#define | IMXRT_PAD_GPIO_AD_B0_00__PWM2_A3 0x00bc 0x02ac 0x0474 0 2 |
#define | IMXRT_PAD_GPIO_AD_B0_00__XBARA1_OUT14 0x00bc 0x02ac 0x0644 1 0 /* Maybe you want to set IOMUXC_GPR_GPR6 IOMUXC_XBAR_DIR_SEL_14 to 0x1 */ |
#define | IMXRT_PAD_GPIO_AD_B0_00__XBARA1_IN14 0x00bc 0x02ac 0x0644 1 0 /* Maybe you want to set IOMUXC_GPR_GPR6 IOMUXC_XBAR_DIR_SEL_14 to 0 */ |
#define | IMXRT_PAD_GPIO_AD_B0_00__XTALOSC24M_REF_CLK_32K 0x00bc 0x02ac 0x0000 2 0 |
#define | IMXRT_PAD_GPIO_AD_B0_00__USB2_usb_otg2_id 0x00bc 0x02ac 0x03f8 3 0 |
#define | IMXRT_PAD_GPIO_AD_B0_00__LPI2C1_SCLS 0x00bc 0x02ac 0x0000 4 0 |
#define | IMXRT_PAD_GPIO_AD_B0_00__GPIO1_gpio_io00 0x00bc 0x02ac 0x0000 5 0 |
#define | IMXRT_PAD_GPIO_AD_B0_00__USDHC1_usdhc_reset_b 0x00bc 0x02ac 0x0000 6 0 |
#define | IMXRT_PAD_GPIO_AD_B0_00__LPSPI3_SCK 0x00bc 0x02ac 0x0510 7 0 |
#define | IMXRT_PAD_GPIO_AD_B0_00__CMP1_IN4 0x00bc 0x02ac 0x0000 5 0 |
#define | IMXRT_PAD_GPIO_AD_B0_01__PWM2_B3 0x00c0 0x02b0 0x0484 0 2 |
#define | IMXRT_PAD_GPIO_AD_B0_01__XBARA1_OUT15 0x00c0 0x02b0 0x0648 1 0 /* Maybe you want to set IOMUXC_GPR_GPR6 IOMUXC_XBAR_DIR_SEL_15 to 0x1 */ |
#define | IMXRT_PAD_GPIO_AD_B0_01__XBARA1_IN15 0x00c0 0x02b0 0x0648 1 0 /* Maybe you want to set IOMUXC_GPR_GPR6 IOMUXC_XBAR_DIR_SEL_15 to 0 */ |
#define | IMXRT_PAD_GPIO_AD_B0_01__XTALOSC24M_REF_CLK_24M 0x00c0 0x02b0 0x0000 2 0 |
#define | IMXRT_PAD_GPIO_AD_B0_01__USB1_usb_otg1_id 0x00c0 0x02b0 0x03f4 3 0 |
#define | IMXRT_PAD_GPIO_AD_B0_01__LPI2C1_SDAS 0x00c0 0x02b0 0x0000 4 0 |
#define | IMXRT_PAD_GPIO_AD_B0_01__GPIO1_gpio_io01 0x00c0 0x02b0 0x0000 5 0 |
#define | IMXRT_PAD_GPIO_AD_B0_01__EWM_EWM_OUT_B 0x00c0 0x02b0 0x0000 6 0 |
#define | IMXRT_PAD_GPIO_AD_B0_01__LPSPI3_SDO 0x00c0 0x02b0 0x0518 7 0 |
#define | IMXRT_PAD_GPIO_AD_B0_01__CMP2_IN4 0x00c0 0x02b0 0x0000 5 0 |
#define | IMXRT_PAD_GPIO_AD_B0_02__CAN2_TX 0x00c4 0x02b4 0x0000 0 0 |
#define | IMXRT_PAD_GPIO_AD_B0_02__XBARA1_OUT16 0x00c4 0x02b4 0x064c 1 0 /* Maybe you want to set IOMUXC_GPR_GPR6 IOMUXC_XBAR_DIR_SEL_16 to 0x1 */ |
#define | IMXRT_PAD_GPIO_AD_B0_02__XBARA1_IN16 0x00c4 0x02b4 0x064c 1 0 /* Maybe you want to set IOMUXC_GPR_GPR6 IOMUXC_XBAR_DIR_SEL_16 to 0 */ |
#define | IMXRT_PAD_GPIO_AD_B0_02__LPUART6_TX 0x00c4 0x02b4 0x0554 2 1 |
#define | IMXRT_PAD_GPIO_AD_B0_02__USB1_usb_otg1_pwr 0x00c4 0x02b4 0x0000 3 0 |
#define | IMXRT_PAD_GPIO_AD_B0_02__PWM1_X0 0x00c4 0x02b4 0x0000 4 0 |
#define | IMXRT_PAD_GPIO_AD_B0_02__GPIO1_gpio_io02 0x00c4 0x02b4 0x0000 5 0 |
#define | IMXRT_PAD_GPIO_AD_B0_02__LPI2C1_HREQ 0x00c4 0x02b4 0x0000 6 0 |
#define | IMXRT_PAD_GPIO_AD_B0_02__LPSPI3_SDI 0x00c4 0x02b4 0x0514 7 0 |
#define | IMXRT_PAD_GPIO_AD_B0_02__CMP3_IN4 0x00c4 0x02b4 0x0000 5 0 |
#define | IMXRT_PAD_GPIO_AD_B0_03__CAN2_RX 0x00c8 0x02b8 0x0450 0 1 |
#define | IMXRT_PAD_GPIO_AD_B0_03__XBARA1_OUT17 0x00c8 0x02b8 0x062c 1 1 /* Maybe you want to set IOMUXC_GPR_GPR6 IOMUXC_XBAR_DIR_SEL_17 to 0x1 */ |
#define | IMXRT_PAD_GPIO_AD_B0_03__XBARA1_IN17 0x00c8 0x02b8 0x062c 1 1 /* Maybe you want to set IOMUXC_GPR_GPR6 IOMUXC_XBAR_DIR_SEL_17 to 0 */ |
#define | IMXRT_PAD_GPIO_AD_B0_03__LPUART6_RX 0x00c8 0x02b8 0x0550 2 1 |
#define | IMXRT_PAD_GPIO_AD_B0_03__USB1_usb_otg1_oc 0x00c8 0x02b8 0x05d0 3 0 |
#define | IMXRT_PAD_GPIO_AD_B0_03__PWM1_X1 0x00c8 0x02b8 0x0000 4 0 |
#define | IMXRT_PAD_GPIO_AD_B0_03__GPIO1_gpio_io03 0x00c8 0x02b8 0x0000 5 0 |
#define | IMXRT_PAD_GPIO_AD_B0_03__XTALOSC24M_REF_CLK_24M 0x00c8 0x02b8 0x0000 6 0 |
#define | IMXRT_PAD_GPIO_AD_B0_03__LPSPI3_PCS0 0x00c8 0x02b8 0x050c 7 0 |
#define | IMXRT_PAD_GPIO_AD_B0_03__CMP4_IN4 0x00c8 0x02b8 0x0000 5 0 |
#define | IMXRT_PAD_GPIO_AD_B0_04__SRC_BOOT_MODE0 0x00cc 0x02bc 0x0000 0 0 |
#define | IMXRT_PAD_GPIO_AD_B0_04__MQS_RIGHT 0x00cc 0x02bc 0x0000 1 0 |
#define | IMXRT_PAD_GPIO_AD_B0_04__ENET_enet_tx_data3 0x00cc 0x02bc 0x0000 2 0 |
#define | IMXRT_PAD_GPIO_AD_B0_04__SAI2_sai_tx_sync 0x00cc 0x02bc 0x05c4 3 1 |
#define | IMXRT_PAD_GPIO_AD_B0_04__CSI_csi_data09 0x00cc 0x02bc 0x041c 4 1 |
#define | IMXRT_PAD_GPIO_AD_B0_04__GPIO1_gpio_io04 0x00cc 0x02bc 0x0000 5 0 |
#define | IMXRT_PAD_GPIO_AD_B0_04__PIT_TRIGGER0 0x00cc 0x02bc 0x0000 6 0 |
#define | IMXRT_PAD_GPIO_AD_B0_04__LPSPI3_PCS1 0x00cc 0x02bc 0x0000 7 0 |
#define | IMXRT_PAD_GPIO_AD_B0_05__SRC_BOOT_MODE1 0x00d0 0x02c0 0x0000 0 0 |
#define | IMXRT_PAD_GPIO_AD_B0_05__MQS_LEFT 0x00d0 0x02c0 0x0000 1 0 |
#define | IMXRT_PAD_GPIO_AD_B0_05__ENET_enet_tx_data2 0x00d0 0x02c0 0x0000 2 0 |
#define | IMXRT_PAD_GPIO_AD_B0_05__SAI2_sai_tx_bclk 0x00d0 0x02c0 0x05c0 3 1 |
#define | IMXRT_PAD_GPIO_AD_B0_05__CSI_csi_data08 0x00d0 0x02c0 0x0418 4 1 |
#define | IMXRT_PAD_GPIO_AD_B0_05__GPIO1_gpio_io05 0x00d0 0x02c0 0x0000 5 0 |
#define | IMXRT_PAD_GPIO_AD_B0_05__XBARA1_OUT17 0x00d0 0x02c0 0x062c 6 2 /* Maybe you want to set IOMUXC_GPR_GPR6 IOMUXC_XBAR_DIR_SEL_17 to 0x1 */ |
#define | IMXRT_PAD_GPIO_AD_B0_05__XBARA1_IN17 0x00d0 0x02c0 0x062c 6 2 /* Maybe you want to set IOMUXC_GPR_GPR6 IOMUXC_XBAR_DIR_SEL_17 to 0 */ |
#define | IMXRT_PAD_GPIO_AD_B0_05__LPSPI3_PCS2 0x00d0 0x02c0 0x0000 7 0 |
#define | IMXRT_PAD_GPIO_AD_B0_06__JTAG_TMS 0x00d4 0x02c4 0x0000 0 0 |
#define | IMXRT_PAD_GPIO_AD_B0_06__GPT2_gpt_compare1 0x00d4 0x02c4 0x0000 1 0 |
#define | IMXRT_PAD_GPIO_AD_B0_06__ENET_enet_rx_clk 0x00d4 0x02c4 0x0000 2 0 |
#define | IMXRT_PAD_GPIO_AD_B0_06__SAI2_sai_rx_bclk 0x00d4 0x02c4 0x05b4 3 1 |
#define | IMXRT_PAD_GPIO_AD_B0_06__CSI_csi_data07 0x00d4 0x02c4 0x0414 4 1 |
#define | IMXRT_PAD_GPIO_AD_B0_06__GPIO1_gpio_io06 0x00d4 0x02c4 0x0000 5 0 |
#define | IMXRT_PAD_GPIO_AD_B0_06__XBARA1_OUT18 0x00d4 0x02c4 0x0630 6 1 /* Maybe you want to set IOMUXC_GPR_GPR6 IOMUXC_XBAR_DIR_SEL_18 to 0x1 */ |
#define | IMXRT_PAD_GPIO_AD_B0_06__XBARA1_IN18 0x00d4 0x02c4 0x0630 6 1 /* Maybe you want to set IOMUXC_GPR_GPR6 IOMUXC_XBAR_DIR_SEL_18 to 0 */ |
#define | IMXRT_PAD_GPIO_AD_B0_06__LPSPI3_PCS3 0x00d4 0x02c4 0x0000 7 0 |
#define | IMXRT_PAD_GPIO_AD_B0_07__JTAG_TCK 0x00d8 0x02c8 0x0000 0 0 |
#define | IMXRT_PAD_GPIO_AD_B0_07__GPT2_gpt_compare2 0x00d8 0x02c8 0x0000 1 0 |
#define | IMXRT_PAD_GPIO_AD_B0_07__ENET_enet_tx_er 0x00d8 0x02c8 0x0000 2 0 |
#define | IMXRT_PAD_GPIO_AD_B0_07__SAI2_sai_rx_sync 0x00d8 0x02c8 0x05bc 3 1 |
#define | IMXRT_PAD_GPIO_AD_B0_07__CSI_csi_data06 0x00d8 0x02c8 0x0410 4 1 |
#define | IMXRT_PAD_GPIO_AD_B0_07__GPIO1_gpio_io07 0x00d8 0x02c8 0x0000 5 0 |
#define | IMXRT_PAD_GPIO_AD_B0_07__XBARA1_OUT19 0x00d8 0x02c8 0x0654 6 1 /* Maybe you want to set IOMUXC_GPR_GPR6 IOMUXC_XBAR_DIR_SEL_19 to 0x1 */ |
#define | IMXRT_PAD_GPIO_AD_B0_07__XBARA1_IN19 0x00d8 0x02c8 0x0654 6 1 /* Maybe you want to set IOMUXC_GPR_GPR6 IOMUXC_XBAR_DIR_SEL_19 to 0 */ |
#define | IMXRT_PAD_GPIO_AD_B0_07__ENET_1588_EVENT3_OUT 0x00d8 0x02c8 0x0000 7 0 |
#define | IMXRT_PAD_GPIO_AD_B0_08__JTAG_MOD 0x00dc 0x02cc 0x0000 0 0 |
#define | IMXRT_PAD_GPIO_AD_B0_08__GPT2_gpt_compare3 0x00dc 0x02cc 0x0000 1 0 |
#define | IMXRT_PAD_GPIO_AD_B0_08__ENET_enet_rx_data3 0x00dc 0x02cc 0x0000 2 0 |
#define | IMXRT_PAD_GPIO_AD_B0_08__SAI2_sai_rx_data 0x00dc 0x02cc 0x05b8 3 1 |
#define | IMXRT_PAD_GPIO_AD_B0_08__CSI_csi_data05 0x00dc 0x02cc 0x040c 4 1 |
#define | IMXRT_PAD_GPIO_AD_B0_08__GPIO1_gpio_io08 0x00dc 0x02cc 0x0000 5 0 |
#define | IMXRT_PAD_GPIO_AD_B0_08__XBARA1_IN20 0x00dc 0x02cc 0x0634 6 1 |
#define | IMXRT_PAD_GPIO_AD_B0_08__ENET_1588_EVENT3_IN 0x00dc 0x02cc 0x0000 7 0 |
#define | IMXRT_PAD_GPIO_AD_B0_09__JTAG_TDI 0x00e0 0x02d0 0x0000 0 0 |
#define | IMXRT_PAD_GPIO_AD_B0_09__PWM2_A3 0x00e0 0x02d0 0x0474 1 3 |
#define | IMXRT_PAD_GPIO_AD_B0_09__ENET_enet_rx_data2 0x00e0 0x02d0 0x0000 2 0 |
#define | IMXRT_PAD_GPIO_AD_B0_09__SAI2_sai_tx_data 0x00e0 0x02d0 0x0000 3 0 |
#define | IMXRT_PAD_GPIO_AD_B0_09__CSI_csi_data04 0x00e0 0x02d0 0x0408 4 1 |
#define | IMXRT_PAD_GPIO_AD_B0_09__GPIO1_gpio_io09 0x00e0 0x02d0 0x0000 5 0 |
#define | IMXRT_PAD_GPIO_AD_B0_09__XBARA1_IN21 0x00e0 0x02d0 0x0658 6 1 |
#define | IMXRT_PAD_GPIO_AD_B0_09__GPT2_gpt_clk 0x00e0 0x02d0 0x0000 7 0 |
#define | IMXRT_PAD_GPIO_AD_B0_10__JTAG_TDO 0x00e4 0x02d4 0x0000 0 0 |
#define | IMXRT_PAD_GPIO_AD_B0_10__PWM1_A3 0x00e4 0x02d4 0x0454 1 3 |
#define | IMXRT_PAD_GPIO_AD_B0_10__ENET_enet_crs 0x00e4 0x02d4 0x0000 2 0 |
#define | IMXRT_PAD_GPIO_AD_B0_10__SAI2_sai_mclk 0x00e4 0x02d4 0x05b0 3 1 |
#define | IMXRT_PAD_GPIO_AD_B0_10__CSI_csi_data03 0x00e4 0x02d4 0x0404 4 1 |
#define | IMXRT_PAD_GPIO_AD_B0_10__GPIO1_gpio_io10 0x00e4 0x02d4 0x0000 5 0 |
#define | IMXRT_PAD_GPIO_AD_B0_10__XBARA1_IN22 0x00e4 0x02d4 0x0638 6 1 |
#define | IMXRT_PAD_GPIO_AD_B0_10__ENET_1588_EVENT0_OUT 0x00e4 0x02d4 0x0000 7 0 |
#define | IMXRT_PAD_GPIO_AD_B0_11__JTAG_TRSTB 0x00e8 0x02d8 0x0000 0 0 |
#define | IMXRT_PAD_GPIO_AD_B0_11__PWM1_B3 0x00e8 0x02d8 0x0464 1 3 |
#define | IMXRT_PAD_GPIO_AD_B0_11__ENET_enet_col 0x00e8 0x02d8 0x0000 2 0 |
#define | IMXRT_PAD_GPIO_AD_B0_11__WDOG1_wdog_b 0x00e8 0x02d8 0x0000 3 0 |
#define | IMXRT_PAD_GPIO_AD_B0_11__CSI_csi_data02 0x00e8 0x02d8 0x0400 4 1 |
#define | IMXRT_PAD_GPIO_AD_B0_11__GPIO1_gpio_io11 0x00e8 0x02d8 0x0000 5 0 |
#define | IMXRT_PAD_GPIO_AD_B0_11__XBARA1_IN23 0x00e8 0x02d8 0x063c 6 1 |
#define | IMXRT_PAD_GPIO_AD_B0_11__ENET_1588_EVENT0_IN 0x00e8 0x02d8 0x0444 7 1 |
#define | IMXRT_PAD_GPIO_AD_B0_12__LPI2C4_SCL 0x00ec 0x02dc 0x04e4 0 1 |
#define | IMXRT_PAD_GPIO_AD_B0_12__CCM_PMIC_RDY 0x00ec 0x02dc 0x03fc 1 1 |
#define | IMXRT_PAD_GPIO_AD_B0_12__LPUART1_TX 0x00ec 0x02dc 0x0000 2 0 |
#define | IMXRT_PAD_GPIO_AD_B0_12__WDOG2_wdog_b 0x00ec 0x02dc 0x0000 3 0 |
#define | IMXRT_PAD_GPIO_AD_B0_12__PWM1_X2 0x00ec 0x02dc 0x0000 4 0 |
#define | IMXRT_PAD_GPIO_AD_B0_12__GPIO1_gpio_io12 0x00ec 0x02dc 0x0000 5 0 |
