Tests timecounter installation related functions and directives of the Clock Manager.
More...
| T_TEST_CASE (ScoreTimecounterValInstall) |
This test case performs the following actions:
- Call the simple timecounter tick service with a zero delta and offset. This will lead to an overflow to zero of the timehand generation. It shall not change the initial clock values.
- Call the directives to get the initial value of CLOCK_REALTIME and the initial boot time.
- Check the initial CLOCK_REALTIME in seconds and nanoseconds format.
- Check that CLOCK_REALTIME is frozen in seconds and nanoseconds format.
- Check the initial CLOCK_REALTIME in coarse resolution in seconds and nanoseconds format.
- Check that CLOCK_REALTIME is frozen in coarse resolution in seconds and nanoseconds format.
- Check the initial CLOCK_REALTIME in binary time format.
- Check that CLOCK_REALTIME is frozen in binary time format.
- Check the initial CLOCK_REALTIME in coarse resolution in binary time format.
- Check that CLOCK_REALTIME is frozen in coarse resolution in binary time format.
- Check the initial CLOCK_REALTIME in seconds and microseconds format.
- Check that CLOCK_REALTIME is frozen in seconds and microseconds format.
- Check the initial CLOCK_REALTIME in coarse resolution in seconds and microseconds format.
- Check that CLOCK_REALTIME is frozen in coarse resolution in seconds and microseconds format.
- Check the initial boot time in seconds and nanoseconds format.
- Check the initial boot time in binary time format.
- Check the initial boot time in seconds and microseconds format.
- Call the directives to get the initial value of CLOCK_MONOTONIC and the initial boot time.
- Check the initial CLOCK_MONOTONIC in seconds and nanoseconds format.
- Check that CLOCK_MONOTONIC is frozen in seconds and nanoseconds format.
- Check the initial CLOCK_MONOTONIC in coarse resolution in seconds and nanoseconds format.
- Check that CLOCK_MONOTONIC is frozen in coarse resolution in seconds and nanoseconds format.
- Check the initial CLOCK_MONOTONIC in binary time format.
- Check that CLOCK_MONOTONIC is frozen in binary time format.
- Check the initial CLOCK_MONOTONIC in coarse resolution in binary time format.
- Check that CLOCK_MONOTONIC is frozen in coarse resolution in binary time format.
- Check the initial CLOCK_MONOTONIC in signed binary time format.
- Check that CLOCK_MONOTONIC is frozen in signed binary time format.
- Check the initial CLOCK_MONOTONIC in seconds and microseconds format.
- Check that CLOCK_MONOTONIC is frozen in seconds and microseconds format.
- Check the initial CLOCK_MONOTONIC in coarse resolution in seconds and microseconds format.
- Check that CLOCK_MONOTONIC is frozen in coarse resolution in seconds and microseconds format.
- Install timecounter of different quality levels and frequencies.
- Install a timecounter with a high quality level and normal frequency. Check that it was installed.
- Install a timecounter with a high quality level and low frequency. Check that it was not installed.
- Install a timecounter with a high quality level and high frequency. Check that it was installed.
- Install a timecounter with a low quality level. Check that it was not installed.
- Call the directives to get the time in the highest resolution available to the system.
- Call the directives to get the time in a coarse resolution.
- Update the oldest timehand after a large time interval.
- Call the simple timecounter tick service with non-zero delta and offset parameter values so that exactly one second passed.
- Check that exactly one second passed due to the simple clock tick service.
- Install a very high quality timecounter with a low frequency to test the NTP support.
- Let the seconds value of CLOCK_REALTIME not change. Check that the NTP update second handler is not called.
- Let the seconds value of CLOCK_REALTIME change by one. Check that the NTP update second handler is called exactly once.
- Let the seconds value of CLOCK_REALTIME change by 200. Check that the NTP update second handler is called exactly 200 times.
- Let the seconds value of CLOCK_REALTIME change by 201. Check that the NTP update second handler is called exactly twice.
- Let the seconds value of CLOCK_REALTIME change by one. Check that the NTP update second handler is incremented the CLOCK_REALTIME by one second.
- Let the seconds value of CLOCK_REALTIME change by one. Check that the NTP update second handler is decremented the CLOCK_REALTIME by one second.
- Let the seconds value of CLOCK_REALTIME change by one. Check that the NTP update second handler increased the timecounter frequency.
- Let the seconds value of CLOCK_REALTIME change by one. Check that the NTP update second handler decreased the timecounter frequency.
