RTEMS 6.1-rc2
Modules | Files | Macros | Variables
spec:/testsuites/fatal-idle-thread-create-failed
This validation test suite contains a test case which is triggered by a fatal error during system initialization. More...
 spec:/score/thread/val/fatal-idle-thread-create-failed
 Tests a fatal error caused by a failing task create extension.
file  ts-fatal-idle-thread-create-failed.c
#define FATAL_SYSINIT_RUN   ScoreThreadValFatalIdleThreadCreateFailed_Run
#define CONFIGURE_APPLICATION_DOES_NOT_NEED_CLOCK_DRIVER
#define CONFIGURE_IDLE_TASK_INITIALIZES_APPLICATION
#define FATAL_SYSINIT_INITIAL_EXTENSION   { .thread_create = CreateTask }
const char rtems_test_name [] = "TestsuitesFatalIdleThreadCreateFailed"
 Each test must define a test name string.
