RTEMS 6.1-rc2
Files | Macros | Variables
spec:/testsuites/fatal-sparc-leon3-shutdown-response
This validation test suite contains a test case which performs a system shutdown. More...
file  ts-fatal-sparc-leon3-shutdown-response.c
#define FATAL_SYSINIT_RUN   BspSparcLeon3ValFatalShutdownResponse_Run
#define FATAL_SYSINIT_EXIT(exit_code)   FatalSysinitExit( exit_code )
#define CONFIGURE_APPLICATION_DOES_NOT_NEED_CLOCK_DRIVER
#define CONFIGURE_MAXIMUM_PROCESSORS   2
const char rtems_test_name [] = "FatalBspSparcLeon3ShutdownResponse"
 Each test must define a test name string.
