37#define IMX_ECSPI_CONREG_BURST_LENGTH(val) BSP_FLD32(val, 20, 31)
38#define IMX_ECSPI_CONREG_BURST_LENGTH_GET(reg) BSP_FLD32GET(reg, 20, 31)
39#define IMX_ECSPI_CONREG_BURST_LENGTH_SET(reg, val) BSP_FLD32SET(reg, val, 20, 31)
40#define IMX_ECSPI_CONREG_CHANNEL_SELECT(val) BSP_FLD32(val, 18, 19)
41#define IMX_ECSPI_CONREG_CHANNEL_SELECT_GET(reg) BSP_FLD32GET(reg, 18, 19)
42#define IMX_ECSPI_CONREG_CHANNEL_SELECT_SET(reg, val) BSP_FLD32SET(reg, val, 18, 19)
43#define IMX_ECSPI_CONREG_DRCTL(val) BSP_FLD32(val, 16, 17)
44#define IMX_ECSPI_CONREG_DRCTL_GET(reg) BSP_FLD32GET(reg, 16, 17)
45#define IMX_ECSPI_CONREG_DRCTL_SET(reg, val) BSP_FLD32SET(reg, val, 16, 17)
46#define IMX_ECSPI_CONREG_PRE_DIVIDER(val) BSP_FLD32(val, 12, 15)
47#define IMX_ECSPI_CONREG_PRE_DIVIDER_GET(reg) BSP_FLD32GET(reg, 12, 15)
48#define IMX_ECSPI_CONREG_PRE_DIVIDER_SET(reg, val) BSP_FLD32SET(reg, val, 12, 15)
49#define IMX_ECSPI_CONREG_POST_DIVIDER(val) BSP_FLD32(val, 8, 11)
50#define IMX_ECSPI_CONREG_POST_DIVIDER_GET(reg) BSP_FLD32GET(reg, 8, 11)
51#define IMX_ECSPI_CONREG_POST_DIVIDER_SET(reg, val) BSP_FLD32SET(reg, val, 8, 11)
52#define IMX_ECSPI_CONREG_CHANNEL_MODE(val) BSP_FLD32(val, 4, 7)
53#define IMX_ECSPI_CONREG_CHANNEL_MODE_GET(reg) BSP_FLD32GET(reg, 4, 7)
54#define IMX_ECSPI_CONREG_CHANNEL_MODE_SET(reg, val) BSP_FLD32SET(reg, val, 4, 7)
55#define IMX_ECSPI_CONREG_SMC BSP_BIT32(3)
56#define IMX_ECSPI_CONREG_XCH BSP_BIT32(2)
57#define IMX_ECSPI_CONREG_HT BSP_BIT32(1)
58#define IMX_ECSPI_CONREG_EN BSP_BIT32(0)
60#define IMX_ECSPI_CONFIGREG_HT_LENGTH(val) BSP_FLD32(val, 24, 28)
61#define IMX_ECSPI_CONFIGREG_HT_LENGTH_GET(reg) BSP_FLD32GET(reg, 24, 28)
62#define IMX_ECSPI_CONFIGREG_HT_LENGTH_SET(reg, val) BSP_FLD32SET(reg, val, 24, 28)
63#define IMX_ECSPI_CONFIGREG_SCLK_CTL(val) BSP_FLD32(val, 20, 23)
64#define IMX_ECSPI_CONFIGREG_SCLK_CTL_GET(reg) BSP_FLD32GET(reg, 20, 23)
65#define IMX_ECSPI_CONFIGREG_SCLK_CTL_SET(reg, val) BSP_FLD32SET(reg, val, 20, 23)
66#define IMX_ECSPI_CONFIGREG_DATA_CTL(val) BSP_FLD32(val, 16, 19)
67#define IMX_ECSPI_CONFIGREG_DATA_CTL_GET(reg) BSP_FLD32GET(reg, 16, 19)
68#define IMX_ECSPI_CONFIGREG_DATA_CTL_SET(reg, val) BSP_FLD32SET(reg, val, 16, 19)
69#define IMX_ECSPI_CONFIGREG_SS_POL(val) BSP_FLD32(val, 12, 15)
70#define IMX_ECSPI_CONFIGREG_SS_POL_GET(reg) BSP_FLD32GET(reg, 12, 15)
71#define IMX_ECSPI_CONFIGREG_SS_POL_SET(reg, val) BSP_FLD32SET(reg, val, 12, 15)
72#define IMX_ECSPI_CONFIGREG_SS_CTL(val) BSP_FLD32(val, 8, 11)
73#define IMX_ECSPI_CONFIGREG_SS_CTL_GET(reg) BSP_FLD32GET(reg, 8, 11)
74#define IMX_ECSPI_CONFIGREG_SS_CTL_SET(reg, val) BSP_FLD32SET(reg, val, 8, 11)
