RTEMS 6.1-rc2
imx_wdogreg.h
1/*-
2 * Copyright (c) 2012, 2013 The FreeBSD Foundation
3 * All rights reserved.
4 *
5 * This software was developed by Oleksandr Rybalko under sponsorship
6 * from the FreeBSD Foundation.
7 *
8 * Redistribution and use in source and binary forms, with or without
9 * modification, are permitted provided that the following conditions
10 * are met:
11 * 1. Redistributions of source code must retain the above copyright
12 * notice, this list of conditions and the following disclaimer.
13 * 2. Redistributions in binary form must reproduce the above copyright
14 * notice, this list of conditions and the following disclaimer in the
15 * documentation and/or other materials provided with the distribution.
16 *
17 * THIS SOFTWARE IS PROVIDED BY THE AUTHOR AND CONTRIBUTORS ``AS IS'' AND
18 * ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
19 * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
20 * ARE DISCLAIMED. IN NO EVENT SHALL THE AUTHOR OR CONTRIBUTORS BE LIABLE
21 * FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
22 * DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS
23 * OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION)
24 * HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT
25 * LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY
26 * OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF
27 * SUCH DAMAGE.
28 *
29 * $FreeBSD: head/sys/arm/freescale/imx/imx_wdogreg.h 291367 2015-11-26 17:26:52Z ian $
30 */
31
32#define WDOG_CLK_FREQ 32768
33
34#define WDOG_CR_REG 0x00 /* Control Register */
35#define WDOG_CR_WT_MASK 0xff00 /* Count of 0.5 sec */
36#define WDOG_CR_WT_SHIFT 8
37#define WDOG_CR_WDW (1 << 7) /* Suspend WDog */
38#define WDOG_CR_WDA (1 << 5) /* Don't touch ipp_wdog */
39#define WDOG_CR_SRS (1 << 4) /* Don't touch sys_reset */
40#define WDOG_CR_WDT (1 << 3) /* Assert ipp_wdog on tout */
41#define WDOG_CR_WDE (1 << 2) /* WDog Enable */
42#define WDOG_CR_WDBG (1 << 1) /* Suspend when DBG mode */
43#define WDOG_CR_WDZST (1 << 0) /* Suspend when LP mode */
44
45#define WDOG_SR_REG 0x02 /* Service Register */
46#define WDOG_SR_STEP1 0x5555
47#define WDOG_SR_STEP2 0xaaaa
48
49#define WDOG_RSR_REG 0x04 /* Reset Status Register */
50#define WDOG_RSR_POR (1 << 4) /* Due to Power-On Reset */
51#define WDOG_RSR_TOUT (1 << 1) /* Due WDog timeout reset */
52#define WDOG_RSR_SFTW (1 << 0) /* Due Soft reset */
53
54#define WDOG_ICR_REG 0x06 /* Interrupt Control Register */
55#define WDOG_ICR_WIE (1 << 15) /* Enable Interrupt */
56#define WDOG_ICR_WTIS (1 << 14) /* Interrupt has occurred */
57#define WDOG_ICR_WTCT_MASK 0x00ff
58#define WDOG_ICR_WTCT_SHIFT 0 /* Interrupt hold time */
59
60#define WDOG_MCR_REG 0x08 /* Miscellaneous Control Register */
61#define WDOG_MCR_PDE (1 << 0)
62
