RTEMS
6.1-rc2
bsps
riscv
riscv
include
dev
serial
htif.h
1
2
* Copyright (c) 2018 embedded brains GmbH & Co. KG
3
4
5
* modification, are permitted provided that the following conditions
6
* are met:
7
* 1. Redistributions of source code must retain the above copyright
8
* notice, this list of conditions and the following disclaimer.
9
* 2. Redistributions in binary form must reproduce the above copyright
10
* notice, this list of conditions and the following disclaimer in the
11
* documentation and/or other materials provided with the distribution.
12
13
* THIS SOFTWARE IS PROVIDED BY THE AUTHOR AND CONTRIBUTORS ``AS IS'' AND
14
* ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
15
* IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
16
* ARE DISCLAIMED. IN NO EVENT SHALL THE AUTHOR OR CONTRIBUTORS BE LIABLE
17
* FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
18
* DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS
19
* OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION)
20
* HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT
21
* LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY
22
* OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF
23
* SUCH DAMAGE.
24
25
26
rtems/termiostypes.h
27
28
#ifndef DEV_SERIAL_HTIF_H
29
#define DEV_SERIAL_HTIF_H
30
31
#ifdef __cplusplus
32
extern
"C"
33
#endif
/* __cplusplus */
34
35
typedef
struct
36
rtems_termios_device_context
base;
37
htif_console_context
38
39
void
htif_console_context_init(
40
*base,
41
int
device_tree_node
42
43
44
void
htif_console_putchar(
*base,
char
c);
45
46
int
htif_console_getchar(
*base);
47
48
extern
const
rtems_termios_device_handler
htif_console_handler;
49
50
#ifdef __cplusplus
51
52
#endif
/* __cplusplus */
53
54
#endif
/* DEV_SERIAL_HTIF_H */
Definition:
htif.h:35
Termios device context.
Definition:
termiosdevice.h:68
Termios device handler.
Definition:
termiosdevice.h:100
termiostypes.h
