RTEMS 6.1-rc2
jffs2_xqspipsu.h
2
11/*
12 * Copyright (C) 2022 On-Line Applications Research Corporation (OAR)
13 *
16 * are met:
22 *
34 */
35
36#ifndef LIBBSP_XILINX_ZYNQMP_JFFS2_XQSPIPSU_H
37#define LIBBSP_XILINX_ZYNQMP_JFFS2_XQSPIPSU_H
38
39#include <dev/spi/xqspipsu.h>
40
41#ifdef __cplusplus
42extern "C" {
43#endif /* __cplusplus */
44
54 const char *mount_dir,
55 XQspiPsu *qspipsu_ptr
56);
57
58#ifdef __cplusplus
59}
60#endif /* __cplusplus */
61
62#endif /* LIBBSP_XILINX_ZYNQMP_JFFS2_XQSPIPSU_H */
int xilinx_zynqmp_nor_jffs2_initialize(const char *mount_dir, XQspiPsu *qspipsu_ptr)
Mount jffs2 filesystem.
Definition: jffs2_xqspipsu.c:152
Definition: xqspipsu.h:251
