RTEMS 6.1-rc2
grslink.h
2
3/*
4 * Header file for RTEMS GRSLINK SLINK master driver
5 *
6 * COPYRIGHT (c) 2009.
7 * Cobham Gaisler AB.
8 *
9 * Redistribution and use in source and binary forms, with or without
10 * modification, are permitted provided that the following conditions
11 * are met:
12 * 1. Redistributions of source code must retain the above copyright
13 * notice, this list of conditions and the following disclaimer.
14 * 2. Redistributions in binary form must reproduce the above copyright
15 * notice, this list of conditions and the following disclaimer in the
16 * documentation and/or other materials provided with the distribution.
17 *
18 * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
19 * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
20 * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
21 * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
22 * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
23 * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
24 * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
25 * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
26 * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
27 * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
28 * POSSIBILITY OF SUCH DAMAGE.
29 */
30
31#ifndef __GRSLINK_H__
32#define __GRSLINK_H__
33
34#ifdef __cplusplus
35extern "C" {
36#endif
37
38/**** Configuration ****/
39/* Collect statistics ? */
40#define SLINK_COLLECT_STATISTICS
41
42/* Frequency of SLINK SCLK */
43#define SLINK_FREQ_HZ 6000000
44/* Number of queues used in driver */
45#define SLINK_NUMQUEUES 4
46
47/* The four values below are only used in the demo software */
48#define SLINK_CORE_REGBASE 0x80000600
49#define SLINK_CORE_IRQ 6
50#define IRQ_CNTRL_REG 0x80000200
51#define IRQ_CNTRL_MASK_OFFSET 0x40
52
53/*
54 * Structure returned by SLINK_statistics if SLINK_COLLECT_STATISTCS has
55 * been defined
56 */
57typedef struct {
58 unsigned int parerr; /* Number of parity errors */
59 unsigned int recov; /* Number of receive overflows */
60 unsigned int reads; /* Number of completed READs */
61 unsigned int writes; /* Number of performed WRITES */
62 unsigned int sequences; /* Number of started SEQUENCEs */
63 unsigned int seqcomp; /* Number of completed SEQUENCEs */
64 unsigned int interrupts; /* Number of INTERRUPT transfers */
65 unsigned int lostwords; /* Number of lost words due to full queue */
67
68/**** SLINK status codes ****/
69#define SLINK_ABORTED 0
70#define SLINK_QFULL 1
71#define SLINK_ACTIVE 2
72#define SLINK_AMBAERR 3
73#define SLINK_COMPLETED 4
74#define SLINK_PARERR 5
75#define SLINK_ROV 6 /* Only used internally in driver */
76
77/**** SLINK master register fields *****/
78/* Control register */
79#define SLINK_C_SLEN_POS 16
80#define SLINK_C_SRO (1 << 8)
81#define SLINK_C_SCN_POS 4
82#define SLINK_C_PAR (1 << 3)
83#define SLINK_C_AS (1 << 2)
84#define SLINK_C_SE (1 << 1)
85#define SLINK_C_SLE (1 << 0)
86
87/* Status register fields */
88#define SLINK_S_SI_POS 16
89#define SLINK_S_PERR (1 << 7)
90#define SLINK_S_AERR (1 << 6)
91#define SLINK_S_ROV (1 << 5)
92#define SLINK_S_RNE (1 << 4)
93#define SLINK_S_TNF (1 << 3)
94#define SLINK_S_SC (1 << 2)
95#define SLINK_S_SA (1 << 1)
96#define SLINK_S_SRX (1 << 0)
97
98/* Mask register fields */
99#define SLINK_M_PERRE (1 << 7)
100#define SLINK_M_AERRE (1 << 6)
101#define SLINK_M_ROVE (1 << 5)
102#define SLINK_M_RNEE (1 << 4)
103#define SLINK_M_TNFE (1 << 3)
104#define SLINK_M_SCE (1 << 2)
105#define SLINK_M_SAE (1 << 1)
106#define SLINK_M_SRXE (1 << 0)
107
108/**** Macros ****/
109/* Get channel field from received SLINK word */
110#define SLINK_WRD_CHAN(x) ((x >> 16) & 0xF)
111/* Get IO card # from received SLINK word */
112#define SLINK_WRD_CARDNUM(x) ((x >> 21) & 0x3)
113/* Get data part from SLINK word */
114#define SLINK_WRD_PAYLOAD(x) (x & 0xFFFF)
115
116/* Checks status value to see if transmit queue has free slot */
117#define SLINK_STS_TRANSFREE(x) (x & SLINK_S_TNF)
118/* Get Sequence Index value */
119#define SLINK_STS_SI(x) ((x >> 16) & 0xFF)
120
121/**** Function declarations, driver interface ****/
122/* Initializes the SLINK core */
123int SLINK_init(unsigned int nullwrd, int parity, int qsize,
124 void (*interrupt_trans_handler)(int),
125 void (*sequence_callback)(int));
126
127/* Enables the core */
128void SLINK_start(void);
129
130/* Disables the core */
131void SLINK_stop(void);
132
133/* Reads one word */
134int SLINK_read(int data, int channel, int *reply);
135
136/* Writes one word */
137int SLINK_write(int data, int channel);
138
139/* Peforms a SEQUENCE */
140int SLINK_seqstart(int *a, int *b, int n, int channel, int reconly);
141
142/* Aborts a SEQUENCE */
143void SLINK_seqabort(void);
144
145/* Status of current or last SEQUENCE */
146int SLINK_seqstatus(void);
147
148/* Number of words transferred in last SEQUENCE */
149int SLINK_seqwrds(void);
150
151/* Returns value of core's status register */
152int SLINK_hwstatus(void);
153
154/* Returns number of elements in queue associated with IO card */
155int SLINK_queuestatus(int iocard);
156
157/* Take first element from queue for IO card # 'iocard' */
158int SLINK_dequeue(int iocard, int *elem);
159
160/* Returns structure containing core driver statistics */
161SLINK_stats *SLINK_statistics(void);
162
163#ifdef __cplusplus
164}
165#endif
166
167#endif /* __GRSLINK_H__ */
