RTEMS 6.1-rc2
PCI Access Methods. More...
#include <stdint.h>
#include <libcpu/byteorder.h>
#include <pci.h>
struct | pci_cfg_ops |
struct | pci_io_ops |
struct | pci_memreg_ops |
struct | pci_access_drv |
int | pci_access_drv_register (struct pci_access_drv *drv) |
void | pci_modify_cmdsts (pci_dev_t dev, uint32_t mask, uint32_t val) |
int | pci_cfg_r8 (pci_dev_t dev, int ofs, uint8_t *data) |
int | pci_cfg_r16 (pci_dev_t dev, int ofs, uint16_t *data) |
int | pci_cfg_r32 (pci_dev_t dev, int ofs, uint32_t *data) |
int | pci_cfg_w8 (pci_dev_t dev, int ofs, uint8_t data) |
int | pci_cfg_w16 (pci_dev_t dev, int ofs, uint16_t data) |
int | pci_cfg_w32 (pci_dev_t dev, int ofs, uint32_t data) |
uint8_t | pci_io_r8 (uint32_t adr) |
uint16_t | pci_io_r16 (uint32_t adr) |
uint32_t | pci_io_r32 (uint32_t adr) |
void | pci_io_w8 (uint32_t adr, uint8_t data) |
void | pci_io_w16 (uint32_t adr, uint16_t data) |
void | pci_io_w32 (uint32_t adr, uint32_t data) |
uint8_t | pci_mem_ld8 (uint8_t *adr) |
void | pci_mem_st8 (uint8_t *adr, uint8_t data) |
uint16_t | pci_mem_be_ld_le16 (uint16_t *adr) |
uint16_t | pci_mem_be_ld_be16 (uint16_t *adr) |
uint32_t | pci_mem_be_ld_le32 (uint32_t *adr) |
uint32_t | pci_mem_be_ld_be32 (uint32_t *adr) |
void | pci_mem_be_st_le16 (uint16_t *adr, uint16_t data) |
void | pci_mem_be_st_be16 (uint16_t *adr, uint16_t data) |
void | pci_mem_be_st_le32 (uint32_t *adr, uint32_t data) |
void | pci_mem_be_st_be32 (uint32_t *adr, uint32_t data) |
uint16_t | pci_mem_le_ld_le16 (uint16_t *adr) |
uint16_t | pci_mem_le_ld_be16 (uint16_t *adr) |
uint32_t | pci_mem_le_ld_le32 (uint32_t *adr) |
uint32_t | pci_mem_le_ld_be32 (uint32_t *adr) |
void | pci_mem_le_st_le16 (uint16_t *adr, uint16_t data) |
void | pci_mem_le_st_be16 (uint16_t *adr, uint16_t data) |
void | pci_mem_le_st_le32 (uint32_t *adr, uint32_t data) |
void | pci_mem_le_st_be32 (uint32_t *adr, uint32_t data) |
int | pci_access_func (int wr, int size, void **func, int endian, int type) |
struct pci_access_drv | pci_access_ops |
struct pci_memreg_ops | pci_mem_le_ops |
struct pci_memreg_ops | pci_mem_be_ops |
PCI Access Methods.
Routines to access PCI memory/configuration space and other PCI related functions the PCI Library provides.
