#ifdef __cplusplus
44extern "C" {
45#endif
46
57typedef enum {
58 #ifdef ARM_MULTILIB_ARCH_V4
59 LCD_MODE_STN_4_BIT = 0,
60 LCD_MODE_STN_8_BIT,
61 LCD_MODE_STN_DUAL_PANEL_4_BIT,
62 LCD_MODE_STN_DUAL_PANEL_8_BIT,
63 LCD_MODE_TFT_12_BIT_4_4_4,
64 LCD_MODE_TFT_16_BIT_5_6_5,
65 LCD_MODE_TFT_16_BIT_1_5_5_5,
66 LCD_MODE_TFT_24_BIT,
67 LCD_MODE_DISABLED
68 #else
69 LCD_MODE_STN_4_BIT = 0x4,
70 LCD_MODE_STN_8_BIT = 0x6,
71 LCD_MODE_STN_DUAL_PANEL_4_BIT = 0x84,
72 LCD_MODE_STN_DUAL_PANEL_8_BIT = 0x86,
73 LCD_MODE_TFT_12_BIT_4_4_4 = 0x2e,
74 LCD_MODE_TFT_16_BIT_5_6_5 = 0x2c,
75 LCD_MODE_TFT_16_BIT_1_5_5_5 = 0x28,
76 LCD_MODE_TFT_24_BIT = 0x2a,
77 LCD_MODE_DISABLED = 0xff
78 #endif
79} lpc24xx_lcd_mode;
80
92 lpc24xx_lcd_mode mode,
93 const lpc24xx_pin_range *pins
94);
95
96lpc24xx_lcd_mode lpc24xx_lcd_current_mode(void);
97
100#ifdef __cplusplus
101}
102#endif /* __cplusplus */
103
104#endif /* LIBBSP_ARM_LPC24XX_LCD_H */
rtems_status_code
Definition: status.h:85
rtems_status_code lpc24xx_lcd_set_mode(lpc24xx_lcd_mode mode, const lpc24xx_pin_range *pins)
Set the LCD mode.
Definition: lcd.c:48
Definition: io.h:237
