RTEMS 6.1-rc2
This group contains the L4STAT interfaces. More...
Modules | |
Counter 0-15 control register (CCTRL) | |
This group contains register bit definitions. | |
Counter 0-15 max/latch register (CSVAL) | |
Counter 0-15 value register (CVAL) | |
Timestamp register (TSTAMP) | |
Files | |
file | l4stat-regs.h |
This header file defines the L4STAT register block interface. | |
struct | l4stat |
This structure defines the L4STAT register block memory map. More... | |
Typedefs | |
typedef struct l4stat | l4stat |
This structure defines the L4STAT register block memory map. | |