#define | IMXRT_PAD_GPIO_AD_B0_12__ENET_1588_EVENT1_OUT 0x00ec 0x02dc 0x0000 6 0 |
#define | IMXRT_PAD_GPIO_AD_B0_12__ARM_arm_nmi 0x00ec 0x02dc 0x0568 7 0 |
#define | IMXRT_PAD_GPIO_AD_B0_12__ADC1_IN1 0x00ec 0x02dc 0x0000 5 0 |
#define | IMXRT_PAD_GPIO_AD_B0_13__LPI2C4_SDA 0x00f0 0x02e0 0x04e8 0 1 |
#define | IMXRT_PAD_GPIO_AD_B0_13__GPT1_gpt_clk 0x00f0 0x02e0 0x0000 1 0 |
#define | IMXRT_PAD_GPIO_AD_B0_13__LPUART1_RX 0x00f0 0x02e0 0x0000 2 0 |
#define | IMXRT_PAD_GPIO_AD_B0_13__EWM_EWM_OUT_B 0x00f0 0x02e0 0x0000 3 0 |
#define | IMXRT_PAD_GPIO_AD_B0_13__PWM1_X3 0x00f0 0x02e0 0x0000 4 0 |
#define | IMXRT_PAD_GPIO_AD_B0_13__GPIO1_gpio_io13 0x00f0 0x02e0 0x0000 5 0 |
#define | IMXRT_PAD_GPIO_AD_B0_13__ENET_1588_EVENT1_IN 0x00f0 0x02e0 0x0000 6 0 |
#define | IMXRT_PAD_GPIO_AD_B0_13__XTALOSC24M_REF_CLK_24M 0x00f0 0x02e0 0x0000 7 0 |
#define | IMXRT_PAD_GPIO_AD_B0_13__ADC1_IN2 0x00f0 0x02e0 0x0000 5 0 |
#define | IMXRT_PAD_GPIO_AD_B0_13__CMP1_IN2 0x00f0 0x02e0 0x0000 5 0 |
#define | IMXRT_PAD_GPIO_AD_B0_14__USB2_usb_otg2_oc 0x00f4 0x02e4 0x05cc 0 0 |
#define | IMXRT_PAD_GPIO_AD_B0_14__XBARA1_IN24 0x00f4 0x02e4 0x0640 1 1 |
#define | IMXRT_PAD_GPIO_AD_B0_14__LPUART1_CTS_B 0x00f4 0x02e4 0x0000 2 0 |
#define | IMXRT_PAD_GPIO_AD_B0_14__ENET_1588_EVENT0_OUT 0x00f4 0x02e4 0x0000 3 0 |
#define | IMXRT_PAD_GPIO_AD_B0_14__CSI_csi_vsync 0x00f4 0x02e4 0x0428 4 0 |
#define | IMXRT_PAD_GPIO_AD_B0_14__GPIO1_gpio_io14 0x00f4 0x02e4 0x0000 5 0 |
#define | IMXRT_PAD_GPIO_AD_B0_14__CAN2_TX 0x00f4 0x02e4 0x0000 6 0 |
#define | IMXRT_PAD_GPIO_AD_B0_14__ADC1_IN3 0x00f4 0x02e4 0x0000 5 0 |
#define | IMXRT_PAD_GPIO_AD_B0_14__CMP2_IN2 0x00f4 0x02e4 0x0000 5 0 |
#define | IMXRT_PAD_GPIO_AD_B0_15__USB2_usb_otg2_pwr 0x00f8 0x02e8 0x0000 0 0 |
#define | IMXRT_PAD_GPIO_AD_B0_15__XBARA1_IN25 0x00f8 0x02e8 0x0650 1 0 |
#define | IMXRT_PAD_GPIO_AD_B0_15__LPUART1_RTS_B 0x00f8 0x02e8 0x0000 2 0 |
#define | IMXRT_PAD_GPIO_AD_B0_15__ENET_1588_EVENT0_IN 0x00f8 0x02e8 0x0444 3 0 |
#define | IMXRT_PAD_GPIO_AD_B0_15__CSI_csi_hsync 0x00f8 0x02e8 0x0420 4 0 |
#define | IMXRT_PAD_GPIO_AD_B0_15__GPIO1_gpio_io15 0x00f8 0x02e8 0x0000 5 0 |
#define | IMXRT_PAD_GPIO_AD_B0_15__CAN2_RX 0x00f8 0x02e8 0x0450 6 2 |
#define | IMXRT_PAD_GPIO_AD_B0_15__WDOG1_wdog_rst_b_deb 0x00f8 0x02e8 0x0000 7 0 |
#define | IMXRT_PAD_GPIO_AD_B0_15__ADC1_IN4 0x00f8 0x02e8 0x0000 5 0 |
#define | IMXRT_PAD_GPIO_AD_B0_15__CMP3_IN2 0x00f8 0x02e8 0x0000 5 0 |
#define | IMXRT_PAD_GPIO_AD_B1_00__USB2_usb_otg2_id 0x00fc 0x02ec 0x03f8 0 1 |
#define | IMXRT_PAD_GPIO_AD_B1_00__TMR3_TIMER0 0x00fc 0x02ec 0x057c 1 1 /* Maybe you want to set IOMUXC_GPR_GPR6 QTIMER3_TRM0_INPUT_SEL to 0 */ |
#define | IMXRT_PAD_GPIO_AD_B1_00__LPUART2_CTS_B 0x00fc 0x02ec 0x0000 2 0 |
#define | IMXRT_PAD_GPIO_AD_B1_00__LPI2C1_SCL 0x00fc 0x02ec 0x04cc 3 1 |
#define | IMXRT_PAD_GPIO_AD_B1_00__WDOG1_wdog_b 0x00fc 0x02ec 0x0000 4 0 |
#define | IMXRT_PAD_GPIO_AD_B1_00__GPIO1_gpio_io16 0x00fc 0x02ec 0x0000 5 0 |
#define | IMXRT_PAD_GPIO_AD_B1_00__USDHC1_usdhc_wp 0x00fc 0x02ec 0x05d8 6 2 |
#define | IMXRT_PAD_GPIO_AD_B1_00__KPP_kpp_row7 0x00fc 0x02ec 0x0000 7 0 |
#define | IMXRT_PAD_GPIO_AD_B1_00__ADC1_IN5 0x00fc 0x02ec 0x0000 5 0 |
#define | IMXRT_PAD_GPIO_AD_B1_00__ADC2_IN5 0x00fc 0x02ec 0x0000 5 0 |
#define | IMXRT_PAD_GPIO_AD_B1_00__CMP4_IN2 0x00fc 0x02ec 0x0000 5 0 |
#define | IMXRT_PAD_GPIO_AD_B1_01__USB1_usb_otg1_pwr 0x0100 0x02f0 0x0000 0 0 |
#define | IMXRT_PAD_GPIO_AD_B1_01__TMR3_TIMER1 0x0100 0x02f0 0x0580 1 0 /* Maybe you want to set IOMUXC_GPR_GPR6 QTIMER3_TRM1_INPUT_SEL to 0 */ |
#define | IMXRT_PAD_GPIO_AD_B1_01__LPUART2_RTS_B 0x0100 0x02f0 0x0000 2 0 |
#define | IMXRT_PAD_GPIO_AD_B1_01__LPI2C1_SDA 0x0100 0x02f0 0x04d0 3 1 |
#define | IMXRT_PAD_GPIO_AD_B1_01__CCM_PMIC_RDY 0x0100 0x02f0 0x03fc 4 2 |
#define | IMXRT_PAD_GPIO_AD_B1_01__GPIO1_gpio_io17 0x0100 0x02f0 0x0000 5 0 |
#define | IMXRT_PAD_GPIO_AD_B1_01__USDHC1_usdhc_vselect 0x0100 0x02f0 0x0000 6 0 |
#define | IMXRT_PAD_GPIO_AD_B1_01__KPP_kpp_col7 0x0100 0x02f0 0x0000 7 0 |
#define | IMXRT_PAD_GPIO_AD_B1_01__ADC1_IN6 0x0100 0x02f0 0x0000 5 0 |
#define | IMXRT_PAD_GPIO_AD_B1_01__ADC2_IN6 0x0100 0x02f0 0x0000 5 0 |
#define | IMXRT_PAD_GPIO_AD_B1_01__CMP1_IN0 0x0100 0x02f0 0x0000 5 0 |
#define | IMXRT_PAD_GPIO_AD_B1_01__CMP2_IN0 0x0100 0x02f0 0x0000 5 0 |
#define | IMXRT_PAD_GPIO_AD_B1_01__CMP3_IN0 0x0100 0x02f0 0x0000 5 0 |
#define | IMXRT_PAD_GPIO_AD_B1_01__CMP4_IN0 0x0100 0x02f0 0x0000 5 0 |
#define | IMXRT_PAD_GPIO_AD_B1_02__USB1_usb_otg1_id 0x0104 0x02f4 0x03f4 0 1 |
#define | IMXRT_PAD_GPIO_AD_B1_02__TMR3_TIMER2 0x0104 0x02f4 0x0584 1 1 /* Maybe you want to set IOMUXC_GPR_GPR6 QTIMER3_TRM2_INPUT_SEL to 0 */ |
#define | IMXRT_PAD_GPIO_AD_B1_02__LPUART2_TX 0x0104 0x02f4 0x0530 2 1 |
#define | IMXRT_PAD_GPIO_AD_B1_02__SPDIF_spdif_out 0x0104 0x02f4 0x0000 3 0 |
#define | IMXRT_PAD_GPIO_AD_B1_02__ENET_1588_EVENT2_OUT 0x0104 0x02f4 0x0000 4 0 |
#define | IMXRT_PAD_GPIO_AD_B1_02__GPIO1_gpio_io18 0x0104 0x02f4 0x0000 5 0 |
#define | IMXRT_PAD_GPIO_AD_B1_02__USDHC1_usdhc_cd_b 0x0104 0x02f4 0x05d4 6 1 |
#define | IMXRT_PAD_GPIO_AD_B1_02__KPP_kpp_row6 0x0104 0x02f4 0x0000 7 0 |
#define | IMXRT_PAD_GPIO_AD_B1_02__ADC1_IN7 0x0104 0x02f4 0x0000 5 0 |
#define | IMXRT_PAD_GPIO_AD_B1_02__ADC2_IN7 0x0104 0x02f4 0x0000 5 0 |
#define | IMXRT_PAD_GPIO_AD_B1_02__CMP1_IN3 0x0104 0x02f4 0x0000 5 0 |
#define | IMXRT_PAD_GPIO_AD_B1_03__USB1_usb_otg1_oc 0x0108 0x02f8 0x05d0 0 1 |
#define | IMXRT_PAD_GPIO_AD_B1_03__TMR3_TIMER3 0x0108 0x02f8 0x0588 1 1 /* Maybe you want to set IOMUXC_GPR_GPR6 QTIMER3_TRM3_INPUT_SEL to 0 */ |
#define | IMXRT_PAD_GPIO_AD_B1_03__LPUART2_RX 0x0108 0x02f8 0x052c 2 1 |
#define | IMXRT_PAD_GPIO_AD_B1_03__SPDIF_spdif_in 0x0108 0x02f8 0x05c8 3 0 |
#define | IMXRT_PAD_GPIO_AD_B1_03__ENET_1588_EVENT2_IN 0x0108 0x02f8 0x0000 4 0 |
#define | IMXRT_PAD_GPIO_AD_B1_03__GPIO1_gpio_io19 0x0108 0x02f8 0x0000 5 0 |
#define | IMXRT_PAD_GPIO_AD_B1_03__USDHC2_usdhc_cd_b 0x0108 0x02f8 0x05e0 6 0 |
#define | IMXRT_PAD_GPIO_AD_B1_03__KPP_kpp_col6 0x0108 0x02f8 0x0000 7 0 |
#define | IMXRT_PAD_GPIO_AD_B1_03__ADC1_IN8 0x0108 0x02f8 0x0000 5 0 |
#define | IMXRT_PAD_GPIO_AD_B1_03__ADC2_IN8 0x0108 0x02f8 0x0000 5 0 |
#define | IMXRT_PAD_GPIO_AD_B1_03__CMP2_IN3 0x0108 0x02f8 0x0000 5 0 |
#define | IMXRT_PAD_GPIO_AD_B1_04__FLEXSPI_FLEXSPI_B_DATA3 0x010c 0x02fc 0x04c4 0 1 |
#define | IMXRT_PAD_GPIO_AD_B1_04__ENET_enet_mdc 0x010c 0x02fc 0x0000 1 0 |
#define | IMXRT_PAD_GPIO_AD_B1_04__LPUART3_CTS_B 0x010c 0x02fc 0x0534 2 1 |
#define | IMXRT_PAD_GPIO_AD_B1_04__SPDIF_spdif_sr_clk 0x010c 0x02fc 0x0000 3 0 |
#define | IMXRT_PAD_GPIO_AD_B1_04__CSI_csi_pixclk 0x010c 0x02fc 0x0424 4 0 |
#define | IMXRT_PAD_GPIO_AD_B1_04__GPIO1_gpio_io20 0x010c 0x02fc 0x0000 5 0 |
#define | IMXRT_PAD_GPIO_AD_B1_04__USDHC2_usdhc_data0 0x010c 0x02fc 0x05e8 6 1 |
#define | IMXRT_PAD_GPIO_AD_B1_04__KPP_kpp_row5 0x010c 0x02fc 0x0000 7 0 |
#define | IMXRT_PAD_GPIO_AD_B1_04__ADC1_IN9 0x010c 0x02fc 0x0000 5 0 |
#define | IMXRT_PAD_GPIO_AD_B1_04__ADC2_IN9 0x010c 0x02fc 0x0000 5 0 |
#define | IMXRT_PAD_GPIO_AD_B1_04__CMP3_IN3 0x010c 0x02fc 0x0000 5 0 |
#define | IMXRT_PAD_GPIO_AD_B1_05__FLEXSPI_FLEXSPI_B_DATA2 0x0110 0x0300 0x04c0 0 1 |
#define | IMXRT_PAD_GPIO_AD_B1_05__ENET_enet_mdio 0x0110 0x0300 0x0430 1 0 |
#define | IMXRT_PAD_GPIO_AD_B1_05__LPUART3_RTS_B 0x0110 0x0300 0x0000 2 0 |
#define | IMXRT_PAD_GPIO_AD_B1_05__SPDIF_spdif_out 0x0110 0x0300 0x0000 3 0 |
#define | IMXRT_PAD_GPIO_AD_B1_05__CSI_csi_mclk 0x0110 0x0300 0x0000 4 0 |
#define | IMXRT_PAD_GPIO_AD_B1_05__GPIO1_gpio_io21 0x0110 0x0300 0x0000 5 0 |
#define | IMXRT_PAD_GPIO_AD_B1_05__USDHC2_usdhc_data1 0x0110 0x0300 0x05ec 6 1 |
#define | IMXRT_PAD_GPIO_AD_B1_05__KPP_kpp_col5 0x0110 0x0300 0x0000 7 0 |
#define | IMXRT_PAD_GPIO_AD_B1_05__ADC1_IN10 0x0110 0x0300 0x0000 5 0 |
#define | IMXRT_PAD_GPIO_AD_B1_05__ADC2_IN10 0x0110 0x0300 0x0000 5 0 |
#define | IMXRT_PAD_GPIO_AD_B1_05__CMP4_IN3 0x0110 0x0300 0x0000 5 0 |
#define | IMXRT_PAD_GPIO_AD_B1_06__FLEXSPI_FLEXSPI_B_DATA1 0x0114 0x0304 0x04bc 0 1 |
#define | IMXRT_PAD_GPIO_AD_B1_06__LPI2C3_SDA 0x0114 0x0304 0x04e0 1 2 |
#define | IMXRT_PAD_GPIO_AD_B1_06__LPUART3_TX 0x0114 0x0304 0x053c 2 0 |
#define | IMXRT_PAD_GPIO_AD_B1_06__SPDIF_spdif_lock 0x0114 0x0304 0x0000 3 0 |
#define | IMXRT_PAD_GPIO_AD_B1_06__CSI_csi_vsync 0x0114 0x0304 0x0428 4 1 |
#define | IMXRT_PAD_GPIO_AD_B1_06__GPIO1_gpio_io22 0x0114 0x0304 0x0000 5 0 |
#define | IMXRT_PAD_GPIO_AD_B1_06__USDHC2_usdhc_data2 0x0114 0x0304 0x05f0 6 1 |
#define | IMXRT_PAD_GPIO_AD_B1_06__KPP_kpp_row4 0x0114 0x0304 0x0000 7 0 |
#define | IMXRT_PAD_GPIO_AD_B1_06__ADC1_IN11 0x0114 0x0304 0x0000 5 0 |
#define | IMXRT_PAD_GPIO_AD_B1_06__ADC2_IN11 0x0114 0x0304 0x0000 5 0 |
#define | IMXRT_PAD_GPIO_AD_B1_06__CMP1_IN1 0x0114 0x0304 0x0000 5 0 |
#define | IMXRT_PAD_GPIO_AD_B1_06__CMP2_IN1 0x0114 0x0304 0x0000 5 0 |
#define | IMXRT_PAD_GPIO_AD_B1_06__CMP3_IN1 0x0114 0x0304 0x0000 5 0 |
#define | IMXRT_PAD_GPIO_AD_B1_06__CMP4_IN1 0x0114 0x0304 0x0000 5 0 |
#define | IMXRT_PAD_GPIO_AD_B1_07__FLEXSPI_FLEXSPI_B_DATA0 0x0118 0x0308 0x04b8 0 1 |
#define | IMXRT_PAD_GPIO_AD_B1_07__LPI2C3_SCL 0x0118 0x0308 0x04dc 1 2 |
#define | IMXRT_PAD_GPIO_AD_B1_07__LPUART3_RX 0x0118 0x0308 0x0538 2 0 |
#define | IMXRT_PAD_GPIO_AD_B1_07__SPDIF_spdif_ext_clk 0x0118 0x0308 0x0000 3 0 |
#define | IMXRT_PAD_GPIO_AD_B1_07__CSI_csi_hsync 0x0118 0x0308 0x0420 4 1 |
#define | IMXRT_PAD_GPIO_AD_B1_07__GPIO1_gpio_io23 0x0118 0x0308 0x0000 5 0 |
#define | IMXRT_PAD_GPIO_AD_B1_07__USDHC2_usdhc_data3 0x0118 0x0308 0x05f4 6 1 |
