RTEMS 6.1-rc2
Unsigned Integer Checks
Checks for unsigned integers (unsigned int). More...
#define T_eq_uint(a, e)   T_flags_eq_uint(a, e, 0)
#define T_assert_eq_uint(a, e)   T_flags_eq_uint(a, e, T_CHECK_STOP)
#define T_quiet_eq_uint(a, e)   T_flags_eq_uint(a, e, T_CHECK_QUIET)
#define T_step_eq_uint(s, a, e)   T_flags_eq_uint(a, e, T_CHECK_STEP(s))
#define T_step_assert_eq_uint(s, a, e)    T_flags_eq_uint(a, e, T_CHECK_STEP(s) | T_CHECK_STOP)
#define T_ne_uint(a, e)   T_flags_ne_uint(a, e, 0)
#define T_assert_ne_uint(a, e)   T_flags_ne_uint(a, e, T_CHECK_STOP)
#define T_quiet_ne_uint(a, e)   T_flags_ne_uint(a, e, T_CHECK_QUIET)
#define T_step_ne_uint(s, a, e)   T_flags_ne_uint(a, e, T_CHECK_STEP(s))
#define T_step_assert_ne_uint(s, a, e)    T_flags_ne_uint(a, e, T_CHECK_STEP(s) | T_CHECK_STOP)
#define T_ge_uint(a, e)   T_flags_ge_uint(a, e, 0)
#define T_assert_ge_uint(a, e)   T_flags_ge_uint(a, e, T_CHECK_STOP)
#define T_quiet_ge_uint(a, e)   T_flags_ge_uint(a, e, T_CHECK_QUIET)
#define T_step_ge_uint(s, a, e)   T_flags_ge_uint(a, e, T_CHECK_STEP(s))
#define T_step_assert_ge_uint(s, a, e)    T_flags_ge_uint(a, e, T_CHECK_STEP(s) | T_CHECK_STOP)
#define T_gt_uint(a, e)   T_flags_gt_uint(a, e, 0)
#define T_assert_gt_uint(a, e)   T_flags_gt_uint(a, e, T_CHECK_STOP)
#define T_quiet_gt_uint(a, e)   T_flags_gt_uint(a, e, T_CHECK_QUIET)
#define T_step_gt_uint(s, a, e)   T_flags_gt_uint(a, e, T_CHECK_STEP(s))
#define T_step_assert_gt_uint(s, a, e)    T_flags_gt_uint(a, e, T_CHECK_STEP(s) | T_CHECK_STOP)
#define T_le_uint(a, e)   T_flags_le_uint(a, e, 0)
#define T_assert_le_uint(a, e)   T_flags_le_uint(a, e, T_CHECK_STOP)
#define T_quiet_le_uint(a, e)   T_flags_le_uint(a, e, T_CHECK_QUIET)
#define T_step_le_uint(s, a, e)   T_flags_le_uint(a, e, T_CHECK_STEP(s))
#define T_step_assert_le_uint(s, a, e)    T_flags_le_uint(a, e, T_CHECK_STEP(s) | T_CHECK_STOP)
#define T_lt_uint(a, e)   T_flags_lt_uint(a, e, 0)
#define T_assert_lt_uint(a, e)   T_flags_lt_uint(a, e, T_CHECK_STOP)
#define T_quiet_lt_uint(a, e)   T_flags_lt_uint(a, e, T_CHECK_QUIET)
#define T_step_lt_uint(s, a, e)   T_flags_lt_uint(a, e, T_CHECK_STEP(s))
#define T_step_assert_lt_uint(s, a, e)    T_flags_lt_uint(a, e, T_CHECK_STEP(s) | T_CHECK_STOP)
