RTEMS 6.1-rc2
iocopy.h
2
3/*
4 * Copyright (c) 2018 embedded brains GmbH & Co. KG
5 *
6 * Redistribution and use in source and binary forms, with or without
7 * modification, are permitted provided that the following conditions
8 * are met:
9 * 1. Redistributions of source code must retain the above copyright
10 * notice, this list of conditions and the following disclaimer.
11 * 2. Redistributions in binary form must reproduce the above copyright
12 * notice, this list of conditions and the following disclaimer in the
13 * documentation and/or other materials provided with the distribution.
14 *
15 * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
16 * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
17 * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
18 * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
19 * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
20 * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
21 * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
22 * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
23 * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
24 * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
25 * POSSIBILITY OF SUCH DAMAGE.
26 */
27
28#ifndef ATSAM_IOCOPY_H
29#define ATSAM_IOCOPY_H
30
31#include <rtems.h>
32#include <stdint.h>
33
34#ifdef __cplusplus
35extern "C" {
36#endif /* __cplusplus */
37
38/*
39 * Note: This functions are for copying from or to memory that is marked as
40 * Peripheral memory. In this regions a misaligned access is not allowed.
41 * Therefore memcopy would not work in all cases.
42 */
43void atsam_copy_to_io(void *dst, const void *src, size_t n);
44void atsam_copy_from_io(void *dst, const void *src, size_t n);
45
46#ifdef __cplusplus
47}
48#endif /* __cplusplus */
49
50#endif /* ATSAM_IOCOPY_H */