#define | IMXRT_PAD_GPIO_AD_B1_07__KPP_kpp_col4 0x0118 0x0308 0x0000 7 0 |
#define | IMXRT_PAD_GPIO_AD_B1_07__ADC1_IN12 0x0118 0x0308 0x0000 5 0 |
#define | IMXRT_PAD_GPIO_AD_B1_07__ADC2_IN12 0x0118 0x0308 0x0000 5 0 |
#define | IMXRT_PAD_GPIO_AD_B1_07__CMP1_IN5 0x0118 0x0308 0x0000 5 0 |
#define | IMXRT_PAD_GPIO_AD_B1_08__FLEXSPI_FLEXSPI_A_SS1_B 0x011c 0x030c 0x0000 0 0 |
#define | IMXRT_PAD_GPIO_AD_B1_08__PWM4_A0 0x011c 0x030c 0x0494 1 1 |
#define | IMXRT_PAD_GPIO_AD_B1_08__CAN1_TX 0x011c 0x030c 0x0000 2 0 |
#define | IMXRT_PAD_GPIO_AD_B1_08__CCM_PMIC_RDY 0x011c 0x030c 0x03fc 3 3 |
#define | IMXRT_PAD_GPIO_AD_B1_08__CSI_csi_data09 0x011c 0x030c 0x041c 4 0 |
#define | IMXRT_PAD_GPIO_AD_B1_08__GPIO1_gpio_io24 0x011c 0x030c 0x0000 5 0 |
#define | IMXRT_PAD_GPIO_AD_B1_08__USDHC2_usdhc_cmd 0x011c 0x030c 0x05e4 6 1 |
#define | IMXRT_PAD_GPIO_AD_B1_08__KPP_kpp_row3 0x011c 0x030c 0x0000 7 0 |
#define | IMXRT_PAD_GPIO_AD_B1_08__ADC1_IN13 0x011c 0x030c 0x0000 5 0 |
#define | IMXRT_PAD_GPIO_AD_B1_08__ADC2_IN13 0x011c 0x030c 0x0000 5 0 |
#define | IMXRT_PAD_GPIO_AD_B1_08__CMP2_IN5 0x011c 0x030c 0x0000 5 0 |
#define | IMXRT_PAD_GPIO_AD_B1_09__FLEXSPI_FLEXSPI_A_DQS 0x0120 0x0310 0x04a4 0 1 |
#define | IMXRT_PAD_GPIO_AD_B1_09__PWM4_A1 0x0120 0x0310 0x0498 1 1 |
#define | IMXRT_PAD_GPIO_AD_B1_09__CAN1_RX 0x0120 0x0310 0x044c 2 2 |
#define | IMXRT_PAD_GPIO_AD_B1_09__SAI1_sai_mclk 0x0120 0x0310 0x058c 3 1 |
#define | IMXRT_PAD_GPIO_AD_B1_09__CSI_csi_data08 0x0120 0x0310 0x0418 4 0 |
#define | IMXRT_PAD_GPIO_AD_B1_09__GPIO1_gpio_io25 0x0120 0x0310 0x0000 5 0 |
#define | IMXRT_PAD_GPIO_AD_B1_09__USDHC2_usdhc_clk 0x0120 0x0310 0x05dc 6 1 |
#define | IMXRT_PAD_GPIO_AD_B1_09__KPP_kpp_col3 0x0120 0x0310 0x0000 7 0 |
#define | IMXRT_PAD_GPIO_AD_B1_09__ADC1_IN14 0x0120 0x0310 0x0000 5 0 |
#define | IMXRT_PAD_GPIO_AD_B1_09__ADC2_IN14 0x0120 0x0310 0x0000 5 0 |
#define | IMXRT_PAD_GPIO_AD_B1_09__CMP3_IN5 0x0120 0x0310 0x0000 5 0 |
#define | IMXRT_PAD_GPIO_AD_B1_10__FLEXSPI_FLEXSPI_A_DATA3 0x0124 0x0314 0x04b4 0 1 |
#define | IMXRT_PAD_GPIO_AD_B1_10__WDOG1_wdog_b 0x0124 0x0314 0x0000 1 0 |
#define | IMXRT_PAD_GPIO_AD_B1_10__LPUART8_TX 0x0124 0x0314 0x0564 2 1 |
#define | IMXRT_PAD_GPIO_AD_B1_10__SAI1_sai_rx_sync 0x0124 0x0314 0x05a4 3 1 |
#define | IMXRT_PAD_GPIO_AD_B1_10__CSI_csi_data07 0x0124 0x0314 0x0414 4 0 |
#define | IMXRT_PAD_GPIO_AD_B1_10__GPIO1_gpio_io26 0x0124 0x0314 0x0000 5 0 |
#define | IMXRT_PAD_GPIO_AD_B1_10__USDHC2_usdhc_wp 0x0124 0x0314 0x0608 6 1 |
#define | IMXRT_PAD_GPIO_AD_B1_10__KPP_kpp_row2 0x0124 0x0314 0x0000 7 0 |
#define | IMXRT_PAD_GPIO_AD_B1_10__ADC1_IN15 0x0124 0x0314 0x0000 5 0 |
#define | IMXRT_PAD_GPIO_AD_B1_10__ADC2_IN15 0x0124 0x0314 0x0000 5 0 |
#define | IMXRT_PAD_GPIO_AD_B1_10__CMP4_IN5 0x0124 0x0314 0x0000 5 0 |
#define | IMXRT_PAD_GPIO_AD_B1_11__FLEXSPI_FLEXSPI_A_DATA2 0x0128 0x0318 0x04b0 0 1 |
#define | IMXRT_PAD_GPIO_AD_B1_11__EWM_EWM_OUT_B 0x0128 0x0318 0x0000 1 0 |
#define | IMXRT_PAD_GPIO_AD_B1_11__LPUART8_RX 0x0128 0x0318 0x0560 2 1 |
#define | IMXRT_PAD_GPIO_AD_B1_11__SAI1_sai_rx_bclk 0x0128 0x0318 0x0590 3 1 |
#define | IMXRT_PAD_GPIO_AD_B1_11__CSI_csi_data06 0x0128 0x0318 0x0410 4 0 |
#define | IMXRT_PAD_GPIO_AD_B1_11__GPIO1_gpio_io27 0x0128 0x0318 0x0000 5 0 |
#define | IMXRT_PAD_GPIO_AD_B1_11__USDHC2_usdhc_reset_b 0x0128 0x0318 0x0000 6 0 |
#define | IMXRT_PAD_GPIO_AD_B1_11__KPP_kpp_col2 0x0128 0x0318 0x0000 7 0 |
#define | IMXRT_PAD_GPIO_AD_B1_11__ADC1_IN0 0x0128 0x0318 0x0000 5 0 |
#define | IMXRT_PAD_GPIO_AD_B1_11__ADC2_IN0 0x0128 0x0318 0x0000 5 0 |
#define | IMXRT_PAD_GPIO_AD_B1_11__CMP1_IN6 0x0128 0x0318 0x0000 5 0 |
#define | IMXRT_PAD_GPIO_AD_B1_12__FLEXSPI_FLEXSPI_A_DATA1 0x012c 0x031c 0x04ac 0 1 |
#define | IMXRT_PAD_GPIO_AD_B1_12__CMP1_OUT 0x012c 0x031c 0x0000 1 0 |
#define | IMXRT_PAD_GPIO_AD_B1_12__LPSPI3_PCS0 0x012c 0x031c 0x050c 2 1 |
#define | IMXRT_PAD_GPIO_AD_B1_12__SAI1_sai_rx_data0 0x012c 0x031c 0x0594 3 1 |
#define | IMXRT_PAD_GPIO_AD_B1_12__CSI_csi_data05 0x012c 0x031c 0x040c 4 0 |
#define | IMXRT_PAD_GPIO_AD_B1_12__GPIO1_gpio_io28 0x012c 0x031c 0x0000 5 0 |
#define | IMXRT_PAD_GPIO_AD_B1_12__USDHC2_usdhc_data4 0x012c 0x031c 0x05f8 6 1 |
#define | IMXRT_PAD_GPIO_AD_B1_12__KPP_kpp_row1 0x012c 0x031c 0x0000 7 0 |
#define | IMXRT_PAD_GPIO_AD_B1_12__ADC2_IN1 0x012c 0x031c 0x0000 5 0 |
#define | IMXRT_PAD_GPIO_AD_B1_12__CMP2_IN6 0x012c 0x031c 0x0000 5 0 |
#define | IMXRT_PAD_GPIO_AD_B1_13__FLEXSPI_FLEXSPI_A_DATA0 0x0130 0x0320 0x04a8 0 1 |
#define | IMXRT_PAD_GPIO_AD_B1_13__CMP2_OUT 0x0130 0x0320 0x0000 1 0 |
#define | IMXRT_PAD_GPIO_AD_B1_13__LPSPI3_SDI 0x0130 0x0320 0x0514 2 1 |
#define | IMXRT_PAD_GPIO_AD_B1_13__SAI1_sai_tx_data0 0x0130 0x0320 0x0000 3 0 |
#define | IMXRT_PAD_GPIO_AD_B1_13__CSI_csi_data04 0x0130 0x0320 0x0408 4 0 |
#define | IMXRT_PAD_GPIO_AD_B1_13__GPIO1_gpio_io29 0x0130 0x0320 0x0000 5 0 |
#define | IMXRT_PAD_GPIO_AD_B1_13__USDHC2_usdhc_data5 0x0130 0x0320 0x05fc 6 1 |
#define | IMXRT_PAD_GPIO_AD_B1_13__KPP_kpp_col1 0x0130 0x0320 0x0000 7 0 |
#define | IMXRT_PAD_GPIO_AD_B1_13__ADC2_IN2 0x0130 0x0320 0x0000 5 0 |
#define | IMXRT_PAD_GPIO_AD_B1_13__CMP3_IN6 0x0130 0x0320 0x0000 5 0 |
#define | IMXRT_PAD_GPIO_AD_B1_14__FLEXSPI_FLEXSPI_A_SCLK 0x0134 0x0324 0x04c8 0 1 |
#define | IMXRT_PAD_GPIO_AD_B1_14__CMP3_OUT 0x0134 0x0324 0x0000 1 0 |
#define | IMXRT_PAD_GPIO_AD_B1_14__LPSPI3_SDO 0x0134 0x0324 0x0518 2 1 |
#define | IMXRT_PAD_GPIO_AD_B1_14__SAI1_sai_tx_bclk 0x0134 0x0324 0x05a8 3 1 |
#define | IMXRT_PAD_GPIO_AD_B1_14__CSI_csi_data03 0x0134 0x0324 0x0404 4 0 |
#define | IMXRT_PAD_GPIO_AD_B1_14__GPIO1_gpio_io30 0x0134 0x0324 0x0000 5 0 |
#define | IMXRT_PAD_GPIO_AD_B1_14__USDHC2_usdhc_data6 0x0134 0x0324 0x0600 6 1 |
#define | IMXRT_PAD_GPIO_AD_B1_14__KPP_kpp_row0 0x0134 0x0324 0x0000 7 0 |
#define | IMXRT_PAD_GPIO_AD_B1_14__ADC2_IN3 0x0134 0x0324 0x0000 5 0 |
#define | IMXRT_PAD_GPIO_AD_B1_14__CMP4_IN6 0x0134 0x0324 0x0000 5 0 |
#define | IMXRT_PAD_GPIO_AD_B1_15__FLEXSPI_FLEXSPI_A_SS0_B 0x0138 0x0328 0x0000 0 0 |
#define | IMXRT_PAD_GPIO_AD_B1_15__CMP4_OUT 0x0138 0x0328 0x0000 1 0 |
#define | IMXRT_PAD_GPIO_AD_B1_15__LPSPI3_SCK 0x0138 0x0328 0x0000 2 0 |
#define | IMXRT_PAD_GPIO_AD_B1_15__SAI1_sai_tx_sync 0x0138 0x0328 0x05ac 3 1 |
#define | IMXRT_PAD_GPIO_AD_B1_15__CSI_csi_data02 0x0138 0x0328 0x0400 4 0 |
#define | IMXRT_PAD_GPIO_AD_B1_15__GPIO1_gpio_io31 0x0138 0x0328 0x0000 5 0 |
#define | IMXRT_PAD_GPIO_AD_B1_15__USDHC2_usdhc_data7 0x0138 0x0328 0x0604 6 1 |
#define | IMXRT_PAD_GPIO_AD_B1_15__KPP_kpp_col0 0x0138 0x0328 0x0000 7 0 |
#define | IMXRT_PAD_GPIO_AD_B1_15__ADC2_IN4 0x0138 0x0328 0x0000 5 0 |
#define | IMXRT_PAD_GPIO_B0_00__LCDIF_lcdif_clk 0x013c 0x032c 0x0000 0 0 |
#define | IMXRT_PAD_GPIO_B0_00__TMR1_TIMER0 0x013c 0x032c 0x0000 1 0 /* Maybe you want to set IOMUXC_GPR_GPR6 QTIMER1_TRM0_INPUT_SEL to 0 */ |
#define | IMXRT_PAD_GPIO_B0_00__MQS_RIGHT 0x013c 0x032c 0x0000 2 0 |
#define | IMXRT_PAD_GPIO_B0_00__LPSPI4_PCS0 0x013c 0x032c 0x051c 3 0 |
#define | IMXRT_PAD_GPIO_B0_00__FLEXIO2_IO00 0x013c 0x032c 0x0000 4 0 |
#define | IMXRT_PAD_GPIO_B0_00__GPIO2_gpio_io00 0x013c 0x032c 0x0000 5 0 |
#define | IMXRT_PAD_GPIO_B0_00__SEMC_CSX1 0x013c 0x032c 0x0000 6 0 |
#define | IMXRT_PAD_GPIO_B0_01__LCDIF_lcdif_enable 0x0140 0x0330 0x0000 0 0 |
#define | IMXRT_PAD_GPIO_B0_01__TMR1_TIMER1 0x0140 0x0330 0x0000 1 0 /* Maybe you want to set IOMUXC_GPR_GPR6 QTIMER1_TRM1_INPUT_SEL to 0 */ |
#define | IMXRT_PAD_GPIO_B0_01__MQS_LEFT 0x0140 0x0330 0x0000 2 0 |
#define | IMXRT_PAD_GPIO_B0_01__LPSPI4_SDI 0x0140 0x0330 0x0524 3 0 |
#define | IMXRT_PAD_GPIO_B0_01__FLEXIO2_IO01 0x0140 0x0330 0x0000 4 0 |
#define | IMXRT_PAD_GPIO_B0_01__GPIO2_gpio_io01 0x0140 0x0330 0x0000 5 0 |
#define | IMXRT_PAD_GPIO_B0_01__SEMC_CSX2 0x0140 0x0330 0x0000 6 0 |
#define | IMXRT_PAD_GPIO_B0_02__LCDIF_lcdif_hsync 0x0144 0x0334 0x0000 0 0 |
#define | IMXRT_PAD_GPIO_B0_02__TMR1_TIMER2 0x0144 0x0334 0x0000 1 0 /* Maybe you want to set IOMUXC_GPR_GPR6 QTIMER1_TRM2_INPUT_SEL to 0 */ |
#define | IMXRT_PAD_GPIO_B0_02__CAN1_TX 0x0144 0x0334 0x0000 2 0 |
#define | IMXRT_PAD_GPIO_B0_02__LPSPI4_SDO 0x0144 0x0334 0x0528 3 0 |
#define | IMXRT_PAD_GPIO_B0_02__FLEXIO2_IO02 0x0144 0x0334 0x0000 4 0 |
#define | IMXRT_PAD_GPIO_B0_02__GPIO2_gpio_io02 0x0144 0x0334 0x0000 5 0 |
#define | IMXRT_PAD_GPIO_B0_02__SEMC_CSX3 0x0144 0x0334 0x0000 6 0 |
#define | IMXRT_PAD_GPIO_B0_03__LCDIF_lcdif_vsync 0x0148 0x0338 0x0000 0 0 |
#define | IMXRT_PAD_GPIO_B0_03__TMR2_TIMER0 0x0148 0x0338 0x056c 1 1 /* Maybe you want to set IOMUXC_GPR_GPR6 QTIMER2_TRM0_INPUT_SEL to 0 */ |
#define | IMXRT_PAD_GPIO_B0_03__CAN1_RX 0x0148 0x0338 0x044c 2 3 |
#define | IMXRT_PAD_GPIO_B0_03__LPSPI4_SCK 0x0148 0x0338 0x0520 3 0 |
#define | IMXRT_PAD_GPIO_B0_03__FLEXIO2_IO03 0x0148 0x0338 0x0000 4 0 |
#define | IMXRT_PAD_GPIO_B0_03__GPIO2_gpio_io03 0x0148 0x0338 0x0000 5 0 |
#define | IMXRT_PAD_GPIO_B0_03__WDOG2_wdog_rst_b_deb 0x0148 0x0338 0x0000 6 0 |
#define | IMXRT_PAD_GPIO_B0_04__LCDIF_lcdif_data00 0x014c 0x033c 0x0000 0 0 |
#define | IMXRT_PAD_GPIO_B0_04__TMR2_TIMER1 0x014c 0x033c 0x0570 1 1 /* Maybe you want to set IOMUXC_GPR_GPR6 QTIMER2_TRM1_INPUT_SEL to 0 */ |
#define | IMXRT_PAD_GPIO_B0_04__LPI2C2_SCL 0x014c 0x033c 0x04d4 2 1 |
#define | IMXRT_PAD_GPIO_B0_04__ARM_TRACE0 0x014c 0x033c 0x0000 3 0 |
#define | IMXRT_PAD_GPIO_B0_04__FLEXIO2_IO04 0x014c 0x033c 0x0000 4 0 |
#define | IMXRT_PAD_GPIO_B0_04__GPIO2_gpio_io04 0x014c 0x033c 0x0000 5 0 |
#define | IMXRT_PAD_GPIO_B0_04__SRC_BOOT_CFG0 0x014c 0x033c 0x0000 6 0 |
#define | IMXRT_PAD_GPIO_B0_05__LCDIF_lcdif_data01 0x0150 0x0340 0x0000 0 0 |
