RTEMS 6.1-rc2
icm7170.h
2
3/*
4 * This file contains the definitions for the following real-time clocks:
5 *
6 * + Harris Semiconduction ICM7170
7 *
8 * COPYRIGHT (c) 1989-1999.
9 * On-Line Applications Research Corporation (OAR).
10 *
11 * Redistribution and use in source and binary forms, with or without
12 * modification, are permitted provided that the following conditions
13 * are met:
14 * 1. Redistributions of source code must retain the above copyright
15 * notice, this list of conditions and the following disclaimer.
16 * 2. Redistributions in binary form must reproduce the above copyright
17 * notice, this list of conditions and the following disclaimer in the
18 * documentation and/or other materials provided with the distribution.
19 *
20 * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
21 * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
22 * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
23 * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
24 * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
25 * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
26 * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
27 * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
28 * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
29 * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
30 * POSSIBILITY OF SUCH DAMAGE.
31 */
32
33#ifndef __LIBCHIP_ICM7170_h
34#define __LIBCHIP_ICM7170_h
35
36/*
37 * Register indices
38 */
39
40#define ICM7170_CONTROL 0x11
41
42
43#define ICM7170_COUNTER_HUNDREDTHS 0x00
44#define ICM7170_HOUR 0x01
45#define ICM7170_MINUTE 0x02
46#define ICM7170_SECOND 0x03
47#define ICM7170_MONTH 0x04
48#define ICM7170_DATE 0x05
49#define ICM7170_YEAR 0x06
50#define ICM7170_DAY_OF_WEEK 0x07
51
52/*
53 * Configuration information in the parameters field
54 */
55
56#define ICM7170_AT_32_KHZ 0x00
57#define ICM7170_AT_1_MHZ 0x01
58#define ICM7170_AT_2_MHZ 0x02
59#define ICM7170_AT_4_MHZ 0x03
60
61/*
62 * Driver function table
63 */
64
65extern rtc_fns icm7170_fns;
66
67/*
68 * Default register access routines
69 */
70
71uint32_t icm7170_get_register( /* registers are at 1 byte boundaries */
72 uintptr_t ulCtrlPort, /* and accessed as bytes */
73 uint8_t ucRegNum
74);
75
76void icm7170_set_register(
77 uintptr_t ulCtrlPort,
78 uint8_t ucRegNum,
79 uint32_t ucData
80);
81
82uint32_t icm7170_get_register_2( /* registers are at 2 byte boundaries */
83 uintptr_t ulCtrlPort, /* and accessed as bytes */
84 uint8_t ucRegNum
85);
86
87void icm7170_set_register_2(
88 uintptr_t ulCtrlPort,
89 uint8_t ucRegNum,
90 uint32_t ucData
91);
92
93uint32_t icm7170_get_register_4( /* registers are at 4 byte boundaries */
94 uintptr_t ulCtrlPort, /* and accessed as bytes */
95 uint8_t ucRegNum
96);
97
98void icm7170_set_register_4(
99 uintptr_t ulCtrlPort,
100 uint8_t ucRegNum,
101 uint32_t ucData
102);
103
104uint32_t icm7170_get_register_8( /* registers are at 8 byte boundaries */
105 uintptr_t ulCtrlPort, /* and accessed as bytes */
106 uint8_t ucRegNum
107);
108
109void icm7170_set_register_8(
110 uintptr_t ulCtrlPort,
111 uint8_t ucRegNum,
112 uint32_t ucData
113);
114
115#endif
116/* end of include file */
Definition: rtc.h:46