75#define IMX_ECSPI_CONFIGREG_SCLK_POL(val) BSP_FLD32(val, 4, 7)
76#define IMX_ECSPI_CONFIGREG_SCLK_POL_GET(reg) BSP_FLD32GET(reg, 4, 7)
77#define IMX_ECSPI_CONFIGREG_SCLK_POL_SET(reg, val) BSP_FLD32SET(reg, val, 4, 7)
78#define IMX_ECSPI_CONFIGREG_SCLK_PHA(val) BSP_FLD32(val, 0, 3)
79#define IMX_ECSPI_CONFIGREG_SCLK_PHA_GET(reg) BSP_FLD32GET(reg, 0, 3)
80#define IMX_ECSPI_CONFIGREG_SCLK_PHA_SET(reg, val) BSP_FLD32SET(reg, val, 0, 3)
81#define IMX_ECSPI_TC BSP_BIT32(7)
82#define IMX_ECSPI_RO BSP_BIT32(6)
83#define IMX_ECSPI_RF BSP_BIT32(5)
84#define IMX_ECSPI_RDR BSP_BIT32(4)
85#define IMX_ECSPI_RR BSP_BIT32(3)
86#define IMX_ECSPI_TF BSP_BIT32(2)
87#define IMX_ECSPI_TDR BSP_BIT32(1)
88#define IMX_ECSPI_TE BSP_BIT32(0)
91#define IMX_ECSPI_DMAREG_RXTDEN BSP_BIT32(31)
92#define IMX_ECSPI_DMAREG_RX_DMA_LENGTH(val) BSP_FLD32(val, 24, 29)
93#define IMX_ECSPI_DMAREG_RX_DMA_LENGTH_GET(reg) BSP_FLD32GET(reg, 24, 29)
94#define IMX_ECSPI_DMAREG_RX_DMA_LENGTH_SET(reg, val) BSP_FLD32SET(reg, val, 24, 29)
95#define IMX_ECSPI_DMAREG_RXDEN BSP_BIT32(23)
96#define IMX_ECSPI_DMAREG_RX_THRESHOLD(val) BSP_FLD32(val, 16, 21)
97#define IMX_ECSPI_DMAREG_RX_THRESHOLD_GET(reg) BSP_FLD32GET(reg, 16, 21)
98#define IMX_ECSPI_DMAREG_RX_THRESHOLD_SET(reg, val) BSP_FLD32SET(reg, val, 16, 21)
99#define IMX_ECSPI_DMAREG_TEDEN BSP_BIT32(7)
100#define IMX_ECSPI_DMAREG_TX_THRESHOLD(val) BSP_FLD32(val, 0, 5)
101#define IMX_ECSPI_DMAREG_TX_THRESHOLD_GET(reg) BSP_FLD32GET(reg, 0, 5)
102#define IMX_ECSPI_DMAREG_TX_THRESHOLD_SET(reg, val) BSP_FLD32SET(reg, val, 0, 5)
105#define IMX_ECSPI_PERIODREG_CSD_CTL(val) BSP_FLD32(val, 16, 21)
106#define IMX_ECSPI_PERIODREG_CSD_CTL_GET(reg) BSP_FLD32GET(reg, 16, 21)
107#define IMX_ECSPI_PERIODREG_CSD_CTL_SET(reg, val) BSP_FLD32SET(reg, val, 16, 21)
108#define IMX_ECSPI_PERIODREG_CSRC BSP_BIT32(15)
109#define IMX_ECSPI_PERIODREG_SAMPLE_PERIOD(val) BSP_FLD32(val, 0, 14)
110#define IMX_ECSPI_PERIODREG_SAMPLE_PERIOD_GET(reg) BSP_FLD32GET(reg, 0, 14)
111#define IMX_ECSPI_PERIODREG_SAMPLE_PERIOD_SET(reg, val) BSP_FLD32SET(reg, val, 0, 14)
113#define IMX_ECSPI_TESTREG_LBC BSP_BIT32(31)
114#define IMX_ECSPI_TESTREG_RXCNT(val) BSP_FLD32(val, 8, 14)
115#define IMX_ECSPI_TESTREG_RXCNT_GET(reg) BSP_FLD32GET(reg, 8, 14)
116#define IMX_ECSPI_TESTREG_RXCNT_SET(reg, val) BSP_FLD32SET(reg, val, 8, 14)
117#define IMX_ECSPI_TESTREG_TXCNT(val) BSP_FLD32(val, 0, 6)
118#define IMX_ECSPI_TESTREG_TXCNT_GET(reg) BSP_FLD32GET(reg, 0, 6)
119#define IMX_ECSPI_TESTREG_TXCNT_SET(reg, val) BSP_FLD32SET(reg, val, 0, 6)
120 uint32_t reserved_24[7];
This header file provides utility macros for BSPs.
Definition: imx_ecspireg.h:33