#define | IMXRT_PAD_GPIO_B0_05__TMR2_TIMER2 0x0150 0x0340 0x0574 1 1 /* Maybe you want to set IOMUXC_GPR_GPR6 QTIMER2_TRM2_INPUT_SEL to 0 */ |
#define | IMXRT_PAD_GPIO_B0_05__LPI2C2_SDA 0x0150 0x0340 0x04d8 2 1 |
#define | IMXRT_PAD_GPIO_B0_05__ARM_TRACE1 0x0150 0x0340 0x0000 3 0 |
#define | IMXRT_PAD_GPIO_B0_05__FLEXIO2_IO05 0x0150 0x0340 0x0000 4 0 |
#define | IMXRT_PAD_GPIO_B0_05__GPIO2_gpio_io05 0x0150 0x0340 0x0000 5 0 |
#define | IMXRT_PAD_GPIO_B0_05__SRC_BOOT_CFG1 0x0150 0x0340 0x0000 6 0 |
#define | IMXRT_PAD_GPIO_B0_06__LCDIF_lcdif_data02 0x0154 0x0344 0x0000 0 0 |
#define | IMXRT_PAD_GPIO_B0_06__TMR3_TIMER0 0x0154 0x0344 0x057c 1 2 /* Maybe you want to set IOMUXC_GPR_GPR6 QTIMER3_TRM0_INPUT_SEL to 0 */ |
#define | IMXRT_PAD_GPIO_B0_06__PWM2_A0 0x0154 0x0344 0x0478 2 1 |
#define | IMXRT_PAD_GPIO_B0_06__ARM_TRACE2 0x0154 0x0344 0x0000 3 0 |
#define | IMXRT_PAD_GPIO_B0_06__FLEXIO2_IO06 0x0154 0x0344 0x0000 4 0 |
#define | IMXRT_PAD_GPIO_B0_06__GPIO2_gpio_io06 0x0154 0x0344 0x0000 5 0 |
#define | IMXRT_PAD_GPIO_B0_06__SRC_BOOT_CFG2 0x0154 0x0344 0x0000 6 0 |
#define | IMXRT_PAD_GPIO_B0_07__LCDIF_lcdif_data03 0x0158 0x0348 0x0000 0 0 |
#define | IMXRT_PAD_GPIO_B0_07__TMR3_TIMER1 0x0158 0x0348 0x0580 1 2 /* Maybe you want to set IOMUXC_GPR_GPR6 QTIMER3_TRM1_INPUT_SEL to 0 */ |
#define | IMXRT_PAD_GPIO_B0_07__PWM2_B0 0x0158 0x0348 0x0488 2 1 |
#define | IMXRT_PAD_GPIO_B0_07__ARM_TRACE3 0x0158 0x0348 0x0000 3 0 |
#define | IMXRT_PAD_GPIO_B0_07__FLEXIO2_IO07 0x0158 0x0348 0x0000 4 0 |
#define | IMXRT_PAD_GPIO_B0_07__GPIO2_gpio_io07 0x0158 0x0348 0x0000 5 0 |
#define | IMXRT_PAD_GPIO_B0_07__SRC_BOOT_CFG3 0x0158 0x0348 0x0000 6 0 |
#define | IMXRT_PAD_GPIO_B0_08__LCDIF_lcdif_data04 0x015c 0x034c 0x0000 0 0 |
#define | IMXRT_PAD_GPIO_B0_08__TMR3_TIMER2 0x015c 0x034c 0x0584 1 2 /* Maybe you want to set IOMUXC_GPR_GPR6 QTIMER3_TRM2_INPUT_SEL to 0 */ |
#define | IMXRT_PAD_GPIO_B0_08__PWM2_A1 0x015c 0x034c 0x047c 2 1 |
#define | IMXRT_PAD_GPIO_B0_08__LPUART3_TX 0x015c 0x034c 0x053c 3 2 |
#define | IMXRT_PAD_GPIO_B0_08__FLEXIO2_IO08 0x015c 0x034c 0x0000 4 0 |
#define | IMXRT_PAD_GPIO_B0_08__GPIO2_gpio_io08 0x015c 0x034c 0x0000 5 0 |
#define | IMXRT_PAD_GPIO_B0_08__SRC_BOOT_CFG4 0x015c 0x034c 0x0000 6 0 |
#define | IMXRT_PAD_GPIO_B0_09__LCDIF_lcdif_data05 0x0160 0x0350 0x0000 0 0 |
#define | IMXRT_PAD_GPIO_B0_09__TMR4_TIMER0 0x0160 0x0350 0x0000 1 0 /* Maybe you want to set IOMUXC_GPR_GPR6 QTIMER4_TRM0_INPUT_SEL to 0 */ |
#define | IMXRT_PAD_GPIO_B0_09__PWM2_B1 0x0160 0x0350 0x048c 2 1 |
#define | IMXRT_PAD_GPIO_B0_09__LPUART3_RX 0x0160 0x0350 0x0538 3 2 |
#define | IMXRT_PAD_GPIO_B0_09__FLEXIO2_IO09 0x0160 0x0350 0x0000 4 0 |
#define | IMXRT_PAD_GPIO_B0_09__GPIO2_gpio_io09 0x0160 0x0350 0x0000 5 0 |
#define | IMXRT_PAD_GPIO_B0_09__SRC_BOOT_CFG5 0x0160 0x0350 0x0000 6 0 |
#define | IMXRT_PAD_GPIO_B0_10__LCDIF_lcdif_data06 0x0164 0x0354 0x0000 0 0 |
#define | IMXRT_PAD_GPIO_B0_10__TMR4_TIMER1 0x0164 0x0354 0x0000 1 0 /* Maybe you want to set IOMUXC_GPR_GPR6 QTIMER4_TRM1_INPUT_SEL to 0 */ |
#define | IMXRT_PAD_GPIO_B0_10__PWM2_A2 0x0164 0x0354 0x0480 2 1 |
#define | IMXRT_PAD_GPIO_B0_10__SAI1_sai_tx_data3 0x0164 0x0354 0x0598 3 1 |
#define | IMXRT_PAD_GPIO_B0_10__FLEXIO2_IO10 0x0164 0x0354 0x0000 4 0 |
#define | IMXRT_PAD_GPIO_B0_10__GPIO2_gpio_io10 0x0164 0x0354 0x0000 5 0 |
#define | IMXRT_PAD_GPIO_B0_10__SRC_BOOT_CFG6 0x0164 0x0354 0x0000 6 0 |
#define | IMXRT_PAD_GPIO_B0_11__LCDIF_lcdif_data07 0x0168 0x0358 0x0000 0 0 |
#define | IMXRT_PAD_GPIO_B0_11__TMR4_TIMER2 0x0168 0x0358 0x0000 1 0 /* Maybe you want to set IOMUXC_GPR_GPR6 QTIMER4_TRM2_INPUT_SEL to 0 */ |
#define | IMXRT_PAD_GPIO_B0_11__PWM2_B2 0x0168 0x0358 0x0490 2 1 |
#define | IMXRT_PAD_GPIO_B0_11__SAI1_sai_tx_data2 0x0168 0x0358 0x059c 3 1 |
#define | IMXRT_PAD_GPIO_B0_11__FLEXIO2_IO11 0x0168 0x0358 0x0000 4 0 |
#define | IMXRT_PAD_GPIO_B0_11__GPIO2_gpio_io11 0x0168 0x0358 0x0000 5 0 |
#define | IMXRT_PAD_GPIO_B0_11__SRC_BOOT_CFG7 0x0168 0x0358 0x0000 6 0 |
#define | IMXRT_PAD_GPIO_B0_12__LCDIF_lcdif_data08 0x016c 0x035c 0x0000 0 0 |
#define | IMXRT_PAD_GPIO_B0_12__XBARA1_OUT10 0x016c 0x035c 0x0000 1 0 /* Maybe you want to set IOMUXC_GPR_GPR6 IOMUXC_XBAR_DIR_SEL_10 to 0x1 */ |
#define | IMXRT_PAD_GPIO_B0_12__XBARA1_IN10 0x016c 0x035c 0x0000 1 0 /* Maybe you want to set IOMUXC_GPR_GPR6 IOMUXC_XBAR_DIR_SEL_10 to 0 */ |
#define | IMXRT_PAD_GPIO_B0_12__ARM_arm_trace_clk 0x016c 0x035c 0x0000 2 0 |
#define | IMXRT_PAD_GPIO_B0_12__SAI1_sai_tx_data1 0x016c 0x035c 0x05a0 3 1 |
#define | IMXRT_PAD_GPIO_B0_12__FLEXIO2_IO12 0x016c 0x035c 0x0000 4 0 |
#define | IMXRT_PAD_GPIO_B0_12__GPIO2_gpio_io12 0x016c 0x035c 0x0000 5 0 |
#define | IMXRT_PAD_GPIO_B0_12__SRC_BOOT_CFG8 0x016c 0x035c 0x0000 6 0 |
#define | IMXRT_PAD_GPIO_B0_13__LCDIF_lcdif_data09 0x0170 0x0360 0x0000 0 0 |
#define | IMXRT_PAD_GPIO_B0_13__XBARA1_OUT11 0x0170 0x0360 0x0000 1 0 /* Maybe you want to set IOMUXC_GPR_GPR6 IOMUXC_XBAR_DIR_SEL_11 to 0x1 */ |
#define | IMXRT_PAD_GPIO_B0_13__XBARA1_IN11 0x0170 0x0360 0x0000 1 0 /* Maybe you want to set IOMUXC_GPR_GPR6 IOMUXC_XBAR_DIR_SEL_11 to 0 */ |
#define | IMXRT_PAD_GPIO_B0_13__ARM_arm_trace_swo 0x0170 0x0360 0x0000 2 0 |
#define | IMXRT_PAD_GPIO_B0_13__SAI1_sai_mclk 0x0170 0x0360 0x058c 3 2 |
#define | IMXRT_PAD_GPIO_B0_13__FLEXIO2_IO13 0x0170 0x0360 0x0000 4 0 |
#define | IMXRT_PAD_GPIO_B0_13__GPIO2_gpio_io13 0x0170 0x0360 0x0000 5 0 |
#define | IMXRT_PAD_GPIO_B0_13__SRC_BOOT_CFG9 0x0170 0x0360 0x0000 6 0 |
#define | IMXRT_PAD_GPIO_B0_14__LCDIF_lcdif_data10 0x0174 0x0364 0x0000 0 0 |
#define | IMXRT_PAD_GPIO_B0_14__XBARA1_OUT12 0x0174 0x0364 0x0000 1 0 /* Maybe you want to set IOMUXC_GPR_GPR6 IOMUXC_XBAR_DIR_SEL_12 to 0x1 */ |
#define | IMXRT_PAD_GPIO_B0_14__XBARA1_IN12 0x0174 0x0364 0x0000 1 0 /* Maybe you want to set IOMUXC_GPR_GPR6 IOMUXC_XBAR_DIR_SEL_12 to 0 */ |
#define | IMXRT_PAD_GPIO_B0_14__ARM_arm_cm7_txev 0x0174 0x0364 0x0000 2 0 |
#define | IMXRT_PAD_GPIO_B0_14__SAI1_sai_rx_sync 0x0174 0x0364 0x05a4 3 2 |
#define | IMXRT_PAD_GPIO_B0_14__FLEXIO2_IO14 0x0174 0x0364 0x0000 4 0 |
#define | IMXRT_PAD_GPIO_B0_14__GPIO2_gpio_io14 0x0174 0x0364 0x0000 5 0 |
#define | IMXRT_PAD_GPIO_B0_14__SRC_BOOT_CFG10 0x0174 0x0364 0x0000 6 0 |
#define | IMXRT_PAD_GPIO_B0_15__LCDIF_lcdif_data11 0x0178 0x0368 0x0000 0 0 |
#define | IMXRT_PAD_GPIO_B0_15__XBARA1_OUT13 0x0178 0x0368 0x0000 1 0 /* Maybe you want to set IOMUXC_GPR_GPR6 IOMUXC_XBAR_DIR_SEL_13 to 0x1 */ |
#define | IMXRT_PAD_GPIO_B0_15__XBARA1_IN13 0x0178 0x0368 0x0000 1 0 /* Maybe you want to set IOMUXC_GPR_GPR6 IOMUXC_XBAR_DIR_SEL_13 to 0 */ |
#define | IMXRT_PAD_GPIO_B0_15__ARM_arm_cm7_rxev 0x0178 0x0368 0x0000 2 0 |
#define | IMXRT_PAD_GPIO_B0_15__SAI1_sai_rx_bclk 0x0178 0x0368 0x0590 3 2 |
#define | IMXRT_PAD_GPIO_B0_15__FLEXIO2_IO15 0x0178 0x0368 0x0000 4 0 |
#define | IMXRT_PAD_GPIO_B0_15__GPIO2_gpio_io15 0x0178 0x0368 0x0000 5 0 |
#define | IMXRT_PAD_GPIO_B0_15__SRC_BOOT_CFG11 0x0178 0x0368 0x0000 6 0 |
#define | IMXRT_PAD_GPIO_B1_00__LCDIF_lcdif_data12 0x017c 0x036c 0x0000 0 0 |
#define | IMXRT_PAD_GPIO_B1_00__XBARA1_OUT14 0x017c 0x036c 0x0644 1 1 /* Maybe you want to set IOMUXC_GPR_GPR6 IOMUXC_XBAR_DIR_SEL_14 to 0x1 */ |
#define | IMXRT_PAD_GPIO_B1_00__XBARA1_IN14 0x017c 0x036c 0x0644 1 1 /* Maybe you want to set IOMUXC_GPR_GPR6 IOMUXC_XBAR_DIR_SEL_14 to 0 */ |
#define | IMXRT_PAD_GPIO_B1_00__LPUART4_TX 0x017c 0x036c 0x0544 2 2 |
#define | IMXRT_PAD_GPIO_B1_00__SAI1_sai_rx_data0 0x017c 0x036c 0x0594 3 2 |
#define | IMXRT_PAD_GPIO_B1_00__FLEXIO2_IO16 0x017c 0x036c 0x0000 4 0 |
#define | IMXRT_PAD_GPIO_B1_00__GPIO2_gpio_io16 0x017c 0x036c 0x0000 5 0 |
#define | IMXRT_PAD_GPIO_B1_00__PWM1_A3 0x017c 0x036c 0x0454 6 4 |
#define | IMXRT_PAD_GPIO_B1_01__LCDIF_lcdif_data13 0x0180 0x0370 0x0000 0 0 |
#define | IMXRT_PAD_GPIO_B1_01__XBARA1_OUT15 0x0180 0x0370 0x0648 1 1 /* Maybe you want to set IOMUXC_GPR_GPR6 IOMUXC_XBAR_DIR_SEL_15 to 0x1 */ |
#define | IMXRT_PAD_GPIO_B1_01__XBARA1_IN15 0x0180 0x0370 0x0648 1 1 /* Maybe you want to set IOMUXC_GPR_GPR6 IOMUXC_XBAR_DIR_SEL_15 to 0 */ |
#define | IMXRT_PAD_GPIO_B1_01__LPUART4_RX 0x0180 0x0370 0x0540 2 2 |
#define | IMXRT_PAD_GPIO_B1_01__SAI1_sai_tx_data0 0x0180 0x0370 0x0000 3 0 |
#define | IMXRT_PAD_GPIO_B1_01__FLEXIO2_IO17 0x0180 0x0370 0x0000 4 0 |
#define | IMXRT_PAD_GPIO_B1_01__GPIO2_gpio_io17 0x0180 0x0370 0x0000 5 0 |
#define | IMXRT_PAD_GPIO_B1_01__PWM1_B3 0x0180 0x0370 0x0464 6 4 |
#define | IMXRT_PAD_GPIO_B1_02__LCDIF_lcdif_data14 0x0184 0x0374 0x0000 0 0 |
#define | IMXRT_PAD_GPIO_B1_02__XBARA1_OUT16 0x0184 0x0374 0x064c 1 1 /* Maybe you want to set IOMUXC_GPR_GPR6 IOMUXC_XBAR_DIR_SEL_16 to 0x1 */ |
#define | IMXRT_PAD_GPIO_B1_02__XBARA1_IN16 0x0184 0x0374 0x064c 1 1 /* Maybe you want to set IOMUXC_GPR_GPR6 IOMUXC_XBAR_DIR_SEL_16 to 0 */ |
#define | IMXRT_PAD_GPIO_B1_02__LPSPI4_PCS2 0x0184 0x0374 0x0000 2 0 |
#define | IMXRT_PAD_GPIO_B1_02__SAI1_sai_tx_bclk 0x0184 0x0374 0x05a8 3 2 |
#define | IMXRT_PAD_GPIO_B1_02__FLEXIO2_IO18 0x0184 0x0374 0x0000 4 0 |
#define | IMXRT_PAD_GPIO_B1_02__GPIO2_gpio_io18 0x0184 0x0374 0x0000 5 0 |
#define | IMXRT_PAD_GPIO_B1_02__PWM2_A3 0x0184 0x0374 0x0474 6 4 |
#define | IMXRT_PAD_GPIO_B1_03__LCDIF_lcdif_data15 0x0188 0x0378 0x0000 0 0 |
#define | IMXRT_PAD_GPIO_B1_03__XBARA1_OUT17 0x0188 0x0378 0x062c 1 3 /* Maybe you want to set IOMUXC_GPR_GPR6 IOMUXC_XBAR_DIR_SEL_17 to 0x1 */ |
#define | IMXRT_PAD_GPIO_B1_03__XBARA1_IN17 0x0188 0x0378 0x062c 1 3 /* Maybe you want to set IOMUXC_GPR_GPR6 IOMUXC_XBAR_DIR_SEL_17 to 0 */ |
#define | IMXRT_PAD_GPIO_B1_03__LPSPI4_PCS1 0x0188 0x0378 0x0000 2 0 |
#define | IMXRT_PAD_GPIO_B1_03__SAI1_sai_tx_sync 0x0188 0x0378 0x05ac 3 2 |
