RTEMS 6.1-rc2
Files | Data Structures | Macros | Functions | Variables
Tests the basedefs macros of the Classic API. More...
file  tc-basedefs-pendant.c
 Helper file to verify the requirements towards the basedefs.
file  tc-basedefs-pendant.h
file  tc-basedefs.c
struct  aligned_member_struct
#define WHITE_SPACE_STRING_MAX_LENGTH   80
#define abccat   concat
#define abc   ABC
#define CON   con
#define CAT   cat
#define defcat   concat
#define GLOBAL_SYMBOL_VALULE(_hex)   0x ## _hex
#define EXPAND   expand
#define PREDICT_FALSE   1 -
#define SECTION_NAME   ".rtemsroset.test"
#define STATIC_ASSERT_COND   0 +
#define STRING_PREFIX   str
#define SYMBOL_NAME   global_object
#define _TO_STR2(_text)   #_text
#define _TO_STR(_text)   _TO_STR2( _text )
 __asm__ ("\n\t.set " RTEMS_XSTRING(RTEMS_SYMBOL_NAME(address_of_global_object)) ", " RTEMS_XSTRING(RTEMS_SYMBOL_NAME(SYMBOL_NAME)) "\n")
 RTEMS_DEFINE_GLOBAL_SYMBOL (GLOBAL_SYMBOL, RTEMS_SYMBOL_NAME(global_symbol_base)+GLOBAL_SYMBOL_VALULE(abc))
 RTEMS_DECLARE_GLOBAL_SYMBOL (global_symbol_2)
 RTEMS_DEFINE_GLOBAL_SYMBOL (global_symbol_2, 0x123)
RTEMS_INLINE_ROUTINE int inline_routine_func (int arg)
 RTEMS_PRINTFLIKE (2, 3)
 RTEMS_SECTION (".rtemsrwset.test")
int basedefs_weak_alias_0_func (int i) RTEMS_WEAK_ALIAS(ori_func)
int basedefs_weak_alias_1_func (int i) RTEMS_WEAK_ALIAS(ori_func)
RTEMS_WEAK int basedefs_weak_0_func (void)
RTEMS_WEAK int basedefs_weak_1_func (void)
 T_TEST_CASE (RtemsBasedefsValBasedefs)
int global_object
int address_of_global_object
RTEMS_WEAK const volatile int basedefs_weak_0_var = 60
RTEMS_WEAK const volatile int basedefs_weak_1_var = 61
This test case performs the following actions:
