RTEMS 6.1-rc2
imx_iomuxreg.h
1/*-
2 * Copyright (c) 2015 Oleksandr Tymoshenko <gonzo@freebsd.org>
3 * All rights reserved.
4 *
5 * Redistribution and use in source and binary forms, with or without
6 * modification, are permitted provided that the following conditions
7 * are met:
8 * 1. Redistributions of source code must retain the above copyright
9 * notice, this list of conditions and the following disclaimer.
10 * 2. Redistributions in binary form must reproduce the above copyright
11 * notice, this list of conditions and the following disclaimer in the
12 * documentation and/or other materials provided with the distribution.
13 *
14 * THIS SOFTWARE IS PROVIDED BY THE AUTHOR AND CONTRIBUTORS ``AS IS'' AND
15 * ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
16 * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
17 * ARE DISCLAIMED. IN NO EVENT SHALL THE AUTHOR OR CONTRIBUTORS BE LIABLE
18 * FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
19 * DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS
20 * OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION)
21 * HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT
22 * LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY
23 * OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF
24 * SUCH DAMAGE.
25 *
26 * $FreeBSD: head/sys/arm/freescale/imx/imx_iomuxreg.h 322015 2017-08-03 14:43:41Z ian $
27 */
28
29#ifndef IMX_IOMUXREG_H
30#define IMX_IOMUXREG_H
31
32#define IMX_IOMUXREG_LOWEST_SET_BIT(__mask) ((((__mask) - 1) & (__mask)) ^ (__mask))
33#define IMX_IOMUXREG_SHIFTIN(__x, __mask) ((__x) * IMX_IOMUXREG_LOWEST_SET_BIT(__mask))
34
35#define IMX_IOMUXREG_BIT(n) (1 << (n))
36#define IMX_IOMUXREG_BITS(__m, __n) \
37 ((IMX_IOMUXREG_BIT(MAX((__m), (__n)) + 1) - 1) ^ (IMX_IOMUXREG_BIT(MIN((__m), (__n))) - 1))
38
39#define IOMUXC_GPR0 0x00
40#define IOMUXC_GPR1 0x04
41#define IOMUXC_GPR2 0x08
42#define IOMUXC_GPR3 0x0C
43#define IOMUXC_GPR3_HDMI_MASK (3 << 2)
44#define IOMUXC_GPR3_HDMI_IPU1_DI0 (0 << 2)
45#define IOMUXC_GPR3_HDMI_IPU1_DI1 (1 << 2)
46#define IOMUXC_GPR3_HDMI_IPU2_DI0 (2 << 2)
47#define IOMUXC_GPR3_HDMI_IPU2_DI1 (3 << 2)
48
49#define IOMUX_GPR13 0x34
50#define IOMUX_GPR13_SATA_PHY_8(n) IMX_IOMUXREG_SHIFTIN(n, IMX_IOMUXREG_BITS(26, 24))
51#define IOMUX_GPR13_SATA_PHY_7(n) IMX_IOMUXREG_SHIFTIN(n, IMX_IOMUXREG_BITS(23, 19))
52#define IOMUX_GPR13_SATA_PHY_6(n) IMX_IOMUXREG_SHIFTIN(n, IMX_IOMUXREG_BITS(18, 16))
53#define IOMUX_GPR13_SATA_SPEED(n) IMX_IOMUXREG_SHIFTIN(n, (1 << 15))
54#define IOMUX_GPR13_SATA_PHY_5(n) IMX_IOMUXREG_SHIFTIN(n, (1 << 14))
55#define IOMUX_GPR13_SATA_PHY_4(n) IMX_IOMUXREG_SHIFTIN(n, IMX_IOMUXREG_BITS(13, 11))
56#define IOMUX_GPR13_SATA_PHY_3(n) IMX_IOMUXREG_SHIFTIN(n, IMX_IOMUXREG_BITS(10, 7))
57#define IOMUX_GPR13_SATA_PHY_2(n) IMX_IOMUXREG_SHIFTIN(n, IMX_IOMUXREG_BITS(6, 2))
58#define IOMUX_GPR13_SATA_PHY_1(n) IMX_IOMUXREG_SHIFTIN(n, (1 << 1))
59#define IOMUX_GPR13_SATA_PHY_0(n) IMX_IOMUXREG_SHIFTIN(n, (1 << 0))
60
61#endif