#define | IMXRT_PAD_GPIO_B1_03__FLEXIO2_IO19 0x0188 0x0378 0x0000 4 0 |
#define | IMXRT_PAD_GPIO_B1_03__GPIO2_gpio_io19 0x0188 0x0378 0x0000 5 0 |
#define | IMXRT_PAD_GPIO_B1_03__PWM2_B3 0x0188 0x0378 0x0484 6 3 |
#define | IMXRT_PAD_GPIO_B1_04__LCDIF_lcdif_data16 0x018c 0x037c 0x0000 0 0 |
#define | IMXRT_PAD_GPIO_B1_04__LPSPI4_PCS0 0x018c 0x037c 0x051c 1 1 |
#define | IMXRT_PAD_GPIO_B1_04__CSI_csi_data15 0x018c 0x037c 0x0000 2 0 |
#define | IMXRT_PAD_GPIO_B1_04__ENET_enet_rx_data0 0x018c 0x037c 0x0434 3 1 |
#define | IMXRT_PAD_GPIO_B1_04__FLEXIO2_IO20 0x018c 0x037c 0x0000 4 0 |
#define | IMXRT_PAD_GPIO_B1_04__GPIO2_gpio_io20 0x018c 0x037c 0x0000 5 0 |
#define | IMXRT_PAD_GPIO_B1_05__LCDIF_lcdif_data17 0x0190 0x0380 0x0000 0 0 |
#define | IMXRT_PAD_GPIO_B1_05__LPSPI4_SDI 0x0190 0x0380 0x0524 1 1 |
#define | IMXRT_PAD_GPIO_B1_05__CSI_csi_data14 0x0190 0x0380 0x0000 2 0 |
#define | IMXRT_PAD_GPIO_B1_05__ENET_enet_rx_data1 0x0190 0x0380 0x0438 3 1 |
#define | IMXRT_PAD_GPIO_B1_05__FLEXIO2_IO21 0x0190 0x0380 0x0000 4 0 |
#define | IMXRT_PAD_GPIO_B1_05__GPIO2_gpio_io21 0x0190 0x0380 0x0000 5 0 |
#define | IMXRT_PAD_GPIO_B1_06__LCDIF_lcdif_data18 0x0194 0x0384 0x0000 0 0 |
#define | IMXRT_PAD_GPIO_B1_06__LPSPI4_SDO 0x0194 0x0384 0x0528 1 1 |
#define | IMXRT_PAD_GPIO_B1_06__CSI_csi_data13 0x0194 0x0384 0x0000 2 0 |
#define | IMXRT_PAD_GPIO_B1_06__ENET_enet_rx_en 0x0194 0x0384 0x043c 3 1 |
#define | IMXRT_PAD_GPIO_B1_06__FLEXIO2_IO22 0x0194 0x0384 0x0000 4 0 |
#define | IMXRT_PAD_GPIO_B1_06__GPIO2_gpio_io22 0x0194 0x0384 0x0000 5 0 |
#define | IMXRT_PAD_GPIO_B1_07__LCDIF_lcdif_data19 0x0198 0x0388 0x0000 0 0 |
#define | IMXRT_PAD_GPIO_B1_07__LPSPI4_SCK 0x0198 0x0388 0x0520 1 1 |
#define | IMXRT_PAD_GPIO_B1_07__CSI_csi_data12 0x0198 0x0388 0x0000 2 0 |
#define | IMXRT_PAD_GPIO_B1_07__ENET_enet_tx_data0 0x0198 0x0388 0x0000 3 0 |
#define | IMXRT_PAD_GPIO_B1_07__FLEXIO2_IO23 0x0198 0x0388 0x0000 4 0 |
#define | IMXRT_PAD_GPIO_B1_07__GPIO2_gpio_io23 0x0198 0x0388 0x0000 5 0 |
#define | IMXRT_PAD_GPIO_B1_08__LCDIF_lcdif_data20 0x019c 0x038c 0x0000 0 0 |
#define | IMXRT_PAD_GPIO_B1_08__TMR1_TIMER3 0x019c 0x038c 0x0000 1 0 /* Maybe you want to set IOMUXC_GPR_GPR6 QTIMER1_TRM3_INPUT_SEL to 0 */ |
#define | IMXRT_PAD_GPIO_B1_08__CSI_csi_data11 0x019c 0x038c 0x0000 2 0 |
#define | IMXRT_PAD_GPIO_B1_08__ENET_enet_tx_data1 0x019c 0x038c 0x0000 3 0 |
#define | IMXRT_PAD_GPIO_B1_08__FLEXIO2_IO24 0x019c 0x038c 0x0000 4 0 |
#define | IMXRT_PAD_GPIO_B1_08__GPIO2_gpio_io24 0x019c 0x038c 0x0000 5 0 |
#define | IMXRT_PAD_GPIO_B1_08__CAN2_TX 0x019c 0x038c 0x0000 6 0 |
#define | IMXRT_PAD_GPIO_B1_09__LCDIF_lcdif_data21 0x01a0 0x0390 0x0000 0 0 |
#define | IMXRT_PAD_GPIO_B1_09__TMR2_TIMER3 0x01a0 0x0390 0x0578 1 1 /* Maybe you want to set IOMUXC_GPR_GPR6 QTIMER2_TRM3_INPUT_SEL to 0 */ |
#define | IMXRT_PAD_GPIO_B1_09__CSI_csi_data10 0x01a0 0x0390 0x0000 2 0 |
#define | IMXRT_PAD_GPIO_B1_09__ENET_enet_tx_en 0x01a0 0x0390 0x0000 3 0 |
#define | IMXRT_PAD_GPIO_B1_09__FLEXIO2_IO25 0x01a0 0x0390 0x0000 4 0 |
#define | IMXRT_PAD_GPIO_B1_09__GPIO2_gpio_io25 0x01a0 0x0390 0x0000 5 0 |
#define | IMXRT_PAD_GPIO_B1_09__CAN2_RX 0x01a0 0x0390 0x0450 6 3 |
#define | IMXRT_PAD_GPIO_B1_10__LCDIF_lcdif_data22 0x01a4 0x0394 0x0000 0 0 |
#define | IMXRT_PAD_GPIO_B1_10__TMR3_TIMER3 0x01a4 0x0394 0x0588 1 2 /* Maybe you want to set IOMUXC_GPR_GPR6 QTIMER3_TRM3_INPUT_SEL to 0 */ |
#define | IMXRT_PAD_GPIO_B1_10__CSI_csi_data00 0x01a4 0x0394 0x0000 2 0 |
#define | IMXRT_PAD_GPIO_B1_10__ENET_enet_tx_clk 0x01a4 0x0394 0x0448 3 1 |
#define | IMXRT_PAD_GPIO_B1_10__FLEXIO2_IO26 0x01a4 0x0394 0x0000 4 0 |
#define | IMXRT_PAD_GPIO_B1_10__GPIO2_gpio_io26 0x01a4 0x0394 0x0000 5 0 |
#define | IMXRT_PAD_GPIO_B1_10__ENET_enet_ref_clk 0x01a4 0x0394 0x042c 6 1 |
#define | IMXRT_PAD_GPIO_B1_11__LCDIF_lcdif_data23 0x01a8 0x0398 0x0000 0 0 |
#define | IMXRT_PAD_GPIO_B1_11__TMR4_TIMER3 0x01a8 0x0398 0x0000 1 0 /* Maybe you want to set IOMUXC_GPR_GPR6 QTIMER4_TRM3_INPUT_SEL to 0 */ |
#define | IMXRT_PAD_GPIO_B1_11__CSI_csi_data01 0x01a8 0x0398 0x0000 2 0 |
#define | IMXRT_PAD_GPIO_B1_11__ENET_enet_rx_er 0x01a8 0x0398 0x0440 3 1 |
#define | IMXRT_PAD_GPIO_B1_11__FLEXIO2_IO27 0x01a8 0x0398 0x0000 4 0 |
#define | IMXRT_PAD_GPIO_B1_11__GPIO2_gpio_io27 0x01a8 0x0398 0x0000 5 0 |
#define | IMXRT_PAD_GPIO_B1_11__LPSPI4_PCS3 0x01a8 0x0398 0x0000 6 0 |
#define | IMXRT_PAD_GPIO_B1_12__LPUART5_TX 0x01ac 0x039c 0x054c 1 1 |
#define | IMXRT_PAD_GPIO_B1_12__CSI_csi_pixclk 0x01ac 0x039c 0x0424 2 1 |
#define | IMXRT_PAD_GPIO_B1_12__ENET_1588_EVENT0_IN 0x01ac 0x039c 0x0444 3 2 |
#define | IMXRT_PAD_GPIO_B1_12__FLEXIO2_IO28 0x01ac 0x039c 0x0000 4 0 |
#define | IMXRT_PAD_GPIO_B1_12__GPIO2_gpio_io28 0x01ac 0x039c 0x0000 5 0 |
#define | IMXRT_PAD_GPIO_B1_12__USDHC1_usdhc_cd_b 0x01ac 0x039c 0x05d4 6 2 |
#define | IMXRT_PAD_GPIO_B1_13__WDOG1_wdog_b 0x01b0 0x03a0 0x0000 0 0 |
#define | IMXRT_PAD_GPIO_B1_13__LPUART5_RX 0x01b0 0x03a0 0x0548 1 1 |
#define | IMXRT_PAD_GPIO_B1_13__CSI_csi_vsync 0x01b0 0x03a0 0x0428 2 2 |
#define | IMXRT_PAD_GPIO_B1_13__ENET_1588_EVENT0_OUT 0x01b0 0x03a0 0x0000 3 0 |
#define | IMXRT_PAD_GPIO_B1_13__FLEXIO2_IO29 0x01b0 0x03a0 0x0000 4 0 |
#define | IMXRT_PAD_GPIO_B1_13__GPIO2_gpio_io29 0x01b0 0x03a0 0x0000 5 0 |
#define | IMXRT_PAD_GPIO_B1_13__USDHC1_usdhc_wp 0x01b0 0x03a0 0x05d8 6 3 |
#define | IMXRT_PAD_GPIO_B1_14__ENET_enet_mdc 0x01b4 0x03a4 0x0000 0 0 |
#define | IMXRT_PAD_GPIO_B1_14__PWM4_A2 0x01b4 0x03a4 0x049c 1 1 |
#define | IMXRT_PAD_GPIO_B1_14__CSI_csi_hsync 0x01b4 0x03a4 0x0420 2 2 |
#define | IMXRT_PAD_GPIO_B1_14__XBARA1_IN02 0x01b4 0x03a4 0x060c 3 1 |
#define | IMXRT_PAD_GPIO_B1_14__FLEXIO2_IO30 0x01b4 0x03a4 0x0000 4 0 |
#define | IMXRT_PAD_GPIO_B1_14__GPIO2_gpio_io30 0x01b4 0x03a4 0x0000 5 0 |
#define | IMXRT_PAD_GPIO_B1_14__USDHC1_usdhc_vselect 0x01b4 0x03a4 0x0000 6 0 |
#define | IMXRT_PAD_GPIO_B1_15__ENET_enet_mdio 0x01b8 0x03a8 0x0430 0 2 |
#define | IMXRT_PAD_GPIO_B1_15__PWM4_A3 0x01b8 0x03a8 0x04a0 1 1 |
#define | IMXRT_PAD_GPIO_B1_15__CSI_csi_mclk 0x01b8 0x03a8 0x0000 2 0 |
#define | IMXRT_PAD_GPIO_B1_15__XBARA1_IN03 0x01b8 0x03a8 0x0610 3 1 |
#define | IMXRT_PAD_GPIO_B1_15__FLEXIO2_IO31 0x01b8 0x03a8 0x0000 4 0 |
#define | IMXRT_PAD_GPIO_B1_15__GPIO2_gpio_io31 0x01b8 0x03a8 0x0000 5 0 |
#define | IMXRT_PAD_GPIO_B1_15__USDHC1_usdhc_reset_b 0x01b8 0x03a8 0x0000 6 0 |
#define | IMXRT_PAD_GPIO_EMC_00__SEMC_DATA00 0x0014 0x0204 0x0000 0 0 |
#define | IMXRT_PAD_GPIO_EMC_00__PWM4_A0 0x0014 0x0204 0x0494 1 0 |
#define | IMXRT_PAD_GPIO_EMC_00__LPSPI2_SCK 0x0014 0x0204 0x0500 2 1 |
#define | IMXRT_PAD_GPIO_EMC_00__XBARA1_IN02 0x0014 0x0204 0x060c 3 0 |
#define | IMXRT_PAD_GPIO_EMC_00__FLEXIO1_IO00 0x0014 0x0204 0x0000 4 0 |
#define | IMXRT_PAD_GPIO_EMC_00__GPIO4_gpio_io00 0x0014 0x0204 0x0000 5 0 |
#define | IMXRT_PAD_GPIO_EMC_01__SEMC_DATA01 0x0018 0x0208 0x0000 0 0 |
#define | IMXRT_PAD_GPIO_EMC_01__PWM4_B0 0x0018 0x0208 0x0000 1 0 |
#define | IMXRT_PAD_GPIO_EMC_01__LPSPI2_PCS0 0x0018 0x0208 0x04fc 2 1 |
#define | IMXRT_PAD_GPIO_EMC_01__XBARA1_IN03 0x0018 0x0208 0x0610 3 0 |
#define | IMXRT_PAD_GPIO_EMC_01__FLEXIO1_IO01 0x0018 0x0208 0x0000 4 0 |
#define | IMXRT_PAD_GPIO_EMC_01__GPIO4_gpio_io01 0x0018 0x0208 0x0000 5 0 |
#define | IMXRT_PAD_GPIO_EMC_02__SEMC_DATA02 0x001c 0x020c 0x0000 0 0 |
#define | IMXRT_PAD_GPIO_EMC_02__PWM4_A1 0x001c 0x020c 0x0498 1 0 |
#define | IMXRT_PAD_GPIO_EMC_02__LPSPI2_SDO 0x001c 0x020c 0x0508 2 1 |
#define | IMXRT_PAD_GPIO_EMC_02__XBARA1_OUT04 0x001c 0x020c 0x0614 3 0 /* Maybe you want to set IOMUXC_GPR_GPR6 IOMUXC_XBAR_DIR_SEL_4 to 0x1 */ |
#define | IMXRT_PAD_GPIO_EMC_02__XBARA1_IN04 0x001c 0x020c 0x0614 3 0 /* Maybe you want to set IOMUXC_GPR_GPR6 IOMUXC_XBAR_DIR_SEL_4 to 0 */ |
#define | IMXRT_PAD_GPIO_EMC_02__FLEXIO1_IO02 0x001c 0x020c 0x0000 4 0 |
#define | IMXRT_PAD_GPIO_EMC_02__GPIO4_gpio_io02 0x001c 0x020c 0x0000 5 0 |
#define | IMXRT_PAD_GPIO_EMC_03__SEMC_DATA03 0x0020 0x0210 0x0000 0 0 |
#define | IMXRT_PAD_GPIO_EMC_03__PWM4_B1 0x0020 0x0210 0x0000 1 0 |
#define | IMXRT_PAD_GPIO_EMC_03__LPSPI2_SDI 0x0020 0x0210 0x0504 2 1 |
#define | IMXRT_PAD_GPIO_EMC_03__XBARA1_OUT05 0x0020 0x0210 0x0618 3 0 /* Maybe you want to set IOMUXC_GPR_GPR6 IOMUXC_XBAR_DIR_SEL_5 to 0x1 */ |
#define | IMXRT_PAD_GPIO_EMC_03__XBARA1_IN05 0x0020 0x0210 0x0618 3 0 /* Maybe you want to set IOMUXC_GPR_GPR6 IOMUXC_XBAR_DIR_SEL_5 to 0 */ |
#define | IMXRT_PAD_GPIO_EMC_03__FLEXIO1_IO03 0x0020 0x0210 0x0000 4 0 |
#define | IMXRT_PAD_GPIO_EMC_03__GPIO4_gpio_io03 0x0020 0x0210 0x0000 5 0 |
#define | IMXRT_PAD_GPIO_EMC_04__SEMC_DATA04 0x0024 0x0214 0x0000 0 0 |
#define | IMXRT_PAD_GPIO_EMC_04__PWM4_A2 0x0024 0x0214 0x049c 1 0 |
#define | IMXRT_PAD_GPIO_EMC_04__SAI2_sai_tx_data 0x0024 0x0214 0x0000 2 0 |
#define | IMXRT_PAD_GPIO_EMC_04__XBARA1_OUT06 0x0024 0x0214 0x061c 3 0 /* Maybe you want to set IOMUXC_GPR_GPR6 IOMUXC_XBAR_DIR_SEL_6 to 0x1 */ |
#define | IMXRT_PAD_GPIO_EMC_04__XBARA1_IN06 0x0024 0x0214 0x061c 3 0 /* Maybe you want to set IOMUXC_GPR_GPR6 IOMUXC_XBAR_DIR_SEL_6 to 0 */ |
#define | IMXRT_PAD_GPIO_EMC_04__FLEXIO1_IO04 0x0024 0x0214 0x0000 4 0 |
#define | IMXRT_PAD_GPIO_EMC_04__GPIO4_gpio_io04 0x0024 0x0214 0x0000 5 0 |
#define | IMXRT_PAD_GPIO_EMC_05__SEMC_DATA05 0x0028 0x0218 0x0000 0 0 |
#define | IMXRT_PAD_GPIO_EMC_05__PWM4_B2 0x0028 0x0218 0x0000 1 0 |
#define | IMXRT_PAD_GPIO_EMC_05__SAI2_sai_tx_sync 0x0028 0x0218 0x05c4 2 0 |
#define | IMXRT_PAD_GPIO_EMC_05__XBARA1_OUT07 0x0028 0x0218 0x0620 3 0 /* Maybe you want to set IOMUXC_GPR_GPR6 IOMUXC_XBAR_DIR_SEL_7 to 0x1 */ |
#define | IMXRT_PAD_GPIO_EMC_05__XBARA1_IN07 0x0028 0x0218 0x0620 3 0 /* Maybe you want to set IOMUXC_GPR_GPR6 IOMUXC_XBAR_DIR_SEL_7 to 0 */ |
#define | IMXRT_PAD_GPIO_EMC_05__FLEXIO1_IO05 0x0028 0x0218 0x0000 4 0 |
#define | IMXRT_PAD_GPIO_EMC_05__GPIO4_gpio_io05 0x0028 0x0218 0x0000 5 0 |
#define | IMXRT_PAD_GPIO_EMC_06__SEMC_DATA06 0x002c 0x021c 0x0000 0 0 |
#define | IMXRT_PAD_GPIO_EMC_06__PWM2_A0 0x002c 0x021c 0x0478 1 0 |
#define | IMXRT_PAD_GPIO_EMC_06__SAI2_sai_tx_bclk 0x002c 0x021c 0x05c0 2 0 |
#define | IMXRT_PAD_GPIO_EMC_06__XBARA1_OUT08 0x002c 0x021c 0x0624 3 0 /* Maybe you want to set IOMUXC_GPR_GPR6 IOMUXC_XBAR_DIR_SEL_8 to 0x1 */ |
#define | IMXRT_PAD_GPIO_EMC_06__XBARA1_IN08 0x002c 0x021c 0x0624 3 0 /* Maybe you want to set IOMUXC_GPR_GPR6 IOMUXC_XBAR_DIR_SEL_8 to 0 */ |
#define | IMXRT_PAD_GPIO_EMC_06__FLEXIO1_IO06 0x002c 0x021c 0x0000 4 0 |
#define | IMXRT_PAD_GPIO_EMC_06__GPIO4_gpio_io06 0x002c 0x021c 0x0000 5 0 |
#define | IMXRT_PAD_GPIO_EMC_07__SEMC_DATA07 0x0030 0x0220 0x0000 0 0 |
#define | IMXRT_PAD_GPIO_EMC_07__PWM2_B0 0x0030 0x0220 0x0488 1 0 |
#define | IMXRT_PAD_GPIO_EMC_07__SAI2_sai_mclk 0x0030 0x0220 0x05b0 2 0 |
#define | IMXRT_PAD_GPIO_EMC_07__XBARA1_OUT09 0x0030 0x0220 0x0628 3 0 /* Maybe you want to set IOMUXC_GPR_GPR6 IOMUXC_XBAR_DIR_SEL_9 to 0x1 */ |
#define | IMXRT_PAD_GPIO_EMC_07__XBARA1_IN09 0x0030 0x0220 0x0628 3 0 /* Maybe you want to set IOMUXC_GPR_GPR6 IOMUXC_XBAR_DIR_SEL_9 to 0 */ |
#define | IMXRT_PAD_GPIO_EMC_07__FLEXIO1_IO07 0x0030 0x0220 0x0000 4 0 |
#define | IMXRT_PAD_GPIO_EMC_07__GPIO4_gpio_io07 0x0030 0x0220 0x0000 5 0 |
#define | IMXRT_PAD_GPIO_EMC_08__SEMC_DM0 0x0034 0x0224 0x0000 0 0 |
#define | IMXRT_PAD_GPIO_EMC_08__PWM2_A1 0x0034 0x0224 0x047c 1 0 |
#define | IMXRT_PAD_GPIO_EMC_08__SAI2_sai_rx_data 0x0034 0x0224 0x05b8 2 0 |
#define | IMXRT_PAD_GPIO_EMC_08__XBARA1_OUT17 0x0034 0x0224 0x062c 3 0 /* Maybe you want to set IOMUXC_GPR_GPR6 IOMUXC_XBAR_DIR_SEL_17 to 0x1 */ |
#define | IMXRT_PAD_GPIO_EMC_08__XBARA1_IN17 0x0034 0x0224 0x062c 3 0 /* Maybe you want to set IOMUXC_GPR_GPR6 IOMUXC_XBAR_DIR_SEL_17 to 0 */ |
#define | IMXRT_PAD_GPIO_EMC_08__FLEXIO1_IO08 0x0034 0x0224 0x0000 4 0 |
#define | IMXRT_PAD_GPIO_EMC_08__GPIO4_gpio_io08 0x0034 0x0224 0x0000 5 0 |
#define | IMXRT_PAD_GPIO_EMC_09__SEMC_ADDR00 0x0038 0x0228 0x0000 0 0 |
#define | IMXRT_PAD_GPIO_EMC_09__PWM2_B1 0x0038 0x0228 0x048c 1 0 |
#define | IMXRT_PAD_GPIO_EMC_09__SAI2_sai_rx_sync 0x0038 0x0228 0x05bc 2 0 |
#define | IMXRT_PAD_GPIO_EMC_09__CAN2_TX 0x0038 0x0228 0x0000 3 0 |
#define | IMXRT_PAD_GPIO_EMC_09__FLEXIO1_IO09 0x0038 0x0228 0x0000 4 0 |
#define | IMXRT_PAD_GPIO_EMC_09__GPIO4_gpio_io09 0x0038 0x0228 0x0000 5 0 |
#define | IMXRT_PAD_GPIO_EMC_10__SEMC_ADDR01 0x003c 0x022c 0x0000 0 0 |
#define | IMXRT_PAD_GPIO_EMC_10__PWM2_A2 0x003c 0x022c 0x0480 1 0 |
#define | IMXRT_PAD_GPIO_EMC_10__SAI2_sai_rx_bclk 0x003c 0x022c 0x05b4 2 0 |
#define | IMXRT_PAD_GPIO_EMC_10__CAN2_RX 0x003c 0x022c 0x0450 3 0 |
#define | IMXRT_PAD_GPIO_EMC_10__FLEXIO1_IO10 0x003c 0x022c 0x0000 4 0 |
#define | IMXRT_PAD_GPIO_EMC_10__GPIO4_gpio_io10 0x003c 0x022c 0x0000 5 0 |
#define | IMXRT_PAD_GPIO_EMC_11__SEMC_ADDR02 0x0040 0x0230 0x0000 0 0 |
#define | IMXRT_PAD_GPIO_EMC_11__PWM2_B2 0x0040 0x0230 0x0490 1 0 |
#define | IMXRT_PAD_GPIO_EMC_11__LPI2C4_SDA 0x0040 0x0230 0x04e8 2 0 |
#define | IMXRT_PAD_GPIO_EMC_11__USDHC2_usdhc_reset_b 0x0040 0x0230 0x0000 3 0 |
#define | IMXRT_PAD_GPIO_EMC_11__FLEXIO1_IO11 0x0040 0x0230 0x0000 4 0 |
#define | IMXRT_PAD_GPIO_EMC_11__GPIO4_gpio_io11 0x0040 0x0230 0x0000 5 0 |
#define | IMXRT_PAD_GPIO_EMC_12__SEMC_ADDR03 0x0044 0x0234 0x0000 0 0 |
#define | IMXRT_PAD_GPIO_EMC_12__XBARA1_IN24 0x0044 0x0234 0x0640 1 0 |
#define | IMXRT_PAD_GPIO_EMC_12__LPI2C4_SCL 0x0044 0x0234 0x04e4 2 0 |
#define | IMXRT_PAD_GPIO_EMC_12__USDHC1_usdhc_wp 0x0044 0x0234 0x05d8 3 0 |
#define | IMXRT_PAD_GPIO_EMC_12__PWM1_A3 0x0044 0x0234 0x0454 4 1 |
#define | IMXRT_PAD_GPIO_EMC_12__GPIO4_gpio_io12 0x0044 0x0234 0x0000 5 0 |
#define | IMXRT_PAD_GPIO_EMC_13__SEMC_ADDR04 0x0048 0x0238 0x0000 0 0 |
#define | IMXRT_PAD_GPIO_EMC_13__XBARA1_IN25 0x0048 0x0238 0x0650 1 1 |
#define | IMXRT_PAD_GPIO_EMC_13__LPUART3_TX 0x0048 0x0238 0x053c 2 1 |
#define | IMXRT_PAD_GPIO_EMC_13__MQS_RIGHT 0x0048 0x0238 0x0000 3 0 |
#define | IMXRT_PAD_GPIO_EMC_13__PWM1_B3 0x0048 0x0238 0x0464 4 1 |
#define | IMXRT_PAD_GPIO_EMC_13__GPIO4_gpio_io13 0x0048 0x0238 0x0000 5 0 |
#define | IMXRT_PAD_GPIO_EMC_14__SEMC_ADDR05 0x004c 0x023c 0x0000 0 0 |
#define | IMXRT_PAD_GPIO_EMC_14__XBARA1_OUT19 0x004c 0x023c 0x0654 1 0 /* Maybe you want to set IOMUXC_GPR_GPR6 IOMUXC_XBAR_DIR_SEL_19 to 0x1 */ |
#define | IMXRT_PAD_GPIO_EMC_14__XBARA1_IN19 0x004c 0x023c 0x0654 1 0 /* Maybe you want to set IOMUXC_GPR_GPR6 IOMUXC_XBAR_DIR_SEL_19 to 0 */ |
#define | IMXRT_PAD_GPIO_EMC_14__LPUART3_RX 0x004c 0x023c 0x0538 2 1 |
#define | IMXRT_PAD_GPIO_EMC_14__MQS_LEFT 0x004c 0x023c 0x0000 3 0 |
#define | IMXRT_PAD_GPIO_EMC_14__LPSPI2_PCS1 0x004c 0x023c 0x0000 4 0 |
#define | IMXRT_PAD_GPIO_EMC_14__GPIO4_gpio_io14 0x004c 0x023c 0x0000 5 0 |
#define | IMXRT_PAD_GPIO_EMC_15__SEMC_ADDR06 0x0050 0x0240 0x0000 0 0 |
#define | IMXRT_PAD_GPIO_EMC_15__XBARA1_IN20 0x0050 0x0240 0x0634 1 0 |
#define | IMXRT_PAD_GPIO_EMC_15__LPUART3_CTS_B 0x0050 0x0240 0x0534 2 0 |
#define | IMXRT_PAD_GPIO_EMC_15__SPDIF_spdif_out 0x0050 0x0240 0x0000 3 0 |
#define | IMXRT_PAD_GPIO_EMC_15__TMR3_TIMER0 0x0050 0x0240 0x057c 4 0 /* Maybe you want to set IOMUXC_GPR_GPR6 QTIMER3_TRM0_INPUT_SEL to 0 */ |
#define | IMXRT_PAD_GPIO_EMC_15__GPIO4_gpio_io15 0x0050 0x0240 0x0000 5 0 |
#define | IMXRT_PAD_GPIO_EMC_16__SEMC_ADDR07 0x0054 0x0244 0x0000 0 0 |
#define | IMXRT_PAD_GPIO_EMC_16__XBARA1_IN21 0x0054 0x0244 0x0658 1 0 |
#define | IMXRT_PAD_GPIO_EMC_16__LPUART3_RTS_B 0x0054 0x0244 0x0000 2 0 |
#define | IMXRT_PAD_GPIO_EMC_16__SPDIF_spdif_in 0x0054 0x0244 0x05c8 3 1 |
#define | IMXRT_PAD_GPIO_EMC_16__TMR3_TIMER1 0x0054 0x0244 0x0580 4 1 /* Maybe you want to set IOMUXC_GPR_GPR6 QTIMER3_TRM1_INPUT_SEL to 0 */ |
#define | IMXRT_PAD_GPIO_EMC_16__GPIO4_gpio_io16 0x0054 0x0244 0x0000 5 0 |
#define | IMXRT_PAD_GPIO_EMC_17__SEMC_ADDR08 0x0058 0x0248 0x0000 0 0 |
#define | IMXRT_PAD_GPIO_EMC_17__PWM4_A3 0x0058 0x0248 0x04a0 1 0 |
#define | IMXRT_PAD_GPIO_EMC_17__LPUART4_CTS_B 0x0058 0x0248 0x0000 2 0 |
#define | IMXRT_PAD_GPIO_EMC_17__CAN1_TX 0x0058 0x0248 0x0000 3 0 |
#define | IMXRT_PAD_GPIO_EMC_17__TMR3_TIMER2 0x0058 0x0248 0x0584 4 0 /* Maybe you want to set IOMUXC_GPR_GPR6 QTIMER3_TRM2_INPUT_SEL to 0 */ |
#define | IMXRT_PAD_GPIO_EMC_17__GPIO4_gpio_io17 0x0058 0x0248 0x0000 5 0 |
#define | IMXRT_PAD_GPIO_EMC_18__SEMC_ADDR09 0x005c 0x024c 0x0000 0 0 |
#define | IMXRT_PAD_GPIO_EMC_18__PWM4_B3 0x005c 0x024c 0x0000 1 0 |
#define | IMXRT_PAD_GPIO_EMC_18__LPUART4_RTS_B 0x005c 0x024c 0x0000 2 0 |
#define | IMXRT_PAD_GPIO_EMC_18__CAN1_RX 0x005c 0x024c 0x044c 3 1 |
#define | IMXRT_PAD_GPIO_EMC_18__TMR3_TIMER3 0x005c 0x024c 0x0588 4 0 /* Maybe you want to set IOMUXC_GPR_GPR6 QTIMER3_TRM3_INPUT_SEL to 0 */ |
#define | IMXRT_PAD_GPIO_EMC_18__GPIO4_gpio_io18 0x005c 0x024c 0x0000 5 0 |
#define | IMXRT_PAD_GPIO_EMC_18__SNVS_snvs_vio_5_ctl 0x005c 0x024c 0x0000 6 0 |
#define | IMXRT_PAD_GPIO_EMC_19__SEMC_ADDR11 0x0060 0x0250 0x0000 0 0 |
#define | IMXRT_PAD_GPIO_EMC_19__PWM2_A3 0x0060 0x0250 0x0474 1 1 |
#define | IMXRT_PAD_GPIO_EMC_19__LPUART4_TX 0x0060 0x0250 0x0544 2 1 |
#define | IMXRT_PAD_GPIO_EMC_19__ENET_enet_rx_data1 0x0060 0x0250 0x0438 3 0 |
#define | IMXRT_PAD_GPIO_EMC_19__TMR2_TIMER0 0x0060 0x0250 0x056c 4 0 /* Maybe you want to set IOMUXC_GPR_GPR6 QTIMER2_TRM0_INPUT_SEL to 0 */ |
#define | IMXRT_PAD_GPIO_EMC_19__GPIO4_gpio_io19 0x0060 0x0250 0x0000 5 0 |
#define | IMXRT_PAD_GPIO_EMC_19__SNVS_snvs_vio_5_b 0x0060 0x0250 0x0000 6 0 |
#define | IMXRT_PAD_GPIO_EMC_20__SEMC_ADDR12 0x0064 0x0254 0x0000 0 0 |
#define | IMXRT_PAD_GPIO_EMC_20__PWM2_B3 0x0064 0x0254 0x0484 1 1 |
#define | IMXRT_PAD_GPIO_EMC_20__LPUART4_RX 0x0064 0x0254 0x0540 2 1 |
#define | IMXRT_PAD_GPIO_EMC_20__ENET_enet_rx_data0 0x0064 0x0254 0x0434 3 0 |
#define | IMXRT_PAD_GPIO_EMC_20__TMR2_TIMER1 0x0064 0x0254 0x0570 4 0 /* Maybe you want to set IOMUXC_GPR_GPR6 QTIMER2_TRM1_INPUT_SEL to 0 */ |
#define | IMXRT_PAD_GPIO_EMC_20__GPIO4_gpio_io20 0x0064 0x0254 0x0000 5 0 |
#define | IMXRT_PAD_GPIO_EMC_21__SEMC_BA0 0x0068 0x0258 0x0000 0 0 |
#define | IMXRT_PAD_GPIO_EMC_21__PWM3_A3 0x0068 0x0258 0x0000 1 0 |
#define | IMXRT_PAD_GPIO_EMC_21__LPI2C3_SDA 0x0068 0x0258 0x04e0 2 0 |
#define | IMXRT_PAD_GPIO_EMC_21__ENET_enet_tx_data1 0x0068 0x0258 0x0000 3 0 |
#define | IMXRT_PAD_GPIO_EMC_21__TMR2_TIMER2 0x0068 0x0258 0x0574 4 0 /* Maybe you want to set IOMUXC_GPR_GPR6 QTIMER2_TRM2_INPUT_SEL to 0 */ |
#define | IMXRT_PAD_GPIO_EMC_21__GPIO4_gpio_io21 0x0068 0x0258 0x0000 5 0 |
#define | IMXRT_PAD_GPIO_EMC_22__SEMC_BA1 0x006c 0x025c 0x0000 0 0 |
#define | IMXRT_PAD_GPIO_EMC_22__PWM3_B3 0x006c 0x025c 0x0000 1 0 |
#define | IMXRT_PAD_GPIO_EMC_22__LPI2C3_SCL 0x006c 0x025c 0x04dc 2 0 |
#define | IMXRT_PAD_GPIO_EMC_22__ENET_enet_tx_data0 0x006c 0x025c 0x0000 3 0 |
#define | IMXRT_PAD_GPIO_EMC_22__TMR2_TIMER3 0x006c 0x025c 0x0578 4 0 /* Maybe you want to set IOMUXC_GPR_GPR6 QTIMER2_TRM3_INPUT_SEL to 0 */ |
#define | IMXRT_PAD_GPIO_EMC_22__GPIO4_gpio_io22 0x006c 0x025c 0x0000 5 0 |
#define | IMXRT_PAD_GPIO_EMC_23__SEMC_ADDR10 0x0070 0x0260 0x0000 0 0 |
#define | IMXRT_PAD_GPIO_EMC_23__PWM1_A0 0x0070 0x0260 0x0458 1 0 |
#define | IMXRT_PAD_GPIO_EMC_23__LPUART5_TX 0x0070 0x0260 0x054c 2 0 |
#define | IMXRT_PAD_GPIO_EMC_23__ENET_enet_rx_en 0x0070 0x0260 0x043c 3 0 |
#define | IMXRT_PAD_GPIO_EMC_23__GPT1_gpt_capture2 0x0070 0x0260 0x0000 4 0 |
#define | IMXRT_PAD_GPIO_EMC_23__GPIO4_gpio_io23 0x0070 0x0260 0x0000 5 0 |
#define | IMXRT_PAD_GPIO_EMC_24__SEMC_semc_cas 0x0074 0x0264 0x0000 0 0 |
#define | IMXRT_PAD_GPIO_EMC_24__PWM1_B0 0x0074 0x0264 0x0468 1 0 |
#define | IMXRT_PAD_GPIO_EMC_24__LPUART5_RX 0x0074 0x0264 0x0548 2 0 |
#define | IMXRT_PAD_GPIO_EMC_24__ENET_enet_tx_en 0x0074 0x0264 0x0000 3 0 |
#define | IMXRT_PAD_GPIO_EMC_24__GPT1_gpt_capture1 0x0074 0x0264 0x0000 4 0 |
#define | IMXRT_PAD_GPIO_EMC_24__GPIO4_gpio_io24 0x0074 0x0264 0x0000 5 0 |
#define | IMXRT_PAD_GPIO_EMC_25__SEMC_semc_ras 0x0078 0x0268 0x0000 0 0 |
#define | IMXRT_PAD_GPIO_EMC_25__PWM1_A1 0x0078 0x0268 0x045c 1 0 |
#define | IMXRT_PAD_GPIO_EMC_25__LPUART6_TX 0x0078 0x0268 0x0554 2 0 |
#define | IMXRT_PAD_GPIO_EMC_25__ENET_enet_tx_clk 0x0078 0x0268 0x0448 3 0 |
#define | IMXRT_PAD_GPIO_EMC_25__ENET_enet_ref_clk 0x0078 0x0268 0x042c 4 0 |
#define | IMXRT_PAD_GPIO_EMC_25__GPIO4_gpio_io25 0x0078 0x0268 0x0000 5 0 |
#define | IMXRT_PAD_GPIO_EMC_26__SEMC_semc_clk 0x007c 0x026c 0x0000 0 0 |
#define | IMXRT_PAD_GPIO_EMC_26__PWM1_B1 0x007c 0x026c 0x046c 1 0 |
#define | IMXRT_PAD_GPIO_EMC_26__LPUART6_RX 0x007c 0x026c 0x0550 2 0 |
#define | IMXRT_PAD_GPIO_EMC_26__ENET_enet_rx_er 0x007c 0x026c 0x0440 3 0 |
#define | IMXRT_PAD_GPIO_EMC_26__FLEXIO1_IO12 0x007c 0x026c 0x0000 4 0 |
#define | IMXRT_PAD_GPIO_EMC_26__GPIO4_gpio_io26 0x007c 0x026c 0x0000 5 0 |
#define | IMXRT_PAD_GPIO_EMC_27__SEMC_semc_cke 0x0080 0x0270 0x0000 0 0 |
#define | IMXRT_PAD_GPIO_EMC_27__PWM1_A2 0x0080 0x0270 0x0460 1 0 |
#define | IMXRT_PAD_GPIO_EMC_27__LPUART5_RTS_B 0x0080 0x0270 0x0000 2 0 |
#define | IMXRT_PAD_GPIO_EMC_27__LPSPI1_SCK 0x0080 0x0270 0x04f0 3 0 |
#define | IMXRT_PAD_GPIO_EMC_27__FLEXIO1_IO13 0x0080 0x0270 0x0000 4 0 |
#define | IMXRT_PAD_GPIO_EMC_27__GPIO4_gpio_io27 0x0080 0x0270 0x0000 5 0 |
#define | IMXRT_PAD_GPIO_EMC_28__SEMC_semc_we 0x0084 0x0274 0x0000 0 0 |
#define | IMXRT_PAD_GPIO_EMC_28__PWM1_B2 0x0084 0x0274 0x0470 1 0 |
#define | IMXRT_PAD_GPIO_EMC_28__LPUART5_CTS_B 0x0084 0x0274 0x0000 2 0 |
#define | IMXRT_PAD_GPIO_EMC_28__LPSPI1_SDO 0x0084 0x0274 0x04f8 3 0 |
#define | IMXRT_PAD_GPIO_EMC_28__FLEXIO1_IO14 0x0084 0x0274 0x0000 4 0 |
#define | IMXRT_PAD_GPIO_EMC_28__GPIO4_gpio_io28 0x0084 0x0274 0x0000 5 0 |
#define | IMXRT_PAD_GPIO_EMC_29__SEMC_CS0 0x0088 0x0278 0x0000 0 0 |
#define | IMXRT_PAD_GPIO_EMC_29__PWM3_A0 0x0088 0x0278 0x0000 1 0 |
#define | IMXRT_PAD_GPIO_EMC_29__LPUART6_RTS_B 0x0088 0x0278 0x0000 2 0 |
#define | IMXRT_PAD_GPIO_EMC_29__LPSPI1_SDI 0x0088 0x0278 0x04f4 3 0 |
#define | IMXRT_PAD_GPIO_EMC_29__FLEXIO1_IO15 0x0088 0x0278 0x0000 4 0 |
#define | IMXRT_PAD_GPIO_EMC_29__GPIO4_gpio_io29 0x0088 0x0278 0x0000 5 0 |
#define | IMXRT_PAD_GPIO_EMC_30__SEMC_DATA08 0x008c 0x027c 0x0000 0 0 |
#define | IMXRT_PAD_GPIO_EMC_30__PWM3_B0 0x008c 0x027c 0x0000 1 0 |
#define | IMXRT_PAD_GPIO_EMC_30__LPUART6_CTS_B 0x008c 0x027c 0x0000 2 0 |
#define | IMXRT_PAD_GPIO_EMC_30__LPSPI1_PCS0 0x008c 0x027c 0x04ec 3 1 |
#define | IMXRT_PAD_GPIO_EMC_30__CSI_csi_data23 0x008c 0x027c 0x0000 4 0 |
#define | IMXRT_PAD_GPIO_EMC_30__GPIO4_gpio_io30 0x008c 0x027c 0x0000 5 0 |
#define | IMXRT_PAD_GPIO_EMC_31__SEMC_DATA09 0x0090 0x0280 0x0000 0 0 |
#define | IMXRT_PAD_GPIO_EMC_31__PWM3_A1 0x0090 0x0280 0x0000 1 0 |
#define | IMXRT_PAD_GPIO_EMC_31__LPUART7_TX 0x0090 0x0280 0x055c 2 1 |
#define | IMXRT_PAD_GPIO_EMC_31__LPSPI1_PCS1 0x0090 0x0280 0x0000 3 0 |
#define | IMXRT_PAD_GPIO_EMC_31__CSI_csi_data22 0x0090 0x0280 0x0000 4 0 |
#define | IMXRT_PAD_GPIO_EMC_31__GPIO4_gpio_io31 0x0090 0x0280 0x0000 5 0 |
#define | IMXRT_PAD_GPIO_EMC_32__SEMC_DATA10 0x0094 0x0284 0x0000 0 0 |
#define | IMXRT_PAD_GPIO_EMC_32__PWM3_B1 0x0094 0x0284 0x0000 1 0 |
#define | IMXRT_PAD_GPIO_EMC_32__LPUART7_RX 0x0094 0x0284 0x0558 2 1 |
#define | IMXRT_PAD_GPIO_EMC_32__CCM_PMIC_RDY 0x0094 0x0284 0x03fc 3 4 |
#define | IMXRT_PAD_GPIO_EMC_32__CSI_csi_data21 0x0094 0x0284 0x0000 4 0 |
#define | IMXRT_PAD_GPIO_EMC_32__GPIO3_gpio_io18 0x0094 0x0284 0x0000 5 0 |
#define | IMXRT_PAD_GPIO_EMC_33__SEMC_DATA11 0x0098 0x0288 0x0000 0 0 |
#define | IMXRT_PAD_GPIO_EMC_33__PWM3_A2 0x0098 0x0288 0x0000 1 0 |
#define | IMXRT_PAD_GPIO_EMC_33__USDHC1_usdhc_reset_b 0x0098 0x0288 0x0000 2 0 |
#define | IMXRT_PAD_GPIO_EMC_33__SAI3_sai_rx_data 0x0098 0x0288 0x0000 3 0 |
#define | IMXRT_PAD_GPIO_EMC_33__CSI_csi_data20 0x0098 0x0288 0x0000 4 0 |
#define | IMXRT_PAD_GPIO_EMC_33__GPIO3_gpio_io19 0x0098 0x0288 0x0000 5 0 |
#define | IMXRT_PAD_GPIO_EMC_34__SEMC_DATA12 0x009c 0x028c 0x0000 0 0 |
#define | IMXRT_PAD_GPIO_EMC_34__PWM3_B2 0x009c 0x028c 0x0000 1 0 |
#define | IMXRT_PAD_GPIO_EMC_34__USDHC1_usdhc_vselect 0x009c 0x028c 0x0000 2 0 |
#define | IMXRT_PAD_GPIO_EMC_34__SAI3_sai_rx_sync 0x009c 0x028c 0x0000 3 0 |
#define | IMXRT_PAD_GPIO_EMC_34__CSI_csi_data19 0x009c 0x028c 0x0000 4 0 |
#define | IMXRT_PAD_GPIO_EMC_34__GPIO3_gpio_io20 0x009c 0x028c 0x0000 5 0 |
#define | IMXRT_PAD_GPIO_EMC_35__SEMC_DATA13 0x00a0 0x0290 0x0000 0 0 |
#define | IMXRT_PAD_GPIO_EMC_35__XBARA1_OUT18 0x00a0 0x0290 0x0630 1 0 /* Maybe you want to set IOMUXC_GPR_GPR6 IOMUXC_XBAR_DIR_SEL_18 to 0x1 */ |
#define | IMXRT_PAD_GPIO_EMC_35__XBARA1_IN18 0x00a0 0x0290 0x0630 1 0 /* Maybe you want to set IOMUXC_GPR_GPR6 IOMUXC_XBAR_DIR_SEL_18 to 0 */ |
#define | IMXRT_PAD_GPIO_EMC_35__GPT1_gpt_compare1 0x00a0 0x0290 0x0000 2 0 |
#define | IMXRT_PAD_GPIO_EMC_35__SAI3_sai_rx_bclk 0x00a0 0x0290 0x0000 3 0 |
#define | IMXRT_PAD_GPIO_EMC_35__CSI_csi_data18 0x00a0 0x0290 0x0000 4 0 |
#define | IMXRT_PAD_GPIO_EMC_35__GPIO3_gpio_io21 0x00a0 0x0290 0x0000 5 0 |
#define | IMXRT_PAD_GPIO_EMC_35__USDHC1_usdhc_cd_b 0x00a0 0x0290 0x05d4 6 0 |
#define | IMXRT_PAD_GPIO_EMC_36__SEMC_DATA14 0x00a4 0x0294 0x0000 0 0 |
#define | IMXRT_PAD_GPIO_EMC_36__XBARA1_IN22 0x00a4 0x0294 0x0638 1 0 |
#define | IMXRT_PAD_GPIO_EMC_36__GPT1_gpt_compare2 0x00a4 0x0294 0x0000 2 0 |
#define | IMXRT_PAD_GPIO_EMC_36__SAI3_sai_tx_data 0x00a4 0x0294 0x0000 3 0 |
#define | IMXRT_PAD_GPIO_EMC_36__CSI_csi_data17 0x00a4 0x0294 0x0000 4 0 |
#define | IMXRT_PAD_GPIO_EMC_36__GPIO3_gpio_io22 0x00a4 0x0294 0x0000 5 0 |
#define | IMXRT_PAD_GPIO_EMC_36__USDHC1_usdhc_wp 0x00a4 0x0294 0x05d8 6 1 |
#define | IMXRT_PAD_GPIO_EMC_37__SEMC_DATA15 0x00a8 0x0298 0x0000 0 0 |
#define | IMXRT_PAD_GPIO_EMC_37__XBARA1_IN23 0x00a8 0x0298 0x063c 1 0 |
#define | IMXRT_PAD_GPIO_EMC_37__GPT1_gpt_compare3 0x00a8 0x0298 0x0000 2 0 |
#define | IMXRT_PAD_GPIO_EMC_37__SAI3_sai_mclk 0x00a8 0x0298 0x0000 3 0 |
#define | IMXRT_PAD_GPIO_EMC_37__CSI_csi_data16 0x00a8 0x0298 0x0000 4 0 |
#define | IMXRT_PAD_GPIO_EMC_37__GPIO3_gpio_io23 0x00a8 0x0298 0x0000 5 0 |
#define | IMXRT_PAD_GPIO_EMC_37__USDHC2_usdhc_wp 0x00a8 0x0298 0x0608 6 0 |
#define | IMXRT_PAD_GPIO_EMC_38__SEMC_DM1 0x00ac 0x029c 0x0000 0 0 |
#define | IMXRT_PAD_GPIO_EMC_38__PWM1_A3 0x00ac 0x029c 0x0454 1 2 |
#define | IMXRT_PAD_GPIO_EMC_38__LPUART8_TX 0x00ac 0x029c 0x0564 2 2 |
#define | IMXRT_PAD_GPIO_EMC_38__SAI3_sai_tx_bclk 0x00ac 0x029c 0x0000 3 0 |
#define | IMXRT_PAD_GPIO_EMC_38__CSI_csi_field 0x00ac 0x029c 0x0000 4 0 |
#define | IMXRT_PAD_GPIO_EMC_38__GPIO3_gpio_io24 0x00ac 0x029c 0x0000 5 0 |
#define | IMXRT_PAD_GPIO_EMC_38__USDHC2_usdhc_vselect 0x00ac 0x029c 0x0000 6 0 |
#define | IMXRT_PAD_GPIO_EMC_39__SEMC_semc_dqs 0x00b0 0x02a0 0x0000 0 0 |
#define | IMXRT_PAD_GPIO_EMC_39__PWM1_B3 0x00b0 0x02a0 0x0464 1 2 |
#define | IMXRT_PAD_GPIO_EMC_39__LPUART8_RX 0x00b0 0x02a0 0x0560 2 2 |
#define | IMXRT_PAD_GPIO_EMC_39__SAI3_sai_tx_sync 0x00b0 0x02a0 0x0000 3 0 |
#define | IMXRT_PAD_GPIO_EMC_39__WDOG1_wdog_b 0x00b0 0x02a0 0x0000 4 0 |
#define | IMXRT_PAD_GPIO_EMC_39__GPIO3_gpio_io25 0x00b0 0x02a0 0x0000 5 0 |
#define | IMXRT_PAD_GPIO_EMC_39__USDHC2_usdhc_cd_b 0x00b0 0x02a0 0x05e0 6 1 |
#define | IMXRT_PAD_GPIO_EMC_40__SEMC_semc_rdy 0x00b4 0x02a4 0x0000 0 0 |
#define | IMXRT_PAD_GPIO_EMC_40__GPT2_gpt_capture2 0x00b4 0x02a4 0x0000 1 0 |
#define | IMXRT_PAD_GPIO_EMC_40__LPSPI1_PCS2 0x00b4 0x02a4 0x0000 2 0 |
#define | IMXRT_PAD_GPIO_EMC_40__USB2_usb_otg2_oc 0x00b4 0x02a4 0x05cc 3 1 |
#define | IMXRT_PAD_GPIO_EMC_40__ENET_enet_mdc 0x00b4 0x02a4 0x0000 4 0 |
#define | IMXRT_PAD_GPIO_EMC_40__GPIO3_gpio_io26 0x00b4 0x02a4 0x0000 5 0 |
#define | IMXRT_PAD_GPIO_EMC_40__USDHC2_usdhc_reset_b 0x00b4 0x02a4 0x0000 6 0 |
#define | IMXRT_PAD_GPIO_EMC_41__SEMC_CSX0 0x00b8 0x02a8 0x0000 0 0 |
#define | IMXRT_PAD_GPIO_EMC_41__GPT2_gpt_capture1 0x00b8 0x02a8 0x0000 1 0 |
#define | IMXRT_PAD_GPIO_EMC_41__LPSPI1_PCS3 0x00b8 0x02a8 0x0000 2 0 |
#define | IMXRT_PAD_GPIO_EMC_41__USB2_usb_otg2_pwr 0x00b8 0x02a8 0x0000 3 0 |
#define | IMXRT_PAD_GPIO_EMC_41__ENET_enet_mdio 0x00b8 0x02a8 0x0430 4 1 |
#define | IMXRT_PAD_GPIO_EMC_41__GPIO3_gpio_io27 0x00b8 0x02a8 0x0000 5 0 |
#define | IMXRT_PAD_GPIO_EMC_41__USDHC1_usdhc_vselect 0x00b8 0x02a8 0x0000 6 0 |
#define | IMXRT_PAD_GPIO_SD_B0_00__USDHC1_usdhc_cmd 0x01bc 0x03ac 0x0000 0 0 |
#define | IMXRT_PAD_GPIO_SD_B0_00__PWM1_A0 0x01bc 0x03ac 0x0458 1 1 |
#define | IMXRT_PAD_GPIO_SD_B0_00__LPI2C3_SCL 0x01bc 0x03ac 0x04dc 2 1 |
#define | IMXRT_PAD_GPIO_SD_B0_00__XBARA1_OUT04 0x01bc 0x03ac 0x0614 3 1 /* Maybe you want to set IOMUXC_GPR_GPR6 IOMUXC_XBAR_DIR_SEL_4 to 0x1 */ |
#define | IMXRT_PAD_GPIO_SD_B0_00__XBARA1_IN04 0x01bc 0x03ac 0x0614 3 1 /* Maybe you want to set IOMUXC_GPR_GPR6 IOMUXC_XBAR_DIR_SEL_4 to 0 */ |
#define | IMXRT_PAD_GPIO_SD_B0_00__LPSPI1_SCK 0x01bc 0x03ac 0x04f0 4 1 |
#define | IMXRT_PAD_GPIO_SD_B0_00__GPIO3_gpio_io12 0x01bc 0x03ac 0x0000 5 0 |
#define | IMXRT_PAD_GPIO_SD_B0_00__FLEXSPI_FLEXSPI_A_SS1_B 0x01bc 0x03ac 0x0000 6 0 |
#define | IMXRT_PAD_GPIO_SD_B0_01__USDHC1_usdhc_clk 0x01c0 0x03b0 0x0000 0 0 |
#define | IMXRT_PAD_GPIO_SD_B0_01__PWM1_B0 0x01c0 0x03b0 0x0468 1 1 |
#define | IMXRT_PAD_GPIO_SD_B0_01__LPI2C3_SDA 0x01c0 0x03b0 0x04e0 2 1 |
#define | IMXRT_PAD_GPIO_SD_B0_01__XBARA1_OUT05 0x01c0 0x03b0 0x0618 3 1 /* Maybe you want to set IOMUXC_GPR_GPR6 IOMUXC_XBAR_DIR_SEL_5 to 0x1 */ |
#define | IMXRT_PAD_GPIO_SD_B0_01__XBARA1_IN05 0x01c0 0x03b0 0x0618 3 1 /* Maybe you want to set IOMUXC_GPR_GPR6 IOMUXC_XBAR_DIR_SEL_5 to 0 */ |
#define | IMXRT_PAD_GPIO_SD_B0_01__LPSPI1_PCS0 0x01c0 0x03b0 0x04ec 4 0 |
#define | IMXRT_PAD_GPIO_SD_B0_01__GPIO3_gpio_io13 0x01c0 0x03b0 0x0000 5 0 |
#define | IMXRT_PAD_GPIO_SD_B0_01__FLEXSPI_FLEXSPI_B_SS1_B 0x01c0 0x03b0 0x0000 6 0 |
#define | IMXRT_PAD_GPIO_SD_B0_02__USDHC1_usdhc_data0 0x01c4 0x03b4 0x0000 0 0 |
#define | IMXRT_PAD_GPIO_SD_B0_02__PWM1_A1 0x01c4 0x03b4 0x045c 1 1 |
#define | IMXRT_PAD_GPIO_SD_B0_02__LPUART8_CTS_B 0x01c4 0x03b4 0x0000 2 0 |
#define | IMXRT_PAD_GPIO_SD_B0_02__XBARA1_OUT06 0x01c4 0x03b4 0x061c 3 1 /* Maybe you want to set IOMUXC_GPR_GPR6 IOMUXC_XBAR_DIR_SEL_6 to 0x1 */ |
#define | IMXRT_PAD_GPIO_SD_B0_02__XBARA1_IN06 0x01c4 0x03b4 0x061c 3 1 /* Maybe you want to set IOMUXC_GPR_GPR6 IOMUXC_XBAR_DIR_SEL_6 to 0 */ |
#define | IMXRT_PAD_GPIO_SD_B0_02__LPSPI1_SDO 0x01c4 0x03b4 0x04f8 4 1 |
#define | IMXRT_PAD_GPIO_SD_B0_02__GPIO3_gpio_io14 0x01c4 0x03b4 0x0000 5 0 |
#define | IMXRT_PAD_GPIO_SD_B0_03__USDHC1_usdhc_data1 0x01c8 0x03b8 0x0000 0 0 |
#define | IMXRT_PAD_GPIO_SD_B0_03__PWM1_B1 0x01c8 0x03b8 0x046c 1 1 |
#define | IMXRT_PAD_GPIO_SD_B0_03__LPUART8_RTS_B 0x01c8 0x03b8 0x0000 2 0 |
#define | IMXRT_PAD_GPIO_SD_B0_03__XBARA1_OUT07 0x01c8 0x03b8 0x0620 3 1 /* Maybe you want to set IOMUXC_GPR_GPR6 IOMUXC_XBAR_DIR_SEL_7 to 0x1 */ |
#define | IMXRT_PAD_GPIO_SD_B0_03__XBARA1_IN07 0x01c8 0x03b8 0x0620 3 1 /* Maybe you want to set IOMUXC_GPR_GPR6 IOMUXC_XBAR_DIR_SEL_7 to 0 */ |
#define | IMXRT_PAD_GPIO_SD_B0_03__LPSPI1_SDI 0x01c8 0x03b8 0x04f4 4 1 |
#define | IMXRT_PAD_GPIO_SD_B0_03__GPIO3_gpio_io15 0x01c8 0x03b8 0x0000 5 0 |
#define | IMXRT_PAD_GPIO_SD_B0_04__USDHC1_usdhc_data2 0x01cc 0x03bc 0x0000 0 0 |
#define | IMXRT_PAD_GPIO_SD_B0_04__PWM1_A2 0x01cc 0x03bc 0x0460 1 1 |
#define | IMXRT_PAD_GPIO_SD_B0_04__LPUART8_TX 0x01cc 0x03bc 0x0564 2 0 |
#define | IMXRT_PAD_GPIO_SD_B0_04__XBARA1_OUT08 0x01cc 0x03bc 0x0624 3 1 /* Maybe you want to set IOMUXC_GPR_GPR6 IOMUXC_XBAR_DIR_SEL_8 to 0x1 */ |
#define | IMXRT_PAD_GPIO_SD_B0_04__XBARA1_IN08 0x01cc 0x03bc 0x0624 3 1 /* Maybe you want to set IOMUXC_GPR_GPR6 IOMUXC_XBAR_DIR_SEL_8 to 0 */ |
#define | IMXRT_PAD_GPIO_SD_B0_04__FLEXSPI_FLEXSPI_B_SS0_B 0x01cc 0x03bc 0x0000 4 0 |
#define | IMXRT_PAD_GPIO_SD_B0_04__GPIO3_gpio_io16 0x01cc 0x03bc 0x0000 5 0 |
#define | IMXRT_PAD_GPIO_SD_B0_04__CCM_CLKO1 0x01cc 0x03bc 0x0000 6 0 |
#define | IMXRT_PAD_GPIO_SD_B0_05__USDHC1_usdhc_data3 0x01d0 0x03c0 0x0000 0 0 |
#define | IMXRT_PAD_GPIO_SD_B0_05__PWM1_B2 0x01d0 0x03c0 0x0470 1 1 |
#define | IMXRT_PAD_GPIO_SD_B0_05__LPUART8_RX 0x01d0 0x03c0 0x0560 2 0 |
#define | IMXRT_PAD_GPIO_SD_B0_05__XBARA1_OUT09 0x01d0 0x03c0 0x0628 3 1 /* Maybe you want to set IOMUXC_GPR_GPR6 IOMUXC_XBAR_DIR_SEL_9 to 0x1 */ |
#define | IMXRT_PAD_GPIO_SD_B0_05__XBARA1_IN09 0x01d0 0x03c0 0x0628 3 1 /* Maybe you want to set IOMUXC_GPR_GPR6 IOMUXC_XBAR_DIR_SEL_9 to 0 */ |
#define | IMXRT_PAD_GPIO_SD_B0_05__FLEXSPI_FLEXSPI_B_DQS 0x01d0 0x03c0 0x0000 4 0 |
#define | IMXRT_PAD_GPIO_SD_B0_05__GPIO3_gpio_io17 0x01d0 0x03c0 0x0000 5 0 |
#define | IMXRT_PAD_GPIO_SD_B0_05__CCM_CLKO2 0x01d0 0x03c0 0x0000 6 0 |
#define | IMXRT_PAD_GPIO_SD_B1_00__USDHC2_usdhc_data3 0x01d4 0x03c4 0x05f4 0 0 |
#define | IMXRT_PAD_GPIO_SD_B1_00__FLEXSPI_FLEXSPI_B_DATA3 0x01d4 0x03c4 0x04c4 1 0 |
#define | IMXRT_PAD_GPIO_SD_B1_00__PWM1_A3 0x01d4 0x03c4 0x0454 2 0 |
#define | IMXRT_PAD_GPIO_SD_B1_00__SAI1_sai_tx_data3 0x01d4 0x03c4 0x0598 3 0 |
#define | IMXRT_PAD_GPIO_SD_B1_00__LPUART4_TX 0x01d4 0x03c4 0x0544 4 0 |
#define | IMXRT_PAD_GPIO_SD_B1_00__GPIO3_gpio_io00 0x01d4 0x03c4 0x0000 5 0 |
#define | IMXRT_PAD_GPIO_SD_B1_01__USDHC2_usdhc_data2 0x01d8 0x03c8 0x05f0 0 0 |
#define | IMXRT_PAD_GPIO_SD_B1_01__FLEXSPI_FLEXSPI_B_DATA2 0x01d8 0x03c8 0x04c0 1 0 |
#define | IMXRT_PAD_GPIO_SD_B1_01__PWM1_B3 0x01d8 0x03c8 0x0464 2 0 |
#define | IMXRT_PAD_GPIO_SD_B1_01__SAI1_sai_tx_data2 0x01d8 0x03c8 0x059c 3 0 |
#define | IMXRT_PAD_GPIO_SD_B1_01__LPUART4_RX 0x01d8 0x03c8 0x0540 4 0 |
#define | IMXRT_PAD_GPIO_SD_B1_01__GPIO3_gpio_io01 0x01d8 0x03c8 0x0000 5 0 |
#define | IMXRT_PAD_GPIO_SD_B1_02__USDHC2_usdhc_data1 0x01dc 0x03cc 0x05ec 0 0 |
#define | IMXRT_PAD_GPIO_SD_B1_02__FLEXSPI_FLEXSPI_B_DATA1 0x01dc 0x03cc 0x04bc 1 0 |
#define | IMXRT_PAD_GPIO_SD_B1_02__PWM2_A3 0x01dc 0x03cc 0x0474 2 0 |
#define | IMXRT_PAD_GPIO_SD_B1_02__SAI1_sai_tx_data1 0x01dc 0x03cc 0x05a0 3 0 |
#define | IMXRT_PAD_GPIO_SD_B1_02__CAN1_TX 0x01dc 0x03cc 0x0000 4 0 |
#define | IMXRT_PAD_GPIO_SD_B1_02__GPIO3_gpio_io02 0x01dc 0x03cc 0x0000 5 0 |
#define | IMXRT_PAD_GPIO_SD_B1_02__CCM_WAIT 0x01dc 0x03cc 0x0000 6 0 |
#define | IMXRT_PAD_GPIO_SD_B1_03__USDHC2_usdhc_data0 0x01e0 0x03d0 0x05e8 0 0 |
#define | IMXRT_PAD_GPIO_SD_B1_03__FLEXSPI_FLEXSPI_B_DATA0 0x01e0 0x03d0 0x04b8 1 0 |
#define | IMXRT_PAD_GPIO_SD_B1_03__PWM2_B3 0x01e0 0x03d0 0x0484 2 0 |
#define | IMXRT_PAD_GPIO_SD_B1_03__SAI1_sai_mclk 0x01e0 0x03d0 0x058c 3 0 |
#define | IMXRT_PAD_GPIO_SD_B1_03__CAN1_RX 0x01e0 0x03d0 0x044c 4 0 |
#define | IMXRT_PAD_GPIO_SD_B1_03__GPIO3_gpio_io03 0x01e0 0x03d0 0x0000 5 0 |
#define | IMXRT_PAD_GPIO_SD_B1_03__CCM_PMIC_RDY 0x01e0 0x03d0 0x03fc 6 0 |
#define | IMXRT_PAD_GPIO_SD_B1_04__USDHC2_usdhc_clk 0x01e4 0x03d4 0x05dc 0 0 |
#define | IMXRT_PAD_GPIO_SD_B1_04__FLEXSPI_FLEXSPI_B_SCLK 0x01e4 0x03d4 0x0000 1 0 |
#define | IMXRT_PAD_GPIO_SD_B1_04__LPI2C1_SCL 0x01e4 0x03d4 0x04cc 2 0 |
#define | IMXRT_PAD_GPIO_SD_B1_04__SAI1_sai_rx_sync 0x01e4 0x03d4 0x05a4 3 0 |
#define | IMXRT_PAD_GPIO_SD_B1_04__FLEXSPI_FLEXSPI_A_SS1_B 0x01e4 0x03d4 0x0000 4 0 |
#define | IMXRT_PAD_GPIO_SD_B1_04__GPIO3_gpio_io04 0x01e4 0x03d4 0x0000 5 0 |
#define | IMXRT_PAD_GPIO_SD_B1_04__CCM_STOP 0x01e4 0x03d4 0x0000 6 0 |
#define | IMXRT_PAD_GPIO_SD_B1_05__USDHC2_usdhc_cmd 0x01e8 0x03d8 0x05e4 0 0 |
#define | IMXRT_PAD_GPIO_SD_B1_05__FLEXSPI_FLEXSPI_A_DQS 0x01e8 0x03d8 0x04a4 1 0 |
#define | IMXRT_PAD_GPIO_SD_B1_05__LPI2C1_SDA 0x01e8 0x03d8 0x04d0 2 0 |
#define | IMXRT_PAD_GPIO_SD_B1_05__SAI1_sai_rx_bclk 0x01e8 0x03d8 0x0590 3 0 |
#define | IMXRT_PAD_GPIO_SD_B1_05__FLEXSPI_FLEXSPI_B_SS0_B 0x01e8 0x03d8 0x0000 4 0 |
#define | IMXRT_PAD_GPIO_SD_B1_05__GPIO3_gpio_io05 0x01e8 0x03d8 0x0000 5 0 |
#define | IMXRT_PAD_GPIO_SD_B1_06__USDHC2_usdhc_reset_b 0x01ec 0x03dc 0x0000 0 0 |
#define | IMXRT_PAD_GPIO_SD_B1_06__FLEXSPI_FLEXSPI_A_SS0_B 0x01ec 0x03dc 0x0000 1 0 |
#define | IMXRT_PAD_GPIO_SD_B1_06__LPUART7_CTS_B 0x01ec 0x03dc 0x0000 2 0 |
#define | IMXRT_PAD_GPIO_SD_B1_06__SAI1_sai_rx_data0 0x01ec 0x03dc 0x0594 3 0 |
#define | IMXRT_PAD_GPIO_SD_B1_06__LPSPI2_PCS0 0x01ec 0x03dc 0x04fc 4 0 |
#define | IMXRT_PAD_GPIO_SD_B1_06__GPIO3_gpio_io06 0x01ec 0x03dc 0x0000 5 0 |
#define | IMXRT_PAD_GPIO_SD_B1_07__SEMC_CSX1 0x01f0 0x03e0 0x0000 0 0 |
#define | IMXRT_PAD_GPIO_SD_B1_07__FLEXSPI_FLEXSPI_A_SCLK 0x01f0 0x03e0 0x04c8 1 0 |
#define | IMXRT_PAD_GPIO_SD_B1_07__LPUART7_RTS_B 0x01f0 0x03e0 0x0000 2 0 |
#define | IMXRT_PAD_GPIO_SD_B1_07__SAI1_sai_tx_data0 0x01f0 0x03e0 0x0000 3 0 |
#define | IMXRT_PAD_GPIO_SD_B1_07__LPSPI2_SCK 0x01f0 0x03e0 0x0500 4 0 |
#define | IMXRT_PAD_GPIO_SD_B1_07__GPIO3_gpio_io07 0x01f0 0x03e0 0x0000 5 0 |
#define | IMXRT_PAD_GPIO_SD_B1_08__USDHC2_usdhc_data4 0x01f4 0x03e4 0x05f8 0 0 |
#define | IMXRT_PAD_GPIO_SD_B1_08__FLEXSPI_FLEXSPI_A_DATA0 0x01f4 0x03e4 0x04a8 1 0 |
#define | IMXRT_PAD_GPIO_SD_B1_08__LPUART7_TX 0x01f4 0x03e4 0x055c 2 0 |
#define | IMXRT_PAD_GPIO_SD_B1_08__SAI1_sai_tx_bclk 0x01f4 0x03e4 0x05a8 3 0 |
#define | IMXRT_PAD_GPIO_SD_B1_08__LPSPI2_SDO 0x01f4 0x03e4 0x0508 4 0 |
#define | IMXRT_PAD_GPIO_SD_B1_08__GPIO3_gpio_io08 0x01f4 0x03e4 0x0000 5 0 |
#define | IMXRT_PAD_GPIO_SD_B1_08__SEMC_CSX2 0x01f4 0x03e4 0x0000 6 0 |
#define | IMXRT_PAD_GPIO_SD_B1_09__USDHC2_usdhc_data5 0x01f8 0x03e8 0x05fc 0 0 |
#define | IMXRT_PAD_GPIO_SD_B1_09__FLEXSPI_FLEXSPI_A_DATA1 0x01f8 0x03e8 0x04ac 1 0 |
#define | IMXRT_PAD_GPIO_SD_B1_09__LPUART7_RX 0x01f8 0x03e8 0x0558 2 0 |
#define | IMXRT_PAD_GPIO_SD_B1_09__SAI1_sai_tx_sync 0x01f8 0x03e8 0x05ac 3 0 |
#define | IMXRT_PAD_GPIO_SD_B1_09__LPSPI2_SDI 0x01f8 0x03e8 0x0504 4 0 |
#define | IMXRT_PAD_GPIO_SD_B1_09__GPIO3_gpio_io09 0x01f8 0x03e8 0x0000 5 0 |
#define | IMXRT_PAD_GPIO_SD_B1_10__USDHC2_usdhc_data6 0x01fc 0x03ec 0x0600 0 0 |
#define | IMXRT_PAD_GPIO_SD_B1_10__FLEXSPI_FLEXSPI_A_DATA2 0x01fc 0x03ec 0x04b0 1 0 |
#define | IMXRT_PAD_GPIO_SD_B1_10__LPUART2_RX 0x01fc 0x03ec 0x052c 2 0 |
#define | IMXRT_PAD_GPIO_SD_B1_10__LPI2C2_SDA 0x01fc 0x03ec 0x04d8 3 0 |
#define | IMXRT_PAD_GPIO_SD_B1_10__LPSPI2_PCS2 0x01fc 0x03ec 0x0000 4 0 |
#define | IMXRT_PAD_GPIO_SD_B1_10__GPIO3_gpio_io10 0x01fc 0x03ec 0x0000 5 0 |
#define | IMXRT_PAD_GPIO_SD_B1_11__USDHC2_usdhc_data7 0x0200 0x03f0 0x0604 0 0 |
#define | IMXRT_PAD_GPIO_SD_B1_11__FLEXSPI_FLEXSPI_A_DATA3 0x0200 0x03f0 0x04b4 1 0 |
#define | IMXRT_PAD_GPIO_SD_B1_11__LPUART2_TX 0x0200 0x03f0 0x0530 2 0 |
#define | IMXRT_PAD_GPIO_SD_B1_11__LPI2C2_SCL 0x0200 0x03f0 0x04d4 3 0 |
#define | IMXRT_PAD_GPIO_SD_B1_11__LPSPI2_PCS3 0x0200 0x03f0 0x0000 4 0 |
#define | IMXRT_PAD_GPIO_SD_B1_11__GPIO3_gpio_io11 0x0200 0x03f0 0x0000 5 0 |
